2017 Tiguan Seat Basic Setting
IsDon
AU/TH
C?ID=206763
Hi Guys,
I have a new Tiguan, only had it a few weeks.
The seat memory for the drivers seat had been working fine and the seat and mirrors had been automatically setting themselves in accordance with the key used to open the drivers door. Recently this has stopped working. I can't even save a seat position using the memory buttons on the seat.
The scan of module 36 reveals that it has somehow lost its basic setting. I had a similar issue with the rear cargo blind on my A6 Allroad and used the basic settings within VCDS to drive the blind through its full range of movement and the problem was solved. I thought the seat would be another straightforward procedure. Not so lucky.
The basic setting gives me three options, the first of which is labelled "Norming" automatically runs the seat through its full range of travel, as expected, but has no effect on the problem and the fault codes reappear. The second option is "Reset to factory setting" but activating it gives an Error:Request out of range. The third option is "Resetting Standardization" but it seems to need a 0-3 digit code that VCDS doesn't know. Running it gives the same out of range error message.
I read somewhere on the forum, Uwe suggested that VCDS wasn't used for basic settings for the seat and that all was required was to run the seat through the full range of travel in all axes so I tried this as well without success.
I know the car is still under warranty, and I could just take it back to the dealer. Trouble is I'm certain its a quick fix but the dealer wants the car for the whole day and its 3 weeks until I can get an appointment. Its easier to launch a satellite into orbit.
Any ideas anyone?
Thursday,15,June,2017,15:48:18:54078
VCDS Version: 17.4.2.3 (x64)  HEX-NET CB: 0.4341.4
Data version: 20170505 DS270.4
VIN: WVGZZZ5NZHW405800   License Plate: NBV72J
Mileage: 3530km-2193mi   Repair Order:
Chassis Type: 5N (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 52
          5F 6C 6D A5 BB BC CF
VIN: WVGZZZ5NZHW405800   Mileage: 3530km-2193miles
Address 01: Engine (J623-CHHB)       Labels: None
   Part No SW: 5N0 906 259     HW: 06K 907 425 B
   Revision: --H13---
   Coding: 092500322466050B3000
   ASAM Dataset: EV_ECM20TFS0205N0906259 001004
   ROD: EV_ECM20TFS0205N0906259.rod
   VCID: 72A83921A57C1FD70A-8026
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0DL 300 011 P    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2001
   Revision: 00H06V07
   VCID: 3522C23D949248EFEF-8060
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 60277000001739
   Coding: 0AEE939A54202371477F070062C34950C92AC4E2E046927D384250B8C2AA4200002F641A1B13111435351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 79BA0E0DF80A6C8F4B-802C
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0429866611
   Coding: 032C2C070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   VCID: 3C34D719B7B899A710-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98140687
133124 - Databus
                    Reset counter: 157
                    Mileage: 2891 km
                    Date: 2017.06.12
                    Time: 10:49:34
Address 08: Auto HVAC (E87)       Labels: 3V0-907-044.clb
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000E00406453
   Coding: 0012000420010000110510001210142A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: 4AD881C1ED6C371792-801E
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001703400452
   ROD: EV_BCMBOSCH_017_VW27.rod
   VCID: 7EB01D11E1244BB77E-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 161201  033 0372
   Serial number: 00000001611280414593
   Component: RLHS  042 0105
   Serial number: S3Y17M02D13H21M37S04
   Coding: 00A8DD
534549 - Databus
                    Reset counter: 128
                    Mileage: 298 km
                    Date: 2017.05.07
                    Time: 15:10:47
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H10 0021
   Serial number: 002601177478080
   Coding: 0331667851
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B36D405B2B69E9F19-806E
13679388 - Databus
                    Reset counter: 165
                    Mileage: 829 km
                    Date: 2017.05.26
                    Time: 20:00:33
1112305 - Parking Sensor; Front Left Center
          U8EB251 F1 [008] - Reverberation Time too Long
                    Reset counter: 149
                    Mileage: 2280 km
                    Date: 2017.06.09
                    Time: 16:25:45
1113328 - Parking Sensor(s); Front
          U8EB650 F0 [008] - Function Limitation due to External Factors
                    Reset counter: 140
                    Mileage: 1150 km
                    Date: 2017.06.05
                    Time: 16:13:45
1080304 - Parking Sensor(s); Rear
          U8E3550 F0 [008] - Function Limitation due to External Factors
                    Reset counter: 157
                    Mileage: 2582 km
                    Date: 2017.06.12
                    Time: 07:41:45
10494464 - Function Limitation due to Environmental Factors
          B2022 00 [008] -  -
                    Reset counter: 149
                    Mileage: 2280 km
                    Date: 2017.06.09
                    Time: 16:25:45
Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320047C358FF8428749C8065303085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001_VW37.rod
196741 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Reset counter: 149
                    Mileage: 1855 km
                    Date: 2017.06.09
                    Time: 11:50:46
                    Voltage terminal 15: 12.7 V
                    Control Module temperature: 24 °C
                    Velocity_vehicle_reference: 28.96 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.22 m/s²
                    Status_ACC_System: ACC_activ_controlled
   Serial number: 21011741350073
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383CCB098380B587F4-806C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2JYSK3
   Coding: 98CCC0C00C0000005C540000008800000065
   VCID: 106C53A9CBB04DC79C-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 000 102 17
   Serial number: 357000000000D545B02C
   Subsystem 2 - Part No SW: -----------    HW: 480 000 102 17
   Serial number: 3580000000018999BF1-
   Subsystem 3 - Part No SW: -----------    HW: 480 400 902 17
   Serial number: 3510001A1244A733250I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 902 17
   Serial number: 3520001A1244A734523N
   Subsystem 5 - Part No SW: -----------    HW: 480 400 302 17
   Serial number: 3550001C1246A8E4D158
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 902 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001BF244A735F3BH
   Subsystem 7 - Part No SW: -----------    HW: 480 401 002 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A52465B3591D2
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 902 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001C1247FF93F429
   Subsystem 9 - Part No SW: -----------    HW: 480 000 502 17
   Serial number: I0M00000000FB16DF02H
   Subsystem 10 - Part No SW: -----------    HW: 480 000 502 17
   Serial number: I0N00000000A9884B128
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20170210201096
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB_VW37.rod
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         408 2170
   Coding: 27A400187F88000801887B0B1401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 41CAA6EDD05AF44F43-8014
          U1110 00 [008] - -
                    Fault Frequency: 25
                    Reset counter: 159
                    Mileage: 1255 km
                    Date: 2017.06.08
                    Time: 11:43:22
   Component: GW MQB High   515 5286
   Serial number: 09021710520351
   Coding: 030500347F085900FB07225A9E0F00010001050000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 2F2EF05576CE723FA5-807A
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170000163510017042
   Coding: 2DFFFF
   Serial number: 3943583004
   Serial number: HA1-00024.01.17
   Coding: 0101
   Serial number: 17000031089005
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71AA362DA07A24CFF3-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0021
   Serial number: Y0006QB414275
   Coding: 0014000000000500018281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
7 Faults Found:
9655636 - Motor for Seat Fore/Aft Adjustment
          B1355 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 125
                    Mileage: 3527 km
                    Date: 2017.06.15
                    Time: 14:23:31
9655892 - Motor for Seat Backrest Adjustment
          B1356 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 165
                    Mileage: 3527 km
                    Date: 2017.06.15
                    Time: 14:23:42
9655380 - Motor for seat height adjustment
          B1354 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 125
                    Mileage: 3527 km
                    Date: 2017.06.15
                    Time: 14:23:31
9655124 - Motor for Seat Tilt Adjustment
          B1353 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 125
                    Mileage: 3527 km
                    Date: 2017.06.15
                    Time: 14:23:31
9654868 - Motor for Lumbar Support Fore/Aft Adjustment
          B1352 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 125
                    Mileage: 3527 km
                    Date: 2017.06.15
                    Time: 14:23:31
9654612 - Motor for Lumbar Support Height Adjustment
          B1351 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 125
                    Mileage: 3527 km
                    Date: 2017.06.15
                    Time: 14:23:31
10489856 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 125
                    Mileage: 3527 km
                    Date: 2017.06.15
                    Time: 14:23:31
Address 3C: Lane Change (J769)       Labels: None
   Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0310
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   Serial number: 150117EAE04628
   Coding: 003F1B20D201040000000000
   VCID: 43C6ACE5CA46E65F51-8016
   Part No SW: 5QF 909 144     HW: 5QF 909 144 _
   Component: EPS_MQB_ZFLS  506 5572
   Coding: 9307
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 075E78F5BEFE0A7F4D-8052
   Serial number: 200117EAK03718
   Coding: 003F1120DE01040000000000
   VCID: 42C8A9E1D55CEF575A-8016
   Part No SW: 3G0 035 045 D    HW: 3G0 035 045
   Component: MU-H-N-RW     H51 0814
   Serial number: A688B0H2511982
