Disable TCS/ESP on 2017 Passat NMS
yogibearal
C?ID=292451
Bought the Passat last November and got caught in slippery snow storm over the winter. I believe I could have gotten through this with TCS/ESP off button, like I did on my previous Audi A6. So I looked into adding a TCS/ESP defeat button connected to the ABS module. I've since connected everything and verified that ABS module is getting the 12V+ pulse but TCS/ESP does not seem to be turned off when clicking the button either momentarily or after a long press. From what I can gather it will likely require an update to the long coding for the ABS module.
I've read that 2012-2013 Passat have the following changes to get TCS/ESP defeat. - For some folks it just worked without coding, but for 2014+ required coding.
MY12 - C54BC0F549288002A31203EB921E0142A61000 - 19 byte - Trying this with VCDS returned values out of range.
MY14 - C54BC0F549280001A30F03E692190042A1180022 - 20 byte - Have not tried this, because the bytes on my coding is not like on this users original values.
However those are from vehicles prior to automatic braking and ACC (Active Cruise Control)
MY17 - C54BC0F549230000A30C03EB921E004100F1F01A - 20 byte This is my default ABS module Long Code,
Note: This is a 2017 NMS Passat SEL Premium which has the auto braking, auto cruise control, park assist etc....
Ideally we can find a vehicle with similar equipment and ABS module with ACC/automatic braking that also has the ESP defeat button, to see their coding. Maybe a vehicle from a different market?
ABS Module Component ESP MK6EC1
ABS Module information:
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F549230000A30C03EB921E004100F1F01A
   Shop #: WSC 09003 957 00200
   VCID: 75A22D83DC6DBDEAEA-8020
Full Scan Report
Saturday,24,December,2016,11:51:16:44171
VCDS Version: 16.8.4.2 (x64)  HEX-NET CB: 0.4323.4
VIN: 1VWCT7A37HC016175   License Plate:
Mileage: 900km-559mi   Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 36 3C 42 44 46 47
          4F 52 5F 61 62 72 75 A5
VIN: 1VWCT7A37HC016175   Mileage: 900km-559miles
Address 01: Engine (J623-CPRA)       Labels: None
   Part No SW: 06K 906 071 BJ    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 3685
   Revision: --H13---
   Coding: 001A0092244400179000
   ASAM Dataset: EV_ECM18TFS02006K906071BJ 001006
   ROD: N/A
   VCID: 74A41087DF17A4E2DD-8020
No ASAM data for: "EV_ECM18TFS02006K906071BJ" (VW41)
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 BD    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3121
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_VW31.rod
   VCID: 76A02A8FC96BB6F2E3-8022
   Revision: 00H46001
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1305
   Revision: 00093000    Serial number: 0410221359
   Coding: 132C0C
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 3A38FEBFBDF31292C7-806E
   Slave 1:
   Serial number: 93845109
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0050019012
   VCID: 5AF85E3F5DB3F292E7-800E
   Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
   Component: BCM PQ35 H++  122 0184
   Revision: BN122001
   Coding: EF200E3BD82B08D409880601340081C002F1000645A00DB0E4806200BC70
   VCID: 7F4ECFABEE51F7BAB0-802A
   Subsystem 1 - Part No: 5K7 955 559 C
   Component: RLS 120716 04  42  0106
   Coding: 0038DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39431617701915
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00.rod
   VCID: 3B36FBBBB2C92B9ADC-806E
Address 13: Auto Dist. Reg (J428)       Labels: 7N0-907-572.clb
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 01071677090183
   Coding: 01001002FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361.rod
   VCID: 3522ED8394EDFDEA2A-8060
Address 15: Airbags (J234)       Labels: 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM07PVCV
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 638663DB6AF9335AB4-8036
   Serial number: IBH000000000005PMNYQ
   Coding: 30324A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 107 16
   Serial number: 35700000000040251C1/
   Subsystem 3 - Part No SW: -----------    HW: 480 002 106 16
   Serial number: 358000000005C4B81C1R
   Subsystem 4 - Part No SW: -----------    HW: 480 022 306 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001AF210BB1421D
   Subsystem 5 - Part No SW: -----------    HW: 480 020 407 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001AB2134BB1647$
   Subsystem 6 - Part No SW: -----------    HW: 480 020 207 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001B321816E2558.
