2015 Audi S3 DSG Transmission Problem P2711 - Any Input Appreciated!
lordjop
C?ID=306886
Hello Everyone,
I own a 2015 Audi S3 with 56,000 miles. A week ago I experienced a problem with my transmission. I connected my VCDS and it gave some trouble codes. Here's a little history of my car: meticulously maintained (Audi Care serviced for 5000, 15000, 25000, 35000 and 45000 miles) with oil changes in between done by myself (Liqui Moly). Besides a cold air intake the car is NOT modified at all - completely stock. I had the car towed to my original dealership and they did NOTHING to the car for three days. I spoke with the service writer and he told me "they're trying to diagnose the problem". I asked him several questions, including a list of any DTC's they may have pulled and he had nothing. Had the car towed to my new home in Florida and spoke with the Service Director of the dealership nearest me. He told me to have the vehicle towed to him (at my own expense) and for a $365 diagnostic fee, he'd see what was wrong with the car but made no promises. I contacted Audi of America to see if they'd attempt a "goodwill repair' once we found out what was wrong, but they were not very helpful nor did they seem too "motivated" to assist me. I drove the car around the block but it is stuck in first gear (limp mode i guess) and will not let me shift manually. The transmission doesn't grind or clunk, and i am able to engage reverse for a brief period of time before the car goes into limp mode again.
I am just requesting a little guidance so to speak on how to troubleshoot some of the sensors, check the clutch packs, check the mecatronic, etc. I used the VCDS but it appears my transmission (OD9, DQ250) won't allow me to choose measuring blocks. I'm trying to narrow down the problem myself and "pinpoint" what's wrong. I'm hoping it's a sensor or maybe one of the valves // solenoids on the mecatronic unit. Any assistance would be greatly appreciated!! Thanks in advance !!
       Address 02: Auto Trans       Labels: 0D9-927-770.clb
Control Module Part Number: 0D9 300 012 L    HW: 02E 927 770 AQ
  Component and/or Version: DQ250-6A MQB  H53 4521
           Software Coding: 0014
            Work Shop Code: WSC 04742 780 00200
              ASAM Dataset: EV_TCMDQ250021 001001 (AU37)
                       ROD: EV_TCMDQ250021.rod
                      VCID: 1F18EABC573249FF343-804A
21148 - Gear 2
          P0732 00 [072] - Incorrect Ratio
                    Mileage: 91016 km
                    Date: 2017.04.26
                    Time: 17:36:50
21150 - Gear 4
          P0734 00 [072] - Incorrect Ratio
                    Mileage: 91003 km
                    Date: 2017.04.20
                    Time: 15:40:27
21152 - Gear 6
          P0729 00 [072] - Incorrect Gear Ratio
                    Mileage: 91003 km
                    Date: 2017.04.20
                    Time: 15:41:07
21181 - Unexpected / Implausible Mechanical Gear Disengagement
          P2711 00 [200] - -
                    Mileage: 90998 km
                    Date: 2017.04.20
                    Time: 15:06:47
21188 - Unexpected / Implausible Mechanical Gear Disengagement
          P2711 00 [072] - -
                    Mileage: 91003 km
                    Date: 2017.04.20
                    Time: 15:41:05
Your TCU uses the UDS protocol; use Advanced Measuring Values instead of Measuring Blocks.
Since you say the car has been meticulously maintained, I'm going to assume that the oil in the DSG has been changed at least once?
The thing that usually fails on the DSG is the Mechatronic....
lordjop
C?ID=306886
Thanks for the prompt reply. Yes the DSG Fluid was changed by the dealership at 35,000 miles. I am not sure if they did the adaptation. There is a popular website that shows a DSG DIY and they simply drained the fluid, measured what came out, then filled the same amount back into the system. Someone in the comments area of that video questioned why they didnt use a VCDS and the author stated "this is how we did it when i worked at the dealership".
I looked at the advanced function but wasn't sure what to input. I wanted to compare input and output shaft speeds, check the clutch temp sensors, etc. I logged onto the audi repair website but i cant get odis access to run diagnostics.
