2017 Seat Ateca 2.0 TDI 190 DSG7 4DRIVE (DFHA)
kickdown
Unverified
Auto Scan:
VCDS Version: 17.1.3.0
Data version: 20170602 DS267.2
VIN: VSSZZZ5FZH6535211   License Plate:
Mileage: 8442km-5245mi   Repair Order:
Chassis Type  5F (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 5F 6C
          6D A5
VIN: VSSZZZ5FZH6535211   Mileage: 8442km-5245miles
Address 01: Engine (J623-DFHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 NQ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3614
   Revision: B4H24---
   Coding: 01250032036605083000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026NQ 004001
   ROD: N/A
   VCID: 062BCC0EA7F21D13BD-8052
No ASAM data for: "EV_ECM20TDI01104L906026NQ" (SE37)
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 300 011 Q    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 0706
   Revision: 00H06V07
   ROD: N/A
   VCID: 305178807FA011354D-8064
No ASAM data for: "EV_TCMDQ381061" (SE37)
   Revision: 00000000    Serial number: 63456000001184
   Coding: 22EE6A9234230C718779070162C42844562C30E1E046147D38625074E2A3430000100212121212A635351919323200
   Shop #: WSC 33361 790 00063
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 7798EABB9BCDA72A35-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0425586801
   Coding: 032C0C0F03
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB_SE37.rod
   VCID: 3C6560EC8FE4D989ED-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98110728
   Part No SW: 5F0 907 044 AL    HW: 5F0 907 044 AL
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 06000104200110011105004100101020
   VCID: 7091F8407FE091754D-8024
   Air quality sensor:
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001633801369
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7FA0DA93BB1577E2F5-802A
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S5Y16M12D08H05M48S07
   Coding: 00996E
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY162702E34
   Serial number: 00000000000067852418
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616334
   Coding: 0271267051
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 0D32BE79C3DF23C065-8058
Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320047C354FF8728749C8065804081
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_VW37.rod
   VCID: 3B6462EF8BF9DF8615-806E
   Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003R6PR1BCN6
   Coding: 98CCC0C0000000005C5400CC000800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0728CA0BDBFD071AB5-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 002 511 16
   Serial number: 35700000000667A0802B
   Subsystem 2 - Part No SW: -----------    HW: 454 002 711 16
   Serial number: 35800000000DEC51802S
   Subsystem 3 - Part No SW: -----------    HW: 454 802 811 16
   Serial number: 3510000215D0D0000000
   Subsystem 4 - Part No SW: -----------    HW: 454 802 711 16
   Serial number: 35200077D570D000000J
   Subsystem 5 - Part No SW: -----------    HW: 454 801 311 16
   Serial number: 35500A03B840D000000J
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 EE    HW: 5Q0 953 569 A
   Revision: FF036036    Serial number: 20161207500561
   Coding: 6C14
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 5F0 920 751 D    HW: 5F0 920 751 D
   Component: KOMBI         306 8311
   Coding: 07AD201AEF8C000801887E0B1001000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 27488AAB5B5D477AB5-8072
   Component: GW MQB High   515 5286
   Serial number: 14121610800612
   Coding: 030500F40F086A00EB0022581E0F00010001050000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewConti_013.rod
   VCID: 2F507A837BA5173275-807A
   Subsystem 2 - Part No SW: 5F0 959 537 A    HW: 5F0 959 537 A
   Serial number: 000000000A1493111116
   Coding: 012000
   Serial number: 75410803001612076605
   Serial number: HA1-00017.11.16
   Coding: 0001
   VCID: 4A774432D72EB56F9D-801E
   Serial number: 16000262321010
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 719EF64D73EB9B7C45-8024
Address 3C: Lane Change (J1086)       Labels: None
   Serial number: 0423373954
   Coding: 02011103
   ROD: EV_HREntryHella.rod
   Lane Change Assistant 2:
   Component: TSG FS        010 0032
   Serial number: 0000232419189
   Coding: 00311220D000040000001000
   VCID: 47684ACBDB3D875AB5-8012
   Serial number: 00000000000012609885
   Coding: 210000
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Revision: 00000000    Serial number: 0001266088
   Coding: 01010011004001
   ROD: EV_SteerAssisVWBSMQBA_SK37.rod
   VCID: 406158D0BFD0F1A5CD-8014
   Component: TSG BFS       010 0032
   Serial number: 0000233137979
   Coding: 00311220DC00040000001000
   VCID: 466B4CCEA7329D53BD-8012
   Serial number: 00000000000012599089
   Coding: 390000
   Part No SW: 5F0 035 043 D    HW: 5F0 035 043
   Component: MU-H-N-EU     H50 0897
   Serial number: A679K0G7520477
   Coding: 04230601FF0A000011110001000808232F0101C4012001009E
   ASAM Dataset: EV_MUHig6C3Gen2HBAS 001001
   ROD: EV_MUHig6C3Gen2HBAS_SE37.rod
   VCID: 1E439CB6070A8DBBFD-804A
   Subsystem 1 - Part No SW: 575 919 606     HW: 575 919 606
   Component: ABT_High-2_N  H41 1041
   Serial number: SEZ8Z9SCB00LGD
   Subsystem 2 - Part No SW: V03 959 801 NT    HW: -----------
   Component: ECE 2017  --- 0157
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG007982
   Coding: 06230601260FA00000606014
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 385968F89F8821ED0D-806C
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31083461800000
   Coding: 1908
   ROD: EV_DeckLidCONTIAU736_SE37.rod
   VCID: 416E56DDB3DBFBACC5-8014
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Serial number: 13121612P12100
   Coding: 030307060000040000222354C050A90098000E200020
   ROD: EV_MFKBoschMQBB.rod
End-------------------------(Elapsed Time: 05:32)--------------------------
kickdown
Unverified
01
	SW:04L-906-026-NQ   HW:04L-907-309-P ---  Engine
	Component:R4 2.0l TDI   H24 3614, Coding:01250032036605083000
	EV_ECM20TDI01104L906026NQ,004001,
	Wednesday,05,July,2017,22:28:16:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 06B344F65F7A859B35-8052
Elapsed Time: 00:00
02
	SW:0GC-300-011-Q   HW:0GC-927-711-G ---  Auto Trans
	Component:GSG DQ381     H06 0706, Coding:0014
	EV_TCMDQ381061,001,
	Wednesday,05,July,2017,22:28:56:46934
	VCID: 30D9F008F72899BDC5-8064
Elapsed Time: 00:00
03
	SW:5Q0-614-517-CF   HW:5Q0-614-517-AD ---  ABS Brakes
	Component:ESC           H25 0513, Coding:22EE6A9234230C718779070162C42844562C30E1E046147D38625074E2A3430000100212121212A635351919323200
	EV_Brake1UDSContiMK100IPB,036010,EV_Brake1UDSContiMK100IPB_034_VW48.rod
	Wednesday,05,July,2017,22:29:21:46934
	VCID: 7720622313B52FB28D-8022
IDE00001-Production mode,not active
IDE00252-Brake system vacuum pump,5
IDE00820-Activating and deactivating all development messages,0
IDE01763-Dimming,activated
IDE02332-Deactivate production mode,Deactivating
IDE03493-Driver door status,activated
IDE03659-Roller test bench mode,Manual activation: possible
IDE04456-Brake disk drying,Medium
IDE04508-Hydraulic brake booster,8
IDE04643-Overboost in brake system,activated
IDE04645-IDE05287-Electromechanical parking brake-Automatic application,not activated
IDE04645-MAS05667-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated
IDE04774-Vehicle and trailer stabilization,not activated
IDE04871-Dynamic starting assist,normal
IDE04939-Tire pressure monitoring display,2
IDE04944-Brake pedal evaluation,activated
IDE04949-Engine drag torque control,activated
IDE04951-Brake booster,4
IDE04952-Braking torque boost for distance regulation,3
IDE05055-Hydraulic brake assistant,normal
IDE05057-Brake prefill,activated
IDE05161-Straight ahead brake stabilization,activated
IDE05263-AUTO HOLD functionality,not activated
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %
IDE05286-Expanded electronic differential lock,Strong
IDE05337-IDE05337-Starting vibration reduction-,Strong
IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated
IDE05711-Automatic application during engine stalling,activated
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7
IDE06139-AUTO HOLD slippage recognition,activated
IDE06425-Roller test bench mode: functional,not activated
IDE06505-Electromechanical parking brake: delay level,6
IDE07006-Tire pressure monitoring display: tire selection,1
IDE07565-ABS in lower speed range,activated
IDE07848-Thresholds for brake performance,activated
MAS00122-Electronic Stability Program,not activated
MAS00970-Running manufacturer number,activated
MAS01180-AUTO HOLD functional status,Last setting
MAS01299-Offroad,0
MAS02080-XCP calibration protocol,not activated
MAS02138-Hill-start assistant,normal
MAS02666-Seat belt buckle scan,activated
MAS09008-MAS00988-Plausibility check-Reverse gear,activated
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated
MAS09008-MAS10668-Plausibility check-Clutch movement,activated
MAS11606-Electromechanical parking brake: emergency braking,activated
ENG118148-Developer_Function_1,0
ENG130301-Developer_Function_121,not activated
ENG122844-ENG101574-dimming_characteristic_1-X1,0
ENG122844-ENG99557-dimming_characteristic_1-X2,10
ENG122844-ENG102140-dimming_characteristic_1-X3,100
ENG122844-ENG102936-dimming_characteristic_1-X4,150
ENG122844-ENG103548-dimming_characteristic_1-X5,220
ENG122844-ENG113992-dimming_characteristic_1-X6,253
ENG122844-ENG99777-dimming_characteristic_1-Y1,2
ENG122844-ENG100480-dimming_characteristic_1-Y2,2
ENG122844-ENG100773-dimming_characteristic_1-Y3,5
ENG122844-ENG100631-dimming_characteristic_1-Y4,40
ENG122844-ENG102174-dimming_characteristic_1-Y5,82
ENG122844-ENG113993-dimming_characteristic_1-Y6,100
ENG122845-ENG101574-dimming_characteristic_2-X1,0
ENG122845-ENG99557-dimming_characteristic_2-X2,10
ENG122845-ENG102140-dimming_characteristic_2-X3,100
ENG122845-ENG102936-dimming_characteristic_2-X4,150
ENG122845-ENG103548-dimming_characteristic_2-X5,220
ENG122845-ENG113992-dimming_characteristic_2-X6,253
ENG122845-ENG99777-dimming_characteristic_2-Y1,2
ENG122845-ENG100480-dimming_characteristic_2-Y2,2
ENG122845-ENG100773-dimming_characteristic_2-Y3,5
ENG122845-ENG100631-dimming_characteristic_2-Y4,40
ENG122845-ENG102174-dimming_characteristic_2-Y5,82
ENG122845-ENG113993-dimming_characteristic_2-Y6,100
Elapsed Time: 00:22
05
	SW:3Q0-959-435-E   HW:3Q0-959-435-E ---  Acc/Start Auth.
