MY17 Škoda Kodiaq Edition 190 TDi DSG 4x4 (UK spec)
Gizmo
S.E.Kent UK
C?ID=49193
Monday,01,May,2017,11:08:04:36443VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.4.1.1  HEX-NET CB: 0.4336.4
Data version: 20170413 DS270.4
VIN: TMBMK9NS4H8017066   License Plate: **17 ***
Mileage: 150   Repair Order: 1
Chassis Type: NS (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44
          47 52 55 5F 69 6C 6D 75 A5 BB BC CA
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3916
   Revision: B4H25---
   Coding: 0125001204771D083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
   ROD: EV_ECM20TDI01104L906026EJ_001.rod
   VCID: 76A02384C94966F72A-8022
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2014
   Revision: 00H06V07
   VCID: 3326DA909ABB33DFCD-8066
   Revision: 00000000    Serial number: 60817000001508
   Coding: 6007929F54210B734777070662C94906492AD0E2E046927DB86150F8E2AA4200002F641A1B13111435351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 77BE2E80CE431FFF31-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0435660719
   Coding: 032C0C0F03
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   VCID: 3C34F1ACB7E5FCA71C-8068
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58037761
1077250 - Transport Mode Active
          U1105 00 [008] - -
                    Fault Frequency: 25
                    Reset counter: 42
                    Mileage: 9 km
                    Date: 2017.03.30
                    Time: 14:43:30
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0021
   Serial number: Y0006QBR21177
   Coding: 0014000000000500018281818181000000008181000000D400
   ASAM Dataset: EV_SeatMemorPasseSide 002021
   ROD: EV_SeatMemorPasseSide_VW37.rod
   Part No SW: 565 907 044 AD    HW: 565 907 044 AD
   Revision: 00001K00
   Coding: 16110104003410011105100D0010110A
   Shop #: WSC 73430 790 00063
   VCID: 5DF25C284CBFD5AF4B-8008
   Air quality sensor:
   Subsystem 4 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 60413724
          B10CD 00 [008] -  -
                    Fault Frequency: 16
                    Reset counter: 42
                    Mileage: 9 km
                    Date: 2017.03.30
                    Time: 14:43:51
                    Dynamic environmental data: 02 86
                    Voltage terminal 30: 12.6 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
                    CAN input signal(s) status-Back-up light: OFF
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: 86581403170190
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017_VW27.rod
   VCID: 014A40589087514F0F-8054
   Subsystem 1 - Part No SW: 567 955 119     HW: 567 955 119
   Component: WWS326 170103  051 0905
   Serial number: 887253F0401700300225
   Coding: 065DDD
   Component: RLHS  042 0105
   Serial number: S4Y17M03D19H22M10S38
   Coding: 0088DF
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY170523HCP
   Serial number: 00000000000037810819
   Seat Backrest Fan 1 Front Left:
   Seat Cushion Fan 1 Front Left:
   Seat Backrest Fan 1 Front Right:
   Seat Cushion Fan 1 Front Right:
527872 - Transport Mode Active
          U1105 00 [008] - -
                    Fault Frequency: 72
                    Reset counter: 42
                    Mileage: 9 km
                    Date: 2017.03.30
                    Time: 14:43:36
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0021
   Serial number: 000303177478040
   Coding: 0D31267A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B36F2B0B2EBFB9F15-806E
13679388 - Databus
                    Reset counter: 60
                    Mileage: 9 km
                    Date: 2017.03.30
                    Time: 15:57:26
Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320147C950FF8728749C8065304085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001_VW37.rod
0110 - Transport Mode Active
          U1105 00 [008] - -
                    Fault Frequency: 27
                    Reset counter: 42
                    Mileage: 9 km
                    Date: 2017.03.30
                    Time: 14:43:32
                    Voltage terminal 15: 12.5 V
                    Control Module temperature: 35 ∞C
                    Longitudinal_acceleration_vehicle_reference: 0.03 m/s≤
   Serial number: 27021741350506
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383CEDBC83DDD087F8-806C
   Part No SW: 3Q0 959 655 AP    HW: 3Q0 959 655 AP
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003RAP5EZ2C4
   Coding: 98FCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 0C54616CA7C50C276C-8058
   Belt Pretensioner left:
   Serial number: 567857705A0059R01365
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 567857706A0059R00849
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 302 17
   Serial number: 35700000000A0CC0C22M
   Subsystem 4 - Part No SW: -----------    HW: 454 002 102 17
   Serial number: 3580000000086A20D22G
   Subsystem 5 - Part No SW: -----------    HW: 454 802 802 17
   Serial number: 351009E5D7D0F000000%
   Subsystem 6 - Part No SW: -----------    HW: 454 800 703 17
   Serial number: 35200E927890F000000V
   Subsystem 7 - Part No SW: -----------    HW: 454 800 203 17
   Serial number: 3550007F7D90D000000Y
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0245
   Revision: FF036036    Serial number: 20170322500173
   Coding: 6414
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH_VW37.rod
   VCID: 7CB431ACF7653CA75C-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Reset counter: 63
                    Mileage: 1048574 km
                    Ubat 30 Voltage: 13.10 V
                    Internal error state: 0
                    LIN_Temp: 0
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 255
                    Slope: 133
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    Tsoll Wert 0: 34.00 ∞C
                    Tsoll Wert 1: 39.00 ∞C
                    Tsoll Wert 2: 44.00 ∞C
Address 17: Instruments (J285)       Labels: None
   Part No SW: 565 920 951     HW: 565 920 951
   Component: KOMBI         311 8311
   Coding: 27A4081CFF84A60001886B0B7001000800000000
   Shop #: WSC 73430 031 00063
   ROD: N/A
   VCID: 5AF857345D9122972E-800E
No ASAM data for: "EV_DashBoardVDDMQBAB" ()
   Component: GW MQB High   515 5286
   Serial number: 23031710521005
   Coding: 030100344F087300EB03225E9E0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewNF_VW27.rod
   VCID: 2F2ED6E07693173FA9-807A
   Subsystem 2 - Part No SW: 3V0 919 719 D    HW: 3V0 919 719 D
   Serial number: 000000000C1156250217
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 758861000017031701B6
8531970 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 49
                    Mileage: 79 km
                    Date: 2017.04.20
                    Time: 02:11:56
                    Supply voltage: Terminal 30: 12.6 V
                    Terminal 15: OFF
   Serial number: HA1-00014.02.17
   Coding: 0101
   ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
   VCID: 4AD8A774ED3152179E-801E
   Serial number: 17000066577012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71AA1098A02741CFFF-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Serial number: Y0006QBS11805
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 3C: Lane Change (J1086)       Labels: None
   Serial number: 0433913037
   Coding: 02012203
   ROD: EV_HREntryHella_VW32.rod
   Lane Change Assistant 2:
   Component: TSG FS        010 0032
   Serial number: 0000246863683
   Coding: 00158820DE01048000001100
   VCID: 47DE9E40FE23AF7F81-8012
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 45C29448C42FBD6F73-8010
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1HJE01GAUJ
   Coding: 0323160000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
   ROD: N/A
   VCID: 59FA48385897298F27-800C
No ASAM data for: "EV_AMPMst16C4Gen2ALPI" (VW48)
15360256 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 42
                    Mileage: 9 km
                    Date: 2017.03.30
                    Time: 14:47:26
   Component: TSG BFS       010 0032
   Serial number: 0000246545101
   Coding: 00158020DE01048000001100
   VCID: 46C09344F929B6777A-8012
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Coding: 03E602003D210901
   ROD: N/A
   VCID: 41CA8058D007914F4F-8014
No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VW52)
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 021 D    HW: 3V0 035 021
   Component: MU-H-LND-EU   H50 0942
   Serial number: A674C0HS022730
   Coding: 032316010000000051111202008808332F0300E6012081009E
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 281C3DFC537D400768-807C
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H35 8077
   Serial number: SKZ6ZET0771767
   Subsystem 2 - Part No SW: V03 959 801 JM    HW: -----------
   Component: ECE 2017  --- 0157
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0435603998
   Coding: 0100000202000000
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG011946
   Coding: 04231601A30FA00000604894
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31257774700000
   Coding: 1B88
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5NA 035 284 A    HW: 5NA 035 284 A
   Component: OCULowMQBLGE  H13 0614
   Coding: 03231601EA423A0D3B1C9E020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 003042
   ROD: EV_OCULowMQBLGE.rod
12866050 - Terminal 15
          B1148 29 [008] - Signal Implausible
                    Reset counter: 42
                    Mileage: 9 km
                    Date: 2017.03.30
                    Time: 14:47:56
                    Voltage terminal 30: 13.4 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Serial number: 19031711K21799
   Coding: 020307060000040100062355C050A90098000E200020
   ROD: EV_MFKBoschMQBB_VW36.rod
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       011 0032
   Serial number: 0000234327541
   Coding: 001880208001048000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   VCID: 49DA9878E837590F97-801C
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      011 0032
   Serial number: 0000234327488
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
Address CA: Sunroof (J245)       Labels: None
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 308040648202
   ROD: EV_SunRoofCONTIAU736.rod
   VCID: 3D32FCA8ACFFF5AF2B-8068
End----------(Elapsed Time: 02:32, VBatt start/end: 12.5V/12.5V)-----------
Gizmo
S.E.Kent UK
C?ID=49193
All DTCs cleared after the scan above, looks like the car was not scanned after the PDI
Gizmo
S.E.Kent UK
C?ID=49193
01 Admap:
[TABLE="width: 1083"]
[TR]
[TD];SW:04L-906-026-EJ   HW:04L-907-309-P ---  Engine[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];Component:R4 2.0l TDI   H25 3916[/TD]
[TD="colspan: 2"] Coding:0125001204771D083000[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];EV_ECM20TDI01104L906026EJ[/TD]
[TD="align: right"]4004[/TD]
[TD="colspan: 4"]EV_ECM20TDI01104L906026EJ_001.rod[/TD]
[/TR]
[TR]
[TD];Monday[/TD]
[TD="align: right"]1[/TD]
[TD]May[/TD]
[TD="align: right"]2017[/TD]
[TD="colspan: 2"]11:09:52:36443[/TD]
[/TR]
[TR]
[TD];VCDS Version: Beta 17.4.1  Data version: 20170413 DS270.4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];VCID: 76A02384C94966F72A-8022[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-Production mode[/TD]
[TD]00 00 00[/TD]
[TD="align: right"]3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00263-Injector 1 correction value[/TD]
[TD]7ZZIH1A[/TD]
[TD="align: right"]7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00264-Injector 2 correction value[/TD]
[TD]7RRPD1B[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00265-Injector 3 correction value[/TD]
[TD]AASLFNB[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00266-Injector 4 correction value[/TD]
[TD]8H8SCN8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01096-Particulate Filter Statistics[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01711-Blocking of particle filter regeneration[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01945-Engine run-in oil pressure[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02248-Individually adjustable maximum speed limit[/TD]
[TD]300.0 km/h[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02332-Deactivate production mode[/TD]
[TD]00 00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02637-Adaptation for metering quantity measurement[/TD]
[TD="align: right"]4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04158-Activation of start-stop function[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04617-Protective function[/TD]
[TD]Enabled[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06425-Roller test bench mode: functional[/TD]
[TD]not activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07903-Adaptation of ash mass[/TD]
[TD]0.13 g[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08287-Bleeding of coolant circuit[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10309-Adaptation of oxidation catalytic converter ageing[/TD]
[TD]6400 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105853-MAS04051-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation for precontrol and damping[/TD]
[TD]Not blocked[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105853-MAS04052-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation of pressure sensor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Elapsed Time: 00:05[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
09 Admap:
[TABLE="width: 2445"]
[TR]
[TD];SW:5Q0-937-086-BH   HW:5Q0-937-086-BH ---  Cent. Elect.[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];Component:BCM PQ37BOSCH 032 0223[/TD]
[TD] Coding:[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];EV_BodyContrModul1UDSBosc[/TD]
[TD="align: right"]17002[/TD]
[TD="colspan: 3"]EV_BCMBOSCH_017_VW27.rod[/TD]
[TD][/TD]
[/TR]
[TR]
[TD];Monday[/TD]
[TD]May[/TD]
[TD="colspan: 2"]11:10:21:36443[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];VCID: 014A40589087514F0F-8054[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG99061-Production mode-Access control[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG115730-Production mode-Aussenbeleuchtung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG112304-Production mode-Heckwischer[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG98647-Production mode-Interior lighting[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG115729-Production mode-Scheinwerferreinigung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG115731-Production mode-Virtuel_pedal[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00002-Transport mode[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00820-Activating and deactivating all development messages[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01550-Service position[/TD]
[TD]157.999843 °[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02152-Characteristics in production mode[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking[/TD]
[TD]Decelerate[/TD]
[TD="align: right"]10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn[/TD]
[TD]normal[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG11176-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG11175-Acknowledgement signals-ZV-Blinken_Dunkelzeit[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG11174-Acknowledgement signals-ZV-Blinken_Hellzeit[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02488-DWA Interior monitoring[/TD]
[TD="align: right"]100%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen[/TD]
[TD]active[/TD]
[TD="align: right"]8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1[/TD]
[TD]8 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2[/TD]
[TD]16 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG112304-Rear Window Wiper-Heckwischer[/TD]
[TD]logikgesteuert[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1[/TD]
[TD]5 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2[/TD]
[TD]3 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik[/TD]
