Purchased Q7 at impound auction. Purchased new key based on vin from dealer. Key is not immobilizer adapted. New battery, power seats work. Flasher flash at a high rate when battery is attached, hitting flasher button slows them down but they cannot be turned off. Nothing happens when key is turned.
Ran vcds after battery change, cleared codes, tried to start vehicle, again dead with key turn. Ran VCDS again as follows:
any suggestion as to where to start would be appreciated
Saturday,03,June,2017,17:37:17:43981
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
Mileage: 189640km-117836mi Repair Order: june 3 2017
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
55 56 61 62 65 69 6D 6F 72 77
Mileage: 189640km-117836miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100607161
Coding: 0000131
Shop #: WSC 31414 790 00001
VCID: 6390A7A1775F04CF50B-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Address 07: Control Head
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000000198185
Coding: 0524326
Shop #: WSC 06117 444 53447
VCID: 619CADA96D4316DF427-8034
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0014123
VCID: 313C1DE97D23E65F927-8064
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
Reset counter: 158
Mileage: 189640 km
Date: 2006.11.23
Time: 16:18:00
Address 0E: Media Player 1
Address 0F: Digital Radio
Address 15: Airbags
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054063010194
Coding: 0002042
VCID: 6696BEB5846D71E7B75-8032
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0170
Revision: 00700000 Serial number: 5HH73EYC6
Coding: 2641268
Shop #: WSC 06128 067 57207
VCID: 2310E7A137DF44CF10B-8076
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06B12809F
Coding: E7D7BE77303A02
Shop #: WSC 06117 444 84511
VCID: 6C82CC9D9A814BB7E11-8038
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082946
Address 37: Navigation
Address 46: Central Conv.
Address 47: Sound System
Address 4F: Centr. Electr. II
Address 52: Door Elect, Pass.
Address 55: Headlight Range
Address 56: Radio
Address 61: Battery Regul.
Address 62: Door, Rear Left
Address 65: Tire Pressure
Address 69: Trailer
Address 6D: Trunk Elect.
Address 6F: Centr. Conv. II
Address 72: Door, Rear Right
Address 77: Telephone
End----------(Elapsed Time: 01:19, VBatt start/end: 13.4V/13.4V)-----------
