Hi Guys,
I have a new Tiguan, only had it a few weeks.
The seat memory for the drivers seat had been working fine and the seat and mirrors had been automatically setting themselves in accordance with the key used to open the drivers door. Recently this has stopped working. I can't even save a seat position using the memory buttons on the seat.
The scan of module 36 reveals that it has somehow lost its basic setting. I had a similar issue with the rear cargo blind on my A6 Allroad and used the basic settings within VCDS to drive the blind through its full range of movement and the problem was solved. I thought the seat would be another straightforward procedure. Not so lucky.
The basic setting gives me three options, the first of which is labelled "Norming" automatically runs the seat through its full range of travel, as expected, but has no effect on the problem and the fault codes reappear. The second option is "Reset to factory setting" but activating it gives an Error:Request out of range. The third option is "Resetting Standardization" but it seems to need a 0-3 digit code that VCDS doesn't know. Running it gives the same out of range error message.
I read somewhere on the forum, Uwe suggested that VCDS wasn't used for basic settings for the seat and that all was required was to run the seat through the full range of travel in all axes so I tried this as well without success.
I know the car is still under warranty, and I could just take it back to the dealer. Trouble is I'm certain its a quick fix but the dealer wants the car for the whole day and its 3 weeks until I can get an appointment. Its easier to launch a satellite into orbit.
Any ideas anyone?
Any ideas anyone?
Thursday,15,June,2017,15:48:18:54078
VCDS Version: 17.4.2.3 (x64) HEX-NET CB: 0.4341.4
Data version: 20170505 DS270.4
VIN: WVGZZZ5NZHW405800 License Plate: NBV72J
Mileage: 3530km-2193mi Repair Order:
Chassis Type: 5N (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 52
5F 6C 6D A5 BB BC CF
VIN: WVGZZZ5NZHW405800 Mileage: 3530km-2193miles
Address 01: Engine (J623-CHHB) Labels: None
Part No SW: 5N0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 092500322466050B3000
ASAM Dataset: EV_ECM20TFS0205N0906259 001004
ROD: EV_ECM20TFS0205N0906259.rod
VCID: 72A83921A57C1FD70A-8026
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0DL 300 011 P HW: 0GC 927 711 G
Component: GSG DQ500 H06 2001
Revision: 00H06V07
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 3522C23D949248EFEF-8060
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 60277000001739
Coding: 0AEE939A54202371477F070062C34950C92AC4E2E046927D384250B8C2AA4200002F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 79BA0E0DF80A6C8F4B-802C
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0429866611
Coding: 032C2C070F
VCID: 3C34D719B7B899A710-8068
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98140687
133124 - Databus
Reset counter: 157
Mileage: 2891 km
Date: 2017.06.12
Time: 10:49:34
Address 08: Auto HVAC (E87) Labels: 3V0-907-044.clb
Part No SW: 5NA 907 044 N HW: 5NA 907 044 N
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000E00406453
Coding: 0012000420010000110510001210142A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 4AD881C1ED6C371792-801E
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001703400452
ROD: EV_BCMBOSCH_017_VW27.rod
VCID: 7EB01D11E1244BB77E-802A
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 161201 033 0372
Serial number: 00000001611280414593
Component: RLHS 042 0105
Serial number: S3Y17M02D13H21M37S04
Coding: 00A8DD
534549 - Databus
Reset counter: 128
Mileage: 298 km
Date: 2017.05.07
Time: 15:10:47
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 3Q0 919 298 A HW: 3Q0 919 298
Component: PLA 3.0 12K H10 0021
Serial number: 002601177478080
Coding: 0331667851
