How to program 2012 Audi Q5 for after-market Westfalia & Jaeger tail hitch
Bojole
C?ID=27403
Hi guys,
Would you be able to help me properly code a newly installed Westfalia hitch for my 2012 Audi Q5.
I check for ideas/hints on the forums but seems like the closest I found was the 2013 Q5 conversation that you recently had
I am getting a TPMS and Stability Control program failures, and assuming that the reason is the fact I did not program all of the modules needed.
On the instructions coming with the Jaeger trailer control module it asks for Software Version Management (SVM) coding, which unfortunately is not an option for owners of the USB Hex+Can cable. Otherwise you just run SVN with code 050200, and be done with it ;)
Cheers, and thanks!
Bojole
C?ID=27403
As a note: I ran an “all scan” with debug level of 2, and have the file ready, but refraining of posting it, as it's super long.
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
Post it in between code tags then it won't be that long. [CODE] Full Autoscan [/CODE]
Bojole
C?ID=27403
Thanks Keithuk!
Here is the Full Autoscan with Debug 2
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
BV
Friday,01,August,2014,03:50:02:02041
Chassis Type: FP (8T0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 36 3C 42 46 47 52
          53 55 56 5F 62 69 6C 6D 72
VIN:...   Mileage: 40830km/25370miles
Address 01: Engine (J623-CALB)       Labels: 06E-907-559-CAL.clb
   Part No SW: 8R0 907 559 G    HW: 8F0 907 559 A
   Component: 3.2 SIMOS8.2  H08 0004
   Revision: --------
   Coding: 0121000A190F0A21
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
   ROD: EV_ECM32FSI.rod
   VCID: 448D34EFCF9C263EFFF-8011
6628 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Mileage: 40832 km
                    Date: 2014.08.01
                    Time: 02:23:56
7193 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Mileage: 40832 km
                    Date: 2014.08.01
                    Time: 02:23:56
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
   Part No SW: 8R0 927 158 H    HW: 0B6 927 156
   Component: 0B6 32 FSIUSA H05 0006
   Revision: --H05---
   Coding: 001012
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMAL651211 001012
   ROD: EV_TCMAL651.rod
   VCID: 428132F7D588280ECD3-8017
Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.CLB
   Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
   Component: ESP8 quattro  H06 0110
   Coding: 043D18
   VCID: 458B29EBCCA61F36E81-8010
                    Reset counter: 105
                    Mileage: 40832 km
                    Date: 2014.08.01
                    Time: 02:51:12
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0041
                    Hex Value: 0x0396
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.CLB
   Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H10 0602
   Coding: 0D854000000000000000
   VCID: 830F77F302126106065-80D6
Address 08: Auto HVAC (J255)       Labels: REDIR FAIL!
   Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
   Revision: C1000000    Serial number: 01060620122377
   Coding: 46112000
   VCID: 7AF18A17F5D8A0CED53-802F
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.CLB
   Part No SW: 8K0 907 063 CE    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0410
   Revision: 10030001    Serial number: 00000001513663
   Coding: 26001091423CAF311F01090300001D0D0F9CE74802010161000000
   Shop #: WSC 06335 123 12345
   VCID: 74EDA42FD7BCD6BE8FF-8021
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 120526  H11 0050
   Coding: 01DD13
   Component: RLS  H04 0003
   Coding: 024D25
   Component: E1 - LDS  H03 0031
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.CLB
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0081
   Revision: 11001001    Serial number: 12511216100321
   Coding: 300108
   VCID: 78F5901FCBD4B2DEA37-802D
Address 13: Auto Dist. Reg (J428)       Labels: REDIR FAIL!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H09 0100
   Coding: 00C7AE
   VCID: 37775323864A7DA66AD-8062
                    Reset counter: 101
                    Mileage: 40784 km
                    Date: 2014.07.31
                    Time: 10:04:09
                    Temperature: 23.0°C
                    Voltage: 11.78 V
                    Hex Value: 0x005D
                    Lateral Accel.: 0.00 m/s^2
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 105
                    Mileage: 40784 km
                    Date: 2014.07.31
                    Time: 10:04:09
                    Temperature: 23.0°C
                    Voltage: 11.78 V
                    Hex Value: 0x00BE
                    Fault Frequency: 8
                    Reset counter: 105
                    Mileage: 40784 km
                    Date: 2014.07.31
                    Time: 10:04:09
                    Temperature: 23.0°C
                    Voltage: 11.78 V
                    Hex Value: 0x00C0
