ECM replacement question
jimbo_sl1ce
C?ID=165681
Have a customer with an audi A8 that has a bad ecm. Below is a vag log from before the module went haywire.
His question is can a used ecm be installed in the vehicle. My question is what sort of programming will be needed to work. Thanks in advance!
Friday,17,March,2017,15:26:45:05056
VCDS Version: 17.1.3.0 (x64)
VIN: WAUMV44E47N020729   License Plate:
Mileage: 125250km-77826mi   Repair Order: sv09930cosgrove
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 1E 28 34 36 37 38 42
          46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV44E47N020729   Mileage: 125250km-77826miles
38-Roof Electronics -- Status: OK 0000
Address 01: Engine        Labels: 079-907-560-BVJ.clb
   Part No SW: 4E1 910 560 A    HW: 4E1 907 560
   Component: 4.2l V8/4V          0050
   Revision: 71H22---    Serial number: AUX3Z0G2720519
   Coding: 01060009190F0120
   Shop #: WSC 22189 444 12575
   VCID: 204F1AC7F3D02341C9-8074
005137 - Secondary Air Injection System; Bank 2
               P1411 - 002 - Insufficient Flow - MIL ON
                    Fault Status: 11100010
                    Mileage: 120117 km
                    Date: 2016.11.08
                    Time: 14:45:05
                    RPM: 1123 /min
                    Load: 29.0 %
                    Temperature: 27.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.335 V
004964 - Cylinder 4 Ignition Circuit
               P1364 - 004 - Open Circuit - Intermittent
                    Mileage: 120117 km
                    Date: 2016.11.08
                    Time: 14:45:05
               P0300 - 001 -  - Intermittent - MIL ON
                    Fault Status: 10100001
                    Fault Frequency: 11
                    Mileage: 124497 km
                    Date: 2017.03.01
                    Time: 22:20:27
                    RPM: 1385 /min
                    Load: 61.9 %
                    Speed: 58.0 km/h
                    Temperature: 99.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.224 V
000772 - Cylinder 4
               P0304 - 001 - Misfire Detected - Intermittent - MIL ON
                    Fault Frequency: 11
                    Mileage: 124497 km
                    Date: 2017.03.01
                    Time: 22:20:27
   Part No SW: 4E1 910 156 C    HW: 09L 927 156 A
   Component: AG6 09L 4,2lFSI USA 0030
   Revision: --H01---    Serial number:        4313649
   Coding: 0000002
   Shop #: WSC 02313 758 00200
   VCID: 234515CBE2C63859D4-8076
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0007597
   Shop #: WSC 02313 000 00000
   VCID: 224B10CFFDDC3151DF-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 L
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0G2720519
   Coding: 0410624
   Shop #: WSC 02311 785 00200
   VCID: 58BF7227EB00AB81F1-800C
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4071648
   Shop #: WSC 02313 785 00200
   VCID: 244716D7E7C83F61AD-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 731 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 3360
   Revision: 00000000    Serial number: 348CQ077522562
   Coding: 0000003
   VCID: 2E53F4FFB90485314B-807A
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0040
   Subsystem 2 - Serial number: 00000000035903
   Subsystem 3 - Serial number: 0114.04.070000000100010021ÿ
   Subsystem 4 - Serial number: 010021ÿ
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 H
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000118912
   Coding: 0102865
   VCID: 1C372E37DFB807A115-8048
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO12042007065A000000000115ÿ†89
   Subsystem 5 - Serial number: 000115ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO11042007065A00000000
   Subsystem 7 - Serial number: 65A000000000042ÿ
00065 - Rear Left Footwell Heater (Z42)
                    Fault Status: 00101100
                    Reset counter: 213
                    Mileage: 113955 km
                    Date: 2015.11.09
                    Time: 10:55:50
                    Voltage: 13.60 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 Q    HW: 4E1 955 113 C
   Component: ILM Fahrer      H15 0230
   Coding: 0143123
   VCID: 3663DC9F4154BDF103-8062
   Subsystem 1 - Part No: 4E1 910 113 C
   Component: Wischer WWS D3  H60 0420
   Coding: 00000036
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00139548
   Shop #: WSC 02313
Address 0E: Media Player 1 (R192)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785     HW: 4E0 035 785
   Component: SG ext.Player H09 0170
   Revision: 00000000
   VCID: 65C14BD36C7206697A-8030
