2011 VW passat 2.0L TDI SE Drive mode disabled
billscott
C?ID=288506
Hi
Have the Radio, Odometer and some bulbs out on this Passat, looks like I might of accidentally disabled the drive mode and I cannot get it to enable, is this a dealer software job? Hope not and that Aag Com can sort it - has anyone struck this problem.
Bill
billscott
C?ID=288506
This is the reading
Please post an Auto-Scan for context.
VIN: WVWZZZ3CZBP351906   License Plate:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 53 56 61 62 72
          77
VIN: WVWZZZ3CZBP351906   Mileage: 230530km-143244miles
2E-Media Player 3 -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9978
   Revision: 47H24---    Serial number: VWZCZ000000000
   Coding: 00190012042501080000
   Shop #: WSC 00058 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003008
   ROD: EV_ECM20TDI01103L906018BE.rod
   VCID: 6FAE0130B61BCB3900-803A
5462 - Starter Control; Returned Message
          P3053 00 [096] - 50 Short to Ground
4715 - No Communication with Instrument Cluster
          U0155 00 [032] - -
                    Mileage: 229864 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 82 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 12.880 V
                    Unlearning counter according OBD: 20
                    Limitation: accelerator pedal: 126.7 Nm
                    CAN status - engine control module-Bit 0: 00000000
                    Cruise Control System (CCS): status-Bit 0: 00001000
                    CAN status - transmission control module-Bit 0: 00000000
                    CAN status - brake control module 1-Bit 0: 00000000
                    CAN status - brake control module 2-Bit 0: 00000000
                    selected gear-Bit 0: 00000000
   Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
   Component: J104   C2 450M VDF3 0005
   Revision: --H07---    Serial number: 00000004118406
   Coding: 0004016
   Shop #: WSC 00028 028 00001
   VCID: 383CFA6C4BD54C8111-806C
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 230
                    Mileage: 224667 km
                    Date: 2011.10.08
                    Time: 23:12:29
                    Speed: 75.0 km/h
                    Hex Value: 0x0100
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
                    Reset counter: 8
                    Hex Value: 0x0000
                    Voltage: 12.75 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 8
                    Hex Value: 0x0000
                    Voltage: 12.75 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
01200 - ABS Valves Supply Voltage
                    Fault Status: 00101011
                    Reset counter: 8
                    Hex Value: 0x0000
                    Voltage: 12.75 V
                    Bin. Bits: 00011111
                    Count: 170
                    Hex Value: 0x0000
01169 - Door Contact Switch Driver Side (F2)
                    Fault Frequency: 12
                    Reset counter: 10
                    Mileage: 229920 km
                    Date: 2011.11.12
                    Time: 00:27:19
                    Speed: 57.0 km/h
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 303
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000000003
   Shop #: WSC 00028 028 00022
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3C34E67CB7ED60A1F5-8068
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 8
          B10AB F0 [009] - Too Low
                    Reset counter: 114
                    Mileage: 203757 km
                    Date: 2016.11.10
                    Time: 14:10:09
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087     HW: 3AA 937 087
   Component: BCM PQ47 M    413 0452
   Revision: BA413001
   Coding: 000000000000000000180080140000E443516488406C81606480C7200041
   VCID: 77BE3950C64B83F9D8-8022
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 29031  26  0612
   Coding: 00B795
   Component: RLS 230411 05  54  0403
   Coding: 0330ED
7 Faults Found:
00984 - Left Tail Light (M4)
                    Fault Status: 00101010
                    Reset counter: 28
                    Mileage: 203625 km
                    Date: 2016.11.09
                    Time: 17:05:41
                    Voltage: 13.50 V
00985 - Right Tail Light (M2)
                    Reset counter: 28
                    Mileage: 203625 km
                    Date: 2016.11.09
                    Time: 17:19:19
                    Voltage: 14.05 V
                    Reset counter: 8
                    Voltage: 12.90 V
                    Fault Status: 01101010
                    Fault Frequency: 134
                    Reset counter: 41
                    Mileage: 213335 km
                    Date: 2011.06.04
                    Time: 15:59:46
                        Term 15 Off
                    Voltage: 12.40 V
                    Reset counter: 106
                    Mileage: 222119 km
                    Date: 2011.09.16
                    Time: 18:37:38
                    Voltage: 14.50 V
                    Fault Frequency: 11
                    Reset counter: 190
                    Mileage: 211873 km
                    Date: 2011.05.28
                    Time: 07:44:09
                        Term 15 Off
                    Voltage: 12.75 V
03789 - Terminal 75 Limp Mode Active