In the selection dialog that pops up when you open Advanced Measuring Values, there's a search/filter box. Type "temp" (without the quotes) and you should easily find "Transmission fluid temperature" and a number of others. Similarly, if you type "speed", you should find a number of values with descriptions. Then just put a check mark in the box next to the ones you actually want to see.
lordjop
C?ID=306886
I really appreciate all of your help ! I did exactly as you said and was able to play around and test some of the sensors. At this point i think it's either the clutch packs (incorrect ratio for gears 2,3,6) or the mechatronic unit itself. I was also able to go onto the Audi Erwin website and download the repair manuals. I've been reading and i don't think there is a direct way to test the solenoids or valves without removing the mechatronic unit.
I'll keep you posted but it appears that i'll have to take it to an indie shop. Having just moved, i have limited access to my tools and time is limited due to my work schedule.
Thanks again for an awesome product and your help!
NostraJackAss
I think that can be good faith warrantied no?
I would call Audi customer care to see.............
lordjop
C?ID=306886
I really, REALLY appreciate everyone's input so far. You guys have been great! I have ZERO confidence in any of these dealerships. This is the reason i purchased a VCDS in the first place, so i could do my OWN repairs. It's killing me because i'm renting a car now and i'm waiting for my tools to arrive here. The ONLY reason i took out Audi Care (pre-paid maintenance) was to avoid any issues with repairs during the warranty period. Lucky me, the car is 6,000 miles PAST warranty. I originally took the vehicle to Audi of Someplace in Suffolk County, Long Island. My car was towed there, arriving Thursday evening. The service manager took my keys, and told me he'd call me sometime, not even offering a ride or a cab back home. So the car sat there all day Friday and all day Saturday. Once i spoke with the service guy on Monday he told me they couldn't find any fault codes and they'd have to "look into it more". Right there i knew he was lying to me (that and the fact the car was in the SAME spot collecting dust) , so i had my car towed to my new home in Florida.
The indie shop where the car is now told me they believe the fluid might be dirty. This confirms my original statement in which i SUSPECT the dealership did not perform the proper adaptation procedure during the DSG fluid change. Which is WHY i am so apprehensive about bringing my car to the dealer in the FIRST place. I'm pretty confident that any "deal" the dealership would make with me, would be to run up a massive repair bill, then offer to "split" the difference with me in "good faith". I read a thread within the Ross Tech forums about someone that attempted a goodwill repair, got the run around from the dealership and Audi of America, then ended paying out of pocket anyway. I don't trust ANY of these dealerships for service. Period. Audi of America was totally useless as well, offering ZERO help or sympathy.
So that's where i stand. The mechanic of the indie shop wants to drain and refill the DSG fluid and change the filter. Then take it from there. I've read also it might be an issue with the mechanical clutches, but we'll see what happens next.
I'll keep you all posted. Thanks again !
vu2gte
India
C?ID=262838
I am under the impression that the vag group had extended the warranty on dsg for 10 years in the US and China.
NostraJackAss
Seems to only apply to 2007-2009?
That is correct Uwe, however, I have it under advisement & personal experience observing these failures, it needs to be reported so that a real campaign will be forced to be initiated.
OP get me a VIN # and a complete auto-scan please.......thank you!
NostraJackAss
You know what Uwe
I think you should make a sticky for important reports to the NHTSA and how people are to look up recalls TPI or TSB's etc. at the site.
People should consider that by submitting reports, it will help the community & get them possible help.
https://www.nhtsa.gov/recalls
VAG in the USA has been less than forthcoming with TSB's to the public & I see gross inconsistencies for how they are disseminating the repair or technical information.
Not everything is proprietary!
lordjop
C?ID=306886
Hello Everyone,
Sorry for the late posts i'm just busy with work. My VIN is WAUBFGFF3F1083628. I did not save my Auto Scan because i'm a moron. I am going back to the indie shop with my VCDS cable to handle that, and i will post afterwards. Had i known that these DSG transmissions were such a problem i would have went with my heart and purchased an E46 M3, stick. Living in New York i needed AWD for the snow and the wife doesn't drive a manual. I live in Florida now so it's a double kick in my butt.
