Gen4 Door controllers retrofit
kamold
Australia
C?ID=241363
Hi All,
I've installed some Gen4 door controllers to replace my gen3s.
The Gen4 controllers came from a RHD CC so they were already coded and parametized for that car.
I have the following problems:
-Missing calibration errors against both front door controllers.
-Autorun works down on front doors but they won't autorun back up
-Rear door switches operate in reverse ie push down and windows come up, pull up and they go down...
I've validated the coding against similar RHD vehicles (a B6 and a B7 who both have Gen4 controllers from factory).
I've tried turning the RHD bit on and off for rear doors, as well as rear door control modules bit on and off neither makes any difference.
I've run the windows all the way down and held for 5 seconds, then all the way up and held then repeated many times, I can't get front door calibration to complete.
Basic settings has a 'reset all adaptations' channel however even with SA code entered I get a request out of range error.
I tried comparing adaptation channel maps and then trying to copy system parameter block strings however I just get 'error 0x00' when I try and apply the new data to the adaptation channel even after entering SA...
Anyone have any ideas apart from going to the dealer for an online coding session?
Original door controller:
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000691888917
Coding: 0005047
Shop #: WSC 05311 000 00000
VCID: 71E2276768A046CFF3-8024
Autoscan with Gen4s installed:
Thursday,15,June,2017,12:23:08:02396
VCDS Version: 17.4.2.3 (x64)
Data version: 20170505 DS270.4
VIN: WVWZZZ3CZ9E0   License Plate:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 36 37 42 44 46 47 52
          53 55 56 62 65 6C 6D 72 77
VIN: WVWZZZ3CZ9E083538   Mileage: 106920km-66437miles
Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 AM    HW: 03H 906 032 AB
   Component: R3.6-FSI-EU4    A   3488
   Revision: 5GH04---    Serial number: VWZCZ000000000
   Coding: 0000175
   VCID: 6DDA3B177498A22FD7-8038
   Part No SW: 02E 300 012 E    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1903
   Revision: 04844002    Serial number: 00000810231260
   Coding: 0000024
   VCID: 122048EB0D66DDD7AA-8046
   Part No SW: 3AA 614 109 AJ    HW: 3AA 614 109 AL
   Component: J104   C2 450M VE90 0023
   Revision: --H07---    Serial number: 00000007379684
   Coding: 0103076
   Shop #: WSC 12345 123 00000
   VCID: 75EA13771CC86AEF2F-8020
   Part No SW: 3AD 907 044 G    HW: 3AD 907 044 G
   Component: Climatronic   H03 0404
   Coding: 0011000002
   Shop #: WSC 12345 123 61029
   VCID: 3776D97F8E44D8FFFD-8062
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 24
                    Reset counter: 144
                    Mileage: 106625 km
                    Date: 2017.06.13
                    Time: 17:09:41
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000009027172
   Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
   VCID: 336EED6F523C34DFC1-8066
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 100908 022  0601
   Coding: 00047029
   Shop #: WSC 12345
   Component: RLS     121108 054  0402
   Coding: 00208936
   Shop #: WSC 12345
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0013
   Revision: --------    Serial number: 97540830907185
   Coding: 300102
   VCID: 3874DA438B5AD787F4-806C
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000569541
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 3874DA434B5AD787F4-806C
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__00S VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPMPB81T
   Coding: 0012371
   VCID: 7AF0004B35D6059742-802E
   Subsystem 1 - Serial number: 6333FTS665962908
   Subsystem 2 - Serial number: 6343FTS632552888
   Subsystem 3 - Serial number: 6353ETS6NTCKVVNR
   Subsystem 4 - Serial number: 6363ETS640PKVVNR
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20160725000799
   Coding: 1992A50003
   VCID: 71E22767A0A046CFF3-8024
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Coding: 830000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 881     HW: 3AA 920 881
   Component: KOMBI         H03 0705
   Coding: 711F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 110114F2000857
   Coding: 462007
   Shop #: WSC 12345 123 12345
   VCID: 7BFE054FFAEC3C9F59-802E
   Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
   Component: Haldex 4Motion      4013
