VW Polo 9N Intermittant EHPS failure
dbac
C?ID=108746
Hi Guys, I have an intermittant Electro-hydraulic power steering failure on a 2005 9N VW Polo. The "steering assist" warning light comes on and the steering goes heavy due to no power assistance. I have checked all electrical connections to the electric hydraulic pump and steering angle sensor on the rack. The confusion is the fault codes the car logs. The central electrics and the CAN gateway both log a failed communication with the G85 steering angle sensor on the top of the steering column. However this model does not have this sensor. G85 (according to SSP-259 doc) is only fitted on cars that have ESP as well, otherwise they use G220 sensor on the rack . Not BOTH!. Mine has G220 as I have already removed it to inspect it. I cannot clear these DTCs for the G85. The other issue is , when I observe the measuring blocks on the Steering Assist controller, the third block on group 4 says "Steering Assist sensor ref voltage --Too Low".. (scan log at end of this post) This doesn't change yet the power assistance is working most of the time and I can see the pump rpm, amperage and sensor angular velocity , change as I move the steering ,lock to lock.
Any ideas/thories welcome . kind regards Dave
Tuesday,12,August,2014,09:53:46:18348
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: AAVZZZ9NZ5U0XXXXX   License Plate: CFM62675
Mileage: 146420km-90981mi   Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: AAVZZZ9NZ5U0XXXXX   Mileage: 146420km/90981miles
   Part No: 030 906 032 EL
   Component: ME7.5.10           *2902
   Coding: 00071
   Shop #: WSC 31414
   VCID: 58B493D6B854C7DE837-5102
   AAVZZZ9NZ5U0XXXXX     VWZ7Z0E1311179
16500 - Engine Coolant Temp. Sensor (G62)
            P0116 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.lbl
   Part No SW: 6Q0 907 379 AA    HW: 6Q0 907 379 AA
   Component: ABS 8.0 front   H03 0001
   Coding: 0000005
   Shop #: WSC 31414 000 00000
   VCID: 7CFCEF463CACCBFEC7F-50C8
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: EAD0591E9638C54EA53-50E6
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25646
   Shop #: WSC 31414
   VCID: 3C7C2F462C2C0BFE87F-50C8
            49-00 - No Communications
01598 - Drive Battery Voltage
            35-00 - -
   Part No: 6Q0 909 601 F
   Component: 05 AIRBAG VW5       0010
   Coding: 12341
   Shop #: WSC 31414
   VCID: 36683D6E1200D1AE71B-50C8
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 800 B
   Component: KOMBI+WEGFAHRSP VDO V19
   Coding: 00141
   VCID: 2C5C1F06DC4C9B7E17F-50E6
   Part No: 6N0 909 901
   Component: 001K GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 31414
   VCID: F0E44B76B0E43F9EEB7-50E6
            35-00 - -
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10140
   Shop #: WSC 31414
   VCID: 6FE6C80A2DDAA06672D-50E6
01288 - Terminal 30; Steering Assist
            06-10 - Signal too High - Intermittent
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 H
   Component: 1N Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 31414
   VCID: 40845BB640C46F1EDB7-4A9C
Address 56: Radio        Labels: None
   Part No: 6Q0 035 186 A
   Component:  Radio FF6         0001
   Coding: 00403
   Shop #: WSC 31414
   VCID: 2F66080AED5AE06632D-515A
Tuesday,12,August,2014,13:24:33:18348
   Coding: 00071
   Shop #: WSC 31414
   VCID: 58B493D6B854C7DE837-50E6
Readiness: 0110 0100
   Coding: 0000005
   Coding: 25646
   Shop #: WSC 31414
   VCID: 3C7C2F462C2C0BFE87F-50E6
   Coding: 12341
   Shop #: WSC 31414
   Coding: 00141
   VCID: 2C5C1F06DC4C9B7E17F-50C8
   Coding: 00014
   Shop #: WSC 31414
   VCID: F0E44B76B0E43F9EEB7-50C8
   Coding: 10140
   Shop #: WSC 31414
   VCID: 6FE6C80A2DDAA06672D-50C8
   Coding: 00019
   Shop #: WSC 31414
   Coding: 00403
   Shop #: WSC 31414
Tuesday,12,August,2014,13:11:36:18348
VIN:    License Plate:
                Address 44: Steering Assist  (6Q0 423 156 AB)
13:11:20 Group 001: Electrical System
  14.01 V  Voltage (Terminal 30)
  3.0 A  Pump Motor Voltage
  22.0°C  Control Module Temperature
  ON  Pump Motor Status
13:11:20 Group 002: Steering
  0.0°/s  Steer. Aid Sensor Angular Velocity
  1126 /min  Pump Motor Speed (specified)
  1126 /min  Pump Motor Speed (actual)
13:11:20 Group 004
  3288 h  Power Steering Activation Time
  1372  Power Steering Activation Counter
  Too Low  Steer. Aid Sensor Reference Voltage
  13.85 V  Voltage (Terminal 15)
Gone But Not Forgotten
This appears to be a clear over charge condition and all connections positive and negative must be checked in addition to regulation of the alternator.
Devices by design will auto-shut down if exceeding specified voltage under and over...........
dbac
C?ID=108746
Hi Jack, many thanks for your response. I checked the battery,fuse and ground connections as well as Alternator after seeing the Term 30 high and all looked good. Charge voltage was 14.1v. Unfortunately (as normal) the intermittant fault is not there at the moment so I am waiting for the next instance. The codes are stll confusing tho for G85.
Kind regards Dave
Maybe change the voltage regulator in the alternator or entire alternator before something gets hot and damages other devices.
I would run additional ground straps.
Don't ignore this issue.
Absolutely check the battery has the ability to maintain voltage over 12.5 V with VCDS logged in engine controller ( engine not running for over 10 minutes ignition on and NO! other consumers switched ON )
If it drops below 12.5V in less then 10 minutes,the battery is toasters.
dafrazi
Norristown, PA
C?ID=173774
You do have an incorrect coding fault? Do you know what was coded incorrectly? Maybe coding for the G85 sensor was put in where it doesn't belong.
golfi_vend
Tartu, Estonia
C?ID=195131
The only connection with can coding and steering is +8, as this is short coding can gateway, but from description, it should still have +8.
+00001 = Automatic Transmission (through MY 2001 and all PQ24 | Polo/Fabia/Ibiza/Cordoba)
+00002 = Brake Electronics
+00004 = Airbags (not for VW Transporter/Multivan 70/7D)
+00008 = Steering Aid (only PQ24 | Polo/Fabia/Ibiza/Cordoba)
+00016 = All-Wheel-Drive (only Transporter/Multivan 7H/7J)
You have active
+2
+4
+8