Jack and UWE thanks for your assistance, as well as everyone else that posted. I just finished writing up a complaint to the NHSTA under complaint # 10983595. My next step is to write DIRECTLY to the CEO of Audi of America, Scott KEOGH. I will be very professional and detailed in my complaint, naming names and the dealerships i went to. I will also emphasize that i did not receive TRULY EXCEPTIONAL service from anyone i spoke with during this whole ordeal. It's funny how after all of my Audi Care appointments i get a survey stating 7 is Excellent but we want to be TRULY EXCEPTIONAL, so please rate us a 10. Except when your car breaks down out of warranty then we could care less.
I'll let you know how things go and i'll try to get the auto scan up either tomorrow or by this weekend. Thanks !
NostraJackAss
Mormon huh that explains it after all those Davey and Goliath .......Cloaky Productions.
Thank you for taking the time to register the complaint and contacting the CEO was a great idea.
0D9-300-012L ( f05/14-05/15 008 ) QSP+PR-7GB on sale for $9230 USD minus labor WTF!
Vehicle Identification No.
WAUBFGFF3F1083628
Model
audi s3 sal. qu. 2.0
A3
Date of production
24.11.2014
Year
2015
Sales type
8VS51L
Engine Code
CYFB
Transmission Code
QSP
Axle drive
6A
Equipment
XS
Roof color
L5
Exterior color / Paint Code
L5 / Z7G
"Charism"
2H6
"drive select"
Activated carbon canister
1E7
Activated charcoal canister ORVR, for
intensified evaporation system, purge
device for fueling
Additional child seat anchors
3B7
Child seat anchor according to
Canadian requirements and
child seat system ISOFIX
Additional tires (winter tires)
2WA
Without additional tires
Additional warning lights
9TC
Additional reflectors (door area)
Air bag
4UB
Air bag for NAR
Airscarf
9K0
Without airscarf
Alternative drive module
0K0
Without alternative drive module
Anti-theft protection system
7AJ
Electronic vehicle immobilization device
with alarm system and backup horn
Auxiliary heating
9M0
Without auxiliary/parking heater
Backrest release
3H0
Without backrest release for front seats
Base engine
TT6
4-cylinder SI engine 2.0 l
unit 06K.C
Batteries
J1D
Battery 380 A (72 Ah)
Battery/alternator capacity
NY2
Increased battery capacity
Body measures
5C1
Body measures for increased safety
requirements
Body style
K8S
Sports sedan
Brake pad wear indicator
9U1
Brake type, front
1LC
Disc brakes, front
Brake type, rear
1KY
Disc brakes, rear
Braking systems
1AT
Electronic stabilization program (ESP)
Breakaway interior mirror
4L2
Dipping breakaway interior rear view
mirror
Bumper
2JU
Standard bumpers
Camera systems/accident sensors
KA0
Without camera systems/accident sensors
Camera/distance sensor
QK0
Without camera without distance sensor
(driver assistance system)
Carrier frequency for radio remote control
5D2
Carrier frequency 315 MHz
Center armrest
6E3
Front center armrest
Charging cable
EV0
Without charging cable
Child lock
4H3
Manual child lock
Child seat anchor, front
3G0
Without child seat anchor front (ISOFIX)
Chrome work package
QJ1
Chrome work package
Climatic zones
0Y3
Cold zones
CO2 variant
0C0
Standard
Component part sets with country-specific design requirements
B0D
Component parts set, complying with
vehicle type for USA (without
California), various parts
Components with special surface appearance
6FC
Aluminum exterior mirror housings
Cruise control
8T2
Cruise control system (CCS)
electronic
Customized installation
FC0
Without customized installation
Decorative films / emblems
6F3
Emblems
Door and lid locking system
4I3
Central locking system "Keyless Entry"
without deadlock
Doors
0A2
4 doors
Drive layout
1X1
Four wheel drive
Driving on the left/on the right
AV2
Driving on the right (NAR)
ECO function for driving profiles and drive select
EF0
Without ECO function
Electric interface for external use
UE7
AUX-IN, USB and iPod
Emission standard
7GB