   Coding: 0000005
   VCID: 448CBEB30792836768-8010
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         052 0407
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 12345 123 2097151
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F66E11FBE14103FA5-807A
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
   Component: RNS-MID       H30 6276
   Revision: AB001001    Serial number: VWZ6Z7M5270061
   Coding: 04050002010000910000
   VCID: 3668D47B814E21F7E6-8062
   Subsystem 1 - Part No: 7L6 919 859 G
   Component: AUNZ V9  8333
02877 - Digital Radio Antenna (R183)
                    Fault Status: 01101011
                    Fault Frequency: 83
                    Reset counter: 144
                    Mileage: 106560 km
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0502
   Revision: 12110009    Serial number: 0002023240
   Coding: 0013B7
   Shop #: WSC 05311 115 12345
   VCID: 6DDA3B17BC98A22FD7-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001872006
   Coding: 000210
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 143    2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C5CF6138F026B2780-8078
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 052 0638
   Coding: 00900A00D1034E7F000294157008DFCE607801
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466     HW: 3AA 035 466
   Component: KonzernAmp12K H03 6904
   Revision: --------    Serial number: A1108A00010581
   ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
   ROD: EV_AudioVerst12KanalSTT1.rod
9461523 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
                    Reset counter: 144
                    Mileage: 106921 km
                    Date: 2017.06.15
                    Time: 12:17:31
9462035 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
                    Reset counter: 144
                    Mileage: 106921 km
                    Date: 2017.06.15
                    Time: 12:17:31
9463314 - Rear Left Treble Speaker
          B1066 12 [009] - Short to Plus
                    Reset counter: 144
                    Mileage: 106921 km
                    Date: 2017.06.15
                    Time: 12:17:31
9463826 - Rear Right Treble Speaker
          B1068 12 [009] - Short to Plus
                    Reset counter: 144
                    Mileage: 106921 km
                    Date: 2017.06.15
                    Time: 12:17:31
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0502
   Revision: 14110009    Serial number: 0002020021
   Coding: 0013B6
   VCID: 6ED83C1BB19E5937EE-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001884015
   Coding: 000210
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 144
                    Mileage: 106921 km
                    Date: 2017.06.15
                    Time: 12:15:06
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000248887
   Coding: 0022157
   Shop #: WSC 05311 000 00001
   Component: AFS-Steuergeraet    0136
   Coding: 2344193
   VCID: 346CEE73573233E7D8-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
                    Fault Frequency: 83
                    Reset counter: 144
                    Mileage: 106560 km
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 40000000055443
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30.rod
   Part No SW: 3C0 907 441     HW: 3C0 907 441
   Component: J772__Rearview      0042
   Revision: 00H05000    Serial number:    PA8 J890694
   Coding: 0020007
   VCID: 5FC651DF8E34C0BF55-800A
   Part No SW: 3C9 827 383 F    HW: 3C9 827 383 F
   Component: J605  HECKDECKEL    0720
   Revision: 00H27001
   Subsystem 1 - Part No: 3C9 827 384 F
   Component: J756  HECKDECKEL    0720
   Subsystem 2 - Serial number: 0800H27001001B0148ÿ
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105271202
   Coding: 020000010100110000000001
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 254A033724E85A6F5F-8070
End-------------------------(Elapsed Time: 03:33)--------------------------
downtime
C?ID=280813
You need to do basic settings to windows. Not with VCDS but manually.
Procedure :
Prerequisite :
Window completely up
1. Lower the window completely down and keep the window button pressed for about 5 seconds
2. Raise the window completely up and keep the window button pulled for about 5 seconds
That's it. Basic setting / calibration done
kamold
Australia
C?ID=241363
I've tried that a dozen times with no result unfortunately.