Address 14: Susp. Elect. (J250)       Labels: NONE
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 30051205420001
   Coding: 070181
   VCID: 3A714A17B55860CE953-806F
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD90GLZ9
   Coding: 303333313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 479723E3FEAA0D261AD-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R120000996E
   Serial number: 6334MSME70050A5DD
   Serial number: 6344MSME6E740C43O
   Serial number: 6352QSME3718434CJ
   Serial number: 6362QSME27170D6CQ
   Serial number: 63732SME3E122678%
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME69173F424
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.CLB
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372LET0001I
   Coding: 00003F
   VCID: 3E794607A9704CEEA9B-806B
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8R0-920-XXX-17.CLB
   Part No SW: 8R0 920 981 K    HW: 8R0 920 981 K
   Component: KOMBIINSTR.   H44 0640
   Revision: 00000000    Serial number: RSS46D44D
   Coding: 035622003F005604020101
   VCID: 428132F7DD88280ECD3-8017
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.CLB
   Part No SW: 8T0 907 468 AJ    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0120
   Revision: FC201059    Serial number: 5900F12524004A
   Coding: 00C303
   VCID: 891365DB203E3B564C9-80DC
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
Address 1B: Active Steering (J792)       Labels: NONE
   Part No SW: 8K0 907 144 E    HW: 8K0 907 144 E
   Component: DYNAMIKLENK.  H06 0580
   Revision: 50001005    Serial number: --------------
   Coding: 820000
   VCID: 31636D3B682EA396249-8064
Address 36: Seat Mem. Drvr (J136)       Labels: NONE
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000029817658
   Coding: 00581B00000000000000
Address 3C: Lane Change        Labels: REDIR FAIL!
   Part No SW: 8R0 907 566 A    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH12 0040
   Revision: 00H12000    Serial number: 6PZ 009 014-05
   Coding: 0000007
   VCID: 3C7D4C0F7F6C5EFE87F-8069
   Subsystem 1 - Part No: 8R0 907 568 A
   Component: J0770_SWA_Slave_H10 0040
   Subsystem 2 - Serial number: 6PZ 009 014-25
   Subsystem 3 - Serial number: 5F24.05.1200H100003CX14929ÿ
   Subsystem 4 - Serial number: X14929ÿ
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.CLB
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000031657697
   Coding: 011D13205E00440004
   VCID: 4FA70BC31EDAD56652D-801A
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.CLB
   Revision: 00002001    Serial number: 0177685403
   Coding: 01260E3A20FA749784B005B200000000
   Shop #: WSC 06334 123 12345
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H03 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H03 0220
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.CLB
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804015684004
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.CLB
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000031279256
   VCID: 4E9916C719D0DC6E59B-801B
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.CLB
   Revision: 00000003    Serial number: 00000001129150
   VCID: 346D642F973C96BE4FF-8061
Address 55: Xenon Range        Labels: 8T0-907-357.CLB
   Part No SW: 8H0 907 357 D    HW: 8H0 907 357 D
   Revision: 00H01001    Serial number:
   Coding: 0000022
   Shop #: WSC 06334 000 00000
   VCID: 336F673352329186565-8066
Address 56: Radio (R)       Labels: REDIR FAIL!
   Part No SW: 4G0 035 082 C    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0101
   Revision: AB001007    Serial number: 236F%0C7542379
   Coding: 020007010000000001
   VCID: 2045987F33C41A1EBB7-8075
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6XX-5F.CLB
   Part No SW: 8T1 035 664 D    HW: 8T1 035 664 B
   Component: H-BN-NA       H52 0165
   Revision: --------    Serial number: 490F/0C7680706
   Coding: 010200060105EBFF77000B0E000000030000
   VCID: 3973551BB05E6BD69C9-806C
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
                    Reset counter: 105
                    Mileage: 40832 km
                    Date: 2014.08.01
                    Time: 03:07:38
                    Bin. Bits: 00000001 00000000
                    Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.CLB
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000031844766
   Coding: 010C13204000240004
   VCID: 46892EE7F1A0142EE1B-8013
Address 69: Trailer (J345)       Labels: 8K0-907-383.CLB
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: ConWys Trailer H09 0100
   Revision: 1A001001    Serial number: 00000161077413
   Coding: 0100000000000000
   Shop #: WSC 00007 223 57222
   VCID: 36695E27814084AE71B-8063
Address 6C: Back-up Cam.        Labels: 4L0-910-441.CLB
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J23A3OY
   Coding: 1031010
   VCID: 346D642F573C96BE4FF-8061
Address 6D: Trunk Elect. (J605)       Labels: REDIR FAIL!
