hello people forum newbie and total vcds novice so please be gentle with me
ok after shelling out £300 quid for this great piece of diagnostic pc technology i am pretty much clueless how to use it apart from doing a needle sweep & alarm chirp mods with instructions on my wifes audi which i managed to do with step by step guide worked a treat
i have just purchased a 2010 audi a4 b8 s-line avant special edition 2.0 143 6 speed manual damaged to drivers front corner mainly suspension damage.
after replacing the front sub-frame,suspension leg,driveshaft,anti-roll bar and power steering rack all good used replacement parts i have the scan of my problems below which will not delete from the vcds.....there was no airbag damage i have simply removed and replaced all these bolt on parts from underneath the car not touched steering inside the car but have undone the steering knuckle to replace the rack so possibly this may be my problem i think
i have the yellow dash light squiggle and bleeping esp fault on display
could anyone please help me resolve the problems.......does a used power steering rack need re-coding or sommat ?
i look forward to hearing from anybody who might be able to help me many thanks in advance daz
scan details below :
Tuesday,05,August,2014,14:47:03:64312
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ8K4AA132341 License Plate: MJ10KCE
Mileage: 94320km-58607mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
VIN: WAUZZZ8K4AA132341 Mileage: 94320km/58607miles
Address 01: Engine (J623-CAGA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
Component: R4 2,0L EDC H22 9096
Revision: 25H22---
Coding: 12194012232503080000
Shop #: WSC 00561 210 181929
ASAM Dataset: EV_ECM20TDI03L906022NN A02011
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7EF9F619E10C4DEEE9B-802B
U1113 00 [039] - -
Mileage: 94320 km
Date: 2014.08.05
Time: 14:29:19
U1113 00 [039] - -
Mileage: 94320 km
Date: 2014.08.05
Time: 14:29:19
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BB HW: 8K0 907 379 BB
Component: ESP8 front H04 0020
Coding: 160504
Shop #: WSC 06335 000 00000
VCID: 7AF1FA09F52461CED53-802F
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0327
Coding: 033200
VCID: 81030DE518F2B216149-80D4
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01110220100714
Coding: 34240000
VCID: 76E9EE39C13C05AEB1B-8023
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000458608
Coding: 260050914034AF010001000000001D0D001D070806010141000000
VCID: 3A713A09B5A4A1CE953-806F
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 090210 H05 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 218
Mileage: 94320 km
Date: 2014.08.05
Time: 14:33:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51241004406567
Coding: 000003
VCID: 479753FDF656CC261AD-8012
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD0BYA2G
Coding: 30363435363030303030554A3052384B3053
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 41834DE5D072F216D49-8014
Serial number: 6334MSME4F213A55I
Serial number: 6344MSME4F206678M
Serial number: 6352QSME7C4D1E3E2
Serial number: 6362QSME0150481C9
Serial number: 63732SME464B49341
Crash sensor for front airbag; passenger side:
Serial number: 63832SME314E2216X
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JB8000DE
Coding: 000017
VCID: 3D7B3115A48A96F6B01-8068
Component: E221 - MFL H02 0010
014 - Defective
Fault Status: 01101110
Reset counter: 218
Mileage: 94320 km
Date: 2014.08.05
Time: 14:38:31
(no units): 44.0
Text: 2CFFFFFF91FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFFC0FFFFFFFF
Fuel Consump.: 650.3 l/100
Raw, Index/Key Err.: 255 255 000
Text: 35FFFFFF9A00004A1FFFFFFFFC1FFFFFFFFF
Angle: 0°
Time (Months): 781
(no units): 11.75
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 N HW: 8K0 920 980 N
Component: KOMBIINSTR. H20 0255
Revision: 00300000 Serial number: CIZ31982A
Coding: 2F04100002002600010000
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G102028263
Coding: 00CF07
VCID: 50A578A103180B9E4B7-8005
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0125
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H04 0003
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000102812005
Coding: 011002204001410001
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0126712806
Coding: 013B0622203904400020023680000000
Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
Component: DSP Prem H19 0320
Revision: 00019001 Serial number: 34835000614202
Coding: 0203010302
VCID: 7EF9F619E90C4DEEE9B-802B
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
Component: TSG BF H11 0306
Revision: Serial number: 0000102846316
VCID: 46895EF9F15CD52EE1B-8013
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000430770
VCID: 346D143197C057BE4FF-8061
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 A
Component: Dynamische LWR H01 0010
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 387520014BA8B3DE637-806D
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 Q HW: 8T2 035 186 Q
Component: Concert3 DAB H07 0350
Revision: 00000009 Serial number: AUZ5Z6J1349436
Coding: 0503008201028D00035B070000
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102854147
Coding: 010002204001210001
VCID: 428142E9DD74E90ECD3-8017
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102854150
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005159688
Coding: 0010320
VCID: 3B7F3F0D7A9E98C68E5-806E
End