Rear windows will adapt but operate in the wrong direction. Which means comfort function has the rear windows opening when they should be closing...
nateo83
Canada
C?ID=398539
Hi there, just to resurrect this subject, I've retrofitted gen4 door controllers to my 2009 B6, the donor car is a Touran and a Passat CC - and I've also gotten some controller mapping from a few other guys on another forum. Essentially I started with the issue that the windows would always auto-index when I opened and closed the door (CC has frameless windows, B6 does not). I noticed that I could complete the auto calibration and so the auto up and auto down would work but only if I didn't allow the window to go all the way down. If I allow it to go all the way down, it seems to stop just before reaching the end, and I actually need to press the window door switch down and hold it and it does go down further - but if it hits this intermediary window down position and the ultimate window down position the auto up/down, pinch protection, and the convenience close don't work (actually the convenience close results in a full auto window down SAFE operation - not good!).
Anyways I actually worked out the system parameter which causes the auto index and turned it off, I also found the adaptation parameter that causes the mirror adjustment to be 90 deg. out of sync (from a Tiguan map).
Here is the link to autoscan, admap and block map
Anyways I was wondering if you or anyone else has solved the auto up/down and pinch protection issue. I took the step in May of actually solving the auto-index and I got that turned off but with the remaining issue of not being able to do the auto down all the way - and I had no errors. I also (repeatedly) tried to do the window calibration (probably like 20-30 times, with car start/stops, etc.) and could not get it to work. Recently I've actually gone and loaded all the system parameters (parameters system_parameter_0 through 15) from a Passat b7 (NMS) to the (right) passenger door controller - now it's actually saying I have a incorrectly coded door controller. I think it's probably because there is some remaining discrepancy in the rest (i.e. system data parameters, vw identification, etc.) - but I don't want to mess around with it blindly.
Hoping someone has some better knowledge on this subject than me..
Here is an auto scan:
Wednesday,07,October,2020,22:12:30:08140
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WVWNK73C09E096517   License Plate:
Mileage: 171020km-106266mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 53 55 56 62 6D 72
VIN: WVWNK73C09E096517   Mileage: 171020km-106266miles
0F-Digital Radio -- Status: Not registered 0011
   Part No SW: 06J 906 026 AF    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3318
   Revision: AAH03---    Serial number: VWZCZ000000000
   Coding: 0404010A18070160
   Shop #: WSC 05314 000 00000
   VCID: 6E85C81A8C96F9BBB0F-803A
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 79
                    Mileage: 168699 km
                    Date: 2015.02.28
                    Time: 12:02:11
                    RPM: 2222 /min
                    Load: 17.2 %
                    Speed: 60.0 km/h
                    Temperature: 87.0°C
                    Temperature: 40.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
006472 - Control Module 2 for Cooling Fan
               P1948 - 000 - Output Short Circuit - Intermittent
                    Fault Frequency: 20
                    Mileage: 170258 km
                    Date: 2015.02.28
                    Time: 11:44:29
                    RPM: 849 /min
                    Load: 23.5 %
                    Temperature: 91.0°C
                    Temperature: 54.0°C
                    Voltage: 13.843 V
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AJ    HW: 3C0 614 109 T
   Component: J104    C4 440 V2   0016
   Revision: --025---    Serial number: 00000786422456
   Coding: 0002421
   Shop #: WSC 00017 666 02327
   VCID: 6695B03AA46631FBC8F-8032
   Part No SW: 1K0 820 047 JE    HW: 1K0 820 047 JE
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 70B9D66296A2EF4BA23-8024
   Revision: 00H54000    Serial number: 00000009135800
   Coding: 8F8C8F2700041A00870000630F000000005B7F4D00401120000000000000
   Shop #: WSC 05124 123 12345
   VCID: 3333196EA73494539F1-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 031008 004  0206
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0476922
   Coding: 0000000
00003 - Control Module
                    Fault Status: 00101110
                    Reset counter: 250
                    Mileage: 144245 km
                    Date: 2011.07.18
                    Time: 19:20:57
                    Reset counter: 82
                    Mileage: 170731 km
                    Date: 2015.02.28