	Component:VWKESSYMQB    036 0811, Coding:032C0C0F03
	EV_KessyHellaMQBAB,004039,EV_KessyHellaMQBAB_SE37.rod
	Wednesday,05,July,2017,22:30:55:46934
	VCID: 3CEDD854076C411165-8068
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not activated
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not activated
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not activated
IDE00820-Activating and deactivating all development messages,not active
IDE02332-Deactivate production mode,0
IDE03251-Stop release for start-stop function,According to function requirements
IDE04159-Deactivation of start-stop function,not active
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min
IDE09735-CU tailgate opener: sensor 1: threshold value 1,69
IDE09736-CU tailgate opener: sensor 1: threshold value 2,16
IDE09737-CU tailgate opener: sensor 1: threshold value 3,16
IDE09738-CU tailgate opener: sensor 1: threshold value 4,16
IDE09739-CU tailgate opener: sensor 1: threshold value 5,16
IDE09740-CU tailgate opener: sensor 2: threshold value 1,2
IDE09741-CU tailgate opener: sensor 2: threshold value 2,31
IDE09742-CU tailgate opener: sensor 2: threshold value 3,2
IDE09743-CU tailgate opener: sensor 2: threshold value 4,31
IDE09744-CU tailgate opener: sensor 2: threshold value 5,224
IDE09745-CU tailgate opener: sensor 1: timer value 1,170
IDE09746-CU tailgate opener: sensor 1: timer value 2,0
IDE09747-CU tailgate opener: sensor 1: timer value 3,9
IDE09748-CU tailgate opener: sensor 1: timer value 4,241
IDE09749-CU tailgate opener: sensor 1: timer value 5,40
IDE09750-CU tailgate opener: sensor 2: timer value 1,11
IDE09751-CU tailgate opener: sensor 2: timer value 2,165
IDE09752-CU tailgate opener: sensor 2: timer value 3,138
IDE09753-CU tailgate opener: sensor 2: timer value 4,204
IDE09754-CU tailgate opener: sensor 2: timer value 5,228
IDE09755-CU tailgate opener: sensor 1: burst length,16
IDE09756-CU tailgate opener: sensor 1: active screening,16
IDE09757-CU tailgate opener: sensor 2: burst length,2
IDE09758-CU tailgate opener: sensor 2: active screening,31
IDE09760-CU for tailgate opener: check sum,170
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,2
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,31
IDE09831-CU for tailgate opener: play protection increments,6
IDE09832-CU for tailgate opener: play protection decrements,25
IDE09833-CU for tailgate opener: play protection threshold active,255
IDE09834-CU for tailgate opener: play protection threshold inactive,5
IDE09835-CU for tailgate opener: play protection decrement interval,60
IDE09836-CU tailgate opener: sensor 1: control parameter,16
IDE09837-CU tailgate opener: sensor 2: control parameter,16
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,0
IDE09839-CU for tailgate opener: parameter set version,30
IDE10844-Control module rear lid opening: duration status query,4960 ms
IDE10845-Control module rear lid opening: vehicle type,28
ENG126964-ENG129122-Byt12_umgebungsscan-environment_scan_step1,not activated
ENG126964-ENG126978-Byt12_umgebungsscan-environment_scan_step2,not activated
ENG129012-ENG129126-Byte13_vit-vit_evaluate_inversbit,not activated
ENG129012-ENG129125-Byte13_vit-vit_exit,not activated
ENG126956-ENG126976-Byte9_VIP-active_vip,activated
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated
ENG126956-ENG129120-Byte9_VIP-vip_deactivation_on_clamp15,not activated
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s
ENG105462-CAN-timeout service-key message,260 ms
ENG105634-Correction value LED dimming,1.0
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms
ENG120046-Cyclic interior scan during clamp 15 on,10 s
ENG126961-deactivation_time_vip_slidingdoor,15 s
ENG126960-Debounce_time_detection,500 ms
ENG126959-Debounce_time_driver_presence,200 ms
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,120.00 s
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,Fahrertürgriff wird nicht abgeschaltet
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",Fehlerspeichereintrag wird unterdrueckt
ENG123036-ENG129118-DeveloperCoding: Search lights-ELV_Handling_MQBB,activated
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,installed
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive
ENG105825-Diagnostic: wait time after power on,500 ms
ENG126943-Display_duration_emergency_off,3000 ms
ENG126944-Display_duration_error_mode_2_SPN,10 s
ENG126941-Display_duration_please_engage_P,10 s
ENG105898-Doorknob contact sensor disconnecting time,5400 min
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms
ENG126950-duration_ZAT_debounce,50 ms
ENG129029-ENG11056-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %
ENG129029-ENG11055-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s
ENG129029-ENG11057-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s
ENG129029-ENG11058-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150
ENG129029-ENG11054-Easy_close_alignment-Min_threashold_trunk,70 %
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s
ENG129028-ENG129028-Easy_close_detection_areas-,70 mV/m
ENG129028-ENG129028-Easy_close_detection_areas-,65 mV/m
ENG126966-environment_scan_cyclic_step1,700 ms
ENG126967-environment_scan_cyclic_step2,2000 ms
ENG126965-environment_scan_duration_step1,300 min
ENG126971-environment_scan_duration_step2,24 H
ENG126969-environment_scan_level_bem,2
ENG126968-environment_scan_responselevel_reduction,500
ENG126970-environment_scan_startdelay_time,5 s
ENG126958-Ignition_For_Immobilizer,Default
ENG129016-Initialization_diagnostics_switching_terminal,not activated
ENG107050-Interior scan: deceleration after comfort closing,3200 ms
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h
ENG107052-Interior scan: opening threshold sliding roof,1 %
ENG107053-Interior scan: opening threshold window lifter,5.0 %
ENG107054-Interior scan: Speed - threshold,20 km/h
ENG98656-internal,0 B
ENG129022-ENG129116-internal_keyminder_byte1-aktivate_function_trigger_unlocking_elv,activated
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,not activated
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,ZV entriegeln
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated
ENG129023-ENG129117-internal_keyminder_byte2-Send numbers of ID-transmitters interior ELV-Scan,not activated
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,activated
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated
ENG107211-Key Minder: delay reunlocking tailgate,500 ms
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s
ENG107213-Key Minder: p_keyless_eventsearch_retries,2
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %
ENG107592-MCTX Pause,1 B
ENG107593-MCTX pause for Go / Key Minder,20 ms
ENG107594-MCTX pause for Go authentification,14 B
ENG107595-MCTX settling phase,10 B
ENG129013-min_receptiontime_vit,0 ms
ENG126945-min_time_for_Terminal_50_request,200 ms
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2
ENG126940-Number_of_ZAT_activations_to_DTC,10
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms
ENG108298-Proximity Sensor: duration of proximity Signal,10 s
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h
ENG108302-Proximity Sensor: max. Impulslength,75 ms
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s
ENG108309-Proximity Sensor: max. signal-length,120 s
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs
ENG108317-Proximity Sensor: SP_X2,10 min
ENG108318-Proximity Sensor: SP_X3,1
ENG108319-Proximity Sensor: SP_X4,80
ENG108320-Proximity Sensor: SP_X5,1
ENG108321-Proximity Sensor: SP_X6,30 min
ENG108322-Proximity Sensor: SP_X7,1
ENG108323-Proximity Sensor: Time Power On,1960 ms
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms
ENG108325-Proximity sensor: turn-off limit from battery-manager,2
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms
ENG120045-Reduced current for transponder-ID request,0 Step
ENG126939-rpm_threshold_engine_runnning,100 /min
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms
ENG108577-Scan Procedure: Number of Repeats,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms
ENG108585-ScanProcedure: Timeout Entry Response,260 ms
ENG108586-ScanProcedure: Timeout Response,100 ms
ENG126963-settime_trigger_entry_vehicle,500 ms
ENG126962-settime_trigger_exit_vehicle,500 ms
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated
ENG129025-ENG10879-sonstiges_byte2-hybrid_vehicle,not activated
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated
ENG129025-ENG125240-sonstiges_byte2-lf_crc,not activated
ENG129025-ENG11050-sonstiges_byte2-sad_existing,not activated
ENG129025-ENG11051-sonstiges_byte2-trunk_ecu_existing,activated
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h
ENG109053-Standard dimming value ZAT,80 %
ENG126938-Terminal_15_adaption_body_control_module,Default
ENG126946-Terminal_S_Timeout,30 min
ENG102207-Time Sensor Power Off Group 2,3600 min
ENG129027-Time_frame_VIP_kick_forecast,5
ENG126942-time_to_drive_cycle_detection,1.00 s
ENG126947-time_to_ignore_ignition_trigger,35 s
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s
ENG126949-time_ZAT_actuation_detection,3000 ms
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms
ENG129019-timeout_convenience_coverage_limiting,75 s
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s
ENG109974-Voltage monitoring: overvoltage Delta,500 mV
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV
ENG109978-Voltage monitoring: undervoltage Delta,500 mV
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV
ENG120047-ZAT init value,0 %
ENG110364-ZAT nominal voltage,13.0 V
ENG110365-ZAT post-carridge during clamp 15 off,10 min
Elapsed Time: 01:06
08
	SW:5F0-907-044-AL   HW:5F0-907-044-AL ---  Auto HVAC
	Component:Climatronic   H05 1801, Coding:06000104200110011105004100101020
	EV_ACClimaBHBVW37X,006145,EV_ACClimaBHBVW37X_005_VW37.rod
	Wednesday,05,July,2017,22:32:28:46934
	VCID: 701970C8F76819FDC5-8024
IDE00001-Production mode,Deactivating
IDE01067-Retention of driver's seat heater level,active for 10 minutes
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore
IDE01479-Gear ratio of engine - A/C compressor,0.00
IDE01483-Blower voltage for voice operation,not activated
IDE01488-Retrofitting of parking heater without CAN,not installed
IDE01493-Air quality sensor sensitivity,Maximum
IDE01503-Runtime for compressor run-in basic setting,60 s
IDE01536-Post-heating of parking heater,10 min
IDE02155-Reset all counters,not activated
IDE03176-Duration of compressor run in,60 s
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min
IDE06545-Blower voltage for production routines,11.0 V
IDE06546-Interior target temperature for production routines,22 °C
IDE06547-Air distribution for production routines,No effect
IDE06593-Recirculation air for production routines,No effect
IDE07108-Climate modes,Matching coding
IDE07301-Remotestart-Funktion: Aktivierung Sitzheizung,Seat heater front
IDE07302-Remotestart-Funktion: Innenraumklimatisierung Status,Remote start function with fixed rated temperature active
IDE07303-Remotestart-Funktion: Aktivierungungstemperatur Scheibenheizung,4 °C
IDE07304-Remotestart-Funktion: Aktivierung Sitzlüftung,activated
IDE07305-Remotestart-Funktion: Aktivierungungstemperatur Sitzheizung,15 °C
IDE07306-Remotestart-Funktion: Aktivierungungstemperatur Sitzlüftung,20 °C
IDE07307-Remotestart-Funktion: Aktivierungungsstufe Sitzheizung,2
IDE07308-Remotestart-Funktion: Aktivierungungsstufe Sitzlüftung,2
IDE07398-Blower logic for manual adjustment,Matching coding
IDE07585-Hand heater function during cold start,active
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,active
IDE07948-Retention of frt.pass. seat heater level,not active
IDE80006-Analysis 6,not activated
IDE80007-Analysis 7,00000000 00000000
IDE80008-Analysis 8,not active
MAS05739-CO2 compressor on-time reduction,Matching coding
MAS06564-Window condensation exterior reduction at high humidity,Matching coding
MAS07251-Cut-in behavior,Matching coding
ENG122844-ENG99557-dimming_characteristic_1-X2,6
ENG122844-ENG102140-dimming_characteristic_1-X3,40
ENG122844-ENG102936-dimming_characteristic_1-X4,60
ENG122844-ENG103548-dimming_characteristic_1-X5,80
ENG122844-ENG113992-dimming_characteristic_1-X6,100
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %
ENG122845-ENG102140-dimming_characteristic_2-X3,50
ENG122845-ENG102936-dimming_characteristic_2-X4,100
ENG122845-ENG99777-dimming_characteristic_2-Y1,3 %
ENG122845-ENG100480-dimming_characteristic_2-Y2,3 %
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %
ENG122845-ENG100631-dimming_characteristic_2-Y4,45 %
ENG122845-ENG102174-dimming_characteristic_2-Y5,100 %
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %
ENG122846-ENG101574-dimming_characteristic_3-X1,0
ENG122846-ENG99557-dimming_characteristic_3-X2,10
ENG122846-ENG102140-dimming_characteristic_3-X3,50
ENG122846-ENG102936-dimming_characteristic_3-X4,100
ENG122846-ENG103548-dimming_characteristic_3-X5,220
ENG122846-ENG113992-dimming_characteristic_3-X6,253
ENG122846-ENG99777-dimming_characteristic_3-Y1,5 %
ENG122846-ENG100480-dimming_characteristic_3-Y2,5 %
ENG122846-ENG100773-dimming_characteristic_3-Y3,15 %
ENG122846-ENG100631-dimming_characteristic_3-Y4,70 %
ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %
ENG122847-ENG101574-dimming_characteristic_4-X1,0
ENG122847-ENG99557-dimming_characteristic_4-X2,10
ENG122847-ENG102140-dimming_characteristic_4-X3,50
ENG122847-ENG102936-dimming_characteristic_4-X4,100
ENG122847-ENG103548-dimming_characteristic_4-X5,220
ENG122847-ENG113992-dimming_characteristic_4-X6,253
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %
ENG122847-ENG100773-dimming_characteristic_4-Y3,4 %
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %
ENG122848-ENG101574-dimming_characteristic_5-X1,0
ENG122848-ENG99557-dimming_characteristic_5-X2,10
ENG122848-ENG102140-dimming_characteristic_5-X3,50
ENG122848-ENG102936-dimming_characteristic_5-X4,100
ENG122848-ENG103548-dimming_characteristic_5-X5,220
ENG122848-ENG113992-dimming_characteristic_5-X6,253
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %
ENG122848-ENG100773-dimming_characteristic_5-Y3,4 %
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %
ENG130577-Knockout_timer_activation,not activated
Elapsed Time: 00:16
kickdown
Unverified
09
	SW:5Q0-937-084-CG   HW:5Q0-937-084-CG ---  Cent. Elect.