[TD]7 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall[/TD]
[TD]7 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG23759-Rear Window Wiper-Zeit_wasch_min_heck[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-IDE04231-static AFS light-Steering wheel angle: offset[/TD]
[TD]-0.3 °[/TD]
[TD="align: right"]16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit[/TD]
[TD]26.5 %/s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt[/TD]
[TD]both sides[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116675-static AFS light-Lower speed threshold[/TD]
[TD]0.0 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116682-static AFS light-Maximaltemperatur[/TD]
[TD]1.0 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116679-static AFS light-obere Grenztemperatur[/TD]
[TD]127.5 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel[/TD]
[TD]55 °[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116680-static AFS light-untere Grenztemperatur[/TD]
[TD]127.0 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel[/TD]
[TD]30 °[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116676-static AFS light-Upper speed threshold[/TD]
[TD]40.0 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116674-static AFS light-Vorschrift[/TD]
[TD]ECE R119[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht[/TD]
[TD]17 min[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03787-Activate left/right hand drive switch-over[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-IDE01446-Window heater-Running time of heated front window[/TD]
[TD]600 s[/TD]
[TD="align: right"]11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung[/TD]
[TD]35.0 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung[/TD]
[TD]35.0 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG11179-Window heater-Frontscheibenheizung _maximale_Dauer[/TD]
[TD]0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG10963-Window heater-Frontscheibenheizung_LED_direkt[/TD]
[TD]not installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG10946-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG126845-Window heater-FSH Automatik[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert[/TD]
[TD]600 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG10883-Window heater-heizbare Heckscheibe[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG10949-Window heater-Heizbare_Frontscheibe[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG10890-Window heater-Waschduesenheizung[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG23738-Window heater-window heating front activation time pause[/TD]
[TD]240 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-MAS01577-Anti-theft device-Parking heater[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115864-Anti-theft device-Alarmsignal[/TD]
[TD]frequency modulated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG10888-Anti-theft device-Anti-theft alarm system[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung[/TD]
[TD]driver door contact thatcham[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115812-Anti-theft device-DWA Camper Modus[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG10935-Anti-theft device-DWA_Einfachhorn_oder_Sounder[/TD]
[TD]Sounder_verbaut[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG10889-Anti-theft device-Heckscheibenbruchsensor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG10934-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG11177-Anti-theft device-OBD Alarm[/TD]
[TD]activ[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG10937-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG10938-Anti-theft device-Sensor_fuer_Innenraumueberwachung[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl[/TD]
[TD]10 Alarme[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG10936-Anti-theft device-tilt_sensor[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm[/TD]
[TD]2 sekunden verzoegerung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05143-MAS02985-Writing parameter-Value[/TD]
[TD="align: right"]130[/TD]
[TD="align: right"]5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05143-MAS04381-Writing parameter-Parameter address[/TD]
[TD]FE 00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05144-Read parameter address[/TD]
[TD]FE 00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05145-Light configuration[/TD]
[TD]00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 38 00 24 12 16 64 1E 00 64 00 00 00 00 00 00 04 42 00 25 13 17 64 1E 00 64 00 00 00 00 00 00 01 42 00 23 13 17 7F 1E 00 7F 00 00 00 00 00 00 01 38 00 22 12 16 7F 1E 00 7F 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 0A 08 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 09 08 7F 00 00 00 00 00 00 29 45 00 1E 46 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00[/TD]
[TD="align: right"]224[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05822-DWA Vehicle inclination sensor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05823-DWA Interior monitoring parameter set[/TD]
[TD]01 0A 08 00 43 53 0A C6 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 65 63 57 9B 25 44 3F 3A 69 58 95 1F 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 53 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 53 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 52 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 65 53 57 9B 25 24 0C FA 0A 34 95 1F 09 A3 21 03 00 02 02 02 02 02 02 B1 40 E1 28 FE[/TD]
[TD="align: right"]172[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG10904-Seat heater level current consumption allocation-Sitzheitzung_CAN[/TD]
[TD]Heizmatten am BCM[/TD]
[TD="align: right"]30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss[/TD]
[TD]1 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss[/TD]
[TD]0.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle[/TD]
[TD]33.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle[/TD]
[TD]32.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle[/TD]
[TD]33.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle[/TD]
[TD]32.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle[/TD]
[TD]38.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle[/TD]
[TD]37.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle[/TD]
[TD]38.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle[/TD]
[TD]37.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle[/TD]
[TD]43.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle[/TD]
[TD]42.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle[/TD]
[TD]43.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle[/TD]
[TD]42.00 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG10905-Seat heater level current consumption allocation-Sitzheizungsfreigabe[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-MAS13125-Button in center console-Function of button 1[/TD]
[TD]Start-stop[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-MAS13129-Button in center console-Function of button 2[/TD]
[TD]Offroad[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-MAS13132-Button in center console-Function of button 3[/TD]
[TD]Driving program[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-MAS13135-Button in center console-Function of button 4[/TD]
[TD]not coded/not installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-ENG09171-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED[/TD]
[TD]LED installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG11181-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG11180-A/C heater function via remote control-Abbruch_Hupen_RSt[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG11183-A/C heater function via remote control-Aktivierung_Drehzahlanzeige[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG11182-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG115720-A/C heater function via remote control-Remotestart[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07356-Position during interval mode[/TD]
[TD]21.999978 °[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs[/TD]
[TD]abschalten nach der Nachlaufzeit[/TD]
[TD="align: right"]6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit[/TD]
[TD]30 min[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen[/TD]
[TD]active[/TD]
[TD="align: right"]9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG10884-Assistance light functions-Humidity sensor[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit[/TD]
[TD]normal[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG11156-Assistance light functions-Maskierung_Regenfunktion[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG10913-Assistance light functions-Regen_Lichtsensor[/TD]
[TD]LIN_REGEN_LICHT_SENSOR[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG124476-Assistance light functions-Sunlight Sensor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit[/TD]
[TD]0.40 s[/TD]
[TD="align: right"]19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach[/TD]
[TD="align: right"]80%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum[/TD]
[TD="align: right"]20%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer[/TD]
[TD="align: right"]30%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn[/TD]
[TD="align: right"]0%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG11161-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG10959-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG11112-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG114629-Interior light: light configuration-Foot well lighting[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne[/TD]
[TD="align: right"]17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne[/TD]
[TD="align: right"]50%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne[/TD]
[TD="align: right"]70%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG10952-Seat fan charac. curve-Sitzlueftung[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG11111-Seat fan charac. curve-Sitzlueftung_reduzierbar[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG10953-Seat fan charac. curve-Sitzpneumatik[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10298-Alternating park position 1[/TD]
[TD]0.000000 °[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10299-Alternating park position 2[/TD]
[TD]18.296685 °[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit[/TD]
[TD="align: right"]256[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer[/TD]
[TD="align: right"]0.37[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2[/TD]
[TD="align: right"]110000[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2[/TD]
[TD="align: right"]1100[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI[/TD]
[TD="align: right"]11001[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum[/TD]
[TD="align: right"]40%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht[/TD]
[TD="align: right"]10%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren[/TD]
[TD="align: right"]37%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum[/TD]
[TD="align: right"]127%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit[/TD]
[TD="align: right"]126%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum[/TD]
[TD="align: right"]125%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum[/TD]
[TD]1.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1[/TD]
[TD="align: right"]71[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02360-Ambient light color list-Blauwert Farbe 10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02342-Ambient light color list-Blauwert Farbe 4[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02345-Ambient light color list-Blauwert Farbe 5[/TD]
[TD="align: right"]106[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02348-Ambient light color list-Blauwert Farbe 6[/TD]
[TD="align: right"]182[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02351-Ambient light color list-Blauwert Farbe 7[/TD]
[TD="align: right"]254[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02354-Ambient light color list-Blauwert Farbe 8[/TD]
[TD="align: right"]153[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02357-Ambient light color list-Blauwert Farbe 9[/TD]
[TD="align: right"]4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1[/TD]
[TD="align: right"]231[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02359-Ambient light color list-Gruenwert Farbe 10[/TD]
[TD="align: right"]132[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2[/TD]
[TD="align: right"]200[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3[/TD]
[TD="align: right"]73[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02341-Ambient light color list-Gruenwert Farbe 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02344-Ambient light color list-Gruenwert Farbe 5[/TD]
[TD="align: right"]134[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02347-Ambient light color list-Gruenwert Farbe 6[/TD]
[TD="align: right"]140[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02350-Ambient light color list-Gruenwert Farbe 7[/TD]
[TD="align: right"]110[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02353-Ambient light color list-Gruenwert Farbe 8[/TD]
[TD="align: right"]255[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02356-Ambient light color list-Gruenwert Farbe 9[/TD]
[TD="align: right"]245[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1[/TD]
[TD="align: right"]120[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02358-Ambient light color list-Rotwert Farbe 10[/TD]
[TD="align: right"]57[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3[/TD]
[TD="align: right"]173[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02340-Ambient light color list-Rotwert Farbe 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02343-Ambient light color list-Rotwert Farbe 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02346-Ambient light color list-Rotwert Farbe 6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02349-Ambient light color list-Rotwert Farbe 7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02352-Ambient light color list-Rotwert Farbe 8[/TD]
[TD="align: right"]29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG02355-Ambient light color list-Rotwert Farbe 9[/TD]
[TD="align: right"]58[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG10942-Keyless access and start authorization-Elektische_Lenkradverriegelung[/TD]
[TD]installed[/TD]
[TD="align: right"]3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG10876-Keyless access and start authorization-Kessy[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG10955-Energy management-Energiemanagement Abschaltung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG116830-Energy management-Energy_Management_Adaptation[/TD]
[TD]Energy management active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG11184-Energy management-Hochvoltfahrzeug[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG10878-Energy management-Hybrid vehicle[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG10906-Energy management-Recuperation[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG10965-Energy management-Zweitbatterie[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS05055-lower turn position[/TD]
[TD]20.692287 °[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS05056-upper turn position[/TD]
[TD]159.999841 °[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze[/TD]
[TD]1200 lx[/TD]
[TD="align: right"]24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze[/TD]
[TD]2200 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle[/TD]
[TD]59395 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO[/TD]
[TD]600 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten[/TD]
[TD]1200 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten[/TD]
[TD]2200 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red[/TD]
[TD]50 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell[/TD]