                    Time: 08:43:28
   Component: J234__003 VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPQ7V11S
   Coding: 0012339
   VCID: 7AADF44AC0DEA51B1C7-802E
   Subsystem 1 - Serial number: 6333FTS611243198
   Subsystem 2 - Serial number: 6343FTS645622908
   Subsystem 3 - Serial number: 6353ETS6FOA0V5KJ
   Subsystem 4 - Serial number: 6363ETS6OU4VVVNR
   Subsystem 5 - Serial number: 6374CTS6H9JQVVNR
   Subsystem 6 - Serial number: 6384CTS6TRF1V5KR
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0030
   Revision: 00032000    Serial number: 3C5953507CN
   Coding: 0000712
   VCID: 74B1DA72E2BAD36B46B-8020
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Part No SW: 3C0 920 871 R    HW: 3C0 920 871 R
   Component: KOMBI         H04 0107
   Coding: 360D00
   Shop #: WSC 05314 115 12345
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
   VCID: 3333196EABB494539F1-8066
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P08C05031F
   Coding: F9817F06020202002002
   Shop #: WSC 05314 123 12345
   VCID: 2A0D040A70FED59B2C7-807E
                    Reset counter: 131
                    Mileage: 171021 km
                    Date: 2015.02.28
                    Time: 22:06:40
   Part No SW: 3C0 959 433 AT    HW: 3C0 959 433 AT
   Component:    IMMO         042 0383
   Shop #: WSC 06402 785 00200
   VCID: 7CA1F252CAEA9B2B0EB-8028
   Component: TUER-SG FT    002 0501
   Revision: 12110009    Serial number: 0001817230
   Coding: 0010F7
   VCID: 6D87CF168D1002A3895-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
   Component: J388__TSG-HL  004 0307
   Serial number: 00000000707439
   Coding: 0004D0
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 27
                    Reset counter: 171
                    Mileage: 168456 km
                    Date: 2020.10.07
                    Time: 13:07:10
66561 - Motor for mirror fold-in
          B11F6 01 [008] - Electrical Failure
                    Reset counter: 152
                    Mileage: 170908 km
                    Date: 2020.10.07
                    Time: 19:33:25
67074 - Motors for Central Locking
          B122B 01 [008] - Electrical Failure
                    Reset counter: 171
                    Mileage: 168368 km
                    Date: 2020.10.07
                    Time: 12:51:58
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.081 0502
   Revision: 1AH02240    Serial number: 00083290202402
   Coding: 0000258
   VCID: 392F2B4685586E0355D-806C
   Component:    KSG PQ46 ELV 042 0612
   Coding: 13900E80D10306767204141FF08A8F0E087C01
   Shop #: WSC 94718 999 15553
   Part No SW: 1T0 959 702 AC    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0307
   Revision: 14101005    Serial number: 0000306918
   Coding: 0015F6
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 79AFEB46C958AE0315D-802C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
   Component: J389__TSG-HR  004 0307
   Serial number: 00000000727654
   Coding: 0004D0
                    Reset counter: 171
                    Mileage: 171021 km
                    Date: 2020.10.07
                    Time: 19:07:38
66821 - Position Sensor for Mirror Adjustment
          B11FA 29 [009] - Signal Implausible
                    Reset counter: 131
                    Mileage: 171021 km
                    Date: 2020.10.07
                    Time: 19:07:28
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000208591
   Coding: 0000057
   VCID: 2809FE026EF2E78B3A3-807C
   Coding: 2323457
   VCID: 34311A72A23A936B86B-8060
   Coding: 00000035
   Coding: 00000035
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5406
   Revision: --------    Serial number: VWZZZ4J6253087
   Coding: 16000440010005
   Shop #: WSC 127395 840 08317
   VCID: 46D550BAC8A611FB28F-8012
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 E
   Component: J605  HECKDECKEL    0600
   Revision: 00H27001
   Shop #: WSC 23250 384 715754
   VCID: 303916625622AF4BE23-8064
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0600
   Subsystem 2 - Serial number: 0800H27001001B0050ÿ
00317 - Rear Lid Control Module (J605)
                    Reset counter: 160
                    Mileage: 170946 km
                    Date: 2015.02.28
                    Time: 17:08:30
End----(Elapsed Time: 01:27, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
siLc
Tallinn, Estonia
C?ID=330192
Well, in my experience I would say its not advisable using CC door modules (no matter if front or rear) for anything else than a CC :) Years ago, I inadvertently ordered a CC rear module and the windows switch indeed worked in reverse. Also when opening the door, the window notced down a bit (because of CC's frameless windows). Because door modules aren't expensive, bought a proper B7 one and everything was good.