	Component:BCM MQBAB H   H34 0236, Coding:000000000000000000000000000000000000000000000000000000000000
	EV_BCMMQB,017001,EV_BCMBOSCH_017.rod
	Wednesday,05,July,2017,22:33:24:46934
	VCID: 7F28521B339DFF6A4D-802A
IDE00001-ENG99061-Production mode-Access control,not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active
IDE00002-Transport mode,active
IDE02152-Characteristics in production mode,2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
IDE02269-ENG11176-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms
IDE02269-ENG11175-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms
IDE02269-ENG11174-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms
IDE02488-DWA Interior monitoring,100 %
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s (second)
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s (second)
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s (second)
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s (second)
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s (second)
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s (second)
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,127.5 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE03787-Activate left/right hand drive switch-over,not active
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s (second)
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.0 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.0 °C
IDE04927-ENG11179-Window heater-Frontscheibenheizung _maximale_Dauer,0 s (second)
IDE04927-ENG10963-Window heater-Frontscheibenheizung_LED_direkt,not installed
IDE04927-ENG10946-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus,not installed
IDE04927-ENG126845-Window heater-FSH Automatik,active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s (second)
IDE04927-ENG10883-Window heater-heizbare Heckscheibe,installed
IDE04927-ENG10949-Window heater-Heizbare_Frontscheibe,installed
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
IDE04927-ENG10890-Window heater-Waschduesenheizung,installed
IDE04927-ENG10945-Window heater-window heating front activation time,240 s (second)
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG10888-Anti-theft device-Diebstahlwarnanlage,active
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG10935-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut
IDE04928-ENG10889-Anti-theft device-Heckscheibenbruchsensor,not installed
IDE04928-ENG10934-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No
IDE04928-ENG11177-Anti-theft device-OBD Alarm,activ
IDE04928-ENG10937-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No
IDE04928-ENG10938-Anti-theft device-Sensor_fuer_Innenraumueberwachung,Yes
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
IDE04928-ENG10936-Anti-theft device-tilt_sensor,Yes
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05144-Read parameter address,00 00 00
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 49 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 05 4D 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 37 00 1C 46 08 7F 09 3A 7F 00 00 00 00 00 00 06 41 00 1D 46 08 7F 0A 3A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00
IDE05822-DWA Vehicle inclination sensor,100 %
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C6 01 14 0A 03 81 33 0C 00 00 00 01 FF 46 06 00 0F 1D 00 85 0F 39 F7 64 23 65 31 57 9B 25 44 3F 3A 69 35 95 1D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 31 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 31 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 87 09 30 33 67 23 65 31 57 9B 25 24 0C FA 0A 34 95 1D 09 A3 21 03 00 02 02 02 02 02 02 B1 30 81 27 B4
IDE06089-ENG10904-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,10 s (second)
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,23.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,53.00 °C
IDE06089-ENG10905-Seat heater level current consumption allocation-Sitzheizungsfreigabe,not installed
IDE06425-Roller test bench mode: functional,not active
IDE06507-MAS13125-Button in center console-Funktion Taster 1,Start-stop
IDE06507-MAS13129-Button in center console-Funktion Taster 2,not coded/not installed
IDE06507-MAS13132-Button in center console-Funktion Taster 3,Driving program
IDE06507-MAS13135-Button in center console-Funktion Taster 4,not coded/not installed
IDE06507-ENG09171-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed
IDE07007-ENG11181-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active
IDE07007-ENG11180-A/C heater function via remote control-Abbruch_Hupen_RSt,not active
IDE07007-ENG11183-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active
IDE07007-ENG11182-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active
IDE07007-ENG115720-A/C heater function via remote control-Remotestart,not installed
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active
IDE08786-ENG10884-Assistance light functions-Humidity sensor,installed
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active
IDE08786-ENG11156-Assistance light functions-Maskierung_Regenfunktion,not active
IDE08786-ENG10913-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s (second)
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,1
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,5
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,20 %
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,100 %
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,100 %
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,not active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,not active
IDE09731-ENG11161-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
IDE09731-ENG10959-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht,not installed
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel,not installed
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
IDE09731-ENG11112-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active
IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI,active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed
IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %
IDE09761-ENG10952-Seat fan charac. curve-Sitzlueftung,not installed
IDE09761-ENG11111-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed
IDE09761-ENG10953-Seat fan charac. curve-Sitzpneumatik,not installed
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,0.00
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.00
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,1.00
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.00
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,0.00
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,0.00
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.00
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000001
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00010000
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4,0
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000100
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab,1
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf,1
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay,0
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,0 %
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,0 %
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,100 %
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,0 %
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,0 %
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,0 %
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,0 %
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,0 %
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,100 %
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,0 %
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,0 %
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,0 %
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,100 %
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,0 %
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,0 %
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,100 %
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,0 %
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,0 %
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,0 %
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,0 %
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,0 %
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,0 %
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,100 %
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,0 %
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,0 %
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,0 %
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,0 %
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,100 %
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,0 %
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,0 %
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,100 %
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht,100 %
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,0 %
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,0 %
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,0 %
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,0 %
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,100 %
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,0 %
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,0 %
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht,100 %
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,0 %
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,0 %
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,0 %
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,0 %
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,0 %
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,0 %
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,0 %
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,0 %
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,0 %
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,0 %
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,0 %
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,0 %
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,0 %
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,0 %
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,0 %
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,0 %
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,0 %
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,0 %
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,0 %
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,0 %
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,0 %
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,0 %
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,0 %
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,0 %
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,0 %
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,0 %
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,0 %
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,0 %
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,0 %
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,0 %
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,0 %
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,0 %
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,100 %
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht,100 %
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,0 %
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,0 %
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,0 %
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,0 %
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,100 %
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,0 %
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,0 %
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,0 %
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,0 %
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,0 %
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,0 %
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,0 %
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,0 %
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,0 %
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,0 %
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,0 %
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,0 %
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,0 %
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,0 %
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,0 %
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,0 %
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %
IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,3200 ms
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit,0.0 s (second)
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach,0.0 s (second)
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum,0.0 s (second)
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht,0.0 s (second)
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko,0.0 s (second)
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren,0.0 s (second)
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0.0 s (second)
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach,0.0 s (second)
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s (second)
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht,0.0 s (second)
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko,0.0 s (second)
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s (second)
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit,0.0 s (second)
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach,0.0 s (second)
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum,0.0 s (second)
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht,0.0 s (second)
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko,0.0 s (second)
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren,0.0 s (second)
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit,0.0 s (second)
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach,0.0 s (second)
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum,0.0 s (second)
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht,0.0 s (second)
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko,0.0 s (second)
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren,0.0 s (second)
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit,0.0 s (second)
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach,0.0 s (second)
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum,0.0 s (second)
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht,0.0 s (second)
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko,0.0 s (second)
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren,0.0 s (second)
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit,0.0 s (second)
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach,0.0 s (second)
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum,0.0 s (second)
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0.0 s (second)
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko,0.0 s (second)
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren,0.0 s (second)
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit,0.0 s (second)
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach,0.0 s (second)
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum,0.0 s (second)
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht,0.0 s (second)
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko,0.0 s (second)
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren,0.0 s (second)
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen,0
IDE11714-ENG126827-Ambientelicht Farbliste-Blauwert Farbe 1,255
IDE11714-ENG02360-Ambientelicht Farbliste-Blauwert Farbe 10,0
IDE11714-ENG126830-Ambientelicht Farbliste-Blauwert Farbe 2,207
IDE11714-ENG126833-Ambientelicht Farbliste-Blauwert Farbe 3,0
IDE11714-ENG02342-Ambientelicht Farbliste-Blauwert Farbe 4,34
IDE11714-ENG02345-Ambientelicht Farbliste-Blauwert Farbe 5,0
IDE11714-ENG02348-Ambientelicht Farbliste-Blauwert Farbe 6,246
IDE11714-ENG02351-Ambientelicht Farbliste-Blauwert Farbe 7,213
IDE11714-ENG02354-Ambientelicht Farbliste-Blauwert Farbe 8,251
IDE11714-ENG02357-Ambientelicht Farbliste-Blauwert Farbe 9,0
IDE11714-ENG126826-Ambientelicht Farbliste-Gruenwert Farbe 1,255
IDE11714-ENG02359-Ambientelicht Farbliste-Gruenwert Farbe 10,0
IDE11714-ENG126829-Ambientelicht Farbliste-Gruenwert Farbe 2,230
IDE11714-ENG126832-Ambientelicht Farbliste-Gruenwert Farbe 3,255
IDE11714-ENG02341-Ambientelicht Farbliste-Gruenwert Farbe 4,114
IDE11714-ENG02344-Ambientelicht Farbliste-Gruenwert Farbe 5,0
IDE11714-ENG02347-Ambientelicht Farbliste-Gruenwert Farbe 6,56
IDE11714-ENG02350-Ambientelicht Farbliste-Gruenwert Farbe 7,237
IDE11714-ENG02353-Ambientelicht Farbliste-Gruenwert Farbe 8,218
IDE11714-ENG02356-Ambientelicht Farbliste-Gruenwert Farbe 9,0
IDE11714-ENG126825-Ambientelicht Farbliste-Rotwert Farbe 1,255
IDE11714-ENG02358-Ambientelicht Farbliste-Rotwert Farbe 10,0
IDE11714-ENG126828-Ambientelicht Farbliste-Rotwert Farbe 2,245
IDE11714-ENG126831-Ambientelicht Farbliste-Rotwert Farbe 3,255
IDE11714-ENG02340-Ambientelicht Farbliste-Rotwert Farbe 4,246
IDE11714-ENG02343-Ambientelicht Farbliste-Rotwert Farbe 5,255
IDE11714-ENG02346-Ambientelicht Farbliste-Rotwert Farbe 6,36
IDE11714-ENG02349-Ambientelicht Farbliste-Rotwert Farbe 7,44
IDE11714-ENG02352-Ambientelicht Farbliste-Rotwert Farbe 8,193
IDE11714-ENG02355-Ambientelicht Farbliste-Rotwert Farbe 9,0
IDE11944-ENG10942-Schlüssellose Zugang- und Startberechtigung-Elektische_Lenkradverriegelung,installed
IDE11944-ENG10876-Schlüssellose Zugang- und Startberechtigung-Kessy,installed
IDE11944-ENG116653-Schlüssellose Zugang- und Startberechtigung-Kessy Komfort oeffnen,not active
IDE11944-ENG116654-Schlüssellose Zugang- und Startberechtigung-Kessy Komfort schliessen,active
IDE11944-ENG116655-Schlüssellose Zugang- und Startberechtigung-Kessy Komfortbedienung Reichweitenbegrenzung,active
IDE11944-ENG116626-Schlüssellose Zugang- und Startberechtigung-Oeffnung Heckdeckel bei Wiederentriegelung,not active
MAS01490-ENG10955-Energy management-Energiemanagement Abschaltung,active
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active
MAS01490-ENG11184-Energy management-Hochvoltfahrzeug,not installed
MAS01490-ENG10878-Energy management-Hybridfahrzeug,No
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement,not active
MAS01490-ENG10906-Energy management-Recuperation,active
MAS01490-ENG10965-Energy management-Zweitbatterie,not installed
MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,1200 lx
MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,2200 lx
MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle,1000 lx
MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO,600 lx
MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten,1200 lx
MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten,2200 lx
MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50
MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx
MAS08228-ENG11158-Light sensor-HMI_Exterior_light_on_highway,not active
MAS08228-ENG11159-Light sensor-HMI_Exterior_light_on_rain,not active
MAS08228-ENG11160-Light sensor-HMI_exterior_light_sensitivity,frueh
MAS08228-ENG11157-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF,not active
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe,not active
MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung,4500 mV
MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx
MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung,2000 mV
MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke,0 lx
MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung,02
ENG10611-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active
ENG10611-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active
ENG10611-ENG10903-Allwetterlicht_Spoiler-tt_spoiler,not installed