[TD]2000 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG11158-Light sensor-HMI_Exterior_light_on_highway[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG11159-Light sensor-HMI_Exterior_light_on_rain[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG11160-Light sensor-HMI_exterior_light_sensitivity[/TD]
[TD]frueh[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG11157-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung[/TD]
[TD]37905 mV[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke[/TD]
[TD]225300 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung[/TD]
[TD]53255 mV[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10611-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10611-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10611-ENG10903-Allwetterlicht_Spoiler-tt_spoiler[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1[/TD]
[TD="align: right"]1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1[/TD]
[TD]multicolor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10[/TD]
[TD]not installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2[/TD]
[TD]multicolor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12[/TD]
[TD="align: right"]60[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5[/TD]
[TD="align: right"]5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7[/TD]
[TD="align: right"]7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8[/TD]
[TD="align: right"]8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5[/TD]
[TD="align: right"]12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6[/TD]
[TD="align: right"]13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7[/TD]
[TD="align: right"]16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122212-Außenlicht_Blinker-ABBA_Blinken[/TD]
[TD]not active[/TD]
[TD="align: right"]10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG02307-Außenlicht_Blinker-Abbruch Komfortblinken[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger[/TD]
[TD]separte[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG121966-Außenlicht_Blinker-Crash flashing[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG11122-Außenlicht_Blinker-dynamisch_blinken_10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG11123-Außenlicht_Blinker-Dynamische_Blink_Delay[/TD]
[TD]50 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG115774-Außenlicht_Blinker-Komfortblinken[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG121967-Außenlicht_Blinker-Panic flashing[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG121968-Außenlicht_Blinker-Taxi alarm flashing[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG10957-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10577-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG10914-Außenlicht_Front-Abblendlicht_Leuchtentyp[/TD]
[TD]H7[/TD]
[TD="align: right"]9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze[/TD]
[TD]50 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze[/TD]
[TD]50 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG115833-Außenlicht_Front-Fahrlicht bei Tag[/TD]
[TD]Daytime running lights[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG11121-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL[/TD]
[TD]5 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG11119-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG11118-Außenlicht_Front-Signaturlicht_verbaut[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG11120-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10575-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren[/TD]
[TD]in Betrieb lassen[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10576-ENG10915-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10576-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit[/TD]
[TD]0 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10576-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10576-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10576-ENG10932-Aussenlicht_Heck-Umgreifende_Heckklappe[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG10948-Außenlicht_uebergreifend-All-weather lights[/TD]
[TD="align: right"]18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG02309-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung[/TD]
[TD]abschaltbar über Energiemanagement[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG02308-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG11116-Außenlicht_uebergreifend-bewusstes Standlicht[/TD]
[TD]Aktive Begrenzung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten[/TD]
[TD]Low beam[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus[/TD]
[TD]automatic[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis[/TD]
[TD]Driver door[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig[/TD]
[TD]kein_Hinweis[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG02310-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer[/TD]
[TD]Faktor fuer x5 Minuten[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung[/TD]
[TD]46400 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung[/TD]
[TD]12 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG11117-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht[/TD]
[TD]integriert in Suchbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG11113-Außenlicht_uebergreifend-LCM_blinker[/TD]
[TD]false[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG10920-Außenlicht_uebergreifend-LDS_mit_AFL[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG10919-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG10918-Außenlicht_uebergreifend-LDS_mit_Nebellicht[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG10921-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus[/TD]
[TD]Enabled[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG10917-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)[/TD]
[TD]discrete[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten[/TD]
[TD]klemmenabhaengig[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG10962-Außenlicht_uebergreifend-Light_Control_Module[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO[/TD]
[TD]Menuesteuerung Zeit aktivieren[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome[/TD]
[TD]10 seconds[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP[/TD]
[TD]10 seconds[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert[/TD]
[TD]One-sided[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG126816-Außenlicht_uebergreifend-Standlicht aus[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG02311-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit[/TD]
[TD]24 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10584-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG98399-debug_light_function-Activation[/TD]
[TD="align: right"]11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG101417-debug_light_function-Adresse[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG126820-debug_light_function-Bitmask[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG126821-debug_light_function-Divisor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG98827-debug_light_function-Offset[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG126822-debug_light_function-Polaritaet[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10603-ENG115658-Dimmunt_KL_58xs_PWM-x0[/TD]
[TD="align: right"]0.00%[/TD]
[TD="align: right"]6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10603-ENG101574-Dimmunt_KL_58xs_PWM-X1[/TD]
[TD="align: right"]50.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10603-ENG99557-Dimmunt_KL_58xs_PWM-X2[/TD]
[TD="align: right"]100.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10603-ENG115659-Dimmunt_KL_58xs_PWM-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10603-ENG99777-Dimmunt_KL_58xs_PWM-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10603-ENG100480-Dimmunt_KL_58xs_PWM-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10578-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP[/TD]
[TD]present[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10578-ENG10901-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung[/TD]
[TD]AFS: FLA: Fernlicht ueber AFS[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10578-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10578-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent[/TD]
[TD]present[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10578-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung[/TD]
[TD]present[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG11178-Front_wiper-Anfahrzeit_servicestellung[/TD]
[TD]800 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG115836-Front_wiper-Frontwischer Notlaufprogramm[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG116614-Front_wiper-Frontwischer Referenzlauf[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG02322-Front_wiper-Frontwischer_Abtauposition[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG10894-Front_wiper-Frontwischertyp[/TD]
[TD]LIN[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG116615-Front_wiper-Menuesteuerung Frontwischer[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG23634-Front_wiper-Mindestwaschzeit_Frontwischer[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG115771-Front_wiper-Regensensor aktivieren[/TD]
[TD]Deactivating[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG23718-Front_wiper-Timer_DWP_SRA_delay[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG116618-Front_wiper-Traenenwischen Front Status[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG115770-Front_wiper-Variable Regensensoraktivierung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG126844-Front_wiper-Washer_Tipwiping_Variant[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG116612-Front_wiper-Wischer stop bei KL15 aus[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10610-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG99457-ENG117394-Head area heater-blower_speed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG99457-ENG98971-Head area heater-Temperature[/TD]
[TD="align: right"]-2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-MAS00211-HW_Verbau-Insufficient brake fluid[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-MAS00212-HW_Verbau-Insufficient washer fluid[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-MAS00213-HW_Verbau-Insufficient coolant[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-MAS00214-HW_Verbau-Brake pad wear[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG10954-HW_Verbau-Druckklappe[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG10891-HW_Verbau-Elektrische Laderaumabdeckung aktiv[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG10940-HW_Verbau-Elektrische_Laderaumabdeckung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG10880-HW_Verbau-Exterior temp. sensor[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG10933-HW_Verbau-Kontaktschalter_fuer_Motorhaube[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG11114-HW_Verbau-Ladesteckerverriegelung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG10964-HW_Verbau-PTC Zuheizer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG115809-HW_Verbau-Signalhorn ohne KL15[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10573-ENG10931-HW_Verbau-Status_Tankdeckelverriegelung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG115658-Kennlinie_sLWR_Soll-x0[/TD]
[TD="align: right"]-100.00%[/TD]
[TD="align: right"]30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG101574-Kennlinie_sLWR_Soll-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG99557-Kennlinie_sLWR_Soll-X2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG102140-Kennlinie_sLWR_Soll-X3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG102936-Kennlinie_sLWR_Soll-X4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG103548-Kennlinie_sLWR_Soll-X5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG113992-Kennlinie_sLWR_Soll-X6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG115661-Kennlinie_sLWR_Soll-x7[/TD]
[TD="align: right"]-100[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG115662-Kennlinie_sLWR_Soll-x8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG115663-Kennlinie_sLWR_Soll-x9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG115659-Kennlinie_sLWR_Soll-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG99777-Kennlinie_sLWR_Soll-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG100480-Kennlinie_sLWR_Soll-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG100773-Kennlinie_sLWR_Soll-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG100631-Kennlinie_sLWR_Soll-Y4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG102174-Kennlinie_sLWR_Soll-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG113993-Kennlinie_sLWR_Soll-Y6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG115665-Kennlinie_sLWR_Soll-y7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG115666-Kennlinie_sLWR_Soll-y8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10588-ENG115667-Kennlinie_sLWR_Soll-y9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15[/TD]
[TD="align: right"]100[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15[/TD]
[TD]36 - LED Kleinleistung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10585-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10[/TD]
[TD="align: right"]127[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10[/TD]
[TD]1E[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10[/TD]
[TD="align: right"]45[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10[/TD]
[TD]41 - LED Kleinleistung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10[/TD]
[TD]Versorgungsbedarf der LCM Module[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16[/TD]
[TD="align: right"]27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16[/TD]
[TD]3F[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16[/TD]
[TD]43 - allgemeine LED[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16[/TD]
[TD]Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16[/TD]
[TD]Parking light right[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17[/TD]
[TD="align: right"]26[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17[/TD]
[TD="align: right"]35[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17[/TD]
[TD]Parklicht links (beidseitiges Parklicht aktiviert li & re)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18[/TD]
[TD]38 - LED Blinkleuchten[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18[/TD]
[TD]Blinken links Hellphase[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19[/TD]
[TD]Blinken rechts Hellphase[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20[/TD]
[TD]2B[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20[/TD]
[TD]34 - LED Bremsleuchten[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20[/TD]
[TD]Brake light[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21[/TD]
[TD]2D[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21[/TD]
[TD="align: right"]19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22[/TD]
[TD="align: right"]32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22[/TD]
[TD]2C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22[/TD]
[TD="align: right"]29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22[/TD]
[TD]Quittierungsfunktion 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23[/TD]
[TD]0A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24[/TD]
[TD]2A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24[/TD]
[TD]1A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24[/TD]
[TD]not active[/TD]
[TD="align: right"]16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25[/TD]
[TD="align: right"]28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26[/TD]
[TD]2F[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26[/TD]
[TD]1C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26[/TD]
[TD]only_if_closed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26[/TD]
[TD]Nebelschlusslicht wenn kein Anhaenger gesteckt[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28[/TD]