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 C    HW: 4E0 959 655 J
   Component:    Airbag 9.41  H14 4230
   Revision: 91H14423    Serial number: 0037Q0G02SNJ
   Coding: 0532707
   VCID: 26430CDF91F4CD71B3-8072
   Subsystem 1 - Part No: 4E0 910 339
   Component: BF-Gewichtsens. H01 0030
   Subsystem 2 - Serial number: 3LHKS
   Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†63328RB402496E4CTÿ†63
   Subsystem 5 - Serial number: 96E4CTÿ†63428RB402496E23Jÿ†63
   Subsystem 6 - Serial number: 96E23Jÿ†63528RB402496E75Rÿ†63
   Subsystem 7 - Serial number: 96E75Rÿ†63628RB402496ECC/ÿ†63
   Subsystem 8 - Serial number: 96ECC/ÿ†63729RB403A5BEF97ÿ†63
   Subsystem 9 - Serial number: 5BEF97ÿ†63829RB40130871DHÿ
   Subsystem 10 - Serial number: 0871DHÿ
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0012141
   VCID: 65C14BD3AC7206697A-8030
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 C    HW: 4E0 920 951 C
   Component: KOMBIINSTR. VDO H82 0530
   Revision: D05         Serial number: AUDID3G3003445
   Coding: 0048263
   Shop #: WSC 46281 000 1048576
   VCID: 25410BD3ECF2C669BA-8070
Address 19: CAN Gateway        Labels: 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B07330814E
   Coding: F5F5DF7F70720E
   VCID: 6CD73EF74F98372125-8038
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H44 0350
   Revision: 00044000    Serial number: AUZ5ZBG3210165
   VCID: 183F32272B806B8131-804C
   Part No SW: 4E0 910 158     HW: 4E0 919 158 D
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000019    Serial number: 00000000053460
   Coding: 0000000
   VCID: 61C95FC3B85A6A4986-8034
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015510
   VCID: 2A5BF8EF85ECE91197-807E
   Component: Sitzmemory FS  H02  0010
   Coding: 4071658
   Part No SW: 4E0 910 888 D    HW: 4E0 919 887 M
   Component: MNS US          H49 0970
   Revision: 00000000    Serial number: 381DR077521746
   Shop #: WSC 25166 444 84618
   VCID: 2F6DE9FBBE0E8C3940-807A
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H05 0090
   Serial number: 00000706400115
   Coding: 0003479
   VCID: 1D312333C4A20EA9E2-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 D
   Component: Türsteuer.FS BRM005 0180
   Coding: 0032364
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 C    HW: 4E0 907 289 C
   Component: Komfortgeraet   H09 0020
   Revision: 00200009    Serial number:  W040704160089
   Coding: 0048702
   VCID: 295907E380EAE2099E-807C
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P14H06 0070
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 Q    HW: 4E0 035 223 G
   Component: DSP-High D3     H03 0110
   Revision: PROD_01     Serial number: 00000000007182
   Coding: 0000026
   VCID: 2B55FDEB8A16F0196C-807E
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000111949
   Coding: 0010111
   VCID: 1E33243FC9A415B1FB-804A
02258 - Door Opener Transmitter
                    Reset counter: 178
                    Mileage: 120012 km
                    Date: 2016.10.25
                    Time: 14:29:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 D
   Component: Türsteuer.BF BRM005 0180
   Coding: 0032364
02129 - Automatic Day/Night Exterior Mirror
                    Fault Status: 00100111
                    Reset counter: 198
                    Mileage: 123952 km
                    Date: 2017.02.21
                    Time: 08:44:50
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0000922
   Shop #: WSC 41349 001 1048576
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000018
   Shop #: WSC 26105 444 68460
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 396D3077569837
   Coding: 0000002
                    Reset counter: 218
                    Mileage: 121494 km
                    Date: 2016.12.26
                    Time: 00:00:26
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000003424
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  1234567890
   Coding: 344530393135313035412056413031323334353637383930
02272 - Quiescent Current Stage 1
            000 -  -  - Intermittent
                    Fault Frequency: 35
                    Mileage: 116544 km
                    Date: 2016.02.20
                    Time: 14:19:19
02273 - Quiescent Current Stage 2
                    Fault Frequency: 35
                    Mileage: 116544 km
                    Date: 2016.02.20
                    Time: 14:19:19
02276 - Quiescent Current Stage 5
                    Fault Frequency: 15
                    Mileage: 116544 km
                    Date: 2016.02.20
                    Time: 14:40:37
02277 - Quiescent Current Stage 6
                    Fault Frequency: 15
                    Mileage: 116544 km