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed
ENG10577-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active
ENG10577-ENG02307-Außenlicht_Blinker-Abbruch Komfortblinken,active
ENG10577-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger,separte
ENG10577-ENG121966-Außenlicht_Blinker-Crash flashing,not active
ENG10577-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active
ENG10577-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active
ENG10577-ENG11122-Außenlicht_Blinker-dynamisch_blinken_10,not active
ENG10577-ENG11123-Außenlicht_Blinker-Dynamische_Blink_Delay,50 ms
ENG10577-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken,not active
ENG10577-ENG115774-Außenlicht_Blinker-Komfortblinken,active
ENG10577-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen,3
ENG10577-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken,not active
ENG10577-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,not active
ENG10577-ENG121967-Außenlicht_Blinker-Panic flashing,not active
ENG10577-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active
ENG10577-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active
ENG10577-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active
ENG10577-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active
ENG10577-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
ENG10577-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active
ENG10577-ENG10957-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active
ENG10577-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active
ENG10577-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active
ENG10577-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active
ENG10577-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active
ENG10575-ENG10914-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7
ENG10575-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h
ENG10575-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h
ENG10575-ENG115833-Außenlicht_Front-Fahrlicht bei Tag,Daytime running lights
ENG10575-ENG11121-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h
ENG10575-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active
ENG10575-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
ENG10575-ENG11119-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active
ENG10575-ENG11118-Außenlicht_Front-Signaturlicht_verbaut,not installed
ENG10575-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
ENG10575-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
ENG10575-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
ENG10575-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active
ENG10575-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
ENG10575-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte,not active
ENG10575-ENG11120-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,not active
ENG10575-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
ENG10575-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
ENG10576-ENG10915-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No
ENG10576-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,60 km/h
ENG10576-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active
ENG10576-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,not active
ENG10576-ENG10932-Aussenlicht_Heck-Umgreifende_Heckklappe,not installed
ENG10584-ENG10948-Außenlicht_uebergreifend-All-weather lights,not installed
ENG10584-ENG02309-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement
ENG10584-ENG02308-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement
ENG10584-ENG11116-Außenlicht_uebergreifend-bewusstes Standlicht,Aktive Begrenzung
ENG10584-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam
ENG10584-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic
ENG10584-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis,Driver door
ENG10584-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active
ENG10584-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL
ENG10584-ENG02310-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten
ENG10584-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx
ENG10584-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,18 lx
ENG10584-ENG11117-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige,No
ENG10584-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
ENG10584-ENG11113-Außenlicht_uebergreifend-LCM_blinker,wahr
ENG10584-ENG10920-Außenlicht_uebergreifend-LDS_mit_AFL,Yes
ENG10584-ENG10919-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes
ENG10584-ENG10918-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes
ENG10584-ENG10921-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung,Yes
ENG10584-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus,Enabled
ENG10584-ENG10917-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete
ENG10584-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig
ENG10584-ENG10962-Außenlicht_uebergreifend-Light_Control_Module,installed
ENG10584-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
ENG10584-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,30 s
ENG10584-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,30 s
ENG10584-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung,active
ENG10584-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP,active
ENG10584-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided
ENG10584-ENG126816-Außenlicht_uebergreifend-Standlicht aus,active
ENG10584-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active
ENG10584-ENG02311-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s (second)
ENG10584-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte,not active
ENG126647-ENG98399-debug_light_function-Activation,0
ENG126647-ENG101417-debug_light_function-Adresse,0
ENG126647-ENG126820-debug_light_function-Bitmask,0
ENG126647-ENG126821-debug_light_function-Divisor,0
ENG126647-ENG98827-debug_light_function-Offset,0
ENG126647-ENG126822-debug_light_function-Polaritaet,0
ENG10603-ENG115658-Dimmunt_KL_58xs_PWM-x0,0.0 %
ENG10603-ENG101574-Dimmunt_KL_58xs_PWM-X1,50.0 %
ENG10603-ENG99557-Dimmunt_KL_58xs_PWM-X2,100.0 %
ENG10603-ENG115659-Dimmunt_KL_58xs_PWM-y0,0.0 %
ENG10603-ENG99777-Dimmunt_KL_58xs_PWM-Y1,50.0 %
ENG10603-ENG100480-Dimmunt_KL_58xs_PWM-Y2,100.0 %
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG10578-MAS13782-Fernlicht_assistent-Assistenzfahrlicht: Empfindlichkeit per BAP einstellbar,present
ENG10578-ENG10901-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: BCM-Fernlicht
ENG10578-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active
ENG10578-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present
ENG10578-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present
ENG10610-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active
ENG10610-ENG11178-Front_wiper-Anfahrzeit_servicestellung,800 ms
ENG10610-ENG115836-Front_wiper-Frontwischer Notlaufprogramm,active
ENG10610-ENG116614-Front_wiper-Frontwischer Referenzlauf,active
ENG10610-ENG02322-Front_wiper-Frontwischer_Abtauposition,not active
ENG10610-ENG10894-Front_wiper-Frontwischertyp,Direct
ENG10610-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
ENG10610-ENG116615-Front_wiper-Menuesteuerung Frontwischer,not active
ENG10610-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating
ENG10610-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz,active
ENG10610-ENG116618-Front_wiper-Traenenwischen Front Status,active
ENG10610-ENG115770-Front_wiper-Variable Regensensoraktivierung,active
ENG10610-ENG126844-Front_wiper-Washer_Tipwiping_Variant,not active
ENG10610-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
ENG10610-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active
ENG10610-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active
ENG99457-ENG117394-Head area heater-blower_speed,1
ENG99457-ENG98971-Head area heater-Temperature,-2
ENG10573-MAS00211-HW_Verbau-Insufficient brake fluid,installed
ENG10573-MAS00212-HW_Verbau-Insufficient washer fluid,installed
ENG10573-MAS00213-HW_Verbau-Insufficient coolant,installed
ENG10573-MAS00214-HW_Verbau-Brake pad wear,installed
ENG10573-ENG10954-HW_Verbau-Druckklappe,not installed
ENG10573-ENG10891-HW_Verbau-Elektrische Laderaumabdeckung aktiv,not active
ENG10573-ENG10940-HW_Verbau-Elektrische_Laderaumabdeckung,not installed
ENG10573-ENG10880-HW_Verbau-Exterior temp. sensor,installed
ENG10573-ENG10933-HW_Verbau-Kontaktschalter_fuer_Motorhaube,installed
ENG10573-ENG11114-HW_Verbau-Ladesteckerverriegelung,not installed
ENG10573-ENG10964-HW_Verbau-PTC Zuheizer,not installed
ENG10573-ENG115809-HW_Verbau-Signalhorn ohne KL15,active
ENG10573-ENG10931-HW_Verbau-Status_Tankdeckelverriegelung,not active
ENG10588-ENG115658-Kennlinie_sLWR_Soll-x0,95.00 %
ENG10588-ENG101574-Kennlinie_sLWR_Soll-X1,94.50 %
ENG10588-ENG99557-Kennlinie_sLWR_Soll-X2,94.00 %
ENG10588-ENG102140-Kennlinie_sLWR_Soll-X3,93.50 %
ENG10588-ENG102936-Kennlinie_sLWR_Soll-X4,93.00 %
ENG10588-ENG103548-Kennlinie_sLWR_Soll-X5,92.50 %
ENG10588-ENG113992-Kennlinie_sLWR_Soll-X6,92.00 %
ENG10588-ENG115661-Kennlinie_sLWR_Soll-x7,91.50
ENG10588-ENG115662-Kennlinie_sLWR_Soll-x8,91.00 %
ENG10588-ENG115663-Kennlinie_sLWR_Soll-x9,90.50 %
ENG10588-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %
ENG10588-ENG99777-Kennlinie_sLWR_Soll-Y1,90.0 %
ENG10588-ENG100480-Kennlinie_sLWR_Soll-Y2,80.0 %
ENG10588-ENG100773-Kennlinie_sLWR_Soll-Y3,70.0 %
ENG10588-ENG100631-Kennlinie_sLWR_Soll-Y4,60.0 %
ENG10588-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %
ENG10588-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %
ENG10588-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %
ENG10588-ENG115666-Kennlinie_sLWR_Soll-y8,15.0 %
ENG10588-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
ENG10585-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15,maximize
ENG10585-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15,maximize
ENG10585-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15,maximize
ENG10585-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15,100
ENG10585-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15,0
ENG10585-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15,0
ENG10585-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15,0
ENG10585-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,06
ENG10585-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15,00
ENG10585-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung
ENG10585-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15,Always
ENG10585-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15,not active
ENG10585-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15,not active
ENG10585-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15,not active
ENG10585-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15,not active
ENG10585-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15,not active
ENG10585-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15,not active
ENG10585-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15,not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,0
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,00
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,not active
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,31
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,0B
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,9 - allgemeine Glühlampe 27W: auch H15
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Rueckfahrlicht
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,08
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Quittierungsfunktion 1
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Quittierungsfunktion 1
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,00
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,10
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,37 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Daytime running lights
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,127
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,20
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,37 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Daytime running lights
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,minimize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,127
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,35
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0A
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,37 - allgemeine LED bis 12W
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,Daytime running lights
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,Coming Home oder Leaving Home aktiv
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,Rear lid open
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,minimize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,127
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,37 - allgemeine LED bis 12W
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,Daytime running lights
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Coming Home oder Leaving Home aktiv
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,Parking light right
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,Rear lid open
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,33
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,2A
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,0
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,0
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,127
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,49
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,127
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,4D
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,beidseitiges Dauerparklicht
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Parking light right
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,beidseitiges Dauerparklicht
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active
ENG10589-Leuchtenkonfiguration_Aussenlich_Heck,0C 08 00 16 02 00 64 03 00 80 00 00 00 00 00 00 0C 18 00 18 04 00 64 05 00 80 00 00 00 00 00 00 27 09 00 2B 18 24 7F 00 00 00 00 00 00 00 00 00 27 19 00 2D 18 24 7F 00 00 00 00 00 00 00 00 00 2A 00 00 2C 18 24 64 00 00 00 00 00 00 00 00 00 25 10 00 29 08 09 7F 1E 14 7F 00 00 00 00 00 00 25 20 00 2A 08 0A 7F 1E 14 7F 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 00 00 00 00 00 00 00 00 00 25 0A 00 35 08 14 FF 1E 09 7F 00 00 00 21 00 80 25 1A 00 36 08 14 FF 1E 0A 7F 00 00 00 21 00 80 09 2A 00 33 1A 00 E4 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 E4 00 00 00 00 00 00 00 00 00
ENG10590-Leuchtenkonfiguration_Sonstiges,09 0B 00 31 19 00 E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 06 4C 00 64 00 00 00 00 00 00 00 00 00
ENG10586-ENG11125-Leuchtweitenregulierung-1_Sensor_LWR,1-Sensor_LWR
ENG10586-ENG11147-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2650 mm
ENG10586-ENG11146-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4,4.50 mm/%
ENG10586-ENG11145-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn,3.30 mm/%
ENG10586-ENG11129-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,active
ENG10586-ENG11139-Leuchtweitenregulierung-Ansteuerung_obere_grenze,84.0 %
ENG10586-ENG11138-Leuchtweitenregulierung-Ansteuerung_untere_grenze,20.0 %
ENG10586-ENG11137-Leuchtweitenregulierung-diagnose_soll_toleranz,15 %
ENG10586-ENG11131-Leuchtweitenregulierung-Entprellung_Fehlerlampe,10.0 s (second)
ENG10586-ENG11142-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,4.10 mm/%
ENG10586-ENG11144-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,4.70 mm/%
ENG10586-ENG11141-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.30 mm/%
ENG10586-ENG11143-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.30 mm/%
ENG10586-ENG11126-Leuchtweitenregulierung-Fahrwerk_Variante,2: Variante 3 (Mehrlenkerhinterachse 4-Motion
ENG10586-ENG11132-Leuchtweitenregulierung-Fail_Safe_sLWR,70.0 %
ENG10586-ENG11151-Leuchtweitenregulierung-fFiltEinf,10.00 Hz
ENG10586-ENG11140-Leuchtweitenregulierung-Lineare_Abbildung,1
ENG10586-ENG11130-Leuchtweitenregulierung-Logik_PWM_Signal,Negative
ENG10586-ENG11148-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,550 mm
ENG10586-ENG11149-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,680 mm
ENG10586-ENG11154-Leuchtweitenregulierung-lwr_pwm_obere_schwelle,95.0 %
ENG10586-ENG11153-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,5.0 %
ENG10586-ENG11155-Leuchtweitenregulierung-max_v_slwr,5 km/h
ENG10586-ENG11150-Leuchtweitenregulierung-pa_fDynFiltStatLwr,100 Hz
ENG10586-ENG11152-Leuchtweitenregulierung-pa_fFiltSwNeigung,10.00 Hz
ENG10586-ENG11128-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM
ENG10586-ENG10970-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear
ENG10586-ENG11127-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,not active
ENG10586-ENG11136-Leuchtweitenregulierung-sLWR_Hysterese,10.0 %
ENG10586-ENG11135-Leuchtweitenregulierung-sLWR_SW_Grad,5.0 %/s
ENG10586-ENG11134-Leuchtweitenregulierung-sLWR_Touristenlicht,14.0 %
ENG10586-ENG11124-Leuchtweitenregulierung-sLWR_verbaut,not installed
ENG10586-ENG11133-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s (second)
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,not active
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,not active
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,not active
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.0 %
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,20.0 %
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,30.0 %
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,40.0 %
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,50.0
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,100.0
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,10.0 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,20.0 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,40.0 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %
ENG10587-ENG115658-lwr_ofs_RSw_Ah1S-x0,-3.71 %
ENG10587-ENG101574-lwr_ofs_RSw_Ah1S-X1,-2.96 %
ENG10587-ENG99557-lwr_ofs_RSw_Ah1S-X2,-2.04 %
ENG10587-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.48 %
ENG10587-ENG102936-lwr_ofs_RSw_Ah1S-X4,-0.37 %
ENG10587-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.20
ENG10587-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.10
ENG10587-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-0.05
ENG10587-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-0.01
ENG10587-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.00
ENG122979-ENG10882-Networking-A/C electronics,installed
ENG122979-ENG10896-Networking-Anhaengeranschlussgeraet,not installed
ENG122979-ENG10902-Networking-Bremsen_Steuergeraet,installed
ENG122979-ENG10881-Networking-Getriebesteuergeraet,installed
ENG122979-ENG99457-Networking-Head area heater,not installed
ENG122979-ENG10968-Networking-Kunden_spezifisches_Funktions_SG,not installed
ENG122979-ENG10897-Networking-UGDO,not installed
ENG124714-ENG10972-OCU-DWA_push,not active
ENG124714-ENG11188-OCU-Honk DWA_Ausgabe_Fanfare,not active
ENG124714-ENG124714-OCU-,not installed
ENG124714-ENG11189-OCU-Remote HuF Abbruch,20 km/h
ENG124714-ENG11190-OCU-Remote HuF Hupfrequenz,3
ENG124714-ENG02319-OCU-Remote Lock Unlock Timer s1,80 s (second)
ENG124714-ENG02320-OCU-Remote Lock Unlock Timer s3,20.0 ms
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active
ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,not active
ENG98831-ENG02329-Personalisierung-Anzahl_Benutzerkonten,1
ENG98831-ENG02330-Personalisierung-Automatische_ Schluesselzuordnung,not active
ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active
ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv,not active
ENG98831-ENG10922-Personalisierung-Personalisierung_Profilfunkion,profiles_inactive
ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active
ENG98831-ENG10958-Personalisierung-Profil_Variante,Schluessel
ENG98831-ENG02332-Personalisierung-PSO_FSG_Setup2_Bit_1,not active