[TD="align: right"]31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28[/TD]
[TD]0B[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28[/TD]
[TD]Rueckfahrlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29[/TD]
[TD]1B[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2[/TD]
[TD="align: right"]24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2[/TD]
[TD="align: right"]38[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2[/TD]
[TD]4 - LED Tagfahrlichtmodul Signal[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2[/TD]
[TD]Nebellicht links[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2[/TD]
[TD]Abbiegelicht links[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2[/TD]
[TD]Coming Home oder Leaving Home aktiv[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30[/TD]
[TD]Footwell light[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31[/TD]
[TD="align: right"]3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31[/TD]
[TD]Ambientelicht 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32[/TD]
[TD="align: right"]4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32[/TD]
[TD]Ambientelicht 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33[/TD]
[TD="align: right"]5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33[/TD]
[TD]Ambientelicht 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34[/TD]
[TD="align: right"]6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34[/TD]
[TD]Ambientelicht 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3[/TD]
[TD="align: right"]100[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3[/TD]
[TD="align: right"]25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3[/TD]
[TD="align: right"]42[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3[/TD]
[TD]Nebellicht rechts[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3[/TD]
[TD]Abbiegelicht rechts[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4[/TD]
[TD="align: right"]127[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4[/TD]
[TD="align: right"]23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4[/TD]
[TD]1 - LED Tagfahrlichtmodul Versorgung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5[/TD]
[TD="align: right"]22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6[/TD]
[TD]1A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6[/TD]
[TD="align: right"]36[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6[/TD]
[TD]5 - LED Abblendlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6[/TD]
[TD]Abblendlicht links[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6[/TD]
[TD]Lichthupe generell[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7[/TD]
[TD]1B[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7[/TD]
[TD="align: right"]40[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7[/TD]
[TD]Abblendlicht rechts[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8[/TD]
[TD]4B[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8[/TD]
[TD="align: right"]44[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8[/TD]
[TD]Versorgungsbedarf der LCM Module[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8[/TD]
[TD]Parking light right[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8[/TD]
[TD]Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9[/TD]
[TD="align: right"]49[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9[/TD]
[TD]3A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9[/TD]
[TD]Parklicht links (beidseitiges Parklicht aktiviert li & re)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10589-Leuchtenkonfiguration_Aussenlich_Heck[/TD]
[TD]26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 24 00 20 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1A 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00[/TD]
[TD="align: right"]192[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10590-Leuchtenkonfiguration_Sonstiges[/TD]
[TD]2B 3F 00 27 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 35 00 26 08 09 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00[/TD]
[TD="align: right"]128[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11125-Leuchtweitenregulierung-1_Sensor_LWR[/TD]
[TD]1-Sensor_LWR[/TD]
[TD="align: right"]62[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11147-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges[/TD]
[TD]2700 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11146-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4[/TD]
[TD]5.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11145-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn[/TD]
[TD]3.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11129-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11139-Leuchtweitenregulierung-Ansteuerung_obere_grenze[/TD]
[TD="align: right"]100.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11138-Leuchtweitenregulierung-Ansteuerung_untere_grenze[/TD]
[TD="align: right"]0.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11137-Leuchtweitenregulierung-diagnose_soll_toleranz[/TD]
[TD="align: right"]15%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11131-Leuchtweitenregulierung-Entprellung_Fehlerlampe[/TD]
[TD]10.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11142-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1[/TD]
[TD]5.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11144-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2[/TD]
[TD]5.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11141-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1[/TD]
[TD]3.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11143-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2[/TD]
[TD]3.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11126-Leuchtweitenregulierung-Fahrwerk_Variante[/TD]
[TD]Verbundlenkerhinterachse[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11132-Leuchtweitenregulierung-Fail_Safe_sLWR[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11151-Leuchtweitenregulierung-fFiltEinf[/TD]
[TD]0.03 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11140-Leuchtweitenregulierung-Lineare_Abbildung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11130-Leuchtweitenregulierung-Logik_PWM_Signal[/TD]
[TD]Negative[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG23630-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG23631-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG23632-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG23633-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11148-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand[/TD]
[TD]550 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11149-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe[/TD]
[TD]680 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11154-Leuchtweitenregulierung-lwr_pwm_obere_schwelle[/TD]
[TD="align: right"]95.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11153-Leuchtweitenregulierung-lwr_pwm_untere_schwelle[/TD]
[TD="align: right"]5.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11155-Leuchtweitenregulierung-max_v_slwr[/TD]
[TD]255 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11150-Leuchtweitenregulierung-pa_fDynFiltStatLwr[/TD]
[TD]100 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11152-Leuchtweitenregulierung-pa_fFiltSwNeigung[/TD]
[TD]0.03 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11128-Leuchtweitenregulierung-Quelle_Hoehenwerte[/TD]
[TD]BCM[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG10970-Leuchtweitenregulierung-sensor_headlight_range_control_installed[/TD]
[TD]not installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11127-Leuchtweitenregulierung-sLWR_bei_Abblendlicht[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11136-Leuchtweitenregulierung-sLWR_Hysterese[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG23704-Leuchtweitenregulierung-sLWR_nach_Motorstart[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11135-Leuchtweitenregulierung-sLWR_SW_Grad[/TD]
[TD]1000.0 %/s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11134-Leuchtweitenregulierung-sLWR_Touristenlicht[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11124-Leuchtweitenregulierung-sLWR_verbaut[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10586-ENG11133-Leuchtweitenregulierung-Zyklus_sLWR[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1[/TD]
[TD]not active[/TD]
[TD="align: right"]1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0[/TD]
[TD="align: right"]12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2[/TD]
[TD="align: right"]50.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3[/TD]
[TD="align: right"]75.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4[/TD]
[TD="align: right"]110[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5[/TD]
[TD="align: right"]126.5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1[/TD]
[TD="align: right"]6.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2[/TD]
[TD="align: right"]16.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3[/TD]
[TD="align: right"]30.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4[/TD]
[TD="align: right"]60.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG115658-lwr_ofs_RSw_Ah1S-x0[/TD]
[TD="align: right"]-3.71%[/TD]
[TD="align: right"]20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG101574-lwr_ofs_RSw_Ah1S-X1[/TD]
[TD="align: right"]-2.96%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG99557-lwr_ofs_RSw_Ah1S-X2[/TD]
[TD="align: right"]-2.04%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG102140-lwr_ofs_RSw_Ah1S-X3[/TD]
[TD="align: right"]-1.48%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG102936-lwr_ofs_RSw_Ah1S-X4[/TD]
[TD="align: right"]-0.37%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG115659-lwr_ofs_RSw_Ah1S-y0[/TD]
[TD="align: right"]-0.2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG99777-lwr_ofs_RSw_Ah1S-Y1[/TD]
[TD="align: right"]-0.1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG100480-lwr_ofs_RSw_Ah1S-Y2[/TD]
[TD="align: right"]-0.05[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG100773-lwr_ofs_RSw_Ah1S-Y3[/TD]
[TD="align: right"]-0.01[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10587-ENG100631-lwr_ofs_RSw_Ah1S-Y4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG10972-OCU-DWA_push[/TD]
[TD]active[/TD]
[TD="align: right"]8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG11188-OCU-Honk DWA_Ausgabe_Fanfare[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG124714-OCU-[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG11189-OCU-Remote HuF Abbruch[/TD]
[TD]20 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG11190-OCU-Remote HuF Hupfrequenz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG02319-OCU-Remote Lock Unlock Timer s1[/TD]
[TD]80 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG02320-OCU-Remote Lock Unlock Timer s3[/TD]
[TD]20.0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG125657-OCU-Remote_Unlock_Lock[/TD]
[TD]Via BAP / Fazit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG02329-Personalization-Anzahl_Benutzerkonten[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG02330-Personalization-Automatische_ Schluesselzuordnung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG126848-Personalization-Personalisierung_aktiv[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG10922-Personalization-Personalisierung_Profilfunkion[/TD]
[TD]profiles_active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG10958-Personalization-Profil_Variante[/TD]
[TD]Konto (v. 1.x)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG02332-Personalization-PSO_FSG_Setup2_Bit_1[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG02333-Personalization-PSO_FSG_Setup2_Bit_2[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG02334-Personalization-PSO_FSG_Setup2_Bit_3[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG02335-Personalization-PSO_FSG_Setup2_Bit_4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-MAS01065-Querschnitts_funktionen-Brand[/TD]
[TD]VW[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG10908-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG10895-Querschnitts_funktionen-Codierungsabsicherung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG10956-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG11115-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus[/TD]
[TD]Pin 31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG10892-Querschnitts_funktionen-Lenkungsanordnung[/TD]
[TD]Right[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG10943-Querschnitts_funktionen-Personalisierungsuebernahme[/TD]
[TD]not_installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG10911-Querschnitts_funktionen-Schnittstelle_TrackingSystem[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10574-ENG10893-Querschnitts_funktionen-Verkehrsseite[/TD]
[TD]Left[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung[/TD]
[TD="align: right"]10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG10877-Scheinwerferreinigung-Headlamp washer system[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit[/TD]
[TD]800 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit[/TD]
[TD]600 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09729-Slave_systems_identification-Control Unit For Wiper Motor[/TD]
[TD]Not available[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09730-Slave_systems_identification-Rain Light Recognition Sensor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09731-Slave_systems_identification-Light switch[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09732-Slave_systems_identification-Garage door opener control module[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09733-Slave_systems_identification-Garage Door Opener Operating Unit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09750-Slave_systems_identification-Sensor For Anti Theft Alarm System[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09752-Slave_systems_identification-Alarm horn[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09760-Slave_systems_identification-Sun Roof[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09766-Slave_systems_identification-Ceiling Light Module[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09784-Slave_systems_identification-Roof Blind[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09803-Slave_systems_identification-Relative Air Humidity Interior Sender[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09822-Slave_systems_identification-Neck Heating Left[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09823-Slave_systems_identification-Neck Heating Right[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09921-Slave_systems_identification-Seat Backrest Fan 1 Front Left[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09923-Slave_systems_identification-Seat Cushion Fan 1 Front Left[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09925-Slave_systems_identification-Seat Backrest Fan 1 Front Right[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10612-SFT09927-Slave_systems_identification-Seat Cushion Fan 1 Front Right[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker[/TD]
[TD]SMLS[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116588-ENG116588-Sonderfunktionen-[/TD]
[TD]not enabled[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116588-ENG10907-Sonderfunktionen-Sonderfunktionen 1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG116658-Spiegelverstellung-Funk Spiegelanklappen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus[/TD]
[TD]by look command via remote control key[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG02339-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10563-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0[/TD]
[TD]0.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1[/TD]
[TD]8.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2[/TD]
