Gateway adaptations:
Since it has DSG, I expect that your car has hill hold enabled, correct?If there's anything else you want me to add just let me know.
Looks like the long arm of MQB has extended all the way from Germany to Czech Republic
VCDS Version: Beta 15.3.0 (x64)
Data version: 20150314
Sunday,26,April,2015,17:16:43:61434
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 13 15 17 19 44 5F
VIN: WVWZZZ6RZFUnnnnnn Mileage: 238km-147miles
Address 01: Engine (J623-CJZD) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BC HW: 04E 907 309 AF
Component: 1.2l R4 TSI H21 8229
Revision: R4H21---
Coding: 01190012234411080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS01104E906027BC 001006
ROD: EV_ECM12TFS01104E906027BC_VW26.rod
VCID: 66C30873998837085D-8033
Readiness: 0000 0001
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 H HW: 6C0 907 379 B
Component: ESP9.0i H01 0003
Serial number: 08507972141209
Coding: 23DD4885492A33C1091910710056C41292CC90080005CBFB8700
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
VCID: 3467A23B9FD4959813-8061
Address 08: Auto HVAC (J255) Labels: 6C0-907-044.clb
Part No SW: 6C0 907 044 A HW: 6C0 907 044 A
Component: Climatronic H02 0201
Serial number: 1501201A-0393
Coding: 200020011001100001
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26.rod
VCID: 224B546335200B28F1-8077
590081 - Control Circuit for A/C Compressor
B10A9 11 [012] - Short to Ground
Reset counter: 52
Mileage: 143 km
Date: 2015.04.24
Time: 13:17:15
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 6C0 937 089 B HW: 6C0 937 089
Component: BCM PQ26 Hi4R H07 0065
Serial number: 001098026006
Coding: 0300084042530AF34B8440004027038800005B0253010000000000000000
ASAM Dataset: EV_BCMA0 004008
ROD: EV_BCMA0_VW26.rod
VCID: 2F6DAD5776F2B6406E-807A
Slave 2:
Subsystem 1 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A
Component: RLHS 037 0059
Serial number: S5Y14M12D31H05M34S43
Coding: 0038DD
Subsystem 2 - Part No SW: 6R0 959 802 AT HW: 6R0 959 802 AT Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU008011550083733
Coding: 1400A0
Subsystem 3 - Part No SW: 6R0 959 801 BB HW: 6R0 959 801 BB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU008011550087031
Coding: 0400A0
Subsystem 5 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8611
Serial number: KU0KU009011550097029
Coding: 1400A0
Subsystem 6 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8611
Serial number: KU0KU015121443490091
Coding: 0400A0
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 16101403272899
Coding: 00000000FE0739
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 387F960B83BC71F83F-806D
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 B HW: 6C0 959 655 B
Component: VW20Airbag011 001 0330
Revision: -------- Serial number: 003LN001DUGL
Coding: 88CCC000000000005C000000008800000000
ROD: EV_AirbaVW20BPAVW26X_SK26.rod
VCID: 326BA42365C09BA801-8067
Subsystem 1 - Part No SW: ----------- HW: 410 822 711 14
Component: SideSensor_Df 151 0800
Serial number: 3575H00AD17ADDA143B4
Subsystem 2 - Part No SW: ----------- HW: 410 822 711 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00AD17ADDA3D2AE
Subsystem 3 - Part No SW: ----------- HW: 442 150 201 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A0099183BFD6F23Z
Subsystem 4 - Part No SW: ----------- HW: 442 150 512 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C11746242C2D7
Part No SW: 6C0 920 740 A HW: 6C0 920 740 A
Component: KOMBI 211 0290
Coding: 272409002580000800882A011000000000000000
ROD: EV_DashBoardVDDMQBAB_VW26.rod
VCID: 204F5E6B3B2C1938E7-8075
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H07 0065
Revision: -------- Serial number: 001098026006
Coding: 030100047F0A560071000000000000010001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_VW26.rod
VCID: 65C10F7F648E3C1054-8030
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 3021417061601717AF1B
Coding: 2C0000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 62005522582821284885
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CECK0078
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_VW26.rod
VCID: 3365A1279ADA92A00A-8066
Part No SW: 6C0 035 869 B HW: 6C0 035 869 B
Component: MU-E--ER 820 6230
Serial number: 13111400010664
Coding: 02620000BE00000041510001000020001F0000960000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001017
ROD: EV_MUEnt4CGen2LGE_SK35.rod
VCID: 2A5BBC434D10D368B9-807F
End-------------------------(Elapsed Time: 02:35)--------------------------
Correllation is other way around. If you have DSG, you have also Hill Hold. Of course, Hill Hold can be active also on cars with manual.DSG is not required for hill hold. Hill hold is a brake system function. Our manual Skoda Yeti 5L and Polo 6C both have hill hold. Both have manual cabled parking brakes.
