- Mar 9, 2015
- 474
- 335
- Australia
- C?ID=241363
Hi All,
I've installed some Gen4 door controllers to replace my gen3s.
The Gen4 controllers came from a RHD CC so they were already coded and parametized for that car.
I have the following problems:
-Missing calibration errors against both front door controllers.
-Autorun works down on front doors but they won't autorun back up
-Rear door switches operate in reverse ie push down and windows come up, pull up and they go down...
I've validated the coding against similar RHD vehicles (a B6 and a B7 who both have Gen4 controllers from factory).
I've tried turning the RHD bit on and off for rear doors, as well as rear door control modules bit on and off neither makes any difference.
I've run the windows all the way down and held for 5 seconds, then all the way up and held then repeated many times, I can't get front door calibration to complete.
Basic settings has a 'reset all adaptations' channel however even with SA code entered I get a request out of range error.
I tried comparing adaptation channel maps and then trying to copy system parameter block strings however I just get 'error 0x00' when I try and apply the new data to the adaptation channel even after entering SA...
Anyone have any ideas apart from going to the dealer for an online coding session?
Original door controller:
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000691888917
Coding: 0005047
Shop #: WSC 05311 000 00000
VCID: 71E2276768A046CFF3-8024
Autoscan with Gen4s installed:
Coding: 0005047
Thursday,15,June,2017,12:23:08:02396
VCDS Version: 17.4.2.3 (x64)
Data version: 20170505 DS270.4
VIN: WVWZZZ3CZ9E0 License Plate:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 36 37 42 44 46 47 52
53 55 56 62 65 6C 6D 72 77
VIN: WVWZZZ3CZ9E083538 Mileage: 106920km-66437miles
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 AM HW: 03H 906 032 AB
Component: R3.6-FSI-EU4 A 3488
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
VCID: 6DDA3B177498A22FD7-8038
Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1903
Revision: 04844002 Serial number: 00000810231260
Coding: 0000024
VCID: 122048EB0D66DDD7AA-8046
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AJ HW: 3AA 614 109 AL
Component: J104 C2 450M VE90 0023
Revision: --H07--- Serial number: 00000007379684
Coding: 0103076
Shop #: WSC 12345 123 00000
VCID: 75EA13771CC86AEF2F-8020
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AD 907 044 G HW: 3AD 907 044 G
Component: Climatronic H03 0404
Coding: 0011000002
Shop #: WSC 12345 123 61029
VCID: 3776D97F8E44D8FFFD-8062
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 24
Reset counter: 144
Mileage: 106625 km
Date: 2017.06.13
Time: 17:09:41
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000009027172
Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
VCID: 336EED6F523C34DFC1-8066
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 100908 022 0601
Coding: 00047029
Shop #: WSC 12345
Component: RLS 121108 054 0402
Coding: 00208936
Shop #: WSC 12345
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0013
Revision: -------- Serial number: 97540830907185
Coding: 300102
VCID: 3874DA438B5AD787F4-806C
Address 13: Auto Dist. Reg Labels: 3AA-907-567.clb
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000569541
Coding: 0010000
Shop #: WSC 05311 000 08193
VCID: 3874DA434B5AD787F4-806C
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__00S VW10 HI 1815
Revision: 19013000 Serial number: 0039BPMPB81T
Coding: 0012371
VCID: 7AF0004B35D6059742-802E
Subsystem 1 - Serial number: 6333FTS665962908
Subsystem 2 - Serial number: 6343FTS632552888
Subsystem 3 - Serial number: 6353ETS6NTCKVVNR
Subsystem 4 - Serial number: 6363ETS640PKVVNR
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BM HW: 5K0 953 569 T
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20160725000799
Coding: 1992A50003
VCID: 71E22767A0A046CFF3-8024
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0036
Coding: 830000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 881 HW: 3AA 920 881
Component: KOMBI H03 0705
Coding: 711F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 110114F2000857
Coding: 462007
VCID: 7BFE054FFAEC3C9F59-802E
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 448CBEB30792836768-8010
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 052 0407
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 12345 123 2097151
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F66E11FBE14103FA5-807A
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 E
Component: RNS-MID H30 6276
Revision: AB001001 Serial number: VWZ6Z7M5270061
Coding: 04050002010000910000
VCID: 3668D47B814E21F7E6-8062
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V9 8333
02877 - Digital Radio Antenna (R183)
Fault Frequency: 83
Reset counter: 144
Mileage: 106560 km
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0502
Revision: 12110009 Serial number: 0002023240
Coding: 0013B7
Shop #: WSC 05311 115 12345
VCID: 6DDA3B17BC98A22FD7-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001872006
Coding: 000210
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 143 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C5CF6138F026B2780-8078
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 052 0638
Coding: 00900A00D1034E7F000294157008DFCE607801
Component: Neigungssensor 004 0611
Address 47: Sound System (R184) Labels: 5K0-035-456.clb
Part No SW: 3AA 035 466 HW: 3AA 035 466
Component: KonzernAmp12K H03 6904
Revision: -------- Serial number: A1108A00010581
ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
ROD: EV_AudioVerst12KanalSTT1.rod
9461523 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
Reset counter: 144
Mileage: 106921 km
Date: 2017.06.15
Time: 12:17:31
9462035 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
Reset counter: 144
Mileage: 106921 km
Date: 2017.06.15
Time: 12:17:31
9463314 - Rear Left Treble Speaker
B1066 12 [009] - Short to Plus
Reset counter: 144
Mileage: 106921 km
Date: 2017.06.15
Time: 12:17:31
9463826 - Rear Right Treble Speaker
B1068 12 [009] - Short to Plus
Reset counter: 144
Mileage: 106921 km
Date: 2017.06.15
Time: 12:17:31
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0502
Revision: 14110009 Serial number: 0002020021
Coding: 0013B6
VCID: 6ED83C1BB19E5937EE-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001884015
Coding: 000210
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 144
Mileage: 106921 km
Date: 2017.06.15
Time: 12:15:06
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000248887
Coding: 0022157
Shop #: WSC 05311 000 00001
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0136
Coding: 2344193
VCID: 346CEE73573233E7D8-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Fault Frequency: 83
Reset counter: 144
Mileage: 106560 km
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000055443
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30.rod
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C0 907 441 HW: 3C0 907 441
Component: J772__Rearview 0042
Revision: 00H05000 Serial number: PA8 J890694
Coding: 0020007
VCID: 5FC651DF8E34C0BF55-800A
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 F HW: 3C9 827 383 F
Component: J605 HECKDECKEL 0720
Revision: 00H27001
Subsystem 1 - Part No: 3C9 827 384 F
Component: J756 HECKDECKEL 0720
Subsystem 2 - Serial number: 0800H27001001B0148ÿ
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105271202
Coding: 020000010100110000000001
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 254A033724E85A6F5F-8070
End-------------------------(Elapsed Time: 03:33)--------------------------
