VW Golf 2015 - persistent intermittent transmission error - P17C5
Moni
C?ID=288542
Hi there,
Full scan below, in case there is somebody out there who can give some ideas on this error.
Summary:
Main interest: Transmission errors.
Occur most of the time after the vehicle has been driven for a while, then set in "Park" then set to reverse.
I see a transmission error flashing sometimes while driving.
Some expected Q&A:
Correct, car is under warranty.
The dealer kept it for a week but refused to troubleshoot unless I not only disconnect the dash-camera but also remove the dead wires from the car (~3 hr job).
I did drive with the camera wires completely disconnected from the fuse-box (i.e. factory setup). The errors continued to show.
Currently the camera feeds only from the two fuse-positions for the cabin power outlet (one for constant [+] the other for drive-only [+]), so not a chance for any interference with the CAN interface.
Other Errors:
09-Cent. Elect. -> It should be disregarded - I do not have heated seats.
16-Steering wheel -> Not a priority, although it could be related to the transmission issue via the logic for park-level selector.
Many thanks for any ideas as to what could be causing the issue!
AutoScan:
VIN: 3VWC17AU7FM503xxx
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
Address 01: Engine  (CXBB  J623)	Labels: 5G-01.lbl
	Part No SW: 5GM 906 264	HW: 06K 907 425 B
	Component: 1.8l R4 TFSI  H13 0001
	Revision: --H13---
	Coding: 091A00122424002F0000
	Shop #: WSC 00066 790 00218
	ASAM Dataset: EV_ECM18TFS0205GM906264 001001
	ROD: N/A
	VCID: 044B1F131FE69779072B3E3C7-8051
	No ASAM data for: "EV_ECM18TFS0205GM906264"
015000 - ROD - Unknown faultcode
		Fault Status: 00111010
		Fault Priority: 8
		Fault Frequency: 32
		Reset Counter: 32
		Mileage: 2368512 km
Address 02: Auto Trans  (J217)	Labels: 09G-927-749.clb
	Part No SW: 09G 927 749 D	HW: 09G 927 749 D
	Component: AISIN AG6 G3  129 2866
	Coding: 010200000C000000000000000000000000000000
	ASAM Dataset: EV_TCMAQ250031 002009
	ROD: EV_TCMAQ250031.rod
	VCID: 3A37A1EB2DA211892D4790B45-806F
28269 - Gear Selector
	P17C5 00 [104] - Implausible Signal
		Fault Status: 01101110
		Fault Priority: 13
		Fault Frequency: 104
		Reset Counter: 1
		Mileage: 1901145 km
22960 - Signal Line for Tiptronic
	P1890 00 [032] - Electrical Malfunction
22946 - Gear Shift Lock Solenoid Control Circuit
	P0931 00 [032] - High
Address 03: ABS Brakes  (J104)	Labels: 3Q-03.clb
	Part No SW: 3Q0 907 379 P	HW: 3Q0 907 379 C
	Revision: 00000000
	Coding: 04FA6AA12420096F007C020481CA292056249000408194B400430050C002
	Shop #: WSC 01383 790 50316
	ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
	VCID: 47D1C81F6E507C61A2C90158E-8012
No fault codes found.
