- Aug 5, 2014
- 12
- 0
- C?ID=221718
Well i have had me Audi for about 8 months and when i bough it from the guy i wasn't driving in (D) i had to drive it in sport mode are switch it over into (D) when i get up to like 5MPH and then it drives perfects and the transmission is perfectly sound never any codes and slippage..i though it was the TCM & ECU so i bought new ones well used ones matching model numbers and i used my Vac com to re-code both of them still nothing so i changed (VSS) Vehicle speed sensor and the speed sensor (SS) and dash cluster and new spark plugs and valve cover gasket needed it and also changed the ABS module because im still getting the 18057 Powertrain Data bus missing from the ABS controller and 18258 Powertrain Data bus missing messagefrom ECU and 18034 Powertrain Data Bus missing message from TCU ???? Any ideas anyone
Tuesday,05,August,2014,05:36:44:29655
VCDS Version: 14.7.2.0 (x64)
Data version: 20140714
Dealer/Shop Name:
Mileage: 156129 Repair Order:
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-ATQ.lbl
Part No: 3B0 907 551 BQ
Component: 2.8L V6/5V G 0001
Coding: 07751
Shop #: WSC 02135
VCID: 73EBD75041C6FFA28E-515A
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 AT
Component: AG5 01V 2.8l5V USA 3132
Coding: 01102
Shop #: WSC 05311
VCID: 7F030B607D8EABC2FA-515A
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00031
Shop #: WSC 05314
VCID: 53AB77D0A1869FA26E-515A
30-00 - Open or Short to Plus
18258 - Powertrain Data Bus
P1850 - 35-00 - Missing Message from ECU
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 06435
VCID: 2D5F0128E762E95218-25AA
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 63351
VCID: 3A753A74262C4EEA8D-5196
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 CX
Component: B5-KOMBIINSTR. VDO D13
Coding: 02262
Shop #: WSC 00001
VCID: 030B87901166CF229E-515A
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D10
Coding: 00008
Shop #: WSC 40201
VCID: 4081489C40F0143AC3-4F1E
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
VCID: 60C1A81CE030743AE3-4B7C
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00004
Shop #: WSC 63351
VCID: 65CFB908FF12111210-51D0
35-00 - -
00776 - Level Control System Sensor; Left Front (G78)
31-00 - Open or Short to Ground
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 63351
VCID: 2449E40CB4A8281AC7-4B32
00-00 - -
End-------------------------(Elapsed Time: 03:30)--------------------------