ASAM Dataset: EV_EPHBO2CVW3260000 010016
ROD: EV_EPHBO2CVW3260000.rod
VCID: 3B36D405B2B69E9F19-806E
13679388 - Databus
Reset counter: 165
Mileage: 829 km
Date: 2017.05.26
Time: 20:00:33
1112305 - Parking Sensor; Front Left Center
U8EB251 F1 [008] - Reverberation Time too Long
Reset counter: 149
Mileage: 2280 km
Date: 2017.06.09
Time: 16:25:45
1113328 - Parking Sensor(s); Front
U8EB650 F0 [008] - Function Limitation due to External Factors
Reset counter: 140
Mileage: 1150 km
Date: 2017.06.05
Time: 16:13:45
1080304 - Parking Sensor(s); Rear
U8E3550 F0 [008] - Function Limitation due to External Factors
Reset counter: 157
Mileage: 2582 km
Date: 2017.06.12
Time: 07:41:45
10494464 - Function Limitation due to Environmental Factors
B2022 00 [008] - -
Reset counter: 149
Mileage: 2280 km
Date: 2017.06.09
Time: 16:25:45
Address 13: Auto Dist. Reg (J428) Labels: 2Q0-907-572.clb
Part No SW: 2Q0 907 572 J HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0156
Coding: 320047C358FF8428749C8065303085
ASAM Dataset: EV_ACCMRRCONTIVW376 001011
ROD: EV_ACCMRRCONTIVW376_001_VW37.rod
196741 - Sensor for Automatic Distance Control
Reset counter: 149
Mileage: 1855 km
Date: 2017.06.09
Time: 11:50:46
Voltage terminal 15: 12.7 V
Control Module temperature: 24 °C
Velocity_vehicle_reference: 28.96 m/s
Longitudinal_acceleration_vehicle_reference: -0.22 m/s²
Status_ACC_System: ACC_activ_controlled
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 21011741350073
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 383CCB098380B587F4-806C
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2JYSK3
Coding: 98CCC0C00C0000005C540000008800000065
VCID: 106C53A9CBB04DC79C-8044
Subsystem 1 - Part No SW: ----------- HW: 480 000 102 17
Serial number: 357000000000D545B02C
Subsystem 2 - Part No SW: ----------- HW: 480 000 102 17
Serial number: 3580000000018999BF1-
Subsystem 3 - Part No SW: ----------- HW: 480 400 902 17
Serial number: 3510001A1244A733250I
Subsystem 4 - Part No SW: ----------- HW: 480 400 902 17
Serial number: 3520001A1244A734523N
Subsystem 5 - Part No SW: ----------- HW: 480 400 302 17
Component: FrontSensor_D 000 6149
Serial number: 3550001C1246A8E4D158
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 902 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001BF244A735F3BH
Subsystem 7 - Part No SW: ----------- HW: 480 401 002 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A52465B3591D2
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 902 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001C1247FF93F429
Subsystem 9 - Part No SW: ----------- HW: 480 000 502 17
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000FB16DF02H
Subsystem 10 - Part No SW: ----------- HW: 480 000 502 17
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000A9884B128
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 DM HW: 5Q0 953 569 A
Revision: FF033033 Serial number: 20170210201096
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB_VW37.rod
Part No SW: 5NA 920 791 A HW: 5NA 920 791 A
Component: KOMBI 408 2170
Coding: 27A400187F88000801887B0B1401000000000000
VCID: 41CAA6EDD05AF44F43-8014
U1110 00 [008] - -
Fault Frequency: 25
Reset counter: 159
Mileage: 1255 km
Date: 2017.06.08
Time: 11:43:22
Component: GW MQB High 515 5286
Serial number: 09021710520351
Coding: 030500347F085900FB07225A9E0F00010001050000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 2F2EF05576CE723FA5-807A
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170000163510017042
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 3943583004
Serial number: HA1-00024.01.17
Coding: 0101
ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
Component: ELV-MQBB H05 0032
Serial number: 17000031089005
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71AA362DA07A24CFF3-8024
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0021
