skoda A7 mechtronic control basic setting
mohamed
Egypt
C?ID=211960
could you help me with the basic setting of mechtronic control unit
i have changed the control unit of mechtronic
thanks in advance
Friday,23,June,2017,09:16:39:11183
VCDS Version: 16.8.4.2
Dealer/Shop Name: Harisa car service
VIN: TMBAC2NE3E0006670   License Plate:
Mileage: 40790km-25345mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBAC2NE3E0006670   Mileage: 40790km-25345miles
Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 M    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H08 5762
   Revision: WAH08---
   Coding: 01250012232400080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM14TFS01104E906016M 002008
   ROD: EV_ECM14TFS01104E906016M.rod
   VCID: 2C5286FF4720982245-8078
          U0428 00 [039] - -
                    Mileage: 40790 km
                    Date: 2017.06.16
                    Time: 00:04:53
                    Engine speed: 0.00 /min
                    Coolant temperature: 37 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 12.180 V
                    CAN status - engine control module-Bit 0: 0
                    selected gear-Bit 0: 0
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4506
   Revision: 00043014    Serial number: CU501305125756
   Shop #: WSC 73430 031 00000
   ROD: EV_TCMDQ200021.rod
   VCID: 76E66497C9EC92F2E3-8022
21197 - Transmission Control Unit
          P1701 00 [010] - Locked
                    Mileage: 40790 km
                    Date: 2017.06.16
                    Time: 00:04:53
                    Engine speed: 63.75 /min
                    Engine torque: 920 Nm
                    Vehicle speed: 255 km/h
                    Control Module temperature: 215 °C
                    CURRENT pressure: -10.0 bar
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 102.0 %
                    DTC memory status: 65280
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Revision: 00000000    Serial number:
   Coding: 1A076A9120201272007D060701C3245856044800608024B0002B0020C0
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP_008.rod
   VCID: 3A7EB0A7BD743692C7-806E
          C1146 02 [137] - Signal Failure
                    Fault Frequency: 8
                    Reset counter: 197
                    Mileage: 40606 km
                    Date: 2017.06.08
                    Time: 00:00:33
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5E0 820 047 D    HW: 5E0 820 047 D
   Component: AC Manuell    H02 0604
   Revision: 00001K06
   Coding: 01010004000100000000000000400000
   ASAM Dataset: EV_ACManueBHBVW37X 002017
   ROD: EV_ACManueBHBVW37X_002_VW37.rod
   VCID: 23406DC32AFE575AF4-8076
          B10CD 00 [008] -  -
                    Reset counter: 222
                    Mileage: 40609 km
                    Date: 2017.06.08
                    Time: 12:56:48
                    Voltage terminal 30: 11.1 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011311200603
   Coding: 0C0018424047005B07A04000000407000000000000000000000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 4380CD43CABE775A94-8016
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130426  041 0570
   Serial number:         130427185413
   Coding: 065DDD
          B1263 01 [009] - Electrical Failure
                    Reset counter: 192
                    Mileage: 1048574 km
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  009 0026
   Revision: --------    Serial number: 60831310201196
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002015
   ROD: EV_EPHVA14AU3700000_SK25.rod
   VCID: 3778A9938E662BFA38-8062
1079089 - Center Rear Left Parking Aid Sensor
          B1077 31 [008] - No Signal
                    Reset counter: 230
                    Mileage: 40695 km
                    Date: 2017.06.10
                    Time: 18:33:34
   Part No SW: 3Q0 959 655 AD    HW: 3Q0 959 655 AD
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P5P6U9YLT
   Coding: 8800C00000000000400000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 000A024F9B28AC42C9-8054
   Subsystem 1 - Part No SW: -----------    HW: 454 801 303 13
   Serial number: 3556V7AFA2301000000C
Address 16: Steering wheel
   Part No SW: 5E0 920 860 B    HW: 5E0 920 860 B
   Component: KOMBI         227 0555
   Coding: 07A402082180000801082A00040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 254473DB24CAA96A9A-8070
9634288 - Transmission Control Module
          B1301 F0 [009] - Not Authorized