                    Date: 2016.02.20
                    Time: 14:40:37
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0032364
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000900051014
   Coding: 0202125
01477 - System Switched Off
            000 -  -
                    Fault Frequency: 253
                    Reset counter: 178
                    Mileage: 120033 km
                    Date: 2016.11.02
                    Time: 13:14:25
                    (no units): 0.0
                    Temperature: 25.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000703300297
   Shop #: WSC 12336 024 394758
   VCID: 3467E6975728AFE13D-8060
Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J7310N2
   Coding: 1120503
   VCID: 5CB76E379F3847A1D5-8008
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0032364
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720710601438
   Coding: 0221208
02069 - Front Parking Aid Sensors
                    Reset counter: 241
                    Mileage: 119972 km
                    Date: 2016.10.12
                    Time: 11:12:00
   Part No SW: 4F0 910 336 D    HW: 4E0 862 335
   Component: Handyvorb2      H00 0700
   Coding: 0000000
            000 -  -
                    Reset counter: 4
                    Mileage: 111187 km
                    Date: 2015.06.15
                    Time: 16:30:08
End-------------------------(Elapsed Time: 03:35)--------------------------
and here is the new scan after ecm failure...
Thursday,25,May,2017,16:10:44:05056
VIN: WAUMV44E47N020729   Mileage: 126370km-78522miles
01-Engine -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
   VCID: 55A17B13BC1296E9EA-FFFE
No Faults Found
   Coding: 0000002
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
               U0100 - 000 -
                    Fault Frequency: 25
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 14:56:37
                    RPM: 640 /min
                    RPM: 640 /min
                    (no units): 31.0
                    (no units): 24.0
                    Temperature: 49.0°C
                    T.B. Angle: 60.0°
006273 - Powertrain Data Bus: Missing Message
               P1881 - 000 - Acceleration Request
                    Fault Frequency: 25
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 14:56:37
006231 - Load Signal
               P1857 - 001 - Error Message from ECU
                    Fault Status: 01110001
                    Mileage: 126373 km
                    Date: 2017.05.16
                    Time: 14:35:53
001556 - Transmission Control Module
               P0614 - 000 - Incorrect Software Version
                    Mileage: 126373 km
                    Date: 2017.05.16
                    Time: 14:35:53
   Coding: 0007597
02083 - Message for Delay Request
   Coding: 0410624
                    Fault Frequency: 0
                    Reset counter: 238
                    Mileage: 126368 km
                    Date: 2017.05.19
                    Time: 00:30:18
                    Fault Frequency: 0
                    Reset counter: 238
                    Mileage: 126368 km
                    Date: 2017.05.19
                    Time: 00:30:18
   Coding: 4071648
   Coding: 0000003
   Coding: 0102865
00066 - Rear Right Footwell Heater (Z43)
                    Fault Frequency: 9
                    Reset counter: 22
                    Mileage: 125297 km
                    Date: 2017.03.26
                    Time: 19:25:51
                    Voltage: 13.90 V
                    Fault Frequency: 9
                    Reset counter: 22
                    Mileage: 125297 km
                    Date: 2017.03.26
                    Time: 19:25:51
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 238
                    Mileage: 126373 km
                    Date: 2017.05.19
                    Time: 14:41:26
                    Temperature: 34.0°C
            014 - Defective
                    Reset counter: 238
                    Mileage: 126373 km
                    Date: 2017.05.19
                    Time: 14:41:26
   Coding: 0143123
   Coding: 00000036
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
00908 - Control Module for Wiper Motor
                    Reset counter: 23
   Revision: 00000000
   Coding: 0532707
   Coding: 0012141
   Coding: 0048263
                    Reset counter: 238
                    Mileage: 126374 km
                    Date: 2017.05.25
                    Time: 00:33:45
   Coding: 0000000
   Coding: 0015510
                    Fault Status: 11100100
                    Fault Frequency: 58
                    Reset counter: 238