[TD]50.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3[/TD]
[TD]80.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4[/TD]
[TD]100.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3[/TD]
[TD="align: right"]50[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10606-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0[/TD]
[TD]0.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1[/TD]
[TD]8.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2[/TD]
[TD]50.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3[/TD]
[TD]80.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4[/TD]
[TD]100.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10607-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115658-Suchbeleuchtung_Abdimmen-x0[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG101574-Suchbeleuchtung_Abdimmen-X1[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115664-Suchbeleuchtung_Abdimmen-x10[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG99557-Suchbeleuchtung_Abdimmen-X2[/TD]
[TD]400 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG102140-Suchbeleuchtung_Abdimmen-X3[/TD]
[TD]600 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG102936-Suchbeleuchtung_Abdimmen-X4[/TD]
[TD]800 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG103548-Suchbeleuchtung_Abdimmen-X5[/TD]
[TD]1000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG113992-Suchbeleuchtung_Abdimmen-X6[/TD]
[TD]1200 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115661-Suchbeleuchtung_Abdimmen-x7[/TD]
[TD]1400 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115662-Suchbeleuchtung_Abdimmen-x8[/TD]
[TD]1600 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115663-Suchbeleuchtung_Abdimmen-x9[/TD]
[TD]1800 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115659-Suchbeleuchtung_Abdimmen-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG99777-Suchbeleuchtung_Abdimmen-Y1[/TD]
[TD="align: right"]72.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115668-Suchbeleuchtung_Abdimmen-y10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG100480-Suchbeleuchtung_Abdimmen-Y2[/TD]
[TD="align: right"]48.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG100773-Suchbeleuchtung_Abdimmen-Y3[/TD]
[TD="align: right"]33.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG100631-Suchbeleuchtung_Abdimmen-Y4[/TD]
[TD="align: right"]18.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG102174-Suchbeleuchtung_Abdimmen-Y5[/TD]
[TD="align: right"]12.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG113993-Suchbeleuchtung_Abdimmen-Y6[/TD]
[TD="align: right"]8.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115665-Suchbeleuchtung_Abdimmen-y7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115666-Suchbeleuchtung_Abdimmen-y8[/TD]
[TD="align: right"]4.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10594-ENG115667-Suchbeleuchtung_Abdimmen-y9[/TD]
[TD="align: right"]2.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11168-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM[/TD]
[TD]0.00 s[/TD]
[TD="align: right"]21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11164-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11166-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11167-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11165-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG10916-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung[/TD]
[TD]HMI[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11170-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11169-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten[/TD]
[TD]not_active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11171-Suchbeleuchtung_allgemein-pa_Hysterese_RLS[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11163-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert[/TD]
[TD="align: right"]100%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG11162-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl[/TD]
[TD]Fotosensor_Kombi[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung[/TD]
[TD]Always active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor[/TD]
[TD="align: right"]0.1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10591-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert[/TD]
[TD="align: right"]20.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115658-Suchbeleuchtung_Fotosensor-x0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG101574-Suchbeleuchtung_Fotosensor-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115664-Suchbeleuchtung_Fotosensor-x10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG99557-Suchbeleuchtung_Fotosensor-X2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG102140-Suchbeleuchtung_Fotosensor-X3[/TD]
[TD="align: right"]200[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG102936-Suchbeleuchtung_Fotosensor-X4[/TD]
[TD="align: right"]253[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG103548-Suchbeleuchtung_Fotosensor-X5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG113992-Suchbeleuchtung_Fotosensor-X6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115661-Suchbeleuchtung_Fotosensor-x7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115662-Suchbeleuchtung_Fotosensor-x8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115663-Suchbeleuchtung_Fotosensor-x9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115659-Suchbeleuchtung_Fotosensor-y0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG99777-Suchbeleuchtung_Fotosensor-Y1[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115668-Suchbeleuchtung_Fotosensor-y10[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG100480-Suchbeleuchtung_Fotosensor-Y2[/TD]
[TD]100 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG100773-Suchbeleuchtung_Fotosensor-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG100631-Suchbeleuchtung_Fotosensor-Y4[/TD]
[TD="align: right"]500[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG102174-Suchbeleuchtung_Fotosensor-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG113993-Suchbeleuchtung_Fotosensor-Y6[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115665-Suchbeleuchtung_Fotosensor-y7[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115666-Suchbeleuchtung_Fotosensor-y8[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10595-ENG115667-Suchbeleuchtung_Fotosensor-y9[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115658-Suchbeleuchtung_Hochdimmen-x0[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG101574-Suchbeleuchtung_Hochdimmen-X1[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115664-Suchbeleuchtung_Hochdimmen-x10[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG99557-Suchbeleuchtung_Hochdimmen-X2[/TD]
[TD]400 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG102140-Suchbeleuchtung_Hochdimmen-X3[/TD]
[TD]600 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG102936-Suchbeleuchtung_Hochdimmen-X4[/TD]
[TD]800 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG103548-Suchbeleuchtung_Hochdimmen-X5[/TD]
[TD]1000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG113992-Suchbeleuchtung_Hochdimmen-X6[/TD]
[TD]1200 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115661-Suchbeleuchtung_Hochdimmen-x7[/TD]
[TD]1400 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115662-Suchbeleuchtung_Hochdimmen-x8[/TD]
[TD]1600 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115663-Suchbeleuchtung_Hochdimmen-x9[/TD]
[TD]1800 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115659-Suchbeleuchtung_Hochdimmen-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG99777-Suchbeleuchtung_Hochdimmen-Y1[/TD]
[TD="align: right"]1.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115668-Suchbeleuchtung_Hochdimmen-y10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG100480-Suchbeleuchtung_Hochdimmen-Y2[/TD]
[TD="align: right"]3.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG100773-Suchbeleuchtung_Hochdimmen-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG100631-Suchbeleuchtung_Hochdimmen-Y4[/TD]
[TD="align: right"]11.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG102174-Suchbeleuchtung_Hochdimmen-Y5[/TD]
[TD="align: right"]22.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG113993-Suchbeleuchtung_Hochdimmen-Y6[/TD]
[TD="align: right"]40.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115665-Suchbeleuchtung_Hochdimmen-y7[/TD]
[TD="align: right"]80.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115666-Suchbeleuchtung_Hochdimmen-y8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10593-ENG115667-Suchbeleuchtung_Hochdimmen-y9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10597-ENG115658-Suchbeleuchtung_KL 58xs max-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10597-ENG101574-Suchbeleuchtung_KL 58xs max-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10597-ENG99557-Suchbeleuchtung_KL 58xs max-X2[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10597-ENG102140-Suchbeleuchtung_KL 58xs max-X3[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10597-ENG115659-Suchbeleuchtung_KL 58xs max-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10597-ENG99777-Suchbeleuchtung_KL 58xs max-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10597-ENG100480-Suchbeleuchtung_KL 58xs max-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10597-ENG100773-Suchbeleuchtung_KL 58xs max-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10596-ENG115658-Suchbeleuchtung_KL 58xs min-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10596-ENG101574-Suchbeleuchtung_KL 58xs min-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10596-ENG99557-Suchbeleuchtung_KL 58xs min-X2[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10596-ENG102140-Suchbeleuchtung_KL 58xs min-X3[/TD]
[TD]510 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10596-ENG115659-Suchbeleuchtung_KL 58xs min-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10596-ENG99777-Suchbeleuchtung_KL 58xs min-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10596-ENG100480-Suchbeleuchtung_KL 58xs min-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10596-ENG100773-Suchbeleuchtung_KL 58xs min-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3[/TD]
[TD="align: right"]150[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4[/TD]
[TD="align: right"]220[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10602-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG115658-Suchbeleuchtung_KL_58xd_max-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG101574-Suchbeleuchtung_KL_58xd_max-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG99557-Suchbeleuchtung_KL_58xd_max-X2[/TD]
[TD]200 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG102140-Suchbeleuchtung_KL_58xd_max-X3[/TD]
[TD]300 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG102936-Suchbeleuchtung_KL_58xd_max-X4[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG115659-Suchbeleuchtung_KL_58xd_max-y0[/TD]
[TD="align: right"]16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10601-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG115658-Suchbeleuchtung_KL_58xd_min-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG101574-Suchbeleuchtung_KL_58xd_min-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG99557-Suchbeleuchtung_KL_58xd_min-X2[/TD]
[TD]220 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG102140-Suchbeleuchtung_KL_58xd_min-X3[/TD]
[TD]300 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG102936-Suchbeleuchtung_KL_58xd_min-X4[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG115659-Suchbeleuchtung_KL_58xd_min-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10600-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3[/TD]
[TD="align: right"]10.00%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10605-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10598-ENG115658-Suchbeleuchtung_KL_58xt min-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10598-ENG101574-Suchbeleuchtung_KL_58xt min-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10598-ENG99557-Suchbeleuchtung_KL_58xt min-X2[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10598-ENG102140-Suchbeleuchtung_KL_58xt min-X3[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10598-ENG115659-Suchbeleuchtung_KL_58xt min-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10598-ENG99777-Suchbeleuchtung_KL_58xt min-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10598-ENG100480-Suchbeleuchtung_KL_58xt min-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10598-ENG100773-Suchbeleuchtung_KL_58xt min-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10599-ENG115658-Suchbeleuchtung_KL_58xt_max-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10599-ENG101574-Suchbeleuchtung_KL_58xt_max-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10599-ENG99557-Suchbeleuchtung_KL_58xt_max-X2[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10599-ENG102140-Suchbeleuchtung_KL_58xt_max-X3[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10599-ENG115659-Suchbeleuchtung_KL_58xt_max-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10599-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10599-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10599-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10604-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10604-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10604-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10604-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10604-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10604-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1[/TD]
[TD]200 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2[/TD]
[TD]400 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3[/TD]
[TD]600 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4[/TD]
[TD]800 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5[/TD]
[TD]1020 lx[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1[/TD]
[TD="align: right"]84[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2[/TD]
[TD="align: right"]166[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3[/TD]
[TD="align: right"]250[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4[/TD]
[TD="align: right"]370[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10608-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2[/TD]
[TD]3000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3[/TD]
[TD]4000 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4[/TD]
[TD]5100 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1[/TD]
[TD="align: right"]5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2[/TD]
[TD="align: right"]15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10592-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10560-ENG116647-Sunroof-SAD Komfort oeffnen[/TD]
[TD]not active[/TD]
[TD="align: right"]4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10560-ENG116646-Sunroof-SAD Komfort schliessen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10560-ENG116645-Sunroof-SAD Richtung Komfortoeffnen[/TD]
[TD]tilting[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10560-ENG10898-Sunroof-Schiebedachmodul_MD_1[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10560-ENG10899-Sunroof-Schiebedachmodul_MD_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10560-ENG10900-Sunroof-Schiebedachmodul_MD_Rollo[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10560-ENG10950-Sunroof-Verortung Schiebedachmodule[/TD]
[TD]CAN[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG10941-Verdecksteuergeraet-Cabrio_Verdeck[/TD]
[TD="align: right"]9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG128459-Verdecksteuergeraet-easycloselight_aktiv[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG11187-Verdecksteuergeraet-Kick_and_close[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung[/TD]