                    Mileage: 40790 km
                    Date: 2017.06.16
                    Time: 00:00:57
   Part No SW: 5Q0 907 530 D    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1109
   Revision: --------    Serial number: 0000524733
   Coding: 0100000020086400EF0000081C0F00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 326E98876504CED20F-8066
131596 - Steering Column Control Module
          U0212 00 [008] - No Communications
                    Reset counter: 221
                    Mileage: 1048574 km
                    Supply voltage: Terminal 30: 6.1 V
                    Terminal 15: OFF
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [008] - -
                    Reset counter: 221
                    Mileage: 1048574 km
                    Terminal 15: OFF
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000059017366
   Coding: 00110020D000020000001100
   VCID: 020E08479524BE52DF-8056
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000197949
   Coding: 010200
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D74BBBBAC5A01AAE2-8068
16135 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 0
                    Motor status: 00
                    Supply voltage: 12.75 V
                    Temperature: 29.0 °C
                    KFC: 3F
                    KFA: 00 07
                    Environmental conditions: 5F
                    uAdSensI_U5VFiltered_xdu16: 5.03909 V
                    uioUdNotFilt_xdu16: 12.83 V
                    uAdSensI_SwitchedKl30_xdu16: 12.81 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 18
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000059448198
   Shop #: WSC 73430 790 00100
   VCID: 010C074B9022A54AC6-8054
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000185561
   Coding: 190200
Address 5F: Information Electr. (J794)       Labels: 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 840     HW: 5E0 035 840
   Component: MU-S--ER      039 0171
   Serial number: S3E02404131206
   Coding: 03730100FF00000011110001001100002F0000840100010002
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_AU37.rod
   VCID: 5EB61C37411C3AB29B-800A
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H44 0020
   Serial number: SKZ8Z9N44002XZ
          U1400 00 [008] - -
                    Reset counter: 220
                    Mileage: 1048574 km
                    Voltage terminal 30: 6.1 V
          B2000 87 [008] - Missing message
                    Reset counter: 222
                    Mileage: 40608 km
                    Date: 2017.06.08
                    Time: 00:00:46
                    Voltage terminal 30: 13.7 V
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Reset counter: 197
                    Mileage: 40790 km
                    Date: 2017.06.16
                    Time: 00:01:19
                    Voltage terminal 30: 12.3 V
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 197
                    Mileage: 40790 km
                    Date: 2017.06.16
                    Time: 00:01:19
End-------------------------(Elapsed Time: 07:28)--------------------------
mohamed
Egypt
C?ID=211960
Select]
[02 - Auto Trans]
[Basic Settings - 04]
Select Erase counter for start and stop processes
[Go!] to activate the Basic Setting.
After the result of Finished Correctly or Not Running appears click [Stop]
[Done, Go Back]
Start the Engine and leave the Selector lever in Park
Select Clutch valve calibration [Go!] to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
Select Distance sensor calibration
Clunking noises from the transmission are normal
[Done, Go Back]
Switch off Ignition, wait 10 Seconds and switch it back on.
[Fault Codes - 02]
Check and clear any fault codes
Perform a test drive and check for fault codes again after doing so.
is this will not work ?
xxleeus
Romania
C?ID=26700
Hello guys. I have changed the control unit on mechatronic (Skoda Superb 2009) and I can not do the basic settings. It stops with 255 45 0. The old version of software in MB 41 was v0693y800AM__getriebe_DSG_DD3y and the new one is v0693y330AM___getriebe_DSG_cD3y. Do you think this could be the problem of failured basic settings? The car moves forward all gears (up & down) but for backward I have to stop the engine, put selector in P, restart the engine and put it on R. Thank you.
South Molton, UK
Please post an Auto-Scan so we can see what modules are fitted to this car and fault codes exist, they my be preventing basic settings from running.
