B8 S4 Touch Entry Not Working Correctly
tehfalcon
C?ID=235987
I have a 2010 Audi S4 that was taken to the dealer recently and they messed with the coding in my modules big time, the Push button start no longer worked when I got it back, and the touch entry doesn't work correctly.
I fixed the Push Button start issue by re-enabling the Advance Key Installed in the Comfort Module and ACC/Start Auth Module.
Before you ask, I won't bring it back to that dealer for them to fix, because they have no idea what they are doing, and were claiming I had tons of modules bad (no I didn't) and wanted to charge me a ton to fix it all (keep in mind everything was perfect on the car, no faults, I just wanted a key programmed).
Here is a video of the issue. https://www.youtube.com/watch?v=v1rRiHJIh7k
In a Nutshell, the touch lock portion seems to work fine, but grabbing the handle to unlock causes it to just constantly beep and it to unlock the rear doors if I grab the front handle, or the front doors if I grab the back handle.
I imagine it is just a coding error somewhere since they messed up the coding on several modules.
automech
C?ID=14925
Start by posting recent auto-scan of your car.
Does the problem occur on both keys? I mean if there is any difference if you walk in with new or old key?
tehfalcon
C?ID=235987
Here is my Autoscan
Tuesday,09,May,2017,14:07:09:46885
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WAUKGAFL2AA181459   License Plate:
Mileage: 166920km-103719mi   Repair Order:
Chassis Type: FL (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
          5F 62 6C 72
VIN: WAUKGAFL2AA181459   Mileage: 166920km-103719miles
Address 01: Engine (J623-CCBA)       Labels: 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  X06 0003
   Revision: --X06---
   Coding: 0104010A240F0128
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 323E1302E4A413C7EBD-8066
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8K1 927 156 C    HW: 0B5 927 156 E
   Component: 0B5 30TFSINAR H03 0002
   Revision: --H03---    Serial number: 0000000810
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 3534281E15CA04FFCEF-8060
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0030
   Coding: 294D18
   VCID: 7AAEFB227CD42B8763D-802E
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0328
   Coding: 0D0100
   Shop #: WSC 03889 003 104857
   VCID: 78AAE12A42D83997159-802C
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 0210000064781009
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01100520101050
   Coding: 66002000
   Shop #: WSC 03889 003 1048576
   VCID: 005A89CA1A0871572D9-8054
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H29 0380
   Revision: 10029001    Serial number: 00000000667537
   Coding: 26001897413CAF010000000300003D0D4F1C530800010161000000
   VCID: 3C223D3A3660D5B7311-8068
   Component: WWS 120510  H06 0070
   Serial number: SWF10050125449
   Coding: 00FD31
   Component: RLS  H04 0003
   Serial number: 10900297
   Coding: 035028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000505102274
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
            013 - Check DTC Memory
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51241013008523
   Coding: 30010D
   VCID: 47C852D67FA6866FAC3-8012
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GLD0G0U2F
   Coding: 303837354230303030304A55304C384B3053
   VCID: 45D458DE452A947F5EF-8010
   Serial number: 5810000R1000006Y06
   Serial number: 6334MSME5245635DG
   Serial number: 6344MSME524570399
   Serial number: 6352QSME4260262CB
   Serial number: 6362QSME4C603416E
   Serial number: 63732SME4B601E2E8
   Serial number: 63832SME50603328R
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90304JED000J5
   Coding: 000036
   VCID: 3D24303E2D7ADCBF06F-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 Q    HW: 8K0 920 980 Q
   Component: KOMBIINSTR.   H06 0255
   Revision: 00000000    Serial number: CJ267H95A
   Coding: 8FFF09000300D705020201
   VCID: 40DA49CA5A88B1576D9-8014
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 AE    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0117
   Revision: FC100058    Serial number: 5800F104178163