ENG98831-ENG02333-Personalisierung-PSO_FSG_Setup2_Bit_2,not active
ENG98831-ENG02334-Personalisierung-PSO_FSG_Setup2_Bit_3,not active
ENG98831-ENG02335-Personalisierung-PSO_FSG_Setup2_Bit_4,not active
ENG10574-MAS01065-Querschnitts_funktionen-Brand,Seat
ENG10574-ENG10908-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active
ENG10574-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active
ENG10574-ENG10895-Querschnitts_funktionen-Codierungsabsicherung,not active
ENG10574-ENG10956-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,not active
ENG10574-ENG11115-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin 31
ENG10574-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active
ENG10574-ENG10892-Querschnitts_funktionen-Lenkungsanordnung,Left
ENG10574-ENG10943-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed
ENG10574-ENG10911-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active
ENG10574-ENG10893-Querschnitts_funktionen-Verkehrsseite,Right
ENG122927-RLS_close_glazing,2.0 s (second)
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s (second)
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s (second)
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s (second)
ENG122929-RLS_LIN_Communication,4 s (second)
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
ENG122930-RLS_tunel_gateway_recognize,5 s (second)
ENG122935-RLS_Washer_Front,15 s (second)
ENG122926-RLS_wiper_position_parking,15 s (second)
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5
ENG115729-ENG10877-Scheinwerferreinigung-Headlamp washer system,not installed
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,500 ms
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,500 ms
ENG10612-SFT09729-Slave_systems_identification-Control Unit For Wiper Motor,Not available
ENG10612-SFT09730-Slave_systems_identification-Rain Light Recognition Sensor,Not available
ENG10612-SFT09731-Slave_systems_identification-Light switch,Not available
ENG10612-SFT09732-Slave_systems_identification-Garage door opener control module,Not available
ENG10612-SFT09733-Slave_systems_identification-Garage Door Opener Operating Unit,Not available
ENG10612-SFT09750-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available
ENG10612-SFT09752-Slave_systems_identification-Alarm horn,Not available
ENG10612-SFT09760-Slave_systems_identification-Sun Roof,Not available
ENG10612-SFT09766-Slave_systems_identification-Ceiling Light Module,Not available
ENG10612-SFT09784-Slave_systems_identification-Roof Blind,Not available
ENG10612-SFT09803-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available
ENG10612-SFT09822-Slave_systems_identification-Neck Heating Left,Not available
ENG10612-SFT09823-Slave_systems_identification-Neck Heating Right,Not available
ENG10612-SFT09921-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available
ENG10612-SFT09923-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available
ENG10612-SFT09925-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available
ENG10612-SFT09927-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,SMLS
ENG116588-ENG116588-Sonderfunktionen-,not enabled
ENG116588-ENG10907-Sonderfunktionen-Sonderfunktionen 1,not installed
ENG10563-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active
ENG10563-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key
ENG10563-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active
ENG10563-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active
ENG10563-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active
ENG10563-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active
ENG10563-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung,active
ENG10563-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active
ENG10563-ENG02339-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,active
ENG10563-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active
ENG10606-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0,0.0 lx
ENG10606-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1,8.0 lx
ENG10606-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2,50.0 lx
ENG10606-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3,80.0 lx
ENG10606-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4,100.0 lx
ENG10606-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0,6.0
ENG10606-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1,6.0
ENG10606-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2,20.0
ENG10606-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3,50.0
ENG10606-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4,100.0
ENG10607-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0,0.0 lx
ENG10607-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1,8.0 lx
ENG10607-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2,50.0 lx
ENG10607-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3,80.0 lx
ENG10607-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4,100.0 lx
ENG10607-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0,6.0
ENG10607-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1,6.0
ENG10607-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2,20.0
ENG10607-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3,50.0
ENG10607-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4,100.0
ENG10594-ENG115658-Suchbeleuchtung_Abdimmen-x0,0 ms
ENG10594-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms
ENG10594-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms
ENG10594-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms
ENG10594-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms
ENG10594-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms
ENG10594-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms
ENG10594-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms
ENG10594-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms
ENG10594-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms
ENG10594-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms
ENG10594-ENG115659-Suchbeleuchtung_Abdimmen-y0,100.0 %
ENG10594-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %
ENG10594-ENG115668-Suchbeleuchtung_Abdimmen-y10,0.0 %
ENG10594-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %
ENG10594-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %
ENG10594-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %
ENG10594-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %
ENG10594-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %
ENG10594-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %
ENG10594-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %
ENG10594-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %
ENG10591-ENG11168-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.00 s (second)
ENG10591-ENG11164-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM,0.00 s (second)
ENG10591-ENG11166-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM,0.00 s (second)
ENG10591-ENG11167-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM,0.00 s (second)
ENG10591-ENG11165-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM,0.00 s (second)
ENG10591-ENG10916-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI
ENG10591-ENG11170-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s (second)
ENG10591-ENG11169-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s (second)
ENG10591-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe,not active
ENG10591-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active
ENG10591-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung,active
ENG10591-ENG11171-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11
ENG10591-ENG11163-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM,0.00 s (second)
ENG10591-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %
ENG10591-ENG11162-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi
ENG10591-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung,Always active
ENG10591-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.200
ENG10591-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,0.0 %
ENG10595-ENG115658-Suchbeleuchtung_Fotosensor-x0,0
ENG10595-ENG101574-Suchbeleuchtung_Fotosensor-X1,50
ENG10595-ENG115664-Suchbeleuchtung_Fotosensor-x10,0
ENG10595-ENG99557-Suchbeleuchtung_Fotosensor-X2,100
ENG10595-ENG102140-Suchbeleuchtung_Fotosensor-X3,200
ENG10595-ENG102936-Suchbeleuchtung_Fotosensor-X4,253
ENG10595-ENG103548-Suchbeleuchtung_Fotosensor-X5,0
ENG10595-ENG113992-Suchbeleuchtung_Fotosensor-X6,0
ENG10595-ENG115661-Suchbeleuchtung_Fotosensor-x7,0
ENG10595-ENG115662-Suchbeleuchtung_Fotosensor-x8,0
ENG10595-ENG115663-Suchbeleuchtung_Fotosensor-x9,0
ENG10595-ENG115659-Suchbeleuchtung_Fotosensor-y0,0 lx
ENG10595-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx
ENG10595-ENG115668-Suchbeleuchtung_Fotosensor-y10,0 lx
ENG10595-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx
ENG10595-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200
ENG10595-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500
ENG10595-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0
ENG10595-ENG113993-Suchbeleuchtung_Fotosensor-Y6,0 lx
ENG10595-ENG115665-Suchbeleuchtung_Fotosensor-y7,0 lx
ENG10595-ENG115666-Suchbeleuchtung_Fotosensor-y8,0 lx
ENG10595-ENG115667-Suchbeleuchtung_Fotosensor-y9,0 lx
ENG10593-ENG115658-Suchbeleuchtung_Hochdimmen-x0,0 ms
ENG10593-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms
ENG10593-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms
ENG10593-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms
ENG10593-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms
ENG10593-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms
ENG10593-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms
ENG10593-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms
ENG10593-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms
ENG10593-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms
ENG10593-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms
ENG10593-ENG115659-Suchbeleuchtung_Hochdimmen-y0,0.0 %
ENG10593-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %
ENG10593-ENG115668-Suchbeleuchtung_Hochdimmen-y10,100.0 %
ENG10593-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %
ENG10593-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %
ENG10593-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %
ENG10593-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %
ENG10593-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %
ENG10593-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %
ENG10593-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %
ENG10593-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %
ENG10597-ENG115658-Suchbeleuchtung_KL 58xs max-x0,0 lx
ENG10597-ENG101574-Suchbeleuchtung_KL 58xs max-X1,8 lx
ENG10597-ENG99557-Suchbeleuchtung_KL 58xs max-X2,50 lx
ENG10597-ENG102140-Suchbeleuchtung_KL 58xs max-X3,500 lx
ENG10597-ENG115659-Suchbeleuchtung_KL 58xs max-y0,100.0
ENG10597-ENG99777-Suchbeleuchtung_KL 58xs max-Y1,100.0
ENG10597-ENG100480-Suchbeleuchtung_KL 58xs max-Y2,100.0
ENG10597-ENG100773-Suchbeleuchtung_KL 58xs max-Y3,100.0
ENG10596-ENG115658-Suchbeleuchtung_KL 58xs min-x0,0 lx
ENG10596-ENG101574-Suchbeleuchtung_KL 58xs min-X1,8 lx
ENG10596-ENG99557-Suchbeleuchtung_KL 58xs min-X2,50 lx
ENG10596-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx
ENG10596-ENG115659-Suchbeleuchtung_KL 58xs min-y0,10.0
ENG10596-ENG99777-Suchbeleuchtung_KL 58xs min-Y1,10.0
ENG10596-ENG100480-Suchbeleuchtung_KL 58xs min-Y2,50.0
ENG10596-ENG100773-Suchbeleuchtung_KL 58xs min-Y3,50.0
ENG10602-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 %
ENG10602-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 %
ENG10602-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 %
ENG10602-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 %
ENG10602-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 %
ENG10602-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 %
ENG10602-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0,6
ENG10602-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1,6
ENG10602-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2,100
ENG10602-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3,150
ENG10602-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4,220
ENG10602-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5,253
ENG10601-ENG115658-Suchbeleuchtung_KL_58xd_max-x0,0 lx
ENG10601-ENG101574-Suchbeleuchtung_KL_58xd_max-X1,8 lx
ENG10601-ENG99557-Suchbeleuchtung_KL_58xd_max-X2,200 lx
ENG10601-ENG102140-Suchbeleuchtung_KL_58xd_max-X3,300 lx
ENG10601-ENG102936-Suchbeleuchtung_KL_58xd_max-X4,500 lx
ENG10601-ENG115659-Suchbeleuchtung_KL_58xd_max-y0,16.0
ENG10601-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1,16.0
ENG10601-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2,100.0
ENG10601-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3,100.0
ENG10601-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4,100.0
ENG10600-ENG115658-Suchbeleuchtung_KL_58xd_min-x0,0 lx
ENG10600-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,8 lx
ENG10600-ENG99557-Suchbeleuchtung_KL_58xd_min-X2,220 lx
ENG10600-ENG102140-Suchbeleuchtung_KL_58xd_min-X3,300 lx
ENG10600-ENG102936-Suchbeleuchtung_KL_58xd_min-X4,500 lx
ENG10600-ENG115659-Suchbeleuchtung_KL_58xd_min-y0,6.0
ENG10600-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,6.0
ENG10600-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,100.0
ENG10600-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,100.0
ENG10600-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,100.0
ENG10605-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0,0
ENG10605-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1,10
ENG10605-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,100
ENG10605-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,150
ENG10605-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4,220
ENG10605-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5,253
ENG10605-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %
ENG10605-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,5.0 %
ENG10605-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,15.0 %
ENG10605-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %
ENG10605-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %
ENG10605-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5,100.0 %
ENG10598-ENG115658-Suchbeleuchtung_KL_58xt min-x0,0 lx
ENG10598-ENG101574-Suchbeleuchtung_KL_58xt min-X1,8 lx
ENG10598-ENG99557-Suchbeleuchtung_KL_58xt min-X2,50 lx
ENG10598-ENG102140-Suchbeleuchtung_KL_58xt min-X3,500 lx
ENG10598-ENG115659-Suchbeleuchtung_KL_58xt min-y0,10.0
ENG10598-ENG99777-Suchbeleuchtung_KL_58xt min-Y1,10.0
ENG10598-ENG100480-Suchbeleuchtung_KL_58xt min-Y2,100.0
ENG10598-ENG100773-Suchbeleuchtung_KL_58xt min-Y3,100.0
ENG10599-ENG115658-Suchbeleuchtung_KL_58xt_max-x0,0 lx
ENG10599-ENG101574-Suchbeleuchtung_KL_58xt_max-X1,8 lx
ENG10599-ENG99557-Suchbeleuchtung_KL_58xt_max-X2,50 lx
ENG10599-ENG102140-Suchbeleuchtung_KL_58xt_max-X3,500 lx
ENG10599-ENG115659-Suchbeleuchtung_KL_58xt_max-y0,100.0
ENG10599-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1,100.0
ENG10599-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2,100.0
ENG10599-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3,100.0
ENG10604-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 %
ENG10604-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 %
ENG10604-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 %
ENG10604-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0,0.0 %
ENG10604-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1,50.0 %
ENG10604-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2,100.0 %
ENG10608-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx
ENG10608-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx
ENG10608-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx
ENG10608-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx
ENG10608-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx
ENG10608-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1020 lx
ENG10608-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0
ENG10608-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,84
ENG10608-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,166
ENG10608-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,250
ENG10608-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,370
ENG10608-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500
ENG10592-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ms
ENG10592-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,2000 ms
ENG10592-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,3000 ms
ENG10592-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,4000 ms
ENG10592-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,5100 ms
ENG10592-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,1.0 %
ENG10592-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0
ENG10592-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0
ENG10592-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0
ENG10592-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0
ENG10560-ENG116647-Sunroof-SAD Komfort oeffnen,not active
ENG10560-ENG116646-Sunroof-SAD Komfort schliessen,not active
ENG10560-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,Open
ENG10560-ENG10898-Sunroof-Schiebedachmodul_MD_1,not installed
ENG10560-ENG10899-Sunroof-Schiebedachmodul_MD_3,not installed
ENG10560-ENG10900-Sunroof-Schiebedachmodul_MD_Rollo,not installed
ENG10560-ENG10950-Sunroof-Verortung Schiebedachmodule,CAN
ENG10562-ENG10941-Verdecksteuergeraet-Cabrio_Verdeck,not_installed
ENG10562-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active
ENG10562-ENG128459-Verdecksteuergeraet-easycloselight_aktiv,not active
ENG10562-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active
ENG10562-ENG11187-Verdecksteuergeraet-Kick_and_close,installed
ENG10562-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,not active
ENG10562-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,not active
ENG10562-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,not active
ENG10562-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active
ENG10562-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active
ENG10562-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu
ENG10562-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always
ENG10562-ENG10939-Verdecksteuergeraet-trunk_lid_conrol_unit,installed
ENG10562-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active
ENG10562-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active
ENG10562-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active
ENG10562-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,not active
ENG10562-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active
ENG10562-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,not active
ENG10562-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,not active
ENG10562-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,active
ENG10562-ENG11186-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,active
ENG10562-ENG11185-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,installed
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
ENG10579-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB,not active
ENG10579-ENG02315-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,not active
ENG10579-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
ENG10579-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active
ENG10579-ENG115754-ZV allgemein-Funk bei Klemme 15 ein,not active
ENG10579-ENG10909-ZV allgemein-Lock_Unlock_Taster_direkt,not installed
ENG10579-ENG10947-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed
ENG10579-ENG02316-ZV allgemein-LS_Taster_Togglefunktion,not active
ENG10579-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active
ENG10579-ENG115755-ZV allgemein-Notschließfunktion,active
ENG10579-ENG02317-ZV allgemein-Nutzfahrzeug_Schliessung,not active