[TD]nur wenn mind. 1 Raste zu[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG10939-Verdecksteuergeraet-trunk_lid_conrol_unit[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG11186-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10562-ENG11185-Verdecksteuergeraet-Virtuelles_Pedal_Verbau[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG10882-Vernetzung-A/C electronics[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG10896-Vernetzung-Anhaengeranschlussgeraet[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG10902-Vernetzung-Bremsen_Steuergeraet[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG10881-Vernetzung-Getriebesteuergeraet[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG99457-Vernetzung-Head area heater[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG10968-Vernetzung-Kunden_spezifisches_Funktions_SG[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG10897-Vernetzung-UGDO[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB[/TD]
[TD]not active[/TD]
[TD="align: right"]7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG02315-ZV allgemein-Deaktivierung_Laderaumschliessung_extern[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG115754-ZV allgemein-Funk bei Klemme 15 ein[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG10909-ZV allgemein-Lock_Unlock_Taster_direkt[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG10947-ZV allgemein-Lock_Unlock_Toggle_Taster[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG02316-ZV allgemein-LS_Taster_Togglefunktion[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG115755-ZV allgemein-Notschließfunktion[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG02317-ZV allgemein-Nutzfahrzeug_Schliessung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG10885-ZV allgemein-Radio freq.[/TD]
[TD]434.42MHz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG10886-ZV allgemein-Tankschloss[/TD]
[TD]Bidirectional[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG02318-ZV allgemein-Wiederverriegelung_Laderaum[/TD]
[TD]Freigabe_Softtouch[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG116623-ZV allgemein-ZV Tuerentriegelung[/TD]
[TD]Einzeltuerentriegelung[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10579-ENG10924-ZV allgemein-ZV_ohne_Safe_Funktion[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10582-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck[/TD]
[TD]active[/TD]
[TD="align: right"]3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10582-ENG116621-ZV Autolock-automatisches Entriegeln[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10582-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10582-ENG116706-ZV Autolock-Autounlock NAR[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10582-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10582-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock[/TD]
[TD]adjustable[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10583-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10583-ENG116661-ZV Crash-SAD PreCrash Konturschliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10583-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG10944-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster[/TD]
[TD]via_CAN[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG02314-ZV Heck-Heckfreigabe_Ohne_Verzoegerung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG11173-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG10926-ZV Heck-Heckschloss_mit_Vorraste[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG10923-ZV Heck-Heckschloss_Steuerung[/TD]
[TD]Kontaktsteuerung mit Mindestansteuerzeit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG06090-ZV Heck-Mindestbetaetigung_HDF_Innentaster[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG10910-ZV Heck-Tausch_Tank_Hecktreiberausgang[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10581-ENG10925-ZV Heck-ZV_Heck_Schlosstyp[/TD]
[TD]1 or 2 notch rear actuator[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-IDE02021-ZV Komfort-Comfort closing[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-IDE02022-ZV Komfort-Comfort opening[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG10912-ZV Komfort-elektrischer_Fensterheber_hinten[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit[/TD]
[TD]600 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116652-ZV Komfort-Funk Komfort oeffnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116651-ZV Komfort-Funk Komfort schliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG115670-ZV Komfort-Komfortbedienung global[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar[/TD]
[TD]adjustable[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG125656-ZV Komfort-Regenschliessen_art[/TD]
[TD]once[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG125655-ZV Komfort-Regenschliessen_ein_aus[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10609-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10927-ZV Türkonfiguration-Fond_Schloss[/TD]
[TD]Tuersteuergeraet im Fond verbaut oder keine Fondtuer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10971-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal[/TD]
[TD]nicht invertiert[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10967-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10966-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10929-ZV Türkonfiguration-Schiebetuer_links[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10930-ZV Türkonfiguration-Schiebetuer_rechts[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10969-ZV Türkonfiguration-Schiebetueren_Crafter[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG11172-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM[/TD]
[TD]Driver side[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10928-ZV Türkonfiguration-Schlosstyp_NAR[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG10580-ENG10887-ZV Türkonfiguration-Viertuerer[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Elapsed Time: 02:00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
17 Admap:
[TABLE="width: 948"]
[TR]
[TD];SW:565-920-951   HW:565-920-951 ---  Instruments[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];Component:KOMBI         311 8311[/TD]
[TD="colspan: 3"] Coding:27A4081CFF84A60001886B0B7001000800000000[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];EV_DashBoardVDDMQBAB[/TD]
[TD="align: right"]9051[/TD]
[TD="colspan: 4"]EV_DashBoardVDDMQBAB_009_VW26.rod[/TD]
[/TR]
[TR]
[TD];Monday[/TD]
[TD]May[/TD]
[TD="align: right"]2017[/TD]
[TD="colspan: 2"]11:12:47:36443[/TD]
[/TR]
[TR]
[TD];VCDS Version: Beta 17.4.1  Data version: 20170413 DS270.4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];VCID: 5AF857345D9122972E-800E[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00295-Oil temperature display[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00301-Distance[/TD]
[TD]241 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00342-ESI: Resetting ESI[/TD]
[TD]no warning[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00343-Language version[/TD]
[TD]English[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK[/TD]
[TD]Manual reset: not possible[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel[/TD]
[TD]MFA3-Reset[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00345-MAS05464-MFA3-Reset-Refuel detection gas[/TD]
[TD]MFA3-Reset[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection[/TD]
[TD]MFA3-Reset[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00499-Display correction of consumptions and operating range[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00500-Hour[/TD]
[TD]11 H[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00501-Minute[/TD]
[TD]12 min[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00502-Year[/TD]
[TD]2017 yr[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00503-Month[/TD]
[TD]5 mon[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00504-Day[/TD]
[TD]1 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00510-ESI: distance driven from inspection[/TD]
[TD]228 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00511-ESI: time from inspection[/TD]
[TD]18 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00512-ESI: minimum value km-driving distance/inspection[/TD]
[TD]15000 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00513-ESI: maximum value km-driving distance/inspection[/TD]
[TD]30000 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00514-ESI: maximum value of time between inspections[/TD]
[TD]730 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00515-ESI: oil quality[/TD]
[TD]poor oil quality[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00517-ESI: soot entry[/TD]
[TD]500 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00518-ESI: thermal load[/TD]
[TD]300 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00819-Day counter[/TD]
[TD]34 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00820-Activating and deactivating all development messages[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00827-ESI: minimum value of time between inspections[/TD]
[TD]365 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01153-SIA: maximum value of distance to service[/TD]
[TD]15000 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01154-SIA: maximum value of time to service[/TD]
[TD]365 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02489-Display depiction[/TD]
[TD]Version 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration[/TD]
[TD]-12.8 l[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1[/TD]
[TD]-12.8 l[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2[/TD]
[TD]-12.8 l[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3[/TD]
[TD]12.7 l[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4[/TD]
[TD]12.7 l[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03329-Driving profiled for range remaining[/TD]
[TD]8.3 l/100km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-IDE00301-Units adjusted-Distance[/TD]
[TD]miles[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS01230-Units adjusted-Date[/TD]
[TD]dd_mm_yy[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS01456-Units adjusted-Speed[/TD]
[TD]Miles per hour[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS02201-Units adjusted-Temperature[/TD]
[TD]Degrees Celsius[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS02957-Units adjusted-Time[/TD]
[TD]24h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS03032-Units adjusted-Volume[/TD]
[TD]gallons (UK)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS03034-Units adjusted-Pressure[/TD]
[TD]bar[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)[/TD]
[TD]kg per 100 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)[/TD]
[TD]Miles per gallon (UK)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03346-MAS05875-Units adjusted-Average consumption: electric drive[/TD]
[TD]kWh per 100 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03348-MAS01456-Speed warning-Speed[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03348-MAS01561-Speed warning-Unit[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03348-IDE03348-Speed warning-[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03349-FIX: Max. distance until next mileage-related inspection[/TD]
[TD]32200 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03350-FIX: Maximum time until next time-dependent inspection[/TD]
[TD]730 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03351-FIX: Distance covered since last mileage-dependent inspection[/TD]
[TD]200 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03352-FIX: Time since last time-dependent inspection[/TD]
[TD]18 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03372-Source for synchronization of time[/TD]
[TD]GPS[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time[/TD]
[TD]10 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03568-ENG119827-Service-key settings-p_main_switch_Basic[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03568-ENG102414-Service-key settings-p_main_switch_keyless[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03568-ENG102611-Service-key settings-p_write_delay_speed[/TD]
[TD]20 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03568-ENG103545-Service-key settings-p_write_delay_time[/TD]
[TD]40 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03568-ENG104099-Service-key settings-p_write_distance[/TD]
[TD]20 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03867-Deactivate seat belt warning[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05930-Service notification in days[/TD]
[TD]30 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05931-FIX: Reset value for next mileage-dependent inspection[/TD]
[TD]30000 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05932-FIX: Reset value for next time-dependent inspections[/TD]
[TD]365 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05971-Vehicle Positioning System Interface Control Module[/TD]
[TD]not installed[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06425-Roller test bench mode: functional[/TD]
[TD]not activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06588-Ignition active message: actuator[/TD]
[TD]Driver door[/TD]
[TD="align: right"]1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06922-No-voltage display[/TD]
[TD]No display[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07221-Cylinder shut-off[/TD]
[TD]Display[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11086-Service notification[/TD]
[TD]30 d[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS03685-Digital speedometer[/TD]
[TD]Display[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117917-BAP_Debug_Mode_Release[/TD]
[TD]not_released[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20[/TD]
[TD]OFF[/TD]
[TD="align: right"]20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119875-defuel_threshold[/TD]
[TD]9 l[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1[/TD]
[TD="align: right"]12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2[/TD]
[TD="align: right"]32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3[/TD]
[TD="align: right"]66[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4[/TD]
[TD="align: right"]96[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5[/TD]
[TD]DC[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6[/TD]
[TD]FD[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4[/TD]
[TD]0A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6[/TD]
[TD="align: right"]64[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2[/TD]
[TD]0A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3[/TD]
[TD="align: right"]46[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5[/TD]
[TD]DC[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6[/TD]
[TD]FD[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3[/TD]
[TD="align: right"]11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4[/TD]
[TD]1F[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5[/TD]
[TD]5A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2[/TD]
[TD]0A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5[/TD]
[TD]DC[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6[/TD]
[TD]FD[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4[/TD]
[TD]1E[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5[/TD]
[TD]5A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2[/TD]
[TD]0A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6[/TD]
[TD]FD[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3[/TD]
[TD]0C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4[/TD]
[TD="align: right"]17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2[/TD]
[TD]00 32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3[/TD]
[TD]00 64[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4[/TD]
[TD]00 C8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5[/TD]
[TD]01 F4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2[/TD]
