Audi Q5 2010 Auto gearbox issue
akersgarage
C?ID=179893
hello guys
I have a Audi Q5 giving issue with the auto gearbox, its holding on to 2nd gear when pulling up to junctions then give a surge and selects 1st.
its a 2010 Q5 2.0 TDI common rail
The only fault coming up on VDCS is "gear selector 2 cannot be regulated" 8090 P176B
I have had a look on the net and guys are saying there is a Audi TSH bulletin out reffering to this problem. The TSH is 203221
Can anyone access this bulletin or help in anyway to my above fault
thanks in advance
Actual scan data from the gear box showing the part numbers, the software versions in it, and so on would be very appropriate here.
akersgarage
C?ID=179893
Just to update. The above fault is a known issue with Audi. The cure is a software update on the Auto gearbox control unit.
Just incase anyone else comes across the same fault.
Ive been told in affects other audi models too such as A5
Gone But Not Forgotten
It would be really nice if you posted the scan before the ref flash and after.......... to show the update levels for people if you can.
naushad2982
Kenya
C?ID=58306
can anyone confirm if this issue is only the software update or does it involve replacing the Gear sensor inside the gearbox. from what ive been reading on other forums it isnt very clear. does anyone have a copy of TSB 2032211/1 and can confirm this for me? ive tried looking online but no luck. [FONT=verdana, arial, geneva][/FONT]
How would anyone know without an auto-scan.......?
Take take take no give
