2009 VW Crafter DPF Regen Issue
Chr15
C?ID=207693
Hi All
Could anyone assist with this one.
Ive got a 2009 Vw Crafter that im unable to carry out dpf regeneration, the adaptation and basic settings options show no documentation available and also coding II and securtiy access doesn't give the assist bubbles to help activate regeneration.
Ive checked the ross tech wiki and thats doesnt have informatrion needed either.
Vehicle has recently had a replacement dpf, not by myself and i dont believe the values were reset so already showing blocked. No other faults with vehicle to of caused it to block up so early that im aware of.
Thanks Chris
Tuesday,16,May,2017,12:09:34:26527
VCDS Version: 17.1.3.0 (x64)
VIN: WV1ZZZ2FZA7001509   License Plate: PK59 RNF
Chassis Type: 2F (2F - VW Crafter (LT3 / 2006 >))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (CEB)       Labels: Redir Fail!
   Part No SW: 076 906 022 N    HW: 076 906 022 G
   Component: R5 2,5L EDC A020SG  7731
   Revision: 24H30---    Serial number: VWXDZ0I1012280
   Coding: 0003032
   Shop #: WSC 00011 888 06946
   VCID: 1E33DA5ECAD04AB1FB-5122
009315 - Diesel Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
                    Fault Status: 11100000
                    RPM: 735 /min
                    Pressure: 82 mbar
                    Hex Value: 0xFF00
                    Temperature: 108.0°C
                    (no units): 51.0
Readiness: 0 2 0 0 1
Address 91: LT3 Engine        Labels: Redir Fail!
   Coding: 0003032
   VCID: 1E33DA5EC9D04AB1FB-804A
                    RPM: 735 /min
                    Pressure: 82 mbar
                    Hex Value: 0xFF00
                    (no units): 51.0
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
   Component: IMMO          0805  0815
   Revision: 00805000    Serial number: VWXDZ0I1012280
   VCID: 6DD1CD9274F6612932-8038
Address 94: LT3 Airbag
   Part No HW: 9064461442
   Shop #: WSC 00118 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3332.rod (*)
   VCID: 55A185723466C9E9EA-8000
Address 95: LT3 ESP
   Part No SW: 9064482453    HW: 0004460153
   ASAM Dataset: 3 4101
   ROD: CRFT_ESP_3_4101.rod (*)
   VCID: 0D11AD12DC36C12992-8058
Address 96: LT3 Instruments
   Part No SW: 9064482221    HW: 0034468021
   ASAM Dataset: 32 777
   ROD: CRFT_KOMBI_32_777.rod
   VCID: 0603923EB940B271D3-8052
Address 99: LT3 Ign. Switch
   Part No HW: 9065455808
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  0815
   Revision: 00805000    Serial number: 12345678901234
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
   Part No SW: 9064480323    HW: 9068203601
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 071D9F3ABE4AAB79A8-8052
Address B1: LT3 Upper Console
   Part No HW: 9065453907
   ASAM Dataset: 67 3
   ROD: CRFT1_OBF_67_3.rod (*)
Address B4: LT3 Central Elec.
   Part No SW: 9064420700    HW: 9065453601
   ASAM Dataset: 33 260
   ROD: CRFT_EZE_33_260.rod (*)
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
End-------------------------(Elapsed Time: 03:42)--------------------------
billywhizz
C?ID=278038
can you check and publish the readings for the ash/oil also ,soot measured and soot calculated, once we can see those then we can determine if its possible too do a regen.
What do you have in MVBs 107 and 108?
Also take a look at Adaptation Channel 016, particularly the associated measuring values. I think that's where the ash volume is reset, by storing a 1, which has to be done with the engine running at least 1300 RPM.
Chr15
C?ID=207693
Tuesday,16,May,2017,18:18:15:26527
VCDS Version: 17.4.2.3 (x64)
Data version: 20170505 DS270.4
VIN:    License Plate: PK59 RNF
                Address 91: LT3 Engine  (076 906 022 N)
18:17:50 Group 107
  50.4
  45.6
  27.6
18:17:50 Group 108
  0 ml  milliliters
  0.0
  34.8
Chr15
C?ID=207693
Have updated with MVB's 107 + 108.
Also checked channel 16 and yes it looks to those associated MVB's but didnt want to just reset yet until was more confident as there is no text or info displayed just the numerical values.
Chr15
C?ID=207693
Tuesday,16,May,2017,18:25:48:26527
Long Adaptation Channel 016:
Stored value 0
  0 ml  milliliters
  0.0
  22.8
  0 km  Mileage
Lightboy
C?ID=382313
Hi Chris15
Wondering if you or anyone cpould help me with MVB 107, 108 and 016 as you suggested above .
This is what i got.
15:19:23 Group 107
48.0
45.6
26.4
15:19:23 Group 108
78 ml milliliters
34.8
40.8
15:19:23 Group 016
20.5 % Lambda
00000000 Bin. Bits
0.0 (no units)
14.21 V Voltage
Does this suggest i have a blocked DPF ?