[TD]00 3C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3[/TD]
[TD]00 B4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4[/TD]
[TD]00 DC[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5[/TD]
[TD]00 FD[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2[/TD]
[TD]0A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5[/TD]
[TD]DC[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6[/TD]
[TD]FD[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3[/TD]
[TD="align: right"]6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4[/TD]
[TD]0C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119874-Gas_functionality[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim[/TD]
[TD]terminal_58xd_log_bus_parkinglight[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm[/TD]
[TD]parking_light[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119882-init_fuel_algorithm[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG130585-Leaving_warning_delay[/TD]
[TD]1.6 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0[/TD]
[TD]15 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature[/TD]
[TD]4 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature[/TD]
[TD]6 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG102658-outside_temperature-p_kmt_at_delta[/TD]
[TD]25 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0[/TD]
[TD]5.0 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG103631-outside_temperature-P_speed_threshold[/TD]
[TD]20 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off[/TD]
[TD]180 min[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG104179-outside_temperature-p_tendency_damping[/TD]
[TD]15 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG103335-outside_temperature-p_tendency_threshold[/TD]
[TD]1.0 °C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG100500-outside_temperature-p_time_constant_pt1[/TD]
[TD]40 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119825-Picture_Upload_Download[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG119876-Service_Key_Clear_All_Counter[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG130584-Statistic_phev_mileage[/TD]
[TD]5 km[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms[/TD]
[TD="align: right"]18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms[/TD]
[TD]5 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt[/TD]
[TD]35 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF[/TD]
[TD]300 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms[/TD]
[TD]255 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms[/TD]
[TD]5 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms[/TD]
[TD]6 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms[/TD]
[TD]20 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms[/TD]
[TD]900 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms[/TD]
[TD]10 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms[/TD]
[TD]3 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms[/TD]
[TD]10 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119803-time_parameter_display-hmi_t_USZ[/TD]
[TD]0.40 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG119806-time_parameter_display-rollierblockgroesse[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG101663-time_parameter_display-tDD15_off[/TD]
[TD="align: right"]0.6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG103975-time_parameter_display-tDD15_on[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG109442-ENG100026-time_parameter_display-tDDWUP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG112418-ENG112412-total_range_gas-consumption_factor[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG112418-ENG112411-total_range_gas-consumption_profile[/TD]
[TD]consumption_profile_calculation[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG112418-ENG112410-total_range_gas-selection_consumption_factor[/TD]
[TD]consumption_factor_CAN[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG112418-ENG99298-total_range_gas-State[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Elapsed Time: 00:24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
5F Admap:
[TABLE="width: 1462"]
[TR]
[TD];SW:3V0-035-021-D   HW:3V0-035-021 ---  Information Electr.[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];Component:MU-H-LND-EU   H50 0942[/TD]
[TD] Coding:032316010000000051111202008808332F0300E6012081009E[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];EV_MUHig4CGen2HBAS[/TD]
[TD="align: right"]1001[/TD]
[TD="colspan: 3"]EV_MUHig4CGen2HBAS_SK37.rod[/TD]
[TD][/TD]
[/TR]
[TR]
[TD];Monday[/TD]
[TD]May[/TD]
[TD="colspan: 2"]11:14:03:36443[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD];VCID: 281C3DFC537D400768-807C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-Production mode[/TD]
[TD]00 00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00346-Summertime-automatic[/TD]
[TD]manual[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00759-Base volume of speech output[/TD]
[TD="align: right"]50%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00760-Microphone sensitivity[/TD]
[TD]0 dB[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00768-Country identification: country of sale[/TD]
[TD]GB[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00769-Number 1 for Info call[/TD]
[TD]FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF[/TD]
[TD="align: right"]23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00770-Number 1 for roadside assistance[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00845-Wheel circ.[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01996-ENG99724-Installation list: specified installations-ECU coded[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01996-ENG06573-Installation list: specified installations-ECU coded 2[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02121-CD eject button[/TD]
[TD]Enabled[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02122-Developer mode[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02330-Number 2 for Info call[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02331-Number 2 for roadside assistance[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02332-Deactivate production mode[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-MAS03001-Electrical test of loudspeakers-Mode[/TD]
[TD]automatic[/TD]
[TD="align: right"]49[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume[/TD]
[TD="align: right"]22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency[/TD]
[TD]19000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02502-Confirmation of installation change[/TD]
[TD]1D 12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02506-MAS03229-Copy multimedia data-Data medium[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02506-MAS03230-Copy multimedia data-Optical drive[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02607-Wheel pulse[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02699-Number 1 for roadside assistance[/TD]
[TD]00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02701-Number 1 (roaming) for roadside assistance[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo[/TD]
[TD="align: right"]8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117847-Vehicle configuration-advanced_range_display[/TD]
[TD]OFF[/TD]
[TD="align: right"]30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG130249-Vehicle configuration-Apple_DIO[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG130248-Vehicle configuration-Google_GAL[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117851-Vehicle configuration-gracenote_local_other[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117849-Vehicle configuration-gracenote_online_other[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125049-Vehicle configuration-Joker_button_1[/TD]
[TD]Not Present[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125050-Vehicle configuration-Joker_button_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG127492-Vehicle configuration-LGI[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG130246-Vehicle configuration-LTE_modul[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG07590-Vehicle configuration-Mirror_link[/TD]
[TD]function_on_hmi_on[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117843-Vehicle configuration-my_audi[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117845-Vehicle configuration-online_dictation[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG127495-Vehicle configuration-online_media[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117840-Vehicle configuration-online_navigation[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117837-Vehicle configuration-online_POI[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117838-Vehicle configuration-online_POI_voice[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117841-Vehicle configuration-online_street_view[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode[/TD]
[TD]only data service act.[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117844-Vehicle configuration-picture_navi[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG06574-Vehicle configuration-ProbeCar_vzo[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version[/TD]
[TD]PSD_1.5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117846-Vehicle configuration-remote_HMI[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG07589-Vehicle configuration-RSE_software_component[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG126143-Vehicle configuration-RVC_video_input[/TD]
[TD]FBAS[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG11009-Vehicle configuration-sd_slot_deactivation[/TD]
[TD]no restriction[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag[/TD]
[TD]no_region[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch[/TD]
[TD]present[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG07591-Vehicle configuration-Smartphone_interface_for_rhmi[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG130247-Vehicle configuration-Support_second_phone[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG126994-Vehicle configuration-TPEG_availability[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG06575-Vehicle configuration-UOTA[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117852-Vehicle configuration-UPnP[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117836-Vehicle configuration-VZAPro[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG127494-Vehicle configuration-VZO[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03580-Country code for mobile network[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03902-Automatic ring break diagnostic[/TD]
[TD]No automatic start[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04295-Bluetooth: Preferred connection profile for phone book data[/TD]
[TD]PBAP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04298-MAS01779-Vehicle dimensions-Length[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04298-MAS01780-Vehicle dimensions-Width[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04298-MAS02230-Vehicle dimensions-Height[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04331-Selection of release codes for a SWaP function[/TD]
[TD]FF FF FF FF[/TD]
[TD="align: right"]4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04521-Sporadic ring break detection[/TD]
[TD]Visual[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04522-Awakening ability on optical databus[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04549-Telephone data services[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04550-Bluetooth: Sniff mode[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05111-Fee-based traffic information (TMC)[/TD]
[TD="align: right"]32771[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05113-Infotainment Recorder[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06697-Audio management mute function[/TD]
[TD]Muting of audio sources[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G[/TD]
[TD="align: right"]16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner[/TD]
[TD="align: right"]-128[/TD]
[TD="align: right"]40[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10480-MAS10741-Interface for external media: activation-Connection 1[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10480-MAS10742-Interface for external media: activation-Connection 2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10480-MAS10743-Interface for external media: activation-Connection 3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10480-MAS10744-Interface for external media: activation-Connection 4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10604-Menu entries for mobile online services[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10668-Internal SIM card: use[/TD]
[TD]Never[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold[/TD]
[TD]37 dBµV[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation[/TD]
[TD]32 dB[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo[/TD]
[TD]15.0 s[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11105-Brand-specific display of connect application[/TD]
[TD][/TD]
[TD="align: right"]256[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11122-Country identification: country of sale HMI[/TD]
[TD]--[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11153-IDE11153-Surroundings display: virtual camera positions-[/TD]
[TD="align: right"]32767[/TD]
[TD="align: right"]330[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]65535[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD="align: right"]4294967295[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127601-Locked menu contents-FB_CAR_0[/TD]
[TD]non_blocked[/TD]