xxleeus
Romania
C?ID=26700
Wednesday,26,July,2017,05:30:49:57187
VCDS Version: 17.1.3.0 (x64)
VIN: TMBAB73T999025548 License Plate: 26IUL
Mileage: 78410km-48721mi Repair Order:
Chassis Type: 3T (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 36 42 44 46 52 56 62 72
VIN: TMBAB73T999025548 Mileage: 78410km-48721miles
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 3T0 907 115 B HW: 1Z0 907 115 F
Component: 1.8l R4/4V TFSI 0030
Revision: AAH03--- Serial number:
Coding: 0203000C24070160
Shop #: WSC 35110 377 09999
VCID: 30656858A3FC30C159-8064
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 000 - - Intermittent
Mileage: 78415 km
Date: 2011.12.17
Time: 14:04:27
RPM: 761 /min
Load: 13.7 %
Temperature: 78.0°C
Temperature: 51.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 M HW: 0AM 927 769 D
Component: GSG DSG AG7 431 9033
Revision: 00043014 Serial number: CU501610016757
Shop #: WSC 44551 111 96049
VCID: 3A714A707580FA91E7-806E
005983 - Transmission
P175F - 000 - Basic Settings Not Performed
Reset counter: 10
Mileage: 78415 km
Address 03: ABS Brakes Labels: 1K0-614-517-MK60AT.clb
Part No SW: 3T0 614 517 B HW: 3T0 614 517 B
Component: ESP FRONT MK60-AT 0102
Revision: 00H12001
Coding: 0037506
VCID: 31636D5CA8F639C956-8064
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AF HW: 3T0 907 044 AF
Component: Climatronic 122 0203
Revision: 00003001
Coding: 0100004008
Shop #: WSC 35703 895 09999
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 76E99E40C9185EF1C3-8022
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 A HW: 1K0 937 086 A
Component: BCM PQ35 M+ 020 0358
Revision: 00020000
Coding: 40990AB8D873F1C0408800C7110081A405711BAE43208960284048000000
VCID: 2E59762079C826314B-807A
Subsystem 1 - Part No: 3T1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 05120 22 0602
Coding: 00D7B7
Component: RLS 091208 05 54 0402
Coding: 0730ED
Subsystem 4 - Part No: 1K0 951 605 D
Component: LIN BACKUP HO H08 9001
Part No SW: 3T0 959 655 A HW: 3T0 959 655 A
Component: J234__LBE VW10 HI 1916
Revision: 18013000 Serial number: 003EAPQU6EML
Coding: 0016965
VCID: 3F873B646EA2DFB9D0-806A
Subsystem 1 - Serial number: 6332MTS602423178
Subsystem 2 - Serial number: 6342MTS667983178
Subsystem 3 - Serial number: 6351HTS6MEJGVVNR
Subsystem 4 - Serial number: 6361HTS6NKNGVVNJ
Subsystem 5 - Serial number: 63727TS67AOPU5KR
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001033
VCID: 0201F2905DD07251FF-8056
Part No SW: 3T1 920 841 B HW: 3T1 920 841 B
Component: KOMBI H06 0106
Coding: 110B00
VCID: 3261625065F002D12F-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08C070099
Coding: ED80FF06000202003302
VCID: 377753444692E7F918-8062
Component: IMMO H06 0106
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000003
Shop #: WSC 10125 599 96049
VCID: 72E1A2506D7042D1EF-8026
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 A HW: 7N0 959 793 A
Component: TSG FA H03 0190
Revision: Serial number: 0000100574330
Coding: 011D0220DE00121002
VCID: 40853898D35CA041A9-8014
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 194 2501
Revision: 00H15000
VCID: 2C5D7C288FD4542165-8078
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 A HW: 7N0 959 792 A
Component: TSG BF H03 0190
Revision: Serial number: 0000100575644
VCID: 3F873B64AEA2DFB9D0-806A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3T0 035 156 B HW: 3T0 035 156 B
Component: BOLERO 006 0036
Revision: 0A001001 Serial number: SKZ1Z3H3554812
Coding: 050004000404
VCID: 2D5B712C74CE5D2972-8078
Address 62: Door, Rear Left (J388) Labels: 7N0-959-795.clb
Part No SW: 7N0 959 795 HW: 7N0 959 795
Component: TSG HL H02 0190
Revision: Serial number: 0000100580507
Coding: 010C00200000221002
VCID: 0103FD9C98D66949E6-8054
Address 72: Door, Rear Right (J389) Labels: 7N0-959-794.clb
Part No SW: 7N0 959 794 HW: 7N0 959 795
Component: TSG HR H02 0190
Revision: Serial number: 0000100584162
VCID: 55ABF9CC3CDE35E9EA-8000
End-------------------------(Elapsed Time: 02:14)--------------------------
NEtech
Denmark
C?ID=56995
Information about numbers should be shown when moving mouse over the MWB fields.
Engine speed not correct.
xxleeus
Romania
C?ID=26700
OK, thank you but I need to know if the software version can be the problem.
