1 Fault: 001393 - Brake Switch (F) P0571 - 008 - Implausible Signal
Geoffzie
C?ID=309752
I'm posting this here for a specific problem I'm having with a 2007 VW Passat 2.5L 5-Cyl. engine conversion ... a brake light switch fault. I've had this fault from the beginning of this project and can't seem to get rid of it. (The ABS errors in the scan below are recent ... I had the Brake light fault long before the current ABS issues occurred).
Today I cleared the fault for the umteenth time ... then I drove the car.
Everything works fine ... for a while. The brake lights work ... the green foot peddle light on the dash goes off when the Brake peddle is depressed ... the cruise control turns on and "sets" fine on the freeway ... and depressing the brake peddle deactivates the cruise control fine.
But today, after I had cleared the code, I drove with my VCDS open to Address 01: Engine (CBT) ... Fault Codes - 02 ... and watched for the Brake light switch fault to show up (don't know if VCDS faults show up in real-time). It took about 5 minutes of driving to get the fault to appear ... during that time I set the cruise ... applied the brakes ... used the turn signals ... turned on the headlights.
I was trying to find anything that might set the fault ... but really found nothing ... other than simply pressing the brake peddle ... eventually.
Any ideas as to why the switch would be fine for a while ... but throw a fault after about 5 minutes?
Here's today's scan ...
Friday,07,July,2017,15:35:10:23114
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WVWBA71K78W315062   License Plate:
Chassis Type: 1K (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 6D 72
VIN: WVWBA71K78W315062   Mileage: 220550km-137043miles
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BJ    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1567
   Revision: 1NH01---    Serial number: VWX7Z0H33N97Z2
   Coding: 0000003
   Shop #: WSC 01279 785 00200
   VCID: 72BED2CB78AA85372BD-8026
                    Fault Status: 01101000
                    Mileage: 220546 km
                    Date: 2017.07.07
                    Time: 14:42:25
                    RPM: 646 /min
                    Load: 20.8 %
                    Speed: 4.0 km/h
                    Temperature: 80.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 13.462 V
Readiness: 0110 1100
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
   Component: AQ 250 6F           1068
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 08114 444 84076
   VCID: 005A88034606A7A72D9-8054
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 00066 000 00000
   VCID: 73B0D7CF07B08C3F20B-8026
10 Faults Found:
            000 -  -  - Intermittent
   Part No: 1K0 820 047 EB
   Component: Climatic PQ35   090 0505
   VCID: 688AB0A34E767FE7859-803C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000005468122
   Coding: 008C0F0340041A00470A00000F00000000285D435C0000
   Shop #: WSC 05311 123 12345
   VCID: 372823DF5348201FDC3-8062
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P2W7PWA
   Coding: 0012366
   Shop #: WSC 05311 000 08193
   VCID: 2E0606BBAC12E1D78F5-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000032EPS
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0E716159Eÿ†63
   Subsystem 5 - Serial number: 16159Eÿ†6342MSME105B60746ÿ†63
   Subsystem 6 - Serial number: B60746ÿ†6351HTS64IKQTM627ÿ†63
   Subsystem 7 - Serial number: QTM627ÿ†6361HTS6TLLE15C3Uÿ†63
   Subsystem 8 - Serial number: E15C3Uÿ†63727TS63IK2T6C39ÿ†63
   Subsystem 9 - Serial number: 2T6C39ÿ†63827TS63IKEPNQ25ÿ
   Subsystem 10 - Serial number: EPNQ25ÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C9953507R
   Coding: 0102014
   Shop #: WSC 05311 000 00000
   VCID: 313C1DC7BD2CFE2F927-8064
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: V0033000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 01119 067 57207
   VCID: 333017CF4730CC3FE0B-8066
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C0631304F6
   Coding: 3FFC0C0CD22002
   VCID: 211CED87EDCC4EAF027-8074
   Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1339817TQ3XP02
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 64713 001 1048576
   VCID: 2A0E0AAB90FA8DF753D-807E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2801
   Coding: 0001205
   VCID: 36362EDB5442D917C75-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13900E88D1032E521804141FF00A0F0E083C00
   Part No: 1K0 959 702 K
   Coding: 0001204
   VCID: 372823DF5348201FDC3-FFFE
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
   Component: Radio DE2       012 0015
   Revision: 00012000    Serial number: VWZ4Z7F6117447
   Coding: 0040400
   VCID: 1D64D177D1B46A4F26F-8048
   Part No: 3C9 959 703 A
   Component: Tuer-SG         021 2507
   Coding: 0000144
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
   Component: J605  HECKDECKEL    0405
   Revision: 00H20001
   Shop #: WSC 23250 384 715754
   VCID: 303A18C3B626F7279D9-8064
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0405
   Subsystem 2 - Serial number: 0600H20001001C0055ÿ
   Part No: 3C9 959 704 A
   Coding: 0000144
   VCID: 323E12CBB82AC537EBD-8066
End----------(Elapsed Time: 02:34, VBatt start/end: 13.9V/13.7V)-----------
Geoffzie
C?ID=309752
Something just occurred to me as I was watching YouTube videos on tail light bulb replacement for both 2005> Jetta ... and 2006 - 2010 Passat. The Jetta uses standard Incandescent bulbs ... the Passat doesn't use bulbs, they use LED tail lights / turn signals.
I also found this ...
VAG Error Code: 16955/001393/0003/2644
EOBD II Error Code: P0571
Fault Location:
Brake Light Switch (F) - Circuit Malfunction/Implausible Signal
Possible Cause:
- Malfunction Indicator Lamp (MIL)(K83) active.
- Glow Plug Indicator Light (K29) active.