   Subsystem 7 - Part No SW: -----------    HW: 480 020 307 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001B321816E3532V
   Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20160623301426
   Coding: 2012C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 004C4C579BAF8842C9-8054
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B
   Serial number: 0041603354100367AE2B
   Coding: 2D0000
   Part No SW: 561 920 981 B    HW: 561 920 981 B
   Coding: 221E010000
   VCID: 1B761B3B12094B9A3C-804E
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 17081603010152
   Coding: 461010
   VCID: 7BB63BBBFA49EB9A9C-802E
   Component: IMMO          H03 1104
   Coding: 000007
   VCID: 6A980EFF8DD3621277-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000122996002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 312AD9936085D1CA76-8064
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0183
   Revision: AA000000    Serial number: 00000198134565
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 220826DF3D637A52FF-8076
Address 3C: Lane Change (J1086)       Labels: None
   Serial number: 0410893850
   Coding: 02011102
   ROD: EV_HREntryHella.rod
   VCID: 3C34F8A7B7C72CA2D5-8068
   Lane Change Assistant 2:
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010655765
   Coding: 3415FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E70122F011B5EB2DB-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14102746160813175156
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 313    3501
   Revision: 00H22000
   VCID: 393AE1B370F5198ACE-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0096569
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 281C34F7535F9002A1-807C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1682
   Coding: 01030108
   VCID: 6FAE1FEBBE31873A20-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011612400562
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0003
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0010647830
   Coding: 3415FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F0E2F2B061157BAD0-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14102747160822022247
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H30 0357
   Serial number: VWZAZ2S0385185
   Coding: 02140102AA00000051220003001808009F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 240420C72F7774628D-8070
   Subsystem 1 - Part No SW: 3G0 919 866 AC    HW: -----------
   Component: NAR 2016/17  --- 0445
   Component: Batt.regelung H56 1682
   Coding: E1200859
   VCID: 71AA1993A80591CA36-8024
Address 75: Telematics (J949)       Labels: 12E-035-284.clb
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0158
   Serial number: 000003554140554
   Coding: 02140102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 14647007FFD704E27D-8040
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0220
   Serial number: 29061611P20532
   Coding: 000401010001020100201346C080400080000E200000
   ROD: EV_MFKBoschMQBB.rod
End----------(Elapsed Time: 01:27, VBatt start/end: 12.2V/12.1V)-----------
TBAx
C?ID=287144
Have you checked the advanced measuring values; does the signal reach the module?
You might also want to try the coding C54BC0F549230000A30C03EB921E004100F1F02A
yogibearal
C?ID=292451
Thanks TBAx - Yes advanced measuring values shows that the ESP button is active when it is clicked.
I changed the byte 20 from 1A to 2A which now turns off ASR, but this usually is paired with another byte (for example 2014 uses byte 19 and byte 17). However holding down the button for longer than 3 seconds does not turn off ESP. So this only partially works. Will need to figure out how to turn ESP off. But for now ASR is good enough for the main purpose of gaining some traction in extra slippery conditions.
Will get back to this if I can figure out the correct byte 17 coding - hopefully that will disable ESP with long press.
yogibearal
C?ID=292451
OK just went out for a quick spin - It indeed turns off ASR, while ASR is turned off "Front Assist" also shows as not available. So ACC (Active Cruise) and Front Assist (Auto Braking) is turned off when ASR is Off. This is to be expected since it basically disables ABS activation in these scenarios. Makes sense now that I think of it. When I entered the ABS control module using VCDS, it also said ACC not available, so it disables ACC. I was able to test traction control off because it just so happens we have our first day of rain after a few days without it, and the roads around here are supper slippery. With TCS on tire chirps and gets traction pretty quickly. With ASR turned off it allows the wheels to slip and spin but really if I give it a lot more pedal something else seems to kick in to reduce power, not sure if it is the ESP/ESC or something else.
Hope to figure out ESP off too. Changing byte 18 from F1 to F8 is accepted by the controller, but still does not turn off ESP/ESC. In fact it changes (Extended) Electronic Differential Lock (XDS - PR-UG3/UG4) to active/installed but I don't think the 2017 NMS Passat has XDS installed - although the controller allows this change.
yogibearal
C?ID=292451
OK after doing some additional investigation, it looks like there are multiple "stages" to this and the pairing byte allows the ESP/ESC to be turned off. Will need to figure out which one is the pairing byte to allow this to be turned into 2 stage, where a single click is ASR-off and a prolonged click is ESP/ESC-off.
yogibearal
C?ID=292451
OK After some digging the ABS-ESP module is similar to many in Europe. Basically the last byte 20 allows switching between different stages. If you play around with the bits you can see different behavior.
Byte 20:
change to 2A = Single Stage - ASR-OFF along with front assist and ACC off
change to 6A = Double Stage - ESC-Sport (quick press), ESC-OFF (long press)
change to 7A = Double Stage - ASR-OFF (quick press), ESC-OFF (long press)
Now I'd really have to double check some of this since only 2A turns off Front Assist and ACC. Changing to 6A and 7A leaves front assist and ACC on, so will need to verify if indeed these are working as displayed on the screen.
yogibearal
C?ID=292451
Quick update with ignition on and engine running, it all works, 6A and 7A works but front assist is disabled as expected when doing this. So all is well. There may be other combinations like ASR and esc-sport 2 stage, but i've found what i was after. For others looking for other settings when you go into long coding and select byte 20, edit the actual bits to figure out different settings.
dmacy
Massachusetts, USA
I know this is an old tread but I just found it. I have a 17 Passat with adaptive cruise, parking assist and push button start. It is an SE and I really wanted to add the traction control button. I was wondering if anyone has any updated information. Or updated coding information
Dave