   Coding: 00C303
   VCID: 045285DA0E106D77091-8050
   Component: J367-BDM  H07 0170
   Serial number: 10017C62290410
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001010149479
   Coding: 00581300000000000000
   VCID: 3B203E26336ED28F38B-806E
Address 3C: Lane Change        Labels: None
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Coding: 0000001
   VCID: 3C223D3A3A60D5B7311-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F07.05.1000H010003C323225ÿ
   Subsystem 4 - Serial number: 323225ÿ
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000010631814
   Coding: 011C03204E00410001
   VCID: 45D458DE45AA947F5EF-8010
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0130049961
   Coding: 0106063A00FA040703B0013202000000
   Subsystem 2 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS037  H06 0041
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34882002480001
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000010633869
   VCID: 44D245DA4E90AD77491-8010
   Revision: 00000003    Serial number: 00000000639687
   VCID: 3432151A1E301DF7F91-8060
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77A8E21643C636EF1C3-8022
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335ET0A7570315
   Coding: 020000010000000001
   VCID: 1D64D0BE8DBABCBF26F-8048
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 8T1 035 664 B    HW: 8T1 035 664 B
   Component: H-BN-NA       H47 0042
   Revision: --------    Serial number: 490EY0A7565620
   Coding: 010200000206E3FF53001F0E000000030000
   VCID: 372822160F46F6EFDC3-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356EP0A1312590
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000536796
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000104200939
   Coding: 010C03204000210001
   VCID: 42DE43C25484A3477BD-8016
   Revision: --H04---    Serial number: 525PA8-J0390TU
   Coding: 1000006
   VCID: 382A212A0E58F997D59-806C
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000104200986
End----------(Elapsed Time: 01:44, VBatt start/end: 12.2V/12.1V)-----------
Dana
Western PA, USA
Do you happen to have a scan before the dealer messed it all up? Please check the C:\Ross-Tech\VCDS\Scans -and- C:\Ross-Tech\VCDS\Logs folder for anything earlier than that visit.
Also, let us know about automech's question. Does that happen with both keys (original and new) or just one of the keys?
Jef
HQ
Dana and I have looked this over and would like you to make the following changes:
Door control modules, front doors (J386 & J387), change coding to 011C13204E00410001
Door control modules, rear doors (J388 & J389), change coding to 010C13204000210001
In short, on all door control modules, Byte 2 is going from "03" to "13".
See if that helps. If not, then also do this:
Central Conv. (J393), change coding to 0106063A007A040703B0013200000000
This disables Byte 5/Bit7 and Byte 12/Bit 1.
Please post your results and a fresh follow up Auto-Scan.
tehfalcon
C?ID=235987
It worked! Thanks guys! To answer the other question, it was doing it on both the new and old key.
Here is the new autoscan.
Wednesday,10,May,2017,12:30:54:46885
          5F 62 6C 72
VIN: WAUKGAFL2AA181459   Mileage: 167010km-103775miles
   Revision: --X06---
   Coding: 294D18
   Coding: 0D0100
   Coding: 66002000
   Coding: 260018934134BF010001010300003D0D4F1C530800010161000000
   Coding: 00FD31
   Coding: 035028
   Coding: 30010D
   Coding: 000036
   Coding: 8BFF09000300D705020201
   Coding: 00C303
   Coding: 0000001
   Coding: 011C13204E00410001
   Coding: 01060638007A040703B0013200000000
   Coding: 0000004
   Coding: 010C13204000210001
   Coding: 1000006
End-------------------------(Elapsed Time: 01:43)--------------------------
you wouldn't have any idea on the only fault I have do you? Nothing on the wiki for the "check DTC memory" on that fault code.
This just means your CECM thinks there might be a fault in the CCM. But there isn't. I would explicitly clear faults in both of them again...
Jef
HQ
tehfalcon
C?ID=235987
Was it just recoding the door control modules, or did you have to also recode the Central Conv.?
Just recoding the door control modules made it work.