   Coding: 02730608FF00000051510001000808001F0106E601200002DF
   VCID: 1F0E0095066EE2BF15-804A
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL0763H
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Compact Disc Database:
   Component: Gracenote2---  --- 4009
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG010057
   Coding: 01230600A20F200000204094
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31127952600000
   Coding: 0A28
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H06 0271
   Serial number: 13021711K14115
   Coding: 000307060000010100022346C150A90084000E200020
   Shop #: WSC 12463 002 104857
   ROD: EV_MFKBoschMQBB_VW36.rod
1135140 - Databus
                    Reset counter: 157
                    Mileage: 2582 km
                    Date: 2017.06.12
                    Time: 07:41:46
                    Control Module temperature: 38 °C
                    Outside air temperature: 9.5 °C
                    Vehicle speed: 16.23 km/h
                    System run time: 2170.2 s (second)
                    Voltage terminal 15: 13.0 V
                    mid: 02 65
                    Camera_state: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1135139 - Databus
                    Reset counter: 149
                    Mileage: 1150 km
                    Date: 2017.06.05
                    Time: 16:13:45
                    Control Module temperature: 40 °C
                    Outside air temperature: 18.5 °C
                    Vehicle speed: 58.45 km/h
                    System run time: 869.9 s (second)
                    Voltage terminal 15: 14.3 V
                    mid: 02 64
                    Software_Info_4: 1
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 100117EAA00884
   Coding: 002A11200100040000000000
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   VCID: 45C2B2FDC472D86F7F-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 301216ELM27018
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
End----------(Elapsed Time: 02:29, VBatt start/end: 12.5V/12.3V)-----------
Don: Hi - be very thankful that you got the "Error:Request out of range" message because successful execution of "Reset to factory setting" seems to have profound consequences.
I've had a few distraught forum colleagues visit here after executing this option - what appears to happen (and I'm guessing) is that once this option is selected, the module forgets all (most?) for its basic setting values. I suspect (and I'm guessing, again) that the reference to "factory" means that the module reverts to the its state when taken from stock (i.e. before it was installed into the car).
I would welcome RT's advice on what "Reset to factory" setting really does
Don (the 2nd one)
PS: Given the misleading and benign sounding title of this option and the ramifications of implementation - as well as the unlikely scenario for correctly using this option after the car is purchased, I reckon that implementing "Reset to factory" should be a two step process in RT's software: The first pass should be a warning message indicating the consequences of proceeding - only after the user has confirmed that he/she REALLY wants to continue, the software should allow the user to proceed to implementation - IMO
IsDon
AU/TH
C?ID=206763
Sounds like I dodged a bullet there, thanks DV.
Yes, reset to factory settings sound very innocuous, hence why I didn't hesitate to give it a shot. A reset to factory settings sounds exactly what was needed to fix my problem, or reinitialization which was the other option. Luckily neither of which worked.
I'm still stuck though with an unresponsive seat. Is there anything else worth trying?
Don: Alas I'm not aux fait with how (or even, if) VCDS does seat calibration. I'm aware that there is a "guided service process" for these functions in the dealer ODIS tool, but Uwe's advice is a telling harbinger of bad news - I suspect!
I did manage to compare the code-string on your hex36 module with a new Tiggy in my database (taken from a VWWatercooled colleague of ours who visited here recently to have Traffic alerts implemented) and the two were the same. Also, I looked at the admap for the hex36 module and it is entirely unremarkable (has only two channels). How did you manage to lose the calibrations?
Don (the 2nd one)
IsDon
AU/TH
C?ID=206763
Mate. I don't know.
To tell you the whole story, when we first got the car the seat wasn't working.
I plugged in VCDS and did the "Norming" thing in Basic settings which drove the seats through its full range of travel and it worked for 4 weeks without a problem. Now it's dumped its calibration for some reason but what I did last time no longer works.
I tried running it numerous times in various states. Engine on, engine off, door open, door closed trying to replicate what I stumbled onto to fix it last time but I can't replicate the fix. So I know VCDS can fix it, just not sure how.
Either that, or I'm starting to suspect that I actually have a faulty module. Either way it looks like a visit to the dealer is going to be required.
sasha
Australia
C?ID=287611
@IsDon what was the fix in the end? I ran into the same problem with 2017 Skoda Kodiaq except seats were working fine then just stopped moving to preset positions 1,2 etc and when I connected the cable showed me the error of lost calibration...