Emission standard ULEV 2
Engine cooling system
8Z6
Hot country
Engine specifications
DR8
4-cylinder SI engine 2.0 l/215 KW
TFSI
base engine is TT6
Engine type
IX1
SI engine
Equipment levels
A8U
Executive US equipment
Extended safety system
7W1
With extended safety system
(Pre-Crash Basic)
Exterior mirror setting
6XD
Exterior mirrors: electrically
adjustable/heated
First aid kit / warning triangle
1T0
Without first aid kit and warning
triangle
Floor mats
0TD
Front and rear floor mats
Folding table
1U8
W/o folding table on front seat backrest
Fresh air intake for passenger compartment (with particulate filter)
2V5
Fresh air intake system with activated
charcoal canister
Front Assist
6K0
without Front Assist/without city
automatic emergency braking
Front fog light/additional headlight
8WA
Without front fog light
Front license plate bracket
6W3
Front license plate carrier (small, NAR)
Front seats
Q4H
Comfort sports seats, front
Front stabilizer
0AE
Front stabilizer
Front underbody guard
1SA
Without additional front underbody guard
Fuel quality
0U0
Fuel quality 98 RON
Fuel quantity for initial filling
1Z6
Increase in initial standard fuel
filling
Fuel systems
1A7
Fuel system for fuel-injected engine
(tropicalized)
Gearshift knob/handle
7F9
Plastic/leather gearshift knob/handle
General operating permit, alterations
C00
Operating permit, initial registration
Generators
8GU
Alternator 140 A
Handling standard production and pre-production series
FA0
Control of standard production
Headlight
8IG
Gas discharge headlamp
(D1/D3 system)
Headlight activation
8K4
Separate daytime running lights
NAR
Headlight washer system
8X1
Headlight-range adjustment
8Q3
Automatic headlight-range adjustment
dynamic (self-adjusting while driving)
Headrests
5ZC
Headrests for front seats (x-adjustment)
Heat accumulator system/additional heater
7E0
W/o heat accumulator/auxiliary heating
Heated washer nozzles
9T1
Heated washer nozzles, front
Heating and air conditioning system
9AK
Climatronic with impact pressure
control free of cfc
Horns
8Y1
Two-tone horn
Hybrid drive
20A
Without electric motor ( hybrid )
Identification plates
1EP
Special identification plate (USA)
Insert for the filling up of unleaded fuel/fuel type
2G7
Filler neck module 1 with insert
Inserts
5TG
Decorative aluminum inserts, dulling
Installation differentiation for vehicle components
0ES
transmission DQ250
vehicle components
Instrument inserts
U5C
Instrument insert, mph speedometer
Leather scope
7HA
Without leather
Left exterior mirror
5SG
Left exterior mirror: flat
Light assistance system
8G0
Without light assistant
Light package (lighting)
QQ5
With additional lights (interior
lighting)
Lockable wheel bolts
1PA
Standard wheel bolts
Luggage compartment floor covering
6SS
Luggage compartment lining
5A4
Trunk lining (design 1)
Lumbar support
7P1
Power adjustable lumbar support in front
seats
Maintenance contract
EW0
Without maintenance contract
Manufacturer
A51
Audi AG
Manufacturing sequence differentiation
0FA
Standard manufacturing sequence
Molding roof liner
6NJ
Standard molded headlining
Moldings
4ZB
Bright moldings
Multi-function display/trip computer
9S6
Multi-function display/on-board computer
"Colour"
Nameplate set
0NA
Without nameplate set
(without model designation)
Navigation device
7Q0
Without navigation device
Online services
EL0
Without online service
Owner's manuals
0VM
Information kit in American English
Paint preservative/transit coating
5K4
Transport protection cover (shape-
adapted system) with additional
transport protection measures
Park distance control
7X0
Without park distance control
Parking brake
UH1
Parking brake
Partition
3CA
Without partition
Pedal cluster
VF1
Pedal cluster
Pedestrian protection
VL0
Standard pedestrian protection measures
Platform module floor pan, rear
4P1
Rear floor panel module, type 2
Quality class
AQ0
Standard-production quality
