**This is for a MK7 Golf**..sorry forgot to put in title....
Basically I want to turn of the function that the driving mode selection button (by gearstick) turns from white to orange if you have the car in any other mode other than normal.
Effectively making the button light up white only
I consider an orange light to be a warning that I have activated an on/off button, but that button is not an on/off, it is a selector button & I am fed up having a bright orange led staring at me!!
I briefly saw a post on golf forum that someone had turned it off, but no mention of how.
Now I can't find the post & goggle is not much help either.
I have look in all the modules, & the main "Driving profile select" coding lines are time parameters to adjust! I know I could go into the steering & engine etc. & permanently fix those modes for those parameters.
Still having a look, but if anyone knows without having to rip the switch apart...
EDIT:-
Just had a play in central coding 09
long coding
Byte15
Bit 5 Drive selection button installed
Bit 7 Drive selection button w/o function light installed
My car had bit 5 ticked, bit7 not ticked, so untick 5 & tick 7 = orange light out but button no longer brings up choices on infotainment screen even with engine on.
So tick both boxes = button glows orange, & does not bring up choices on infotainment
Further edit:-
had a mess around in
19 CANgateway
longcoding
Byte8
bits 0,1,2,3,6 were ticked in my car...
Tried various combinations in CANgateway & central electronics....(19 & 09) but is seems that the 09 longcoding Byte15 bit5 has to ticked other wise it effectively cuts of the whole switch & does not bring up the menu on the infotainment screen! But in ticking this the orange light is lit on the button....
I'm out of ideas anyone else have anything???
EDIT:-
long coding
Byte15
Further edit:-
19 CANgateway
longcoding
Byte8
