Sorry last scan of my car, as the car is not with me at the moment.
Need help with correct part numbers please, also the connectors needed, also want too make the (loom or harness) myself
Where do i also need to connect the (loom or harness) into which module. Thank You
Monday,14,November,2016,13:32:03:10786
VCDS Version: 16.8.3.1 (x64)
VIN: WVWZZZ1KZ9W023422 License Plate:
Mileage: 160050km-99450mi Repair Order: Heated Jets
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ9W023422 Mileage: 160050km-99450miles
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Part No SW: 03C 906 032 N HW: 03C 906 032 C
Component: MED17.5.1 2317
Revision: 96H07--- Serial number: VWX7Z0H43NK02R
Coding: 0000072
Shop #: WSC 01279 785 00200
VCID: 285F22289BD93902D4-807C
Readiness: 0110 0101
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 163B600D092400FD680F06E6901B00803000
Shop #: WSC 01316 785 00200
VCID: 74E70658D7910DE2A8-8020
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 77FD315406E766FA8D-8022
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000008508543
Coding: E58D8F2700041500471400001400000000087F075C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 3365C544521F4ADA71-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 230508 021 0501
Coding: 00038805
Component: RLS 120608 054 0402
Coding: 00209069
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 238
Mileage: 160058 km
Voltage: 12.10 V
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD21LMT
Coding: 0013112
Shop #: WSC 01269 785 00200
VCID: 3D71E37C645B8CAA97-8068
Subsystem 1 - Serial number: 6332MSME2721680C9
Subsystem 2 - Serial number: 6342MSME2722370C7
Subsystem 3 - Serial number: 6352QSME63442359D
Subsystem 4 - Serial number: 6362QSME640322454
Part No SW: 1K0 953 549 CA HW: 1K0 953 549 CA
Component: J0527 051 0101
Coding: 0000012
VCID: 73E50544129F0ADAB1-8026
Part No SW: 1K0 920 974 F HW: 1K0 920 974 F
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H43NK02R
Coding: 0003403
VCID: 3169CF4CA80378CA03-8064
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 300508F1001295
Coding: E9801F060002020001
VCID: 3561FB5C5C6B54EA5F-8060
Component: IMMO VDD 2416
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1208
Coding: 0000628
VCID: 387FF2684B79A98244-806C
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A5BD82085D50B12C2-807E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002085103087F2D04840570085AC690BC00
VCID: 03055584423F3A5AA1-8056
Component: LIN BACKUP HORN H08 9001
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
VCID: 3979F76C7073B08ABB-806C
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5ND 035 190 A HW: 5ND 035 190 A
Component: RCD510USBRVC 001 0003
Revision: -----001 Serial number: VWZ4Z3M8098535
Coding: 00000424040000
VCID: 3A7BE860B575BB92B2-806E
Reset counter: 238
Mileage: 160058 km
Time: 12:50:18
End-------------------------(Elapsed Time: 01:51)--------------------------