Quattro GmbH
FQ0
Standard production wheels
Radios
I8D
Standard radio (Gen1)
Rear axle
0N4
4-link rear suspension
Rear fog light
8TB
Rear fog light
Rear headrests
3Q9
Three rear headrests
Rear seat catch
UK1
Standard rear seat release
Rear seats
3NU
Rear seat bench unsplit, backrest split
folding with center armrest
Rear spoiler
5J4
Body-colored rear spoiler
Rear stabilizer
0BF
Rear stabilizer
Rear trim panel
6V2
Rear trim panel
Rear window wiper and washer system
8M0
W/o rear window wiper and washer system
Refrigerant
KK1
Refrigerant R134a
Refrigerator
1W0
Without refrigerator/glove compartment
cooling system
Regional code for radio
ER3
Regional code " NAR " for radio
Right exterior mirror
5RW
Right exterior mirror: convex (US)
large viewing field
Roof insert/convertible top
3FB
Spoiler roof
Roof rails/roof load rack
3S0
Without roof rails/roof load rack
Rough-road/sports version
2UC
Sports version
Safety certificate
0LB
Special plates/stickers/
safety certificates for USA
Scuff plates
7M2
Scuff plates in door apertures with "S"
badge
Seat adjustment
3L5
Electric seat adjustment for both front
seats
Seat belt check
9P7
Seat belt reminder, optical and acoustic
electric contact in buckle
Seat covering
N4V
Seat trim covers in leather
Seat heater
4A3
Seat heater for front seats
separately controlled
Service indicator
QI7
Service indicator ( 10000 miles )
Service interval prolongation
QG1
Shock absorption, chassis, front
G26
Front shock absorption
Shock absorption, chassis, rear
UB5
Rear shock absorption for sports design
Side air bag
4X3
Side air bag front with curtain air bag
Side and rear windows
4KC
Side and rear windows in heat-insulating
glass
Side assist/lane departure warning
7Y0
Without lane change assistant
Ski bag
3X0
Without load-through provision
Smoking/non-smoking package
9JA
Non-smoking package
Spare wheel/breakdown set
1G9
Space-saving spare wheel for temporary
use, radial tire
(5-hole)
Speaker installation
9VS
Sound package "branded"
Special editions
E0A
No special edition
Special labels/plates
0SS
Labels/plates in English and French
Start/stop system/regenerative braking
7L3
Without start/stop system without
Steering
1N7
Dynamic steering
Steering system arrangement
L0L
Left-hand drive vehicle
Steering wheels
2PK
Leather trimmed multi-function sports
steering wheel w/ Tiptronic
Subsequent guarantee
EA0
Without subsequent warranty
Taillight assemblies
8SK
LED taillamp assembly
Telephone/telematics
9ZX
Mobile phone preparation
Tire pressure warning light
7K6
Flat tire indicator
Tire suppliers
V0A
Tires w/o specification of tire brand
Tires
HM4
Tires 225/40 R18 92Y xl
Tool kit and jack
1S1
Tool kit and jack
Trailer hitch
1D0
Without trailer hitch
Transit coating
NT1
Transit coating (type 2)
Transmission specifications
G0R
6-speed automatic transmission for
four-wheel drive vehicle
Tray areas package
QE0
Without tray areas package/box
TV reception/digital radio reception
QV3
Digital radio reception
Type approval countries/countries with special requirements
BU2
Legal requirements USA 2
States with CARB requirement
Type sign
2Z1
Type sign at rear
and "Quattro" nameplates respectively
Vehicle class differentiation units/platform components
7LJ
Vehicle class differentiation -8V0/8VC-
Vehicle inlet
ES0
Without vehicle inlet
Vehicle specifications
F0A
No special purpose vehicle, standard
equipment
Vehicle tracking system
7G0
Without preparation for VTS
(vehicle tracking system)
Versions
FN0
"S" variant
Washer fluid level indicator
8W1
Weight category front axle
L14
Suspension range 14
installation control only, no
requirement forecast
Weight category rear axle
0YG
Weight range 7
Wheelbases
0B1
Wheelbase
Wheels
C0J
Alloy wheels 8J x 18
Wind blocker
7S0
Without wind blocker
Window regulator
4R4
Power windows with comfort operation and
circuit breaker
Windshield glass type
4GH
Windshield in heat-insulating glass