ENG10579-ENG10885-ZV allgemein-Radio freq.,434.42MHz
ENG10579-ENG10886-ZV allgemein-Tankschloss,Bidirectional
ENG10579-ENG02318-ZV allgemein-Wiederverriegelung_Laderaum,Freigabe_Softtouch
ENG10579-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung
ENG10579-ENG10924-ZV allgemein-ZV_ohne_Safe_Funktion,not installed
ENG10582-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck,active
ENG10582-ENG116621-ZV Autolock-automatisches Entriegeln,active
ENG10582-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active
ENG10582-ENG116706-ZV Autolock-Autounlock NAR,not active
ENG10582-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,active
ENG10582-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable
ENG10583-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
ENG10583-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active
ENG10583-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active
ENG10581-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active
ENG10581-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
ENG10581-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
ENG10581-ENG10944-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_pin
ENG10581-ENG02314-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active
ENG10581-ENG11173-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active
ENG10581-ENG10926-ZV Heck-Heckschloss_mit_Vorraste,Yes
ENG10581-ENG10923-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit
ENG10581-ENG06090-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s (second)
ENG10581-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
ENG10581-ENG10910-ZV Heck-Tausch_Tank_Hecktreiberausgang,No
ENG10581-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel,active
ENG10581-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen,not active
ENG10581-ENG10925-ZV Heck-ZV_Heck_Schlosstyp,1 or 2 notch rear actuator
ENG10609-IDE02021-ZV Komfort-Comfort closing,active
ENG10609-IDE02022-ZV Komfort-Comfort opening,active
ENG10609-ENG10912-ZV Komfort-elektrischer_Fensterheber_hinten,Yes
ENG10609-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active
ENG10609-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active
ENG10609-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit,600 s (second)
ENG10609-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus,active
ENG10609-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
ENG10609-ENG116652-ZV Komfort-Funk Komfort oeffnen,active
ENG10609-ENG116651-ZV Komfort-Funk Komfort schliessen,active
ENG10609-ENG115670-ZV Komfort-Komfortbedienung global,active
ENG10609-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer,not active
ENG10609-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar,adjustable
ENG10609-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen,not active
ENG10609-ENG125656-ZV Komfort-Regenschliessen_art,once
ENG10609-ENG125655-ZV Komfort-Regenschliessen_ein_aus,not active
ENG10609-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,active
ENG10609-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,active
ENG10580-ENG10927-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser
ENG10580-ENG10971-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal,nicht invertiert
ENG10580-ENG10967-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite,not installed
ENG10580-ENG10966-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite,not installed
ENG10580-ENG10929-ZV Türkonfiguration-Schiebetuer_links,No
ENG10580-ENG10930-ZV Türkonfiguration-Schiebetuer_rechts,No
ENG10580-ENG10969-ZV Türkonfiguration-Schiebetueren_Crafter,not installed
ENG10580-ENG11172-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM,Driver side
ENG10580-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
ENG10580-ENG10928-ZV Türkonfiguration-Schlosstyp_NAR,No
ENG10580-ENG10887-ZV Türkonfiguration-Viertuerer,Yes
Elapsed Time: 02:15
10
	SW:5QA-919-298   HW:5Q0-919-298-C ---  Park/Steer Assist
	Component:PLA 3.0 12KH08 0161, Coding:0271267051
	EV_EPHVA2CAU3700000,009017,EV_EPHVA2CAU3700000_009.rod
	Wednesday,05,July,2017,22:36:06:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 0DBA36E17B47AB48FD-8058
IDE00001-Production mode,Deactivating
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble,not activated
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble,not activated
IDE00845-Wheel circ.,2080 mm
IDE01165-Park assist activation tone,On
IDE01169-Audio reduction request,On
IDE02328-Distance to curb,19 cm
IDE02329-Allowance for vehicle fittings (width),0 cm
IDE02332-Deactivate production mode,0
IDE02333-Allowance for vehicle fittings (length),0 cm
IDE03782-Switch-off speed for parking assist,15 km/h
IDE03783-Switch-on speed for parallel parking assist,37 km/h
IDE04159-Deactivation of start-stop function,Start-stop function in control module active
IDE05274-Acoustic warning for rear lid assistant,not active
MAS01426-Speaker volume for rear park assist,Stage 6
MAS01427-Speaker frequency for rear park assist,Stage 4
MAS01428-Speaker volume for front park assist,Stage 4
MAS01429-Speaker frequency for front park assist,Stage 6
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners,0.180 1/m
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners,1.308 1/m
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang,0.866 m
Elapsed Time: 00:11
13
	SW:2Q0-907-572-J   HW:2Q0-907-572-B ---  Auto Dist. Reg
	Component:ACCCONTIMQB   H01 0156, Coding:320047C354FF8728749C8065804081
	EV_ACCMRRCONTIVW376,001011,EV_ACCMRRCONTIVW376_VW37.rod
	Wednesday,05,July,2017,22:36:37:46934
	VCID: 3BECDA570361470E6D-806E
IDE00820-ENG00957-Activating and deactivating all development messages-Development Message ECU specific,OFF
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF
IDE00820-ENG00958-Activating and deactivating all development messages-XCP on FlexRay,OFF
IDE01949-Distance basic setting option,On
IDE03642-Presentation mode,not active
IDE05815-Sail function,Deactivating
IDE06425-Roller test bench mode: functional,not activated
IDE08935-Expanded restart function,OFF
IDE09564-Distance change via speed adjustment,OFF
IDE09565-Prioritized target object display,On
IDE10280-Constant delay after transfer request,No
Elapsed Time: 00:07
15
	SW:3Q0-959-655-AK   HW:3Q0-959-655-AK ---  Airbags
	Component:Airbag VW21   004 0306, Coding:98CCC0C0000000005C5400CC000800000065
	EV_AirbaVW21TS6VW48X,001010,EV_AirbaVW21TS6VW48X.rod
	Wednesday,05,July,2017,22:37:08:46934
	VCID: 07B042F353658FA20D-8052
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,not defined
IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,not defined
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,activated
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,activated
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined
Elapsed Time: 00:02
16
	SW:3Q0-953-521-EE   HW:5Q0-953-569-A ---  Steering wheel
	Component:Lenks.Modul   075 0235, Coding:6C14
	EV_SMLSVALEOMQB,001015,EV_SMLSVALEOMQB.rod
	Wednesday,05,July,2017,22:37:32:46934
	VCID: 7720622313B52FB28D-8022
ENG126417-p_n_fehler_p_verriegelt,50
ENG120504-p_s_NWDF_spg,0 ms
ENG102189-p_t_blinker_entprellen,40 ms
ENG102332-p_t_blinker_err_el_kurzschluss,200 ms
ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms
ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms
ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s
ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms
ENG100988-p_t_blinker_err_gra_haengt_ein,300 s
ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms
ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s
ENG100923-p_t_blinker_err_unplausibel,2000 ms
ENG127113-p_t_blinker_err_weckkontakthaengt_aus,5000 ms
ENG127112-p_t_blinker_err_weckkontakthaengt_ein,3000 ms
ENG103471-p_t_blinker_gra_entprellen,40 ms
ENG101294-p_t_blinker_sperrzeit,100 ms
ENG127114-p_t_entprellung_p_unplausibel,400 ms
ENG104033-p_t_entprellzeit_ueberspannung,90000 ms
ENG101392-p_t_entprellzeit_unterspannung,90000 ms
ENG102689-p_t_fas_entprellen,40 ms
ENG120505-p_t_gra_ea_error,2000 ms
ENG101014-p_t_grahebel_entprellen,40 ms
ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms
ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms
ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms
ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s
ENG103536-p_t_grahebel_err_unplausibel,200 ms
ENG99436-p_t_hupe_entprellen,40 ms
ENG102496-p_t_hupe_err_hinweis,2000 ms
ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms
ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s
ENG101702-p_t_hupe_indien_entprellen,500 ms
ENG100796-p_t_spannung_obere_schwelle,18.0 V
ENG102338-p_t_spannung_untere_schwelle,6.5 V
ENG100559-p_t_wischer_entprellen,40 ms
ENG103039-p_t_wischer_err_el_kurzschluss,200 ms
ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s
ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms
ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s
ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms
ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s
ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms
ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s
ENG101592-p_t_wischer_intervall_entprellen,40 ms
ENG103607-p_t_wischer_winterstellung,60 s
Elapsed Time: 00:15
kickdown
Unverified
17
	SW:5F0-920-751-D   HW:5F0-920-751-D ---  Instruments
	Component:KOMBI         306 8311, Coding:07AD201AEF8C000801887E0B1001000000000000
	EV_DashBoardVDDMQBAB,009051,EV_DashBoardVDDMQBAB_009_SK37.rod
	Wednesday,05,July,2017,22:38:05:46934
	VCID: 27D00213D3C5CF820D-8072
IDE00295-Oil temperature display,On
IDE00301-Distance,8442 km
IDE00342-ESI: Resetting ESI,no warning
IDE00343-Language version,Bulgarisch
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset
IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,22 H
IDE00501-Minute,38 min
IDE00502-Year,2017 yr
IDE00503-Month,7 mon
IDE00504-Day,5 d
IDE00510-ESI: distance driven from inspection,8442 km
IDE00511-ESI: time from inspection,195 d
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
IDE00514-ESI: maximum value of time between inspections,730 d
IDE00515-ESI: oil quality,good oil quality
IDE00517-ESI: soot entry,15000 km
IDE00518-ESI: thermal load,6600 km
IDE00819-Day counter,195 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,365 d
IDE01087-Staging,No
IDE01153-SIA: maximum value of distance to service,15000 km
IDE01154-SIA: maximum value of time to service,365 d
IDE02489-Display depiction,Version 2
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
IDE03329-Driving profiled for range remaining,8.1 l/100km
IDE03346-IDE00301-Units adjusted-Distance,Kilometers
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius
IDE03346-MAS02957-Units adjusted-Time,24h
IDE03346-MAS03032-Units adjusted-Volume,Liter
IDE03346-MAS03034-Units adjusted-Pressure,bar
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km
IDE03346-MAS13665-Units adjusted-Anhänge-/Stützlast Masse,Kilogramm (kg)
IDE03348-MAS01456-Speed warning-Speed,0
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour
IDE03348-IDE03348-Speed warning-,not active
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,8400 km
IDE03352-FIX: Time since last time-dependent inspection,153 d
IDE03372-Source for synchronization of time,GPS
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE05930-Service notification in days,30 d
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km
IDE05932-FIX: Reset value for next time-dependent inspections,365 d
IDE05971-Vehicle Positioning System Interface Control Module,not installed
IDE06588-Ignition active message: actuator,Driver door
IDE06922-No-voltage display,No display
IDE07221-Cylinder shut-off,Display
IDE11086-Service notification,30 d
IDE11932-MAS01877-Display Farbabgleich-Red,0
IDE11932-MAS01878-Display Farbabgleich-Green,0
IDE11932-MAS01879-Display Farbabgleich-Blue,0
MAS03555-Lap counter,Display
MAS03685-Digital speedometer,Display
ENG117917-BAP_Debug_Mode_Release,not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
ENG119875-defuel_threshold,50 l
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,1E
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,3C
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,64
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,30
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,06
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,05
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,05
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,36
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,44
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,59
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,64
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,96
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,0F
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,0F
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,64
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,64
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,64
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,64
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,96
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0E
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,0E
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,2D
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,3E
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,57
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 15
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 7D
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,64
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,96
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,13
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,21
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
ENG119874-Gas_functionality,not active
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light
ENG119882-init_fuel_algorithm,No
ENG130585-Leaving_warning_delay,1.6 s
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0
ENG119825-Picture_Upload_Download,not active
ENG126396-Scale_switching_algorithm,lowbeam_foglight
ENG119876-Service_Key_Clear_All_Counter,Yes
ENG130584-Statistic_phev_mileage,5 km
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.6
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.0
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.0
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN
ENG112418-ENG99298-total_range_gas-State,not active
Elapsed Time: 00:32
19
	SW:3Q0-907-530-C   HW:3Q0-907-530-C ---  CAN Gateway
	Component:GW MQB High   515 5286, Coding:030500F40F086A00EB0022581E0F00010001050000000000000000000000
	EV_GatewNF,013020,EV_GatewConti_013.rod
	Wednesday,05,July,2017,22:39:09:46934
	VCID: 2FD8F20BF32D9FBACD-807A
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating
IDE00002-Transport mode,not active
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V
IDE01211-Static current measuring mode,not activated
IDE01457-Energy management deactivation stage,Mode not active
IDE01459-Energy management heat output control status,Mode not active
IDE01844-Increase idle speed request,Mode not active
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,--
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active
IDE01860-Generator specified voltage value variable,10.6 V
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded
IDE01996-SFT00025-Installation list: specified installations-Gateway,1
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,coded
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,coded
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,coded
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,coded
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,coded
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded
IDE01996-SFT00128-Installation list: specified installations-Batterieregelung Zusatzspeicher 1,Not coded
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,coded
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded
IDE01996-ENG118234-Installation list: specified installations-Node_0x09,coded
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded
IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111
IDE03903-Production process data 1,00 00
IDE04159-Deactivation of start-stop function,Mode not active
IDE04186-Battery terminal recognition,connected
IDE04330-Transfer of release code for a SWaP function,00
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error
IDE06530-Distance left for deactivation of static current measuring mode,2
IDE06541-Distance left for deactivation of transport mode,50
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,not activated
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated
IDE07838-Counter for inconsistent states,499
IDE08348-Start/stop start voltage limit,7.6 V
IDE08624-MKE Check box,activated
IDE10735-Number requests autonomous recharging,3
IDE10736-Cyclization limitation request battery service,0
IDE10748-MAS11262-Range gain-Range gain AC system,activated
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated
IDE10748-MAS11264-Range gain-Range gain window defogger,activated
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated
IDE10748-MAS11267-Range gain-Range gain rear heater,activated
IDE10748-MAS11268-Range gain-Range gain fog light,activated
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated
IDE10748-MAS11273-Range gain-Range gain rear seat heater,not activated
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated
IDE10748-MAS11279-Range gain-List at engine still stand,activated
IDE10748-MAS12689-Range gain-Catalogue range display,activated
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated
IDE10748-MAS13161-Range gain-Listendarstellung Absolutwerte mit Gewichtung,activated
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms
ENG05988-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active
ENG05988-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active
ENG05988-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active
ENG05988-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active
ENG06003-EM_heating_power_quota_adjustment,1000 W
ENG05989-EM_nominal_voltage_limitation_low_beams,12.1 V
ENG05992-EM_requirement_cyclic_time_voltage_measurement,0 s
ENG05991-EM_requirement_reduction_air_blowers,Mode not active
ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C
ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C
ENG05986-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled
ENG05986-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled
ENG05986-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled
ENG05986-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled
ENG05986-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled
ENG05986-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled
ENG05986-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled
ENG05986-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled
ENG05986-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled
ENG05986-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled
ENG05986-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled
ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled
ENG05986-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled
ENG05986-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled
ENG05986-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled
ENG05986-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled
ENG05986-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled
ENG05986-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled
ENG05986-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled
ENG05986-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled
ENG05986-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled
ENG05986-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled
ENG05986-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled
ENG05986-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled
ENG05986-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled
ENG05986-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled
ENG05986-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled
ENG05986-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled
ENG05986-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled
ENG05986-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled
ENG05986-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled
ENG05986-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled
ENG05986-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled
ENG05986-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled
ENG05986-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled
ENG05986-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled
ENG05986-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled
ENG05986-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled
ENG05986-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled
ENG05986-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled
ENG05986-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled
ENG05986-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled
ENG05986-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled
ENG05986-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled
ENG05986-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
ENG05986-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled
ENG05986-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled
ENG05986-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled
ENG05986-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled
ENG05986-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled
ENG05986-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled
ENG05986-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled
ENG05986-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled
ENG05986-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled
ENG05986-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled
ENG05986-SFT09787-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled
ENG05986-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled
ENG05986-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled
ENG05986-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled
ENG05986-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled
ENG05986-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled
ENG05986-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled
ENG05986-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled
ENG05986-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled
ENG05986-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled
ENG05986-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled
ENG05986-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled
ENG05986-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled
ENG05986-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled
ENG05986-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled
ENG05986-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled
ENG05986-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled
ENG05986-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled
ENG05986-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled
ENG05986-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled
ENG05986-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled
ENG05986-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled
ENG05986-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled
ENG05986-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled
ENG05986-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled
ENG05986-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled
ENG05986-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled
ENG05986-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled
ENG05986-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled
ENG05986-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled
ENG05986-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled
ENG05986-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled
ENG05986-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled
ENG05986-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled
ENG05986-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled
ENG05986-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled
ENG05986-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled
ENG05986-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled
ENG05986-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled
ENG05986-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled
ENG05986-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled
ENG05986-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled
ENG05986-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled
ENG05986-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled
ENG05986-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled
ENG05986-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled
ENG05986-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled
ENG05986-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled
ENG05986-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled
ENG05986-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled
ENG05986-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled
ENG05986-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled
ENG05986-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled
ENG05986-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled
ENG05986-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled
ENG05986-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled
ENG05986-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled
ENG05986-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled
ENG05986-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled
ENG05986-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled
ENG05986-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled
ENG05986-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled
ENG05986-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled
ENG05986-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled
ENG05986-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled
ENG05986-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled
ENG05986-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled
ENG05986-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled
ENG05986-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled
ENG05986-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled
ENG05986-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled
ENG05986-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled
ENG05986-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled
ENG05986-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled
ENG05986-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled
ENG05986-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled
ENG05986-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled
ENG05986-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled
ENG05986-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled
ENG05986-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled
ENG05986-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled
ENG05986-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled
ENG05986-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled
ENG05986-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled
ENG05986-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled
ENG05986-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled
ENG05986-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled
ENG05986-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled
ENG05986-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled
ENG05986-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled
ENG05986-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled
ENG05986-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled
ENG05986-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled
ENG05986-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled
ENG05986-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled
ENG05986-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled
ENG05986-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled
ENG05986-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled
ENG05986-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled
ENG05986-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled
ENG05986-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled
ENG05986-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled
ENG05986-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled
ENG05986-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled
ENG05986-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled
ENG05986-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled
ENG05986-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled
ENG05986-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled
ENG05986-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled
ENG05986-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled
ENG05986-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled
ENG05986-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled
ENG05986-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled
ENG05986-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled
ENG05986-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled
ENG05986-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled
ENG05986-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled
ENG05986-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled
ENG05986-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled
ENG05986-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled
ENG05986-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled
ENG05986-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled
ENG05986-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled
ENG05986-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled
ENG05986-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled
ENG05986-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled
ENG05986-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled
ENG05986-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled
ENG05986-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled
ENG05986-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled
ENG05986-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled
ENG05986-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled
ENG05986-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled
ENG05986-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled
ENG05986-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled
ENG05986-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled
ENG05986-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled
ENG05986-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled
ENG05986-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled
ENG05986-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled
ENG05986-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled
ENG05986-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled
ENG05986-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled
ENG05986-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled
ENG05986-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled
ENG05986-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled
ENG05986-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled
ENG05986-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled
ENG05986-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled
ENG05986-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled
ENG05986-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled
ENG05986-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled
ENG05986-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled
ENG05986-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled
ENG05986-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled
ENG05986-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled
ENG05986-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled
ENG05986-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled
ENG05986-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled
ENG05986-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled
ENG05986-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled
ENG05986-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled
ENG05986-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled
ENG05986-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled
ENG05986-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled
ENG05986-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled
ENG05986-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled
ENG05986-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled
ENG05986-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled
ENG05986-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled
ENG05986-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled
ENG05986-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled
ENG05986-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled
ENG05986-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled
ENG05986-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled
ENG05986-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled
ENG05986-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled
ENG05986-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled
ENG05986-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled
ENG05986-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled
ENG05986-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled
ENG05986-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled
ENG05986-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled
ENG05986-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled
ENG05986-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled
ENG05986-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled
ENG05986-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled
ENG05986-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled
ENG05986-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled
ENG05986-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled
ENG05986-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled
ENG05986-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled
ENG05986-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled
ENG05986-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled
ENG05986-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled
ENG05986-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled
ENG05986-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled
ENG05986-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled
ENG05986-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled
ENG05986-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled
ENG05987-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain
ENG05987-ENG118465-GW_mirror_mode-mirror_mode_typ,not active
ENG05993-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00
ENG05994-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00
ENG05995-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00
ENG05996-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00
ENG05997-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00
ENG05998-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00
ENG05999-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00
ENG06000-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00
ENG06001-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00
ENG06002-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1,not active
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2,not active
ENG118779-ENG118723-Multi_function_steering_wheel_control_module Coding Value-MuFu-variant_VW,not installed
ENG118779-ENG118722-Multi_function_steering_wheel_control_module Coding Value-Temp Sensor,not installed
ENG118779-ENG109457-Multi_function_steering_wheel_control_module Coding Value-Tiptronic,installed
ENG118774-WakeUpMonitor_Activation,activated
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s
Elapsed Time: 00:28
22
	SW:0CQ-907-554-H   HW:0CQ-525-130 ---  AWD
	Component:Haldex4Motion H52 7083, Coding:0001
	EV_AllWheelContrHA1VW37X,004013,EV_AllWheelContrHA1VW37X_004.rod
	Wednesday,05,July,2017,22:39:56:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 4AFFBCBA4F963DF715-801E
IDE06425-Roller test bench mode: functional,not activated
IDE07843-ENG11033-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_4,0
IDE07843-ENG11035-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_5,1700
IDE07843-ENG11037-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_6,1700
IDE07843-ENG11039-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_7_plus,1700
IDE07843-ENG11032-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_4,0
IDE07843-ENG11034-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_5,1150
IDE07843-ENG11036-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_6,1150
IDE07843-ENG11038-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_7_plus,1150
IDE07844-ENG11041-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_4,0
IDE07844-ENG11043-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_5,2000
IDE07844-ENG11045-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_6,2000
IDE07844-ENG11047-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_7_plus,2000
IDE07844-ENG11040-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_4,0
IDE07844-ENG11042-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_5,1300
IDE07844-ENG11044-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_6,1300
IDE07844-ENG11046-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_7_plus,1300
MAS06098-Acoustic measure: wiring logic,Standard
Elapsed Time: 00:05
42
	SW:5Q4-959-593-E   HW:5Q4-959-593-B ---  Door Elect, Driver
	Component:TSG FS        010 0032, Coding:00311220D000040000001000
	EV_DCUDriveSideEWMAXCONT,006001,EV_DCUDriveSideEWMAXCONT.rod
	Wednesday,05,July,2017,22:40:51:46934
	VCID: 47F0C2B353A50FE20D-8012
IDE00001-Production mode,00000000 00000000 00000000
IDE02332-Deactivate production mode,00000000 00000000 00000000
ENG117304-Patch_Code_Driver_Side_Rear,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %
ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %
ENG117302-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 00 00 00 0A 01 00 00 00 9D 42
ENG117303-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2,02 EE 02 58 14 EC FF 02 02 0A 02 02 00 0A 05 28 04 14 19 0F 00 05 EC 1E 1E 14 00 05 FB 0A 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 28 00 19 1E 20 1E 64 D8 C4 F6 F1 28 1E 32 05 1E 00 00 50 04 19 0C 12 10 64 D8 EC F6 FB 19 14 32 05 0C 00 00 C8 02 19 0F 16 14 64 D8 C4 F6 F1 28 1E 32 0A 0C 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 0B
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 19 00 32 32 01 90 00 00 00 00 00 00 00 86 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 43 34 30 32 01 00 00 00 00 00 00 00 00 00 02 4D
Elapsed Time: 00:08
44
	SW:5Q0-909-143-P   HW:5Q0-909-143-E ---  Steering Assist
	Component:MQB_PP_APA    204 2051, Coding:01010011004001
	EV_SteerAssisVWBSMQBA,009129,EV_SteerAssisVWBSMQBA_SK37.rod
	Wednesday,05,July,2017,22:41:15:46934
	VCID: 40E9D0583758792D45-8014
IDE00820-Activating and deactivating all development messages,not active
IDE03724-Straight line running,active
IDE03734-Support power,100%
IDE04130-Characteristic curve of steering assistance,Not assigned
IDE04555-Activation of pwr steering asst without engine running,not active
IDE05162-Software end stop,active
IDE06419-Driving profile switchover,Incremental: controlled over time
IDE07540-Download without rest bus,not active
MAS02080-XCP calibration protocol,not active
Elapsed Time: 00:03
52
	SW:5Q4-959-592-E   HW:5Q4-959-592-B ---  Door Elect, Pass.