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B7F4F13BA6259C68E5-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.CLB
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000031855161
Bojole
C?ID=27403
Anyone with an idea is welcome, don’t be shy to answer :o
NEtech
Denmark
C?ID=56995
ECU Coding
[03] 04BD18 (First Secure access)
[10] 310108 (First Secure access)
[13] 00C7A7
[3C] 0010007
You have removed VIN, i think the car is not prepared for Trailer.
If you can see the license plate of a car then you also can look up VIN, here in Denmark. Also the VIN is often in the window of the car.
Bojole
C?ID=27403
NEtech, thanks. I will try with the codes you posted.
I removed the VIN from the scan as I didn’t wanted to get into the search engines that crawl the internet these days ;)
The can was prewired from the factory for trailer installation, so I only plugged-in into that, following the instruction that came from Wesfalia and Jaeger controller - link
I also modify the programming base on the thread I posted on the original post, and added the 69 trailer module into the gateways.
So, I will give it a try with your codes, and reply here with the results.
Cheers.
Bojole
C?ID=27403
NEtech, thanks for the codes. I applied all of them, and also used the BETA release of the Ross-Tech software, which had the bit/options specified into the coding.
My TPMS and Stability is back to normal, and the car now acts as should. The Adaptive control, didn't work immediately after I applied the codes, but today after a short drive all readiness codes passed and the Adaptive cruise control, is buck to normal operation.
Cheers, and thanks.
I will post all of my modules so that other with '12 Q5 can use it.
Bojole
C?ID=27403
Thanks again NEtech.
Here is my all modules coding from the car after installing the hitch and following the coding procedures as described earlier in the thread.
VCDS Version: Beta 14.7.2 (x64)
Data version: 20140714
BV
Monday,11,August,2014,18:26:21:02041
VIN: WA1WKBFP9CA126841   Mileage: 41030km-25494miles
   Revision: --------
   VCID: 448D34EFCF9C261AE7-8011
Readiness: 0000 1100
   Revision: --H05---
   Coding: 001012
   VCID: 428132F7D588282AD5-8017
Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
   Coding: 04BD18
   VCID: 458B29EBCCA61F12F0-8010
   VCID: 030FF7F38212E1229E-8056
   Coding: 46112000
   VCID: 7AF18A17F5D8A0EACD-802F
   VCID: 74EDA42FD7BCD69A97-8021
   Coding: 01DD13
   Coding: 024D25
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Coding: 310108
   VCID: 78F5901FCBD4B2FABB-802D
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Coding: 00C7A7
   VCID: 37775323864A7D8272-8062
Address 14: Susp. Elect. (J250)       Labels: None
   Coding: 070181
   VCID: 3A714A17B55860EA8D-806F
   VCID: 479723E3FEAA0D0202-8012
   Coding: 00003F
   VCID: 3E794607A9704CCAB1-806B
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   VCID: 428132F7DD88282AD5-8017
   Coding: 00C303
   VCID: 0913E5DBA03EBB72D4-805C
   Coding: 820000
   VCID: 31636D3B682EA3B23C-8064
   Coding: 0010007
   VCID: 3C7D4C0F7F6C5EDA9F-8069
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   VCID: 4FA70BC31EDAD5424A-801A
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   VCID: 4E9916C719D0DC4A41-801B
   VCID: 346D642F973C969A57-8061
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Coding: 0000022
   VCID: 336F6733523291A24E-8066
   VCID: 2045987F33C41A3AA3-8075
   VCID: 3973551BB05E6BF284-806C
                    Reset counter: 121
                    Mileage: 41011 km
                    Date: 2014.08.11
                    Time: 13:06:45
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   VCID: 46892EE7F1A0140AF9-8013
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   VCID: 36695E278140848A69-8063
   Coding: 1031010
   VCID: 346D642F573C969A57-8061
   VCID: 3B7F4F13BA6259E296-806E
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
End-------------------------(Elapsed Time: 05:08)--------------------------
Note: Never mind my error in module 5F, it's due to some other issue (not sure what exactly) but I had it from before hitch install/coding.
Cheers!
bennjamin
Australia
C?ID=222574
...and how did you go ? Is the audi working all good no issues now ?
PS I have a '14 q5 with the westfalia installed , hasnt been coded - and has the same issues with traction control/auto hold/TPMS etc