- Brake Light(s) not working.
- Fuse(s).
- Wiring/Connector(s).
- Wrong Brake Light Bulb installed (21W instead of 5/21W).
- Brake Light Bulb(s) faulty.
- Brake Light Switch (F) faulty.
- Misadjusted brake switch.
(As taken from my Free EOBD II Error Codes software)
Could this be my problem? ... the Jetta ECU is looking for Jetta tail light bulbs ... instead it sees Passat LED's?
I don't think ECUs don't look for tail-light bulbs. That's a BCM/CECM/CCM's job.
Geoffzie
C?ID=309752
Uwe, the reason I said that was because of this statement (I hadn't posted the entire page from "Free EOBD II Error Codes software") ...
Description:
"When the brake pedal is depressed, the brake light switch sends a signal to the Engine Control Module (ECM). When the Engine Control Module (ECM) receives this signal, it cancels the cruise control."
Also, in the Jetta wiring diagrams, there are two wires from the ECU that are connected to the Brake Peddle Switch (F47) ... T121/55 (White/Green) and T121/56 (Black/Red). The 2007 Passat only has the Black/Red wire connected to the Brake Light Switch ... I had to add the White/Green wire from the Jetta ECU to the Brake Peddle Switch F47.
Apparently, the ECU connections are required for the cruise control ... which makes sense. My brake lights continue to work fine even after the Brake fault is set ... the cruise control does not.
m87a
Bosnia and Herzegovina
C?ID=156900
there are jettas with led brake lights, so you'll have to look elsewhere for fault
in jettas brake sensor is on the brake pedal while in passat it's incorporated in abs if my memory serves me right, so did you try to check brake sensor? this sensor can cause cruise not to work
Geoffzie
C?ID=309752
m87a, I'm specifically referring to the year Jetta that the ECU is from ... a 2008 2.5L. And I don't believe that year had LED brake lights (at least not in the US).
The Jetta, through late 2005, uses a mechanical brake light switch (4-terminal) mounted under the dash on the brake peddle (like older VW's) just as you said. But later Jetta's (2006 on) and the B6 Passat used a hall-effect brake light switch (3-terminal) mounted under the hood on the master cylinder. The B6 Passat also uses a 4-terminal vacuum booster switch that has all 4 wires connected directly to the ABS Control Module ... that's probably what you're referring to.
The Jetta ABS pump and the Jetta ECU have no provisions for the vacuum booster switch, and there's actually a place to disable it in Address 03: ABS Brakes ... so I have it disabled.
Because the Jetta ABS pump and ECU require a 4-wire brake light switch (one side is N/O contacts "F" ... the other side is N/C contacts "F47") ... and the Passat hall-effect switch is only 3-wire ... I had to install a Jetta Peddle-mounted switch under the dash.
Although you could be right, I may have to look elsewhere for the fault ... I'm just examining EVERYTHING. When I started this project, I figured that it would be relatively simple ... because I "assumed" that the Jetta and Passat were much the same ... WRONG!
Keithuk
Stoke on Trent, England
C?ID=122432
Description:
Free EOBD II Error Codes software is my software. The Free one is only on http://www.myturbodiesel.com/threads/free-eobd-ii-error-codes-software.2202/
The other forums don't show Free, just Google EOBD II Error Codes software the new version has been renamed VAG Fault Codes as it only covers VAG vehicles.
That's the older version with 10,266 error codes. There was a lot of EOBD generic codes with no solution. If you search Possible Cause for Unknown Symptom there are 1,629 codes. These have been removed from the new version. There are 132 new codes with no solution in the new version.
m87a
C?ID=156900
i don't know about US but in europe there are led brake lights, also these leds use a lot of resistor so they draw enough power to keep cecm happy, so no error bulb out, yep that's what i was referring to, mechanical brake switch...
you really did open a can of worms with this one... in my opinion look elsewhere for fault
Geoffzie
C?ID=309752
m87a I am.
Today I'm going to recheck the brake light switch wiring (for the umteenth time!). I couldn't get the brake lights to go OFF initially, after the engine conversion ... even with the master cylinder brake light switch ... unplugged! Any time the ignition was on, the brake lights were on!
After trying the post-2005 Jetta brake light wiring (didn't work) ... I ended up using a 2002 VW Beetle wiring diagram (that may be where the problem is) ... and the brake lights worked properly! But that was before I connected the ECU wires T121/55 and T121/56.
Today, I'm going to try to connect it properly and see what happens.
Geoffzie
C?ID=309752
I think I got it fixed!
OK, I think I've got it fixed! I rewired the brake light switch, cleared the codes, and drove the car for about 1/2 hour ... the brake fault didn't return!
I cut the 4 wires to the brake light switch under the dash ... then I temporarily connected them based upon the Jetta wiring diagrams in Bentley. I tried the diagrams for 2006, 2007, and 2008 Jetta's ... no dice. What finally worked was using the diagram for Jettas manufactured from May 2005 (not sure why it worked since the Jetta ECU is 2008, and the Passat is 2007).
What's interesting is ... if you pull the brake light fuse ... the brake lights turn ON! ... that's why my brake lights were on ... no power! On the newer VW's, the tail lights, turn signals, brake lights, and head lights aren't wired from the lights ... to the switches ... to the fuses like they used to be. ALL the lights are wired directly to the J519 Vehicle Electrical System Control Module FIRST, and it controls all their functions through the switches (Head lights, tail lights, turn signals, brake lights, DRL, etc.).
You guys probably already knew that ... but it was news to me!
Thanks for your help on this ... now I've just got to figure out the ABS, and how to get the EPB to work