nateo83
Canada
C?ID=398539
Yeah, but for us here it’s difficult to find a b7 module supporting power mirror folding, and mirror memory.. really I want to know can I not just program it with adaptations, I found the adaptation to turn off the window notching and that has gone away now the only thing left is the adaptation value that holds the small window reserve at the bottom it seems.
siLc
Tallinn, Estonia
C?ID=330192
All B7 RoW front door modules (3AA959701A and 702A) support the full range of features (puddle lights, exit lights, ambient lights, folding and memory). Availability in NAR is another thing :)
nateo83
Canada
C?ID=398539
Ok specifically version code A..? Or A and higher...
siLc
Tallinn, Estonia
C?ID=330192
From my collection of autoscans, there is only index A for the whole production period 2010-2015.
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
nateo83
Canada
C?ID=398539
So lesson in buying this - usually the plug in connectors (the part that is actually the relay) seems to have the HW: numbers as above. The software seems to be on a sticker on the actual window motor. I'll just unclip and swap in the relay though when I get it - I did that last time.
So to summarize... I can spend a $1000 of time screwing around with adaptations, or for 50 bucks I can just replace the damn controllers and call it a day :)..
If anyone else wants to dive into this further, I have found that System_Parameter_0 byte 11 (1E is normal, E4 seems to rotate the mirror adjustment 90 deg) is for the direction of the mirror adjustment knob ( i.e. for tiguans (?)) , and System_Parameter_0 byte 4 (window indexing on/off, off = 0, on seems to be 45)
CF.T
Portugal
C?ID=386461
:D it's amazing I found this post today, I just got my rear CC modules working on my B6 yesterday.
This is the bits to reverse the windows directions (7F) and stop the window indexing is the other (00). But I also switched the sw from both sides with each other, not sure if this is necessary. If you're interested, I can send a link with further explanation.
I'm currently looking, to see if I can get the rear door locking buttons working, for a adpmap from a NAR CC that came with this option from factory , if someone can help me out, I would be very appreciated.
Edit: Also didn't got the pinch protection to work, but last time I checked still hadn't solve all the problems though. Also, my modules were 3C8959703D/704D, yours are 1K0, so those might be different.
Edit2: my guide
CF.T
Portugal
C?ID=386461
Tested pinch protection today, working perfectly.
nateo83
Canada
C?ID=398539
I actually just figured out yesterday how to get the auto up/down and pinch protection working even after fully rolling the window down on the front passenger window. I had mixed some values between two different B7 gen 4 adaptation maps. I think i found the specific value. I’ll check your post above and compare notes. If correct I have two new B7 door controllers to sell as I don’t need to swap mine..
nateo83
Canada
C?ID=398539
It appears to be system-parameter_1 byte 9 need to be recoded to 9E. On my car it was 87 and setting it to 9E fixed this. I still went through and copied all the B7 parameters from my admaps though, just to be safe.
CF.T
Portugal
C?ID=386461
I have 9E in that position also. Great you got it working.
nateo83
Canada
C?ID=398539
Ok thanks. Back to your previous question then, I don’t think you need to do the EEPROM swap. Mine is working without.
CF.T
Portugal
C?ID=386461
Good to know, I did it before finding the correct bits, and since there was no change to their behaviour, now I too think it is unnecessary. Didn't compare both sides bits though, can't be 100% sure.