with sunshield
Windshield wiper intermittent control
8N6
with light/rain sensor
lordjop
C?ID=306886
Jack you're too kind but it WAS pretty dumb of me to run an auto scan without saving it. That was a major VCDS, JPPSG violation ! Just under $10,000 for a new tranny, without labor.... !!? That's crazy. I don't THINK there's a major problem that would need a replacement, but who knows. The little i drove the car (forward in 1st and reverse) i did not feel any grinding, clicking or anything that would suggest a major failure. I suspect it may be an issue with one of the clutch sets (2,4,6, R) or drive shafts. Reading the repair manual makes me think it's fairly easy to reach and retrieve the mechatronic unit and run some troubleshooting diagnostics on it. Perhaps one of the solenoids // valves is malfunctioning and preventing proper gear engagement? I'll post what i DID save here:
 Saturday,29,April,2017,10:35:40:63824
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WAUBFGFF3F1083628   License Plate: GVV6708
Mileage: 56553   Repair Order:
21148 - Gear 2
                    Mileage: 91016 km
                    Date: 2017.04.26
                    Time: 17:36:50
21150 - Gear 4
                    Mileage: 91003 km
                    Date: 2017.04.20
                    Time: 15:40:27
21152 - Gear 6
                    Mileage: 91003 km
                    Date: 2017.04.20
                    Time: 15:41:07
          P2711 00 [200] - -
                    Mileage: 90998 km
                    Date: 2017.04.20
                    Time: 15:06:47
          P2711 00 [072] - -
                    Mileage: 91003 km
                    Date: 2017.04.20
                    Time: 15:41:05
FYI: VCDS saves Auto-Scans surreptitiously whether you ask it to or not. Look in your Scans sub-folder. ;)
ivagp
C?ID=95551
Hi op I Once limped a car home that would not shift past 2nd. In Tiptronic mode after you have not experienced the fault yet on the cycle, in Tiptronic mode in first Revit to 3000 let off the gas pedal and quickly shift into second and see what it does. I would first clear the codes and then after you go through all the gears check the codes again. This is not a fix or anything just to make sure and see if you can get any grinding noises or anything out of the other gears or if the clutch pack is holding or not and do it is only through the Tiptronic
lordjop
C?ID=306886
Just left the indie shop and performed an Auto Scan. Apparently he cleared the DTS's and the car showed "No Fault Code" for all modules. I took this opportunity to play around with the advanced measuring blocks and took the car for a little spin. IVAGP, i reversed the car out from the shop and immediately shifted into manual mode. I drove the car around the lot and manually shifted from 1st, 2nd, 3rd, 4th ... then the car shifted into first and went into "limp mode". All gear shifts were smooth, no grinding, clicking or clunking. As soon as the CEL went on i pulled back into the bay and ran another Auto Scan. While looking at the advanced measuring blocks there were some words in German towards the end that i couldn't understand. I am trying to decipher all of the values from the different logs that i got. The input and output speed sensors appear to be working as they gave readings while i was driving around. What DID catch my attention was "Current of valve for clutch 2 specified value" gave a consistent zero reading. Also, "Current Valve Clutch 2 Actual Value" gave a value rang of .9 to 1.3. Can i assume that this is one of the valves that control the clutch within the DSG // Mechatronic unit? I saw a book on this website's store authored by the ATG entitlted "Volkswagen & Audi Diagnostics". Would this book help in interpreting the measuring block values? I'm trying to isolate the issue before we go in and start taking things apart.
