Hi Im Aaron from UK..
I have 2008 Octavia Mk2 bought with a jamed ignition key.
I changed the barrel and re fitted all the components and trim re conected the battery sanned and cleared the faults , re scanned and this is the result..
I consulted the rosstech wiki and followed the procedures however
Address 44 my vag number is diferent , im thinking when I get to the basic setting 04 and setting group 60 I get "not possible"
http://i8.photobucket.com/albums/a7/baggedonline/DSC_0057_zpsgbsjwixj.jpg
Is this due to the vag numbers being different or am I missing something???
http://i8.photobucket.com/albums/a7/baggedonline/DSC_0056_zps84hb60sd.jpg
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
Saturday,03,June,2017,17:15:55:18685
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: TMBJS21Z182129744 License Plate:
Chassis Type: 1Z (1K0)
VIN: TMBJS21Z182129744 Mileage: 382780km-237848miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 LB HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 9251
Revision: --H07--- Serial number: SKZ7Z0H4730567
Coding: 0000071
Shop #: WSC 73430 790 00000
VCID: 6A8ECB11507B668793D-803E
005746 - Coolant Fan Control 1
P1672 - 000 - Open or Short to Ground
Mileage: 382782 km
Time: 19:11:04
RPM: 798 /min
Voltage: 14.21 V
Bin. Bits: 11000000
Temperature: 74.7°C
Duty Cycle: 9.7 %
001025 - EGR System
P0401 - 000 - Insufficient Flow
Fault Status: 01110000
Mileage: 382782 km
Time: 20:20:17
RPM: 1449 /min
Speed: 12.0 km/h
Load: 16.9 %
Duty Cycle: 14.6 %
Duty Cycle: 100.2 %
Mass Air / Rev.: 225.0 mg/str
Mass Air / Rev.: 510.0 mg/str
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Mileage: 382783 km
Time: 14:12:58
RPM: 882 /min
Voltage: 14.59 V
Bin. Bits: 11000100
Temperature: 15.3°C
Bin. Bits: 10110000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3FD84A457B79332F143-806A
Part No SW: 1Z0 820 047 K HW: 1Z0 820 047 K
Component: Climatic PQ35 140 0909
Revision: 00140009 Serial number: 00000000000000
VCID: 3B203E556F612F0F38B-806E
00003 - Control Module
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
01271 - Positioning Motor for Temperature Flap (V68)
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005435421
Coding: 00880F030004140043110D000000000000087B075C000000000000000000
VCID: 6FB8DA056B9983AFC43-803A
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 060208 022 0601
Coding: 00055223
Shop #: WSC 73430
00985 - Right Tail Light (M2)
Fault Status: 00101100
Reset counter: 97
Mileage: 382782 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.20 V
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1SZULZ
Coding: 0020788
VCID: 3D24304D7175213F06F-8068
Subsystem 1 - Serial number: 6332MSME2B2274504
Subsystem 2 - Serial number: 6342MSME2B22350EB
Part No SW: 1K0 953 549 BM HW: 1K0 953 549 BM
Component: J0527 051 0100
Coding: 0000002
VCID: 7EA6F7413CF3FA275F5-802A
Part No SW: 1Z0 920 902 D HW: 1Z0 920 902 D
Component: KOMBIINSTRUMENT VD1 1620
Revision: V1620056 Serial number: SKZ7Z0H4730567
Coding: 0003401
Shop #: WSC 20022 210 69283
VCID: 3534286D4945F97FCEF-8060
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K081311092
