VW Tiguan 1.4TSI High Fuel Pressure.
golfi_vend
Tartu, Estonia
C?ID=195131
HI
I have a customer with 1.4TSI Tiguan. He has previosly replaced HPFP cause, it makes loud clicking noise. He thought failure of pump. He replaced it, but still the noise and High Pressure fault. Then he came to me. I made autoscan and read SSP.
The High pressure sometimes while working drops(looking at MVB) and the clicking noise
I myself am blaiming the Lift Pump module. Am i in the right track or should i test something more? I looked at adaption and basic settings in VCDS, but didn't notice anything.
Friday,07,July,2017,19:17:37:36026
VCDS Version: 17.6.0.2 (x64)  HEX-NET CB: 0.4346.4
Data version: 20170602 DS274
VIN: WVGZZZ5NZCW073600   License Plate: TIGGY
Mileage: 146580km-91080mi   Repair Order:
Chassis Type: 5N (7N0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 4C 52 53 56 62 69 72
          77
VIN: WVGZZZ5NZCW073600   Mileage: 146580km-91080miles
Address 01: Engine (J623-CAVD)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 DC    HW: 03C 907 309 J
   Component: 1.4l R4/4V TS H04 1686
   Revision: LGH04---    Serial number: 00000000000000
   Coding: 00190012002600000000
   Shop #: WSC 01324 020 00200
   ASAM Dataset: EV_ECM14TSI01103C906027DC 001005
   ROD: EV_ECM14TSI01103C906027DC.rod
   VCID: E582FAD8E4EDFC6FD2-80B0
4608 - Fuel Pressure Regulator Valve (N276)
          P2294 00 [038] - Open Circuit
                    Mileage: 146582 km
                    Date: 2017.07.07
                    Time: 19:11:53
                    Engine speed: 711.00 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 78 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 14.112 V
                    Mass flow through throttle valve: 10.4 kg/h
                    Median injection timing: 0.819 ms
                    Engine operating condition-Channel 87: Idling
                    Relative load value: 27.59 %
                    Torque request: sum of auxiliary aggregate: 4.3 Nm
                    Engine torque: 32.8 Nm
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [237] - Incorrect Correlation
                    Mileage: 146463 km
                    Date: 2017.07.05
                    Time: 16:27:20
                    Engine speed: 879.50 /min
                    Normed load value: 25.1 %
                    Coolant temperature: 53 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 14.065 V
                    Camshaft adjustment intake bank 1: specified value: 21.000 °
                    Camshaft adjustment intake bank 1: actual value: 21.000 °
                    Coolant temperature at engine start: 53.3 °C
                    Camshaft adjustment intake bank 1: activation: 6.250 %
                    Engine oil temperature: 53.2 °C
                    Camshaft adaptation intake bank 1: phase position: 19.23 °
                    Angle difference actual-specified camshaft adjuster: 0.000 °
5657 - Fuel Pressure Regulation
          P1063 00 [109] - Control Range Not Reached
                    Fault Frequency: 12
                    Mileage: 146463 km
                    Date: 2017.07.05
                    Time: 16:27:27
                    Engine speed: 860.50 /min
                    Normed load value: 22.7 %
                    Coolant temperature: 51 °C
                    Voltage terminal 30: 13.994 V
                    Temperature before 2nd compressor: raw value: 26.3 °C
                    Fuel temperature: 52.5 °C
                    Engine oil temperature: 41.1 °C
                    Time since ignition off: 6299 s
                    Adjustment requirements for basic setting-Bit 0: 54
                    Exhaust temp on O2 sensor behind cat conv from model: filtered: 15.55 °C
2837 - Fuel Rail/System Pressure
          P0088 00 [175] - Too High
                    Fault Frequency: 40
                    Mileage: 146463 km
                    Date: 2017.07.05
                    Time: 16:27:32
                    Engine speed: 852.00 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 50 °C
                    Voltage terminal 30: 14.206 V
                    Fuel pump: specified value: 45.605 %
                    High fuel pressure: specified value: 5.0005 MPa
                    High pressure regulation: adaptation value: 0.6560 MPa
                    High fuel pressure: control deviation: -9.1760 MPa
                    Fuel level: 28.00 l
                    Oxygen sensor bank 1 sensor 1: voltage: 1.494 V
Readiness: 1000 0101
   Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
   Component: J104   C6 450M VD17 0005
   Revision: --H07---    Serial number: 00000005359470
   Coding: 0005134
   VCID: F9BAA6A8B055688F06-80AC
   Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000004002
   VCID: FF4E48B0667146BF38-80AA
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0064
   Revision: BC021001
   Coding: 48180A3B8025F3C0400800C0340081E44B510088536D8960648040000040
   VCID: BE3075B429FB8FB773-80EA
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 21021  013 0203
   Serial number: N1955119   °203!