Address 08: Auto HVAC  (J301)	Labels: 5G0-907-426.clb
	Part No SW: 5GM 907 426	HW: 5GM 907 426
	Component: AC Manuell    H02 1001
	Revision: 00001K01
	Coding: 02020004200100000000000000000000
	ROD: EV_ACManueBHBVW37X.rod
	VCID: 054D021714DCAE7110352B304-8050
	Subsystem 1 -
	Subsystem 2 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.lbl
	Part No SW: 5Q0 937 087 Q	HW: 5Q0 937 087 Q
	Revision: --------
	Coding: 000018424041804169E44000000403001000000000000000000000000000
	Shop #: WSC 00066 790 00082
	ROD: EV_BCMBOSCH_VW37.rod
	VCID: 49D5CE2778448A11B4DD37608-801C
	Subsystem 1 - 	Part No SW: 5GM-955-119	Labels: 5Qx-955-119-V1.clb
	Component:  MÝ
204290 - Remote key 1
	B1479 18 [008] - Current Too Low
		Fault Status: 00011110
		Fault Frequency: 8
		Reset Counter: 2
		Mileage: 329480 km
		Fault Status: 00000111
		Fault Priority: 8
		Fault Frequency: 8
		Reset Counter: 1
		Mileage: 4325929 km
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 5Q0 959 655 J	HW: 5Q0 959 655 J
	ROD: EV_AirbaVW20SMEVW37X.rod
	Subsystem 1 - 	Part No SW: 4M0-959-339-B
	Component: 018
	Subsystem 2 - 	Component: ---
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
	Subsystem 5 - 	Component: ---
	Subsystem 6 - 	Component: ---
Address 16: Steering wheel  (J524)	Labels: 5Q-16.lbl
	Part No SW: 5Q0 953 521 P	HW: 5Q0 953 569 A
	Revision: FF032032
	Coding: 0410
	Shop #: WSC 66564 385 16448
	ROD: EV_SMLSVALEOMQB.rod
	VCID: 3FC1D0FF368034A11A79A9F86-806A
617752 - Selector Lever Park Position Lock Switch
	B1162 29 [008] - Signal Implausible
		Fault Status: 01101101
		Fault Priority: 8
		Fault Frequency: 8
		Reset Counter: 1
		Mileage: 852517 km
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5G1 920 840	HW: 5G1 920 840
	Component: KOMBI         243 4270
	Coding: 0BB4110A2180CF0502086A001000000000000000
	ROD: EV_DashBoardVDDMQBAB_VW37.rod
	VCID: E48BBF937FA6B77927EBDEBC7-80B1
Address 19: CAN Gateway  (J533)	Labels: 5Q0-907-530-V1.clb
	Part No SW: 5Q0 907 530 AB	HW: 5Q0 907 530 L
	Component: GW MQB Mid    211 2203
	Revision: --------
	Coding: 0101000820085900EF0000081C0F00000001050000000000000000000000
	Shop #: WSC 00066 790 07029
	ROD: EV_GatewConti.rod
	VCID: 71A546C7305492D1DC6DCF400-8024
	Subsystem 1 -
	Subsystem 2 - 	Component: )ÿÿ
Address 42: Door Elect, Driver  (J386)	Labels: 5QX-959-X93-42.clb
	Part No SW: 5Q0 959 393 B	HW: 5Q0 959 393 B
	Coding: 003003200000040000000000
	VCID: 3E3FADFB318A3DA9116FBCE49-806B
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 5Q0 909 144 R	HW: 5Q0 909 144 R
	Component: EPS_MQB_ZFLS  126 1061
	Coding: 0102
	ROD: EV_SteerAssisMQB_VW37.rod
	VCID: 43C9DC0F5A6850417EA1F528A-8016
Address 52: Door Elect, Pass.  (J387)	Labels: 5QX-959-X92-52.clb
	Part No SW: 5Q0 959 392 B	HW: 5Q0 959 392 B
	VCID: 3D3DAAF73C8C26B10865B3D0C-8068
Address 5F: Information Electr.  (J794)	Labels: 5G-5f.lbl
	Part No SW: 5G0 035 844	HW: 5G0 035 844
	Component: MU-S-S-US     014 0645
	Coding: 02730200FF00000021220001001800001F0100040100010002
	ROD: EV_MUStd4CPASE_VW37.rod
	Subsystem 1 - 	Part No SW: 5G0-919-605-H
	Component: ABT_Std_Plus
Address 75: Telematics  (J949)	Labels: 5QE-035-285.clb
	Part No SW: 5QE 035 285 A	HW: 5QE 035 285 A
	Component: OCULowMQBUS   007 0564
	Coding: 02730202C2821A017F1E06000000
	Shop #: WSC 00066 790 00122
	ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 02:14)--------------------------
Shame on that dealer. But the metro area you're in has a fair number of them doesn't it?
Any chance you could post a scan from VCDS? I'd like to see the mileage in the freeze-frame of the various faults, mostly for comparison, since the values VCDS-Mobile is showing can't possibly be right if this car is still under warranty. :facepalm:
If I had to guess, you've either got a wonky shifter mechanism or a bad connection between it and the TCU.
Moni
C?ID=288542
Thanks Uwe!
Yeah man ... 11K and still under warranty. I got the 50K extended package
Here we go - that's from the laptop.