Thanks for all the help so far ! Here is my latest Auto Scan (i hope i use "code" properly this time, apologies if i don't)
Friday,05,May,2017,17:19:09:63824
Mileage: 91018km-56555mi   Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 55 5F A9 BB
          BC
VIN: WAUBFGFF3F1083628   Mileage: 91018km-56555miles
Address 01: Engine (J623-CYFB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 E    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0A1D00122426000E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259E 001002
   ROD: EV_ECM20TFS0208V0906259E.rod
   VCID: 42DE43C8840044177BD-8016
Readiness: 0010 0101
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4521
   Revision: 03253104    Serial number: TFK01410271096
   Shop #: WSC 04742 780 00200
14 Faults Found:
21148 - Gear 2
          P0732 00 [010] - Incorrect Ratio
                    Mileage: 91017 km
                    Date: 2017.05.05
                    Time: 16:51:42
21150 - Gear 4
          P0734 00 [066] - Incorrect Ratio
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21154 - Gear 2
          P072D 00 [002] - Not Selectable
21155 - Gear 3
          P072E 00 [002] - Not Selectable
21156 - Gear 4
          P072F 00 [002] - Not Selectable
21157 - Gear 5
          P073A 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
10909 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
21207 - Pressure Control Solenoid 3
          P0797 00 [002] - Short to Plus
10906 - Cooling Oil Valve
          P2711 00 [011] - -
                    Mileage: 91018 km
                    Date: 2017.05.05
                    Time: 17:06:34
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 62944000003909
   Coding: 31FF6B9254280A6F017D030241CB698CD62A5080C08296B6024100588208
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 48CA51E0A23C6E47A59-801C
   Revision: 00021000    Serial number: 0352076171
   Coding: 030C0C
   VCID: 3A2E3B28ECD00CD723D-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000487739
   Coding: 03000014010000000000000000001400
   VCID: 3330160CCBBAFD9FE0B-8066
   Serial number: EFF80A57000000000001
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0137
   Serial number: 01011430701262
   Coding: 04151A46C04122F541C04004511807A00800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AAEFB28AC50CCD763D-802E
   Component: WWS371 141009  042 0585
   Serial number:         141108082028
   Coding: 0A47F7
   Serial number: 23391689
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 10 09 2014  00001191
   Serial number: 00000000000060929188
   Sun Roof:
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST0000ZE5I00000
   Coding: 101F00
   Serial number: 003GCR00YML6
   VCID: 47C852DCAF22613FAC3-8012
   Belt Pretensioner left:
   Serial number: 34178311B13111470353
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34178312B11111470450
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y1400018DCA0G
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 000 611 14
   Serial number: 357000000008AC10811D
   Subsystem 5 - Part No SW: -----------    HW: 480 000 611 14
   Serial number: 358000000008EB10811H
   Subsystem 6 - Part No SW: -----------    HW: 480 403 010 14
   Serial number: 3510002A11860BC2A0B/
   Subsystem 7 - Part No SW: -----------    HW: 480 403 010 14
   Serial number: 35200029F1860BC1F0AE
   Subsystem 8 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3550002A9175A921D062
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3560002A9175A92490EA
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 11111408490509
   Coding: A018
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0A4EABE8FCB0DC5773D-805E
   Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
   Component: KOMBI         H02 4291
   Coding: 0BED181B2B80D7050201A8001800000000000000
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   VCID: 4CC26DF0B6448267811-8018
   Revision: --------    Serial number: 21101410802153
   Coding: 0101000830085A005B00022C180B00000001010000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72BED308F420B4972BD-8026
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 01 11 2014  F0001478
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00007.10.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   VCID: 46D65FD8A8287837575-8012
   Revision: 00000000    Serial number: 14000294069005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 34321510CEB4FAA7F91-8060
   Serial number: 22101401101049
   Coding: 00511F204000048000000002
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 8102
   VCID: 3728221CDFC211BFDC3-8062
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN900T2KA
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 382A2120D2DC1EC7D59-806C
   Serial number: 29101401101712
   Coding: 005117204000048000000002
   VCID: 41DC4CC481065F0F627-8014
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 012A000101000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75B4E814854EA3AF0EF-8020
Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844     HW: 8V0 035 844
   Component: MU-S-S-US     013 0626
   Serial number: A7A00411140352
   Coding: 017301000000000021220002001A00002F0002240100010002
   ROD: EV_MUStd4CPASE_AU37.rod
   VCID: 76B6EF189848A8B7075-8022
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY307904
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: C1000011071400020161
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140925200908
   VCID: 7DA4F034BD7EFBEF46F-8028
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 03111403111856
   Coding: 004117204000048000000002
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      020 0028
   Serial number: 03111402081849
End----------(Elapsed Time: 01:34, VBatt start/end: 13.6V/13.7V)-----------
