Octavia Mk2 Steering Assist woes........
Aaron
C?ID=307044
Hi Im Aaron from UK..
I have 2008 Octavia Mk2 bought with a jamed ignition key.
I changed the barrel and re fitted all the components and trim re conected the battery sanned and cleared the faults , re scanned and this is the result..
Saturday,03,June,2017,17:15:55:18685
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: TMBJS21Z182129744   License Plate:
Chassis Type: 1Z (1K0)
VIN: TMBJS21Z182129744   Mileage: 382780km-237848miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000SG  9251
   Revision: --H07---    Serial number: SKZ7Z0H4730567
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 6A8ECB11507B668793D-803E
005746 - Coolant Fan Control 1
               P1672 - 000 - Open or Short to Ground
                    Mileage: 382782 km
                    Time: 19:11:04
                    RPM: 798 /min
                    Voltage: 14.21 V
                    Bin. Bits: 11000000
                    Temperature: 74.7°C
                    Duty Cycle: 9.7 %
001025 - EGR System
               P0401 - 000 - Insufficient Flow
                    Fault Status: 01110000
                    Mileage: 382782 km
                    Time: 20:20:17
                    RPM: 1449 /min
                    Speed: 12.0 km/h
                    Load: 16.9 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 100.2 %
                    Mass Air / Rev.: 225.0 mg/str
                    Mass Air / Rev.: 510.0 mg/str
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 382783 km
                    Time: 14:12:58
                    RPM: 882 /min
                    Voltage: 14.59 V
                    Bin. Bits: 11000100
                    Temperature: 15.3°C
                    Bin. Bits: 10110000
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3FD84A457B79332F143-806A
   Part No SW: 1Z0 820 047 K    HW: 1Z0 820 047 K
   Component: Climatic PQ35   140 0909
   Revision: 00140009    Serial number: 00000000000000
   VCID: 3B203E556F612F0F38B-806E
00003 - Control Module
            000 -  -
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
01271 - Positioning Motor for Temperature Flap (V68)
            000 -  -
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000005435421
   Coding: 00880F030004140043110D000000000000087B075C000000000000000000
   VCID: 6FB8DA056B9983AFC43-803A
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 060208 022  0601
   Coding: 00055223
   Shop #: WSC 73430
00985 - Right Tail Light (M2)
                    Fault Status: 00101100
                    Reset counter: 97
                    Mileage: 382782 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.20 V
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1SZULZ
   Coding: 0020788
   VCID: 3D24304D7175213F06F-8068
   Subsystem 1 - Serial number: 6332MSME2B2274504
   Subsystem 2 - Serial number: 6342MSME2B22350EB
   Part No SW: 1K0 953 549 BM    HW: 1K0 953 549 BM
   Component: J0527           051 0100
   Coding: 0000002
   VCID: 7EA6F7413CF3FA275F5-802A
   Part No SW: 1Z0 920 902 D    HW: 1Z0 920 902 D
   Component: KOMBIINSTRUMENT VD1 1620
   Revision: V1620056    Serial number: SKZ7Z0H4730567
   Coding: 0003401
   Shop #: WSC 20022 210 69283
   VCID: 3534286D4945F97FCEF-8060
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K081311092
I consulted the rosstech wiki and followed the procedures however
Address 44 my vag number is diferent , im thinking when I get to the basic setting 04 and setting group 60 I get "not possible"
http://i8.photobucket.com/albums/a7/baggedonline/DSC_0057_zpsgbsjwixj.jpg
Is this due to the vag numbers being different or am I missing something???
http://i8.photobucket.com/albums/a7/baggedonline/DSC_0056_zps84hb60sd.jpg
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
Uhm, there's a good bit of your Auto-Scan missing. It ends midway through address 19... Can you please post the whole scan?
PS: From your pictures, it seems you have a "Steering angle Sensor -- Defective" fault. "Defective" generally isn't something that can be fixed with a calibration, and would explain the "Not Possible".
Aaron
C?ID=307044
Thanks for your reply @uwe..
Sorry about the short scan I found the rest..
   Coding: E9801F060002022303
   VCID: 34321569423FE077F91-8060
   Component: IMMO            VD1 1620
   Shop #: WSC 58698 001 1048576
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000564
   VCID: 382A21595E570417D59-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.068 H08 1901
   Shop #: WSC 73430 000 90108
   VCID: 36362F615443F267C75-8062
02546 - Steering Limit Stop
                    Mileage: 382760 km
                    Temperature: 36.0°C
                    Voltage: 14.20 V
                    Voltage: 14.00 V
            014 - Defective
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CN
   Coding: 81D002003F098505095B010004CC
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000564
   VCID: 392C245D655D1D1F2A7-806C
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       020 0041
   Revision: 00020000    Serial number: SKZ7Z3H0011032
   Coding: 0000200
   VCID: 2E060701AC13CAA78F5-807A
End----------(Elapsed Time: 00:51, VBatt start/end: 12.3V/12.3V)-----------
Im going to take it all apart again ,maybe somethings not plugged in right..
If its the same result ill be looking at a new angle sensor...
Ashraf6119
C?ID=174194
You need to carry out the Steering Angle Sensor Basic Settings and than take it for a drive by making full lock on lift and full lock on right.........
Aaron
C?ID=307044
Thanks for reply ,
Yes I followed the entire procedure multiple times I suspect the angle sensor is damaged.............
Ashraf6119
C?ID=174194
Did you have to get the steering wheel out for replacing the ignition .......?
Aaron
C?ID=307044
Hi thanks for your input after fitting and messing around with three brand new sensors ive finally got this sorted.
Turns out my angle sensor and two brand new sensors were faulty .
All is now working well thanks again for all your help..
