Okay so decided to recheck everything. All Vac. hoses and no leaks found anywhere. Jack there is no aux Vac pump by the rack on this car.
I also manually opened Kombi valve and jumped the relay to run the pump with engine off and tail pipes blocked.
And I found a very small exhaust leak at the flex joint of down pipe on B1 about 2 inches downstream of the O2 in question.
With this car running the exhaust is loud to a degree but designed that way so you couldn’t hear an exhaust leak.
It is also so tight of an area that hot and running motor you can’t feel for it.
But with a cold not running engine and pump & Kombi jumped I could feel slight air out the flex joint.
So I know the down pipe is leaking at the flex joint and it will have to be replaced at some time soon.
Changing the is a guess at best? I told customer we need to change the down pipe because I know it’s bad and that it is not a guess.
If it fixes the problem great but at least it is not wasted money because sooner or later it will get very loud.
Thought about just welding in a new flex joint but the time it takes to change this down pipe being an R32 AWD OE is the only way to go.
Changing the down pipe was PITA. Saving the flange on the $1500 duel cat was real hard also.
I also used the Northside O2 on bank 2 and the dealer O2 on bank 1 that’s was cool no wasted parts.
Against all advice I again bought the down pipe from Northside Imports for $530 which is nuts for 2 pipes with flex joints and no cat.
But the down pipe was original V.W. OE and a lot cheaper.
Sorry guy’s, but saw no reason to pay more for the exact same part.
But this solved the problem and car is perfect. This flex joint was a very small leak but only a few inches away from B1S1.
I still can’t believe it caused the scanner too totally stop reading the O2 after 4 miles of driving.
I would of expected an inaccurate reading from this O2 because of a small leak but not a totally dead O2 reading on .
Could someone please explain that one? I do know that no exhaust leaks are basic but that’s crazy. This was a very small leak.
Auto scan after fix below…
Thanks &
Good Luck
Thursday,25,May,2017,14:34:32:46081
-- Windows Based VAG/VAS Emulator Running on Windows XP x86
Version: 17.1.3.0
VIN: WVWKG61J64D133455 License Plate:
Mileage: 167600km-104141mi Repair Order:
76
VIN: WVWKG61J64D133455 Mileage: 167600km-104141miles
Address 01: Engine Labels: 022-906-032-BJS.lbl
Part No SW: 022 906 032 EG HW: 14. 4.0 3
Component: MOTRONIC ME7.1.1G 5927
Coding: 0000132
Shop #: 31413 000 00000
VCID: 54ACF01EF44F4EE11D-5102
Address 03: Brakes Labels: 1C0-907-37x-ESP-A.lbl
Part No: 1C0 907 379 P
Component: ESP ALLRAD MK60 0101
Coding: 0023049
Shop #: 31414 000 00000
VCID: 3776A79245F985F918-5102
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11200
Shop #: 31414
VCID: 214269CAAB7DEB49C6-515A
37-10 - Faulty - Intermittent
Part No: 1C0 909 605 F
Component: 17 AIRBAG VW61 0108 0003
Coding: 12599
Shop #: 31414
VCID: 275677D2C559157988-50E6
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 927 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15230
Shop #: 00000
VCID: 295271EAD34D23099E-50E6
WVWKG61J64D133455 VWZ7Z0D9770087
01304 - Radio
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: 31414
VCID: 70E45C8E301712C119-50E6
01304 - Radio
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 D
Component: HALDEX LSC ECC 0011
VCID: 214269CAAB7DEB49C6-4ACE
Part No: 1C0 959 799 C
Component: C7 Komfortgerát HLO 0003
Coding: 00064
Shop #: 31414
VCID: 3776A79215F985F918-4ACE
Component: C7 Tõrsteuer.FS KLO 0202
Component: C7 Tõrsteuer.BF KLO 0202
End-------------------------(Elapsed Time: 05:22)--------------------------
