17.6.0 output test issue
Spacewalker
Poland
C?ID=159607
Guys
Lates version not support any longer Fule gauge output test
Hovewer cluster going into "Black screen" so seems output test should start, but not start and you can see REJECT message
Friday,07,July,2017,10:24:02:25051
VCDS Version: Beta 17.6.0
Address 17: Instruments
Control Module Part Number: 2H0 920 871 A
Component and/or Version: KOMBI H05 0805
Software Coding: 171A00
Work Shop Code: WSC 02310
VCID: 2649F40B5986D6779B-8072
Advanced Identification/FAZIT
Identification: VD1-048
Date: 17.04.15
Manufacturer number: 7394
Test stand number: 3027
Flash Status
Programming Attempts(application): 0/0/0
Successful Attempts(application): 0/0/0
Programming Status: 00000000
Software
BAP: 01.04.01
OSEK-OS: 03.14.00
HiSpd Net: 01.12.01
Misc.
Hardware number: 2H0 920 871 A
Workshop System Name: J285
Equipment/PR Code: 2D2D2D2D2D2D2D2D
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: ------------------
ASAM Dataset: EV_Kombi_UDS_VDD_RM09
ASAM Dataset Revision: A04727
Car Info
Chassis Number: WV1ZZZ2HZFH******
VCDS Info:
Labels: 5K0-920-xxx-17.clb
ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
another cluster , this same issue (LCD is dark too)
Friday,07,July,2017,10:26:49:25051
Control Module Part Number: 5L0 920 840 L
Component and/or Version: KOMBI H06 0811
Software Coding: 120A01
Work Shop Code: WSC 33361
VCID: 346D1E439F5AB4E715-8060
Date: 01.08.13
Manufacturer number: 7392
Test stand number: 0358
Flash Status
Software
BAP: 01.04.01
OSEK-OS: 03.14.00
HiSpd Net: 01.12.01
Misc.
Hardware number: 5L0 920 840 L
ASAM Dataset Revision: A04721
Car Info
Chassis Number: TMBJF75L2D6******
VCDS Info:
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
Eric
HC800000
Ah, you're the second one to notice, after me :)
Here are the binaries with the fix, pick the one that matches your install:
This will work fine with your HEX+CAN, however it requires codeblock 4345 for the HEX-NET and v2. Let me know if you need one of those to be put on the alpha channel, that receives development codeblocks.
Spacewalker
Poland
C?ID=159607
x86 tested - Bingo, working !!!
Thx
icardiag
Europe
C?ID=113031
I downloaded the x64, while testing the cable I'm told that firmware update is required. When checking for update I receive a message, that I'm up to date, currently at codeblock 0.4341.4