                Address 36: Seat Mem. Drvr       Labels: None
Control Module Part Number: 5Q0 959 760 B    HW: 5Q0 959 760 B
  Component and/or Version: Sitzmemory    H08 0022
           Software Coding: 0014000000000500018281818181000000008181000000D400
            Work Shop Code: WSC 33361 790 00063
              ASAM Dataset: EV_SeatMemorDriveSide 002021 (SK37)
                      VCID: 3C76B186B75588AF85-8069
                    Reset counter: 42
                    Mileage: 9238 km
                    Date: 2019.07.10
                    Time: 19:55:47
          B2010 00 [009] - -
                    Reset counter: 42
                    Mileage: 9238 km
                    Date: 2019.07.10
                    Time: 19:55:47
sasha
Australia
C?ID=287611
Sharing for everyone's benefit.. I've done the "Norming" and now have 6 faults vs original 2 :cry:
Tuesday,23,July,2019,14:22:09:15919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 19.6.1.0
VIN: TMBMD9NS9H8030910   License Plate:
                Address 36: Seat Mem. Drvr       Labels: NONE
Fault Codes have been Erased
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
          B2010 00 [009] - -
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
sumsurooah
Milan
C?ID=373826
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
          B2010 00 [009] - -
                    Reset counter: 64
                    Mileage: 9557 km
                    Date: 2019.07.23
                    Time: 14:21:37
Hi, I have just installed the electric heated leather seats in the aftermarket for tiguan my2019.
I also have the same problem. Could I know if you solved the problem and how? Thanks
darkchina811
ITALY
C?ID=333184
alright, so this has happened to my parents Octavia a couple of times, all these cars are MQB so the procedure should work.
first of all, VCDS cannot do anything, and if you do the "reset" option you will wipe the parameterization from the module, which, trust me, you really don't want to.
so basicaly just move the seat with the joystick, ALL the way forward and keep the joystick pressed until you hear a BING, then all the way back and keep the joystick pressed until you hear a BING. all of it with ignition on, of course. no need to move the seat back or lumbar, just the whole seat forward and back.
it worked for me, good luck.
MasterTommy
Amsterdam
C?ID=295586
What i used to do is basically the same as darkchina posted above, except for releasing the button after the movement stops, then holding it again in the same direction. The seat will move a tiny bit further and then save that as the end point. Repeat for all directions of travel/all adjustable seat parts.
darkchina811
ITALY
C?ID=333184
honestly it's been a while so MasterTommy's procedure could be the one, but I am pretty sure only seat forward/back is enough to clear the error.
it won't hurt trying either way :)
sumsurooah
Milan
C?ID=373826
I will start the procedure as you said, hoping that the errors that are many will be canceled:
Sunday,26,April,2020,12:26:08:12184
VIN: WVGZZZ5NZKW826136   License Plate: SEDILI ERROR
Mileage: 25146km-15625mi   Repair Order:
  Component and/or Version: Sitzmemory    H07 0020
           Software Coding: 001000000000000001A481808080000000008181000000F400
            Work Shop Code: WSC 00000 000 00000
              ASAM Dataset: EV_SeatMemorDriveSide 002021 (VW37)
                      VCID: 3C2134C4F6E95E67D61-8068
7 Faults Found:
                    Reset counter: 43
                    Mileage: 25146 km
                    Date: 2020.04.23
                    Time: 19:01:41
                    Reset counter: 43
                    Mileage: 25146 km
                    Date: 2020.04.23
                    Time: 19:01:41
                    Reset counter: 43
                    Mileage: 25146 km
                    Date: 2020.04.23
                    Time: 19:01:41
                    Reset counter: 43
                    Mileage: 25146 km
                    Date: 2020.04.23
                    Time: 19:01:41
                    Reset counter: 43
                    Mileage: 25146 km
                    Date: 2020.04.23
                    Time: 19:01:41
9657617 - Sensor for Seat Fore/Aft Adjustment
          B135D 11 [009] - Short to Ground
                    Reset counter: 43
                    Mileage: 25146 km
                    Date: 2020.04.23
                    Time: 19:01:41
          B2010 00 [009] - -
          [keine oder falsche Grundeinstellung/Adaption]
                    Reset counter: 43
                    Mileage: 25146 km
                    Date: 2020.04.23
                    Time: 19:01:41
Thanks to both of you. I'll let you know.
Hi this morning I tried to do the procedure but it doesn't work, it's probably for CP protection. I have an unregistered seat error.
https://drive.google.com/file/d/1AySwiVcb7C3neddY6PaO65zGjYw6mhB_/view