[TD="align: right"]21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127602-Locked menu contents-FB_CAR_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127611-Locked menu contents-FB_CAR_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127612-Locked menu contents-FB_CAR_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127613-Locked menu contents-FB_CAR_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127614-Locked menu contents-FB_CAR_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127615-Locked menu contents-FB_CAR_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127616-Locked menu contents-FB_CAR_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127617-Locked menu contents-FB_CAR_16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127618-Locked menu contents-FB_CAR_17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127619-Locked menu contents-FB_CAR_18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127620-Locked menu contents-FB_CAR_19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127603-Locked menu contents-FB_CAR_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127621-Locked menu contents-FB_CAR_20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127622-Locked menu contents-FB_CAR_21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127623-Locked menu contents-FB_CAR_22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127624-Locked menu contents-FB_CAR_23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127604-Locked menu contents-FB_CAR_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127605-Locked menu contents-FB_CAR_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127606-Locked menu contents-FB_CAR_5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127607-Locked menu contents-FB_CAR_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127608-Locked menu contents-FB_CAR_7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127609-Locked menu contents-FB_CAR_8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127610-Locked menu contents-FB_CAR_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127625-Locked menu contents-FB_MISC_0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127626-Locked menu contents-FB_MISC_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127635-Locked menu contents-FB_MISC_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127636-Locked menu contents-FB_MISC_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127637-Locked menu contents-FB_MISC_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127638-Locked menu contents-FB_MISC_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127639-Locked menu contents-FB_MISC_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127640-Locked menu contents-FB_MISC_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127641-Locked menu contents-FB_MISC_16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127642-Locked menu contents-FB_MISC_17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127643-Locked menu contents-FB_MISC_18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127644-Locked menu contents-FB_MISC_19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127627-Locked menu contents-FB_MISC_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127645-Locked menu contents-FB_MISC_20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127646-Locked menu contents-FB_MISC_21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127647-Locked menu contents-FB_MISC_22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127648-Locked menu contents-FB_MISC_23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127649-Locked menu contents-FB_MISC_24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127650-Locked menu contents-FB_MISC_25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127651-Locked menu contents-FB_MISC_26[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127652-Locked menu contents-FB_MISC_27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127653-Locked menu contents-FB_MISC_28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127654-Locked menu contents-FB_MISC_29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127628-Locked menu contents-FB_MISC_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127655-Locked menu contents-FB_MISC_30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127656-Locked menu contents-FB_MISC_31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127657-Locked menu contents-FB_MISC_32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127658-Locked menu contents-FB_MISC_33[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127659-Locked menu contents-FB_MISC_34[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127660-Locked menu contents-FB_MISC_35[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127661-Locked menu contents-FB_MISC_36[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127662-Locked menu contents-FB_MISC_37[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127663-Locked menu contents-FB_MISC_38[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127664-Locked menu contents-FB_MISC_39[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127629-Locked menu contents-FB_MISC_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127665-Locked menu contents-FB_MISC_40[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127666-Locked menu contents-FB_MISC_41[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127667-Locked menu contents-FB_MISC_42[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127668-Locked menu contents-FB_MISC_43[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127669-Locked menu contents-FB_MISC_44[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127670-Locked menu contents-FB_MISC_45[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127671-Locked menu contents-FB_MISC_46[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127672-Locked menu contents-FB_MISC_47[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127630-Locked menu contents-FB_MISC_5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127631-Locked menu contents-FB_MISC_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127632-Locked menu contents-FB_MISC_7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127633-Locked menu contents-FB_MISC_8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127634-Locked menu contents-FB_MISC_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127561-Locked menu contents-FB_NAV_0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127562-Locked menu contents-FB_NAV_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127571-Locked menu contents-FB_NAV_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127572-Locked menu contents-FB_NAV_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127573-Locked menu contents-FB_NAV_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127574-Locked menu contents-FB_NAV_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127575-Locked menu contents-FB_NAV_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127576-Locked menu contents-FB_NAV_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127577-Locked menu contents-FB_NAV_16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127578-Locked menu contents-FB_NAV_17[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127579-Locked menu contents-FB_NAV_18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127580-Locked menu contents-FB_NAV_19[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127563-Locked menu contents-FB_NAV_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127581-Locked menu contents-FB_NAV_20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127582-Locked menu contents-FB_NAV_21[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127583-Locked menu contents-FB_NAV_22[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127584-Locked menu contents-FB_NAV_23[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127585-Locked menu contents-FB_NAV_24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127586-Locked menu contents-FB_NAV_25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127587-Locked menu contents-FB_NAV_26[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127588-Locked menu contents-FB_NAV_27[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127589-Locked menu contents-FB_NAV_28[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127590-Locked menu contents-FB_NAV_29[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127564-Locked menu contents-FB_NAV_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127591-Locked menu contents-FB_NAV_30[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127592-Locked menu contents-FB_NAV_31[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127593-Locked menu contents-FB_NAV_32[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127594-Locked menu contents-FB_NAV_33[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127595-Locked menu contents-FB_NAV_34[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127596-Locked menu contents-FB_NAV_35[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127597-Locked menu contents-FB_NAV_36[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127598-Locked menu contents-FB_NAV_37[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127599-Locked menu contents-FB_NAV_38[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127600-Locked menu contents-FB_NAV_39[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127565-Locked menu contents-FB_NAV_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127566-Locked menu contents-FB_NAV_5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127567-Locked menu contents-FB_NAV_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127568-Locked menu contents-FB_NAV_7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127569-Locked menu contents-FB_NAV_8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127570-Locked menu contents-FB_NAV_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127545-Locked menu contents-FB_PHONE_0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127546-Locked menu contents-FB_PHONE_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127555-Locked menu contents-FB_PHONE_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127556-Locked menu contents-FB_PHONE_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127557-Locked menu contents-FB_PHONE_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127558-Locked menu contents-FB_PHONE_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127559-Locked menu contents-FB_PHONE_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127560-Locked menu contents-FB_PHONE_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127547-Locked menu contents-FB_PHONE_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127548-Locked menu contents-FB_PHONE_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127549-Locked menu contents-FB_PHONE_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127550-Locked menu contents-FB_PHONE_5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127551-Locked menu contents-FB_PHONE_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127552-Locked menu contents-FB_PHONE_7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127553-Locked menu contents-FB_PHONE_8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127554-Locked menu contents-FB_PHONE_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127505-Locked menu contents-FB_TUNER_0[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127506-Locked menu contents-FB_TUNER_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127515-Locked menu contents-FB_TUNER_10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127516-Locked menu contents-FB_TUNER_11[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127517-Locked menu contents-FB_TUNER_12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127518-Locked menu contents-FB_TUNER_13[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127519-Locked menu contents-FB_TUNER_14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127520-Locked menu contents-FB_TUNER_15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127507-Locked menu contents-FB_TUNER_2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127508-Locked menu contents-FB_TUNER_3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127509-Locked menu contents-FB_TUNER_4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127510-Locked menu contents-FB_TUNER_5[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127511-Locked menu contents-FB_TUNER_6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127512-Locked menu contents-FB_TUNER_7[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127513-Locked menu contents-FB_TUNER_8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11502-ENG127514-Locked menu contents-FB_TUNER_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11638-Bluetooth Audio Codec[/TD]
[TD]FF[/TD]
[TD="align: right"]1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS00951-Bluetooth[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS02809-MAS02870-Check tone frequency-High note frequency range[/TD]
[TD]4000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS02809-MAS02871-Check tone frequency-Medium note frequency range[/TD]
[TD]1000 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS02809-MAS02872-Check tone frequency-Low note frequency range[/TD]
[TD]100 Hz[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS03690-Telephone[/TD]
[TD]Data & language service active[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS03782-WLAN[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off[/TD]
[TD]OFF[/TD]
[TD="align: right"]12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time[/TD]
[TD]0.00 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time[/TD]
[TD]0.00 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time[/TD]
[TD]0.00 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time[/TD]
[TD]0.00 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117920-Audio_Managment_Soundset_Menu[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117917-BAP_Debug_Mode_Release[/TD]
[TD]not_released[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization[/TD]
[TD]not activated[/TD]
[TD="align: right"]60[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05[/TD]
[TD]activated[/TD]
[TD="align: right"]64[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus[/TD]
[TD]Databus extended[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus[/TD]
[TD]Suspension data bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus[/TD]
[TD]CAB_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus[/TD]
[TD]Comfort data bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus[/TD]
[TD]Terminal 15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus[/TD]
[TD]Databus Infotainment[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus[/TD]
[TD]Databus drivetrain[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34[/TD]
[TD]CAB_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus[/TD]
[TD]CAB_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus[/TD]
[TD]CAB_9[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C[/TD]
[TD]activated[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key[/TD]
[TD]Not available[/TD]
[TD="align: right"]8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL[/TD]
[TD]Available[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering[/TD]
[TD]Available[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN[/TD]
[TD]Available[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG11025-Dashboard_Display_Configuration-ability_switch_nav_maps[/TD]
[TD]OFF[/TD]
[TD="align: right"]10[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG122341-Dashboard_Display_Configuration-coverart[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode[/TD]
[TD]RLE[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution[/TD]
[TD]resolution_1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode[/TD]
[TD]RLE[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122230-ENG122342-Dashboard_Display_Configuration-stationart[/TD]
[TD]OFF[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1[/TD]
[TD="align: right"]0[/TD]
[TD="align: right"]6[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2[/TD]
[TD="align: right"]50[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3[/TD]
[TD="align: right"]100[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1[/TD]
[TD="align: right"]12[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5[/TD]
[TD="align: right"]150[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6[/TD]
[TD="align: right"]253[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1[/TD]
[TD="align: right"]1%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3[/TD]
[TD="align: right"]3%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4[/TD]
[TD="align: right"]6%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5[/TD]
[TD="align: right"]44%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6[/TD]
[TD="align: right"]100%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay[/TD]
[TD]0 ms[/TD]
[TD="align: right"]3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic[/TD]
[TD]On[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG107658-ENG126192-mobile phone voice control availability-apple_device[/TD]
[TD]not installed[/TD]
[TD="align: right"]1[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG107658-ENG126193-mobile phone voice control availability-other_devices[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation[/TD]
[TD]01 01 37 02 37 02 37 02 37 02 50 02 64 02 6E 02 78 02 37 02 37 02 37 02 37 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 0C[/TD]
[TD="align: right"]40[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117809-p_damping_Display[/TD]
[TD]5 ms[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117808-p_HMI_Display[/TD]
[TD="align: right"]13%[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117919-Startup_Screen_Sticker_HMI[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit[/TD]
[TD]0 km/h[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Elapsed Time: 00:45[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
