auto scan results. The left hand headlamp was changed due to crash damage. its the correct part number. the lamp is working fine and I have no bulbs out on the car.
Sunday,07,May,2017,13:12:14:39818
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: WAUZZZ4GXFN070302 License Plate:
Chassis Type: 4G (4G8)
Scan: 01 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F 62
69 6D 72 AC
VIN: WAUZZZ4GXFN070302 Mileage: 47996km-29823miles
Address 01: Engine (J623-CNHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 FR HW: 04L 907 309
Component: R4 2,0L EDC H23 0745
Revision: 85H23---
Coding: 12194012243401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021FR 002003
ROD: EV_ECM20TDI01104L906021FR_002.rod
VCID: 7AAEFBB06C56E17763D-802E
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 06A09E4160057982BB00
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FD84AA437F4045F143-806A
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 03B9704E000000000000
VCID: 7AAEFBB06CD6E17763D-802E
Serial number: 3215000017092015
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 17021500041898
Coding: 342209B8210000
VCID: 6390A6D4FBDC00BF50B-8036
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001009200702
Coding: 0105001440349F6044014083000018000F9DA7082F08020100000894E100140200400024030000
VCID: 71BCDC9C31A0A22FD27-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 150201 H37 0080
Serial number: 150209151145
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23726118
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 16 02 2015 00000136
Serial number: 96384397000000000001
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 73
Mileage: 47996 km
Date: 2017.05.07
Time: 14:06:36
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Revision: -------- Serial number: 003P1003BLP3
Coding: 30333130313630323639554A305234473053
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3B203EB423EC187F38B-806E
Serial number: 3575HRB405T33HNGDOMJ
Serial number: 3585HRB405D34OD43OJK
Serial number: 3515JRB405J33EQGG1MS
Serial number: 3525JRB405J35IMQK1AX
Serial number: 3554VRB400M52NOOC0RE
Serial number: 3564VRB400K52SHK9H71
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OBH000QS
Coding: 000015
VCID: 3B203EB4236C187F38B-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 04 02 2015 10010506
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 985 L HW: 4G8 920 985 L
Component: TDieGb H08 0043
Revision: 04001037 Serial number: 658210215596033
Coding: 33A512000B412600010000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 40DA49584A0A7BA76D9-8014
1048578 - No Basic Setting
B2010 00 [009] - -
Reset counter: 73
Mileage: 47996 km
Date: 2017.05.07
Time: 14:06:01
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001740074
Coding: C0CD074418
ROD: EV_GatewPKOUDS_VW51.rod
VCID: 75B4E88C45488E0F0EF-8020
Serial number: 3031585703
Voltage stabilizer:
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 7CA2FDA866E2DF47711-8028
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 17021500040852
Coding: 22
VCID: 3E2637A030FE0D571F5-806A
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720FXSXQ
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_VW51.rod
VCID: 333016940BBCD03FE0B-8066
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011C16014001620002080002
VCID: 47C852446FA44C9FAC3-8012
Address 44: Steering Assist (J500) Labels: 4G0-909-144.clb
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0016424416
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0361342842
Coding: 013B0622A0B93040C320090420010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 9
Reset counter: 62
Mileage: 47150 km
Date: 2017.03.23
Time: 19:03:00
02616 - Fuel Tank Cap; Unlock
Fault Status: 00101001
Fault Frequency: 11
Reset counter: 113
Mileage: 47150 km
Date: 2017.03.24
Time: 09:26:57
Address 52: Door Elect, Pass. (J387) Labels: None
Component: TSG BF H03 0507
VCID: 46D65F4068AE5597575-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001373414
ROD: EV_ParkiBrake_AU57.rod
VCID: 2D0400ECED9886CFB6F-8078
Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04F2001028630200
Shop #: WSC 00046 123 12345
VCID: 343215880EB2D707F91-8060
Coding: E01E00
Coding: E01E00
13705473 - Databus
U1121 00 [137] - Missing Message
Reset counter: 73
Mileage: 47996 km
Date: 2017.05.07
Time: 14:08:15
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Reset counter: 73
Mileage: 47996 km
Date: 2017.05.07
Time: 14:08:16
5334529 - Fan for Left Headlamp
C1166 01 [137] - Electrical Failure
Reset counter: 73
Mileage: 47996 km
Date: 2017.05.07
Time: 14:08:17
Part No SW: 4G1 035 021 D HW: 4G1 035 021
Component: MU-H-LND-EU 041 0389
Serial number: A588B0F7505850
Coding: 017502010000000013111102000A00132F0006E7F1700100DF
VCID: 1B60DE34832C787FD8B-804E
Subsystem 1 - Part No SW: V03 959 801 FB HW: -----------
Component: ECE 2016/2017 --- 0153
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9EY800GNW
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 710 F HW: 4G2 919 710 F
Serial number: 90349OAK000FB
Compact Disc Database:
Component: Gracenote2 --- 1012
3072 - Cellular Antenna
B1053 11 [009] - Short to Ground
Reset counter: 73
Mileage: 47996 km
Date: 2017.05.07
Time: 14:08:36
Voltage terminal 30: 12.0 V
3083 - GSM antenna 2
B1533 11 [009] - Short to Ground
Reset counter: 73
Mileage: 47996 km
Date: 2017.05.07
Time: 14:08:36
Address 62: Door, Rear Left (J388) Labels: None
Component: TSG HL H03 0507
Coding: 010814004001620002080002
VCID: 49CC547C79B0BAEFBA7-801C
Address 69: Trailer (J345) Labels: 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001001 Serial number: 0360501998
Coding: 0100000202000000
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 030500822
Coding: 093205C011
ROD: EV_HDSGAu571.rod
VCID: 36362F8018CEC517C75-8062
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0507
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150220437
ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 01:40, VBatt start/end: 12.0V/12.0V)-----------