	Component:TSG BFS       010 0032, Coding:00311220DC00040000001000
	EV_DCUPasseSideEWMAXCONT,006001,EV_DCUPasseSideEWMAXCONT.rod
	Wednesday,05,July,2017,22:41:38:46934
	VCID: 46F3C4B65FBA05DB35-8012
ENG117308-Patch_Code_Passenger_Side_Rear,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %
ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %
ENG117306-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 00 00 00 0A 01 00 00 00 CE CA
ENG117307-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2,02 EE 02 58 14 EC FF 02 02 0A 02 02 00 0A 05 28 04 14 19 0F 00 05 EC 1E 1E 14 00 05 FB 0A 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 28 00 19 1E 20 1E 64 D8 C4 F6 F1 28 1E 32 05 1E 00 00 50 04 19 0C 12 10 64 D8 EC F6 FB 19 14 32 05 0C 00 00 C8 02 19 0F 16 14 64 D8 C4 F6 F1 28 1E 32 0A 0C 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 0B
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 19 00 32 32 01 90 00 00 00 00 00 00 00 86 00 00 32 3C C8 00 4E 00 4D 79 00 00 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 43 34 30 32 01 00 00 00 00 00 00 00 00 00 0F CB
Elapsed Time: 00:08
kickdown
Unverified
2B
	SW:3Q0-905-861   HW:3Q0-905-861 ---  Steer. Col. Lock
	Component:ELV-MQBB      H05 0032, Coding:0800000000000000
	EV_ELVMarquMQBB,001007,EV_ELVMarquMQBB.rod
	Wednesday,05,July,2017,22:40:15:46934
	VCID: 71266E35EB530384DD-8024
IDE07566-Steering column lock unlocked,unlock
ENG128823-functional_check_manufacturer,tested
ENG128824-functional_check_steering_column_supplier,tested
Elapsed Time: 00:02
3C
	SW:5Q0-907-686-B   HW:5Q0-907-686-B ---  Lane Change
	Component:HRE_Master    H12 0071, Coding:02011103
	EV_HREntryHella,001028,EV_HREntryHella.rod
	Wednesday,05,July,2017,22:40:33:46934
	VCID: 3CEDD854076C411165-8068
IDE02332-Deactivate production mode,Deactivating
IDE05397-Calibration mode,not activated
IDE80001-Analysis 1,not activated
IDE80004-Analysis 4,not activated
Elapsed Time: 00:02
5F
	SW:5F0-035-043-D   HW:5F0-035-043 ---  Information Electr.
	Component:MU-H-N-EU     H50 0897, Coding:04230601FF0A000011110001000808232F0101C4012001009E
	EV_MUHig6C3Gen2HBAS,001001,EV_MUHig6C3Gen2HBAS_SE37.rod
	Wednesday,05,July,2017,22:42:05:46934
	VCID: 1ECB143EBFF235C375-804A
IDE00001-Production mode,00 00 00
IDE00346-Summertime-automatic,Europe
IDE00759-Base volume of speech output,50 %
IDE00760-Microphone sensitivity,0 dB
IDE00768-Country identification: country of sale,--
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
IDE00845-Wheel circ.,0 mm
IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes
IDE01996-ENG99724-Installation list: specified installations-ECU coded,No
IDE01996-ENG06573-Installation list: specified installations-ECU coded 2,No
IDE02121-CD eject button,Enabled
IDE02122-Developer mode,not activated
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22
IDE02502-Confirmation of installation change,12 F6
IDE02506-MAS03229-Copy multimedia data-Data medium,On
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF
IDE02607-Wheel pulse,0
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,OFF
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present
IDE03471-ENG127492-Vehicle configuration-LGI,OFF
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated
IDE03471-ENG07590-Vehicle configuration-Mirror_link,function_on_hmi_on
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF
IDE03471-ENG127495-Vehicle configuration-online_media,OFF
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active
IDE03471-ENG117844-Vehicle configuration-picture_navi,On
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF
IDE03471-ENG06574-Vehicle configuration-ProbeCar_vzo,OFF
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF
IDE03471-ENG07589-Vehicle configuration-RSE_software_component,activated
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS
IDE03471-ENG11009-Vehicle configuration-sd_slot_deactivation,no restriction
IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag,no_region
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present
IDE03471-ENG07591-Vehicle configuration-Smartphone_interface_for_rhmi,activated
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF
IDE03471-ENG06575-Vehicle configuration-UOTA,OFF
IDE03471-ENG117852-Vehicle configuration-UPnP,On
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF
IDE03471-ENG127494-Vehicle configuration-VZO,OFF
IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI,OFF
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On
IDE03902-Automatic ring break diagnostic,No automatic start
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2
IDE04521-Sporadic ring break detection,Visual
IDE04522-Awakening ability on optical databus,OFF
IDE04550-Bluetooth: Sniff mode,On
IDE05111-Fee-based traffic information (TMC),0
IDE05113-Infotainment Recorder,activated
IDE06697-Audio management mute function,Muting of audio sources
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128
IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated
IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated
IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated
IDE10604-Menu entries for mobile online services,not activated
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,37 dBµV
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,32 dB
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,15.0 s
IDE11105-Brand-specific display of connect application,
IDE11122-Country identification: country of sale HMI,--
IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767
IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535
IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked
IDE11638-Bluetooth Audio Codec,FF
MAS00951-Bluetooth,On
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz
MAS03782-WLAN,On
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,OFF
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,0.00 ms
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,OFF
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,0.00 ms
ENG117920-Audio_Managment_Soundset_Menu,OFF
ENG117917-BAP_Debug_Mode_Release,not_released
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated
ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated
ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated
ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated
ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated
ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated
ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated
ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated
ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated
ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated
ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated
ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated
ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Comfort data bus
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Comfort data bus
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Terminal 15
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Terminal 15
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Terminal 15
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Comfort data bus
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Comfort data bus
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Terminal 15
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Terminal 15
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,Comfort data bus
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Comfort data bus
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus
ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated
ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus
ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated
ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,Comfort data bus
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Terminal 15
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal 15
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Comfort data bus
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Suspension data bus
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Terminal 15
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Terminal 15
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Comfort data bus
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus
ENG122230-ENG11025-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,OFF
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,OFF
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,11 %
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,25 %
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,70 %
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 FA 00 F4 01 5E 01 C8 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 96
ENG117809-p_damping_Display,5 ms
ENG117808-p_HMI_Display,13 %
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
ENG117919-Startup_Screen_Sticker_HMI,00 00
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h
Elapsed Time: 00:46
6C
	SW:5Q0-907-556-B   HW:5Q0-907-556 ---  Back-up Cam.
	Component:Areaview 2    H13 0607, Coding:06230601260FA00000606014
	EV_CamSysRVAV2ARCE2MQBAB,006017,EV_CamSysRVAV2ARCE2MQBAB.rod
	Wednesday,05,July,2017,22:43:12:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 38E1E0601770A97585-806C
Elapsed Time: 00:32
6D
	SW:5Q0-959-107-L   HW:5Q0-959-107-J ---  Trunk Elect.
	Component:HDSG-Modul    H13 0261, Coding:1908
	EV_DeckLidCONTIAU736,001014,EV_DeckLidCONTIAU736_SE37.rod
	Wednesday,05,July,2017,22:44:01:46934
	VCID: 41F6CE452B4363345D-8014
IDE00001-IDE03415-Production mode-Tone sensor,not active
IDE00001-IDE10408-Production mode-Opening height in production mode,not active
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active
IDE00001-MAS10735-Production mode-Calibration,not active
IDE00001-MAS10736-Production mode-Checking the rear lid button,not active
IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active
IDE00820-Activating and deactivating all development messages,not active
IDE02158-Program opening stop,1734
IDE02332-Deactivate production mode,0
IDE03435-Detection area upper,20
IDE03776-Offset for maximum programmable opening stop,12
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,20
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,400
IDE09511-Minimum opening height of tailgate,896
IDE09512-Deactivation of tailgate,active
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,active
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,active
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active
IDE09520-Offset for opening height after basic setting,0
IDE10408-Opening height in production mode,60 %
IDE10695-Dectivation of the luggage compartment cover,not active
IDE10703-Luggage compartment cover: tolerance of the block counter,0
IDE10704-Luggage compartment cover: maximum no. of block drives,0
IDE10705-Luggage compartment cover: number bloom drives,0
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,0
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,0
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,0
IDE10708-Luggage compartment cover: adjust. track tolerance,0
IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active
ENG00160-MAS01911-Ausstattungen aktivieren-Tone sensor,active
ENG00160-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active
ENG00160-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active
ENG00160-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active
ENG00160-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active
ENG00160-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active
ENG00160-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active
ENG00160-MAS08212-Ausstattungen aktivieren-Engine 2,active
ENG00160-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active
ENG00160-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,active
Elapsed Time: 00:07
5A
	SW:3Q0-980-654-G   HW:3Q0-980-654 ---  Frt Sens. Drv. Assist
	Component:MQB_B_MFK     H06 0231, Coding:030307060000040000222354C050A90098000E200020
	EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB.rod
	Wednesday,05,July,2017,22:44:32:46934
	VCID: 3BECDA570361470E6D-806E
IDE00001-Production mode,Deactivating
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated
IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h
IDE04733-Road sign detection fusion mode,Road sign fusion
IDE06425-Roller test bench mode: functional,not activated
IDE07358-Distance to calibration field,1500 mm
IDE09375-IDE05717-Axle offset-Front axle transverse position,-0.299994 mm
IDE09375-IDE05718-Axle offset-Rear axle transverse position,-1.19999 mm
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,765.5 mm
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,767 mm
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,762.5 mm
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,764.5 mm
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2600 mm
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,825 mm
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1730 mm
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2600 mm
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-825 mm
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1730 mm
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2600 mm
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,825 mm
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,1070 mm
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2600 mm
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-825 mm
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,1070 mm
IDE10407-Personalization of intervention moment at T. 15 on,Last setting
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu)
IDE10871-System mode: lane depart. warn:,Steering wheel vibration not active
IDE10872-Warning intensity: lane depart. warning,Medium
IDE10873-BAP personalization,activated
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.143 °
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.051 °
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.063 °
IDE10924-MAS10678-Initial calibration: result-Camera height,1472 mm
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled
ENG120319-Mask_error_reactions_for_development,not activated
ENG107577-ENG107577-Masked_fault_classes-,255
ENG130777-standstill_mode,not activated
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,12.8
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,0
ENG130779-Xcp_interface,not activated
Elapsed Time: 00:09
Keithuk
Stoke on Trent, England
C?ID=122432
How to get Verified
Manufacturer: Seat, Date(s) Used: 06/2016-, Model: Ateca, Engine Code: DFHA, 140Kw, 190PS, 2.0 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Common Rail (TDI-CR)
Manufacturer: Audi, Date(s) Used: 07/2016-, Model: Audi Q2, Engine Code: DFHA, 140Kw, 190PS, 2.0 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Common Rail (TDI-CR)
Manufacturer: Skoda, Date(s) Used: 10/2016-, Model: Kodiaq (SUV), Engine Code: DFHA, 140Kw, 190PS, 2.0 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Common Rail (TDI-CR)
Manufacturer: VW, Date(s) Used: 11/2015-, Model: Touran, Engine Code: DFHA, 140Kw, 190PS, 2.0 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Common Rail (TDI-CR)
Manufacturer: VW, Date(s) Used: 06/2017-, Model: Tiguan Allspace, Engine Code: DFHA, 140Kw, 190PS, 2.0 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Common Rail (TDI-CR)
Manufacturer: VW, Date(s) Used: 05/2017-, Model: Arteon, Engine Code: DFHA, 140Kw, 190PS, 2.0 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) It will be the direct successor to the Volkswagen CC
Manufacturer: VW, Date(s) Used: 04/2016-, Model: Tiguan, Engine Code: DFHA, 140Kw, 190PS, 2.0 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Common Rail (TDI-CR)
As taken from my new VAG Engine & Transmission Codes.
toncsa
Hungary
C?ID=333251
Hello
Available:
Emergency assist?
Traffic jam assist?
The luggage door open-lock with foot?
best regards Toncsa