Monday,08,May,2017,20:44:15:17869
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4336.4
Dealer/Shop Name: Moni-DD
VIN: 3VWC17AU7FM503xxx   License Plate:
Mileage: 17875km-11107mi   Repair Order:
Chassis Type: AU (5Q0)
VIN: 3VWC17AU7FM503xxx   Mileage: 17875km-11107miles
Address 01: Engine (J623-CXBB)       Labels: 06K-907-425-V1.clb
   Revision: --H13---
   ROD: EV_ECM18TFS0208V0906264D.rod
   VCID: 0444442E8F5ED261CD-8050
15000 - Fuel Pump
          P3044 00 [032] - Short Circuit
   ROD: EV_TCMAQ250031_VW31.rod
   VCID: 3A38FAD6BD1A5491E7-806E
                    Fault Frequency: 29
                    Reset counter: 89
                    Mileage: 10792 km
                    Date: 2016.09.06
                    Time: 01:38:23
                    Engine speed: 790.0 /min
                    Transmission input speed: 54 /min
                    Engine torque: 28 Nm
                    Transmission fluid temperature: 81 °C
                    Accelerator position: 0.0 %
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
   Revision: 00000000    Serial number: 50115000000088
   VCID: 47DE9322FEE8397968-8012
   Revision: 00001K01
   ROD: EV_ACManueBHBVW37X_SK48.rod
   VCID: 0542592A8464EB69DA-8050
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-BV1.clb
   Revision: --------    Serial number: 86581201151322
   ROD: EV_BCMBOSCH_014.rod
   VCID: 49DA951AE8FCCF097E-801C
   Component: WWS    140902  043 0581
   Serial number:         150225003202
                    Fault Frequency: 68
                    Reset counter: 43
                    Mileage: 14123 km
                    Date: 2017.01.18
                    Time: 20:43:51
   Serial number: 003GCR0165G0
   Occupant Detection:
   Serial number: IBH0000J150002C9GK01
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 001 912 14
   Serial number: 3570000000070D214212
   Subsystem 3 - Part No SW: -----------    HW: 480 001 912 14
   Serial number: 358000000005AAD0721L
   Subsystem 4 - Part No SW: -----------    HW: 480 401 411 14
   Serial number: 3510002B1188FC13C3DD
   Subsystem 5 - Part No SW: -----------    HW: 480 401 311 14
   Serial number: 35200029D188FC1582DL
   Subsystem 6 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3550002A1196FF60320/
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3560002C9196FF622119
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Revision: FF032032    Serial number: 20150118400498
   Coding: 0410
   VCID: 3FCE8BC2A63871B9D0-806A
                    Fault Frequency: 13
                    Reset counter: 37
                    Mileage: 14368 km
                    Date: 2017.02.05
                    Time: 05:53:20
                    Ubat 30 Voltage: 14.60 V
                    Ignition State: On
                    Terminal 15: 13.80 V
                    A/D #1: 0.00 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
   VCID: 648464AE6F1E72616D-8030
   Revision: --------    Serial number: 22011510001560
   ROD: EV_GatewConti_011.rod
   VCID: 71AA1DFAA0ECD7C916-8024
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 27150000246550085071
   Coding: 29FFFF
   Serial number: 060215060507EO
   VCID: 3E30F6C6A13278B1DB-806A
   Serial number: 00000000000000422812
   Coding: 011000
   Coding: 0102
   VCID: 43C68732CAD01559B4-8016
   Serial number: 060215060509NL
   VCID: 3D32F1CAAC3463A9C2-8068
   Serial number: 00000000000000611718
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Serial number: V7B01701150800
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS5019GL
0023 - Tuner for Satelite Radio
          B11CF 96 [008] - Component internal failure
                    Reset counter: 43
                    Mileage: 17864 km
                    Date: 2017.05.08
                    Time: 00:35:50
                    Voltage terminal 30: 14.2 V
End----------(Elapsed Time: 01:14, VBatt start/end: 13.7V/13.7V)-----------
Moni
C?ID=288542
In case others get the same error.
In short: The gear selector lever assembly was replaced.
They checked the wiring to this module - apparently no issues.
Observation: The error P17C5 was combined with also errors in park position switch.
Driving for a week now - no errors.
