Hello all. This is my first post as not yet verified.
I just got and tried the software for the first time. I want to disable the seatbelt warning chimes.
I found this on a post under teaks:
9. Disabling seatbelt reminder chimes.
Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
Check this option
[Do It!]
Ok I followed the directions up to [ Coding-07] then another window opens but shows nothing with [ Long Coding helper]?
It does warn you to copy down all the values as you can make a module non functional if you do the change wrong which I don't want to do.
Can anyone help with the instructions after I click on "Coding-07"?
I wish I had the program to take a snapshot of the window that opens when I click coding but I don't.
[Select]
[17 - Instruments]
[Coding - 07]
Check this option
[Do It!]