            000 -  -  - Intermittent
                    Reset counter: 23
                    Mileage: 229882 km
                    Date: 2011.11.11
                    Time: 00:28:60
                    Voltage: 9.95 V
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P7GS25K
   Coding: 0012338
   VCID: 4CD4B6BC2F4DD02145-8018
   Subsystem 1 - Serial number: 6332MTS631730911
   Subsystem 2 - Serial number: 6342MTS659190901
   Subsystem 3 - Serial number: 6351HTS6FISVT9KR
   Subsystem 4 - Serial number: 6361HTS6GU5LU9KR
                    Reset counter: 7
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110418301828
   Coding: 0182250000
   VCID: 72A80844A529E6D1EF-8026
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 970 A    HW: 3AA 920 970 A
   Coding: 460F01
   VCID: 312AC74860AF9DC956-8064
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 190411F1001030
   Coding: 461007
   VCID: 3424CE5C97BDA8E13D-8060
                    Reset counter: 7
                    Reset counter: 7
01304 - Radio
                    Fault Status: 00110100
                    Reset counter: 13
                    Mileage: 230033 km
                    Date: 2011.11.14
                    Time: 18:54:22
03272 - Control Module for Audio Interface
                    Reset counter: 13
                    Mileage: 230033 km
                    Date: 2011.11.14
                    Time: 18:54:22
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76A034540141FAF1C3-8022
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669815998
   VCID: 281C2A2C5B75DC0181-807C
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0530
   Revision: 12110009    Serial number: 0002698106
   Coding: 0202B7
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 3522F35894C7B1E90A-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002095552
   Coding: 000290
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 8
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 195    3201
   Revision: 00H20000
   VCID: 3424CE5C57BDA8E13D-8060
                    Reset counter: 8
                    Voltage: 12.88 V
                        DD
                    Temperature: 36.0°C
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0631
   Coding: 01910A0002860E76300494157C085FCE107C01
   Subsystem 1 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HORN H11 9005
   Component: Neigungssensor  004 0611
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FAE0130BE1BCB3900-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
02174 - Analog/Digital clock
                    Reset counter: 7
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0530
   Revision: 14110009    Serial number: 0002693620
   Coding: 0202B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3620F45489C1BAF103-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002099631
   Coding: 000290
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 233
                    Mileage: 203634 km
                    Date: 2016.11.09
                    Time: 18:06:58
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000299672
   Coding: 0022067
   VCID: 3326CD4052B3AFD924-8066
                    Fault Status: 00101101
                    Reset counter: 7
                    Mileage: 229865 km
                    Date: 2011.11.11
                    Time: 00:01:54
                    Voltage: 12.80 V
                    Count: 69
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 9
                    Mileage: 229938 km
                    Date: 2011.11.12
                    Time: 01:24:02
                    Voltage: 13.90 V
                    Count: 10
                    Speed: 16.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0014
                    Hex Value: 0x0101
   Part No SW: 1K0 035 186 AB    HW: 1K0 035 186 AB
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2L8011066
   Coding: 0100040004
   VCID: 6680641491E10A7173-8032
   Component: Batt.regelung H41 1614
   Coding: 030B185A
   VCID: 71AA0748A82FDDC916-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370232070
   Part No SW: 5K0 035 730 J    HW: 5K0 035 730 J
   Component: TELEFON       H09 1031
   Revision: 1B001001    Serial number: 00007661961110
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 2C14D63C478DF02165-8078
          B104F 13 [008] - Short to GND
                    Reset counter: 14
                    Mileage: 230033 km
                    Date: 2017.06.23
                    Time: 18:53:15
13636352 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 112
                    Mileage: 203625 km
                    Date: 2016.11.09
                    Time: 17:13:41
0022 - Radio
          U1066 00 [008] - No Communication
                    Reset counter: 14
                    Mileage: 230033 km
                    Date: 2017.06.23
                    Time: 18:54:17
End----------(Elapsed Time: 01:32, VBatt start/end: 12.6V/12.6V)---------
I guess I would start by clearing all those fault codes. Most of them are flagged Intermittent, meaning the fault condition that set the code did not exist (or could not be detected) at the time the scan was performed. Once you've cleared the faults and take the car for a short test drive, post a fresh scan so we can see what remains or has come back.
billscott
C?ID=288506
Sorted
thanks for that its sorted
Cheers Bill