Serial number: Y0006QB414275
Coding: 0014000000000500018281808181000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide_002_VW48.rod
7 Faults Found:
9655636 - Motor for Seat Fore/Aft Adjustment
B1355 54 [009] - Missing Calibration / Basic Setting
Reset counter: 125
Mileage: 3527 km
Date: 2017.06.15
Time: 14:23:31
9655892 - Motor for Seat Backrest Adjustment
B1356 54 [008] - Missing Calibration / Basic Setting
Reset counter: 165
Mileage: 3527 km
Date: 2017.06.15
Time: 14:23:42
9655380 - Motor for seat height adjustment
B1354 54 [009] - Missing Calibration / Basic Setting
Reset counter: 125
Mileage: 3527 km
Date: 2017.06.15
Time: 14:23:31
9655124 - Motor for Seat Tilt Adjustment
B1353 54 [009] - Missing Calibration / Basic Setting
Reset counter: 125
Mileage: 3527 km
Date: 2017.06.15
Time: 14:23:31
9654868 - Motor for Lumbar Support Fore/Aft Adjustment
B1352 54 [009] - Missing Calibration / Basic Setting
Reset counter: 125
Mileage: 3527 km
Date: 2017.06.15
Time: 14:23:31
9654612 - Motor for Lumbar Support Height Adjustment
B1351 54 [009] - Missing Calibration / Basic Setting
Reset counter: 125
Mileage: 3527 km
Date: 2017.06.15
Time: 14:23:31
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 125
Mileage: 3527 km
Date: 2017.06.15
Time: 14:23:31
Address 3C: Lane Change (J769) Labels: None
Part No SW: 3Q0 907 566 C HW: 3Q0 907 566
Component: MRR1Rear H16 0310
Revision: --------
Coding: 44C002
Component: TSG FS 020 0041
Serial number: 150117EAE04628
Coding: 003F1B20D201040000000000
VCID: 43C6ACE5CA46E65F51-8016
Part No SW: 5QF 909 144 HW: 5QF 909 144 _
Component: EPS_MQB_ZFLS 506 5572
Coding: 9307
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 075E78F5BEFE0A7F4D-8052
Component: TSG BFS 020 0041
Serial number: 200117EAK03718
Coding: 003F1120DE01040000000000
VCID: 42C8A9E1D55CEF575A-8016
Part No SW: 3G0 035 045 D HW: 3G0 035 045
Component: MU-H-N-RW H51 0814
Serial number: A688B0H2511982
Coding: 02730608FF00000051510001000808001F0106E601200002DF
VCID: 1F0E0095066EE2BF15-804A
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL0763H
Subsystem 2 - Part No SW: V03 959 801 EC HW: -----------
Component: ROW 2017 --- 0062
Component: Gracenote2--- --- 4009
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 5Q0 907 556 B HW: 5Q0 907 556
Component: Areaview 2 H13 0607
Serial number: C854707JG010057
Coding: 01230600A20F200000204094
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0261
Revision: -------- Serial number: 31127952600000
Coding: 0A28
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H06 0271
Serial number: 13021711K14115
Coding: 000307060000010100022346C150A90084000E200020
Shop #: WSC 12463 002 104857
ROD: EV_MFKBoschMQBB_VW36.rod
1135140 - Databus
Reset counter: 157
Mileage: 2582 km
Date: 2017.06.12
Time: 07:41:46
Control Module temperature: 38 °C
Outside air temperature: 9.5 °C
Vehicle speed: 16.23 km/h
System run time: 2170.2 s (second)
Voltage terminal 15: 13.0 V
mid: 02 65
Camera_state: operational
Engine_Running_Info: 1
Software_Info_4: 1
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
1135139 - Databus
Reset counter: 149
Mileage: 1150 km
Date: 2017.06.05
Time: 16:13:45
Control Module temperature: 40 °C
Outside air temperature: 18.5 °C
Vehicle speed: 58.45 km/h
System run time: 869.9 s (second)
Voltage terminal 15: 14.3 V
mid: 02 64
Software_Info_4: 1
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 100117EAA00884
Coding: 002A11200100040000000000
ROD: EV_DCURearDriveMAXCONT_VW37.rod
VCID: 45C2B2FDC472D86F7F-8010
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 301216ELM27018
ROD: EV_DCURearPasseMAXCONT_VW37.rod
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 3Q0 907 590 C HW: 3Q0 907 590
Revision: --------
Coding: 44C002
End----------(Elapsed Time: 02:29, VBatt start/end: 12.5V/12.3V)-----------
