05 b3 bhw trans issues
ivagp
C?ID=95551
05 b5.5 bhw trans issues
hi guys wanting to do some tests before removing pan, keep getting limp mode right away. sets codes 17114,17116,17117 on the very first time it tries to shift thru the gears. the fluid is not burnt and the level is full. i disconnected the trans plug per manual, i dont know what its saying to shift manually to check for slippage, dose that mean if i select 2nd that the trans will start in 2nd because all it does is stay in 4th no matter what i select. here is the scan the battery is ok i just left tyhe key on too long. and the other codes are because i disconnected the connector also the code in the abs is because of disconnected the trans connector.
          Friday,19,May,2017,19:46:03:49874
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
VIN: WVWME63B05P025840   License Plate:
Mileage: 159380km-99034mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWME63B05P025840   Mileage: 159380km-99034miles
Address 01: Engine        Labels: 038-906-016-BHW.lbl
   Part No SW: 038 997 016 T    HW: 028 101 198 2
   Component: R4 2,0L EDC G000AG  0314
   Revision: 12345678    Serial number: VWZ7Z0D0307775
   Coding: 0150034
   Shop #: WSC 22147 444 109240
   VCID: 2F66ED77BDDF9E394A-5120
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 3B0 927 156 CF
   Component: AG5 01V 2.0lPD  USA 0404
   Coding: 0001104
   Shop #: WSC 00028 028 00001
   VCID: 6CDC3A7B4C4925212F-5120
17116 - Gear 2
            P0732 - 003 - Incorrect Ratio
18155 - Transmission Solenoid Power Relay
            P1747 - 003 - Open or Short to Ground
17094 - Transmission Fluid Temp Sensor (G93)
            P0710 - 003 - Malfunction
18158 - Supply Voltage
            P1750 - 003 - too Low
17090 - Transmission Range Sensor (F125)
            P0706 - 003 - Implausible Signal
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 04257
   Shop #: WSC 00028
   VCID: 254A0F5FBF23D469B0-5120
01119 - Gear Recognition Signal
            35-00 -  -
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 00028
   VCID: 244C125BB4192D61A7-5102
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 929 C
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 15235
   VCID: 27560557C52FC67982-5102
   WVWME63B05P025840     VWZ7Z0D0307775
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70E42E0B3061C1C113-5102
            49-00 - No Communications
   Part No: 1C0 959 799 C
   Component: 08 Komfortgerát HLO 0004
   Coding: 00258
   Shop #: WSC 00028
   VCID: 3776D517158F56F912-4AE6
   Subsystem 1 - Part No: Steuerger
   Component: t Fahr. antwortet nicht
   Subsystem 2 - Part No: 1C1959802
   Component: 08 Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 08 Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 08 Tõrsteuer.HR KLO 0202
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 F
   Component:    Radio PM6        0016
   Coding: 00401
   Shop #: WSC 00028
   VCID: 234E1147B1172A59DE-5102
End-------------------------(Elapsed Time: 04:42)--------------------------
ivagp
C?ID=95551
game over found aluminum pieces in the pan. code is gmr if anyone has a cool story:popcorn: let me know.
