1999 Passat Throttle body adaption
JWheeler
C?ID=223036
I recently purchased this vehicle not running so I don't know the history. I had to replace the alternator and battery. After I did those the car would start but runs really bad if you try and give it gas. I just purchased the hex-net last week to try and fix this thing. Please forgive me if I am not real familiar yet with the vcds operation. I am using the hex net wired to my laptop. Got a code for throttle body malfunction. Figured it was just due to the dead battery. I followed the procedure in the wiki and got an error message when trying to do the adaption. There are two voltage reading in the left two boxes. The first one changes as I press the pedal down to about .5v. The second reading does not change. Are there dual throttle position sensors in the throttle body? Has one of the failed? If not, what are those voltages? I appreciate any help. Here is a scan, did I do that right?
Sunday,10,August,2014,19:44:46:09251
VCDS Version: 14.7.2.0
Data version: 20140714
Mileage: 322620km-200466mi   Repair Order: 1
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
   Mileage: 322620km-200466miles
Address 01: Engine        Labels: 078-907-551-AHA.lbl
   Part No: 4D0 907 551 AH
   Component: 2.8L V6/5V  MOTR AT D04
   Coding: 06151
   Shop #: WSC 05311
   VCID: 6C9403E61EAFD45A4F-4B3C
17953 - Throttle Valve Controller
            P1545 - 35-00 - Malfunction
Readiness: 0110 1101
Address 02: Auto Trans        Labels: None
   VCID: 55E24602AD25759280-4B3C
No Faults Found
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 8E0 614 111 C
   Component: ABS/ASR 5.3 FRONT   D10
   Coding: 00003
   Shop #: WSC 23339
   VCID: 1E70192E9893F6CA91-5184
            08-10 - Control Limit Surpassed - Intermittent
   Part No: 3B1 907 044 B
   Component: CLIMATRONIC     V 1.0.0
   Coding: 05000
   Shop #: WSC 05311
   VCID: 200C27D6A2E7C03AA3-4B5C
7 Faults Found:
00538 - Reference Voltage
00603 - Footwell/defroster Flap Positioning Motor (V85)
            35-10 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
01272 - Positioning Motor for Central Flap (V70)
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 607 B
   Component: AIRBAG VW3 S        V04
   Coding: 00066
   Shop #: WSC 05311
   VCID: 2C14C3E6DE2F145A0F-4B5C
Address 17: Instruments        Labels: 3B0-919-xxx-17.lbl
   Part No: 3B1 919 930 GX
   Component: B5-KOMBIINSTR. VDO V01
   Coding: 06262
   Shop #: WSC 23339
   VCID: 04444B46163F3C1AA7-5184
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 B
   Component: Sitzverstellung FS 0001
   VCID: 2C14C3E6DE2F145A0F-5184
9 Faults Found:
01008 - Note; Emergency OFF Switch is Active!
            06-10 - Signal too High - Intermittent
01328 - Convenience System Data Bus
01329 - Convenience System Data Bus in Emergency Mode
01010 - Sensor for Driver's Seat Recline (G219)
            36-10 - Open Circuit - Intermittent
   Part No: 1J0 959 799 AJ
   Component: 65 Zentral-SG Komf. 0001
   Coding: 04098
   Shop #: WSC 05311
   VCID: 0640514E20030E0AB9-4B3C
   Subsystem 1 - Part No: 1J0959801H
   Component: 6X Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J0959802J
   Component: 65 Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811D
   Component: 65 Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812D
   Component: 65 Tõrsteuerger. HR0002r
12 Faults Found:
            35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
            35-00 - -
End-------------------------(Elapsed Time: 07:11)--------------------------
JWheeler
C?ID=223036
here is that error message with the voltages. The 3.84 stays steady with throttle input.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Clean the T/B and retry adapt.
"Are there dual throttle position sensors?" not sure on a cable driven T/B There are for sure on Drive by wire T/B
First thing clean the T/B. Second would be load test all 6 wires back to the ECU.
Good luck
I'm pretty sure there's some redundancy in the sensor assembly even on the older TBs, which didn't have "full authority" but still used a motor that moved the throttle plate to control idle speed.
What happens when you clear the fault? How quickly does it come back? A pre-condition for doing a throttle body basic setting is: No fault codes.
JWheeler
C?ID=223036
Thanks for the reply. I will get it cleaned out tonight and see if there is a change.
JWheeler
C?ID=223036
I cleared the fault, cycled the key off then on and tried to perform the setting. The fault does not return until after you start the engine again. It doesn't pop right back after you clear it.
Gone But Not Forgotten
STOP!
Take TV off and clean + lube the unit with light lube such as WD40.
Make sure the TV butterfly can move back at least 5mm before it moves forward.
If it can't due to carbon, the unit will never adapt correctly to start its baseline.
This is in addition to what StanLee Marvel Comics said ( VWtech )
JWheeler
C?ID=223036
Will do. Thanks Jack.
You may even want to run an additional ground strap to this unit being it is bolted to a plastic intake.
These TV units hardly ever fail..........unless like over 300K which you fall into that category however I have seen them keep going after a good cleaning.
JWheeler
C?ID=223036
Got the tb cleaned out last night and was able to do the adaption with my iPad. It passed. Fist time I used the cloud functions. I used my laptop last time. It worked great. Kept loosing connection though. Need to get better wifi in the garage. Thanks for the help guys. Didn't think it was going to be that simple.