   Coding: 009795
   Component: RLS 170212 05  54  0403
   Coding: 02304D
   Component: J234__20J VW10 HI   2118
   Revision: 24017000    Serial number: 003L7P35E8MM
   Coding: 0012362
   VCID: FCB4BFBCBF675DA71D-80A8
   Subsystem 1 - Serial number: 6332MTS654440412
   Subsystem 2 - Serial number: 6342MTS638010392
   Subsystem 3 - Serial number: 6351HTS6ODSJV9KR
   Subsystem 4 - Serial number: 6361HTS6RUKIV9KJ
   Part No SW: 5K0 953 501 BH    HW: 5K0 953 569 L
   Revision: FF010040    Serial number: 20120221100688
   Coding: 118A140000
   VCID: F1AA9E88202520CFBE-80A4
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 5N0 920 882 B    HW: 5N0 920 882 B
   Component: KOMBI         H04 0417
   Coding: 111F01
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: B2285184E5A35BD787-80E6
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 230112F2001242
   Coding: 356002
   VCID: BA3879A435D3A3974F-80EE
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: CDD22278545D242FFA-8098
   Component: IMMO          H04 0417
   VCID: EA9889E40DF3D317FF-80BE
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0004314197
   Coding: 0000B4
   VCID: B83C63AC03DFB187B9-80EC
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1504
   Serial number: 00000006496060
   Coding: 000090
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.285 1002
   Revision: 1AH03836    Serial number: 00120340283901
   Coding: 0000258
   VCID: BC347FBCFFE79DA75D-80E8
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0004281203
   Coding: 0000B4
   VCID: B93A66A838D5A88F46-80EC
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1504
   Serial number: 00000006501864
   Coding: 000090
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000711669
   Coding: 0026157
   VCID: B5226A98DCCD4CEFA2-80E0
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2M4034915
   Coding: 0500040004000C
   VCID: B326548012B952DF8C-80E6
   Revision: 3A001001    Serial number: 00008030042739
   Coding: 410D000100000000
   VCID: B02C5B8CE3AF69C7F1-80E4
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       015 0723
   Revision: --------    Serial number: 35909603322299
   Coding: 020000000100000000000000
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_A02.rod
   VCID: A208A1C4B543CB5777-80F6
End----------(Elapsed Time: 01:25, VBatt start/end: 14.1V/14.0V)-----------
Gone But Not Forgotten
I think you should check oil psi during noise....and measure camshaft endplay lobe run out and see if the roller tappet is damaged.
golfi_vend
Tartu, Estonia
C?ID=195131
Fuel pump plunger has also been replaced.
Can you explain me Yout hought of how does oil pressure alter fuel pressure as the noise is clear indicator of high fuel pressure measured at the same time with VCDS.
Because oil PSI dictates a tolerance in the head cam journals, and when expanded under heat conditions or friction requirements are widened due to duty cycle .......heat grows and oil PSI falls which can create chatter resonance for sound which can travel.
This chatter increases heat and accelerates pump/lifter/cam lobe failure........and vicariously injectors.
Why do you think HPP pumps fail and parts plug the injectors long after a filter process because there is no filter after the HPP........
Same can be observed in TDI HPP pumps.........
Danners74
C?ID=273244
Sounds like you have a wiring issue there for the HPP to be open circuit and all the rest cam sensor etc. They do get a bit tight round there.
Component: 1.4l R4/4V TS H04 1686 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 3535 or higher is needed.......!
Hey I think that might help but also seems like a vapor lock issue too but isn't going to help for the oil being diluted with gasoline further damaging the cam adjuster/chain issue causing the cam/crank correlation DTC.
golfi_vend
Tartu, Estonia
C?ID=195131
Ended up being chain issue after all.
After new chain and CORRECT TIMING(2 jumped teeth) no more fuel pressure issue.
ECU also updated.