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 15:03:33
01598 - Drive Battery Voltage
                    Fault Frequency: 58
                    Reset counter: 238
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 15:03:33
   Coding: 4071658
   Coding: 0003479
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
                    Reset counter: 22
                    Mileage: 126372 km
                    Date: 2017.05.19
                    Time: 12:30:00
                    Reset counter: 22
                    Mileage: 126372 km
                    Date: 2017.05.19
                    Time: 12:30:00
   Coding: 0032364
   Coding: 0048702
                    Fault Frequency: 31
                    Reset counter: 22
                    Mileage: 126371 km
                    Date: 2017.05.16
                    Time: 14:30:55
                    Fault Frequency: 31
                    Reset counter: 22
                    Mileage: 126371 km
                    Date: 2017.05.16
                    Time: 14:30:55
   Coding: 0000026
   Coding: 0010111
                    Fault Frequency: 158
                    Reset counter: 238
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 14:56:00
                    Reset counter: 238
                    Mileage: 120012 km
                    Date: 2016.10.25
                    Time: 14:29:00
   Coding: 0032364
   Revision: --H03---
   Coding: 0000922
                    Fault Frequency: 168
                    Reset counter: 238
                    Mileage: 125760 km
                    Date: 2017.04.19
                    Time: 14:56:38
                    Voltage: 13.04 V
                    Count: 241
   Coding: 0000018
                    Fault Frequency: 166
                    Reset counter: 238
                    Mileage: 125768 km
                    Date: 2017.04.19
                    Time: 14:56:38
   Coding: 0000002
                    Reset counter: 22
                    Mileage: 126373 km
                    Date: 2017.05.19
                    Time: 12:30:24
02274 - Quiescent Current Stage 3
                    Fault Frequency: 11
                    Mileage: 126373 km
                    Date: 2017.05.19
                    Time: 11:55:31
                    Fault Frequency: 11
                    Mileage: 126373 km
                    Date: 2017.05.19
                    Time: 11:55:31
02252 - Generator
                    Reset counter: 248
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 14:56:49
02252 - Generator
                    Reset counter: 248
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 14:56:49
                    Fault Frequency: 30
                    Reset counter: 238
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 14:56:37
Address 62: Door, Rear Left        Labels: None
   VCID: 55A17B13BC1296E9EA-8000
No Faults Found
   Coding: 0202125
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 71
                    Reset counter: 238
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 14:56:47
                    (no units): 0.0
                    Voltage: 0.00 V
                    (no units): 27.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
            000 -  -
                    Fault Frequency: 71
                    Reset counter: 238
                    Mileage: 125764 km
                    Date: 2017.04.19
                    Time: 14:56:47
   Coding: 1120503
   Coding: 0032364
   Coding: 0221208
                    Reset counter: 241
                    Mileage: 119972 km
                    Date: 2016.10.12
                    Time: 11:12:00
   Coding: 0000000
            000 -  -
                    Reset counter: 4
                    Mileage: 111187 km
                    Date: 2015.06.15
                    Time: 16:30:08
End-------------------------(Elapsed Time: 04:29)--------------------------
It should be possible to install and match used ECM to that car, VCDS is not going to do it. The 4E chassis A8 was the first model that used true Immo-4 stuff with challenge/responses, which require an on-line connection to the corporate mothership instead of more straightforward PIN codes. Alternatively, someone might be able to do an identity transfer for you.
jimbo_sl1ce
C?ID=165681
Update, customer decided to go with a reman unit directly from AUDI. Came from germany 7 working days to arrive. Dealer tool programmed for $130.00. Thank you for your help guys.
NostraJackAss
When we sell an ECU we include programming & or data transfer, further no dealer trip is needed..........or additional cost!
I'm glad it worked out for you...........