Please post a full Auto-Scan from at least one of the two cars in question so we can see exactly what HVAC module is installed and how it's configured.
Sunday,17,May,2015,12:11:31:26927
VCDS Version: 15.5.0.0 (x64)
Data version: 20150510
VIN: WVWZZZ6RZFY2xxxxx License Plate:
Mileage: 2009km-1248mi Repair Order:
Scan: 01 03 08 09 10 15 17 19 44 55 5F
VIN: WVWZZZ6RZFY2xxxxx Mileage: 2009km-1248miles
Revision: R4H21---
Coding: 01190032232411080000
Shop #: WSC 00788 648 00255
VCID: 66C5F3BA990EE20F15-8033
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08507548150113
Coding: 23DD4885492833C4091710720057C41292CC90080005CB098F00
VCID: 33635AEE9A5C47A742-8066
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H03 0108
Serial number: 1501221B-0888
Coding: 200000001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26_SE25.rod
VCID: 1D379C560CD8E1D784-8048
Reset counter: 90
Mileage: 1090 km
Date: 2015.04.22
Time: 16:44:50
Serial number: 001098030020
Coding: 03000A4042130A7B0B244080B12F07C800005B0257010000000000000000
VCID: 2F6B569E7674634726-807A
Slave 2:
Subsystem 1 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A
Component: RLS 037 0059
Serial number: S3Y15M01D16H16M13S08
Coding: 0038DD
Subsystem 2 - Part No SW: 6R0 959 802 CE HW: 6R0 959 802 CE Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8620
Serial number: KU0KU006011550066401
Coding: 1400A0
Subsystem 3 - Part No SW: 6R0 959 801 CB HW: 6R0 959 801 CB
Component: J387__TSG_BT 003 8620
Serial number: KU0KU007011550075940
Coding: 0400A0
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143282YJX
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000060858492
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391502009981
Coding: 0031051001
ROD: EV_EPHVA18AU3700000.rod
VCID: 3D777CD6AC1881D7A4-8068
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag010 001 0330
Revision: -------- Serial number: 003LM008E05U
Coding: 88C0C000000000005C000000008800000000
VCID: 316F50E6604075B730-8064
Subsystem 1 - Part No SW: ----------- HW: 410 821 912 14
Serial number: 3575H00C317BDA11B0AV
Subsystem 2 - Part No SW: ----------- HW: 410 820 412 14
Serial number: 3585H00AF16CCCD072A9
Subsystem 3 - Part No SW: ----------- HW: 442 151 801 15
Serial number: 3517A00C1183BFD3832K
Subsystem 4 - Part No SW: ----------- HW: 442 151 001 15
Serial number: 3527A00B3183ADF1613G
Part No SW: 6C0 920 940 A HW: 6C0 920 940 A
Coding: 272401002980260001086A001000000000000000
VCID: 224DAFAA35A6DE2FB9-8077
Revision: -------- Serial number: 001098030020
VCID: 65C7F4B66408E9171C-8030
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Serial number: 0071519274901980AD1B
Coding: 280000
Serial number: 62023A09432821375540
Component: EPS_TRW_ALow 321 3211
Serial number: CF210310
Coding: 0003
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 0D8E000001000000
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75E7A4F6D4A81997AC-8020
Part No SW: 3Q0 035 874 HW: 3Q0 035 874
Component: MU-S-ND-ER H10 0135
Serial number: VWZAZ2R0016690
Coding: 02620001BE00000011111201000808001F0100C601200100C4
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_SK35.rod
VCID: 6FEB969EB6F4234766-803A
Media Player Position 1:
Subsystem 1 - Part No SW: 6C0 919 603 A HW: 6C0 919 603 A
Component: ABTm_Std2_Nav H43 1017
Serial number: VWZ8Z9RH200T8M
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 E HW: -----------
Component: ECE 2015 --- 0335
End-------------------------(Elapsed Time: 02:33)--------------------------
Hmmm.. Can you please go directly to it,
[Select]
[08-HVAC]
[Fault Codes]
I assume at that point, you will see this fault code.
Now uncheck "Use Aggressive Mode". VCDS should repeat the query. I'd like to know if the fault code is still there with "Use Aggressive Mode" unchecked.
Also, if you clear this code, how quickly does it come back, and under what circumstances?
The PQ26 BCM is high on my todo list, the groundwork has been laid but we still need some more reference scans to double check things.
Can you share this with us?I have found how to enable HillHold too.
I don't understand You. I did send You complete Fabia scan month ago with no answer, not even small thanks...
If I use 5Q0-937-08X-HV1.clb with some tweeks in 6C-09.lbl for 6C0-937-090C PQ26 BCM, it works 99% accurate, only the last 12 Bytes, or so, are not included in 5Q0...clb
