logging dpf levels
ES458MC
Italy
C?ID=250891
Hi,
When I try logging my dp filter levels / last regen / etc I get as far as checking the various field entries / tick boxes but then the system freezes and I get no further.
Any Ideas?
Current versions: CB: 0.4344 FW: 0.254 CFB: 0.10 BL: 0.28 DS: 00000050
Regards
Julian
Please post an Auto-Scan so we can see what your car is made of.
What do you mean it "freezes"? Are you using VCDS or VCDS-Mobile?
ES458MC
Italy
C?ID=250891
vcds mobile
The screen / page freezes after I select the check boxes of codes to monitor
here's a recent log
#hndoc:?docid=00003088&xt=hnh:8ECB22ACA0151385C7D8EC2EF30223714E91C770CE773201E983DB74F41BC4FA
VCDS Mobile 0.4344.0.4
VIN: WV2ZZZ7HZAH268966
Scan: 01 02 03 08 09 10 15 17 18 19 22 25 2E 37 56 69 6C 77
Address 01: Engine (CFCA J) Labels: 03-01.clb
Part No SW: 03L 906 022 JE HW: 03L 907 309 H
Component: R4 2,0L EDC H26 9114
Revision: 22H26---
Coding: 0125401A233600080000
Shop #: WSC 01062 202 999999
ASAM Dataset: EV_ECM20BTD01103L906022JE 002008
ROD: EV_ECM20BTD01103L906022JD.rod
VCID: 71A546C73F8992C5836DDF5F38-8024
No fault codes found.
Address 02: Auto Trans (J217) Labels: 0B-02.lbl
Part No SW: 0BT 300 011 H HW: 0BH 927 711 B
Component: DSG DQ500-7A H03 0716
Revision: 00H03V01
ROD: EV_TCMDQ500021_VW36.rod
VCID: 33298CCF0515E0D5B101357762-8066
Address 03: ABS Brakes (-----) Labels: 7E-03.clb
Part No SW: 7E0 907 379 F HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0104
Revision: 00H43001
Coding: 062C0AC4F1DF40
Shop #: WSC 02756 790 49152
VCID: 352DB2D70B61E6E59F154B6F4C-8060
Address 08: Auto HVAC (J255) Labels: 7E5-907-040.clb
Part No SW: 7E5 907 040 E HW: 7E5 907 040 E
Component: ClimatronicT5 H10 0101
Coding: 0004000102
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ClimatronicT5 A01002
ROD: EV_ClimatronicT5.rod
VCID: 2A1791ABD2DFA11D02A7D0EBDD-807F
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 HW: 7H0 937 089
Component: BCM T5GP Li4 H46 0207
Revision: BS046001
Coding: B9F069BA4EE12602932846C07CE99FD58080608F60846841300000000000
Shop #: WSC 02756 790 12345
VCID: F3A9CCCFC59538D5F1817577A2-80A6
Subsystem 1 - Part No SW: 1K0-955-559-AH Labels: 1K0-955-559-AG.clb
Component: RLS 210410 0554 0403
Coding: 03302E
Subsystem 2 - Part No SW: 7E0-959-801-A Labels: 7E0-959-801.clb
Component: J386__TSG_FT 003 3311
Coding: 040000
Subsystem 3 - Part No SW: 7E0-959-802-A Labels: 7E0-959-802.clb
Component: J387__TSG_BT 003 3311
Coding: 040000
Subsystem 4 - Part No SW: 7E1-951-171 Labels: 7E-09-04.clb
Component: DWA-Sensor 00001 0104
Subsystem 5 - Part No SW: 1K0-951-605-C
Component: LIN BACKUP HOH05 1501
Subsystem 6 - Part No SW: 7E1-951-171
Subsystem 7 - Part No SW: 3C8-959-537-D Labels: 3C8-959-537.clb
Component: E221__MFL-TK6H06 0022
Coding: E20000
03304 - Response Closing Status of Rear Right Door
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 A HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0008
Revision: --------
Coding: 310101
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_VW75XParkAssis8K A01003
ROD: EV_VW75XParkAssis8K_VN75.rod
VCID: 302383C3F403DBCDCCE312538B-8065
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7E0 959 655 HW: 7E0 959 655
Component: VW10Airbag01L H05 0011
Revision: --------
Coding: 00000000000000000000000000000000314C
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: F3A9CCCFC59520D5F1817577A2-80A6
Subsystem 1 - Serial Number: 3495ZRB404V6JIHQPP5G
Part No SW: 7E0 920 870 A HW: 7E0 920 870 A
Component: KOMBI H16 0111
Coding: 160D00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 2711689FC1CD9C751D89B1C706-8072
Address 18: Aux. Heat Labels: 7E-18.clb
Part No SW: 7E0 815 071 A
Component: J737__Standheizung 0404
Revision: 00085000 Serial Number: 09019275D00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 23097C8FB5F5E855416185B732-8076
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 0207
Coding: 042200
VCID: F0A3C3C3B48303CD0C635253CB-80A5
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 09N 907 554 A HW: 09N907554A
Component: Haldex 4Motion 6007
Coding: 0000009
Shop #: WSC 02756 790 00000
VCID: 362FB5DB16676DFD961F549B39-8063
00448 - Haldex Clutch Pump (V181)
Component: IMMO H16 0111
Shop #: WSC 00000 000
ROD: EV_Immo_UDS_VDD_RM09_VN75.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003
Coding: 030000
VCID: 260F659BC6C79D7D267FA4DB09-8073
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7E0 035 680 B HW: 7E0 035 680
Component: RNS-MID H06 5238
Revision: AB001001
Coding: 04000402040000A00014
Shop #: WSC 02754 790 00000
VCID: 240B7F93B0FB6F6D386B8EA32F-8071
Subsystem 1 - Part No SW: 1T0-919-859-B
Component: EU West V14 8477
00856 - Radio Antenna
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Revision: AB001001
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Component: Anhaenger H07 0070
Revision: 3A001001
Coding: 410D000100000000
VCID: 302383C3F403C3CDCCE312538B-8065
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0907441
Revision: 00H08000 Serial Number: 525PA8-J040224
Coding: 0030016
VCID: E58DA2977B4156656FF5DBAF5C-80B0
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: --------
Coding: 020000000100000000001101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_VW32.rod
VCID: 240B7F93B0FB776D386B8EA32F-8071
12670208 - No Communication with Instrument Cluster
U0155 00 [008] -
CB: 0.4346
FW: 0.254
CFB: 0.10
BL: 0.28
DS: 00000050
Can you narrow this down to a particular data item that causes VCDS-Mobile to freeze? Also, what is the behavior of the LEDs on the interface when it freezes?
And lastly, we need a scan so we can see what ECU this car has.
