This fault appear to me and i searched for the wires from transmission and ABS and gateway , all the wires is connected
Is this can be fault in coding ??
thanks in advance
thanks in advance
Thursday,27,April,2017,09:55:12:11183
VCDS Version: 16.8.4.2
Dealer/Shop Name: Harisa car service
VIN: WVWZZZ1KZ8W056528 License Plate:
Mileage: 126800km-78789mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ8W056528 Mileage: 126800km-78789miles
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 GK
Component: SIMOS71 1.6l 2V 1028
Revision: --H04--- Serial number: VWX7Z0G53NS1IJ
Coding: 0000075
Shop #: WSC 01392 785 00200
VCID: 6ED64CF779BCAA322B-803A
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 009 - Malfunction / Open Circuit
Bin. Bits: 00000100
Resistance: 16.38 kOhm
Voltage: 2.100 V
Load: 4.7 %
Readiness: 0110 0101
Part No: 09G 927 750 ET
Component: AQ 250 6F 0842
Coding: 0008264
VCID: 0718195376069B7A88-8052
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F88C1B36E5613BAF0-806A
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 78FA6AAF0BF8E482F1-802C
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005020238
Coding: 008D0F2700041500471400001400000000097B075C000100000000000000
Shop #: WSC 01287 785 00200
VCID: 6FE851F37EB6A33A20-803A
Component: Wischer 040707 021 0501
Coding: 00038805
Shop #: WSC 01287
Fault Status: 01101100
Reset counter: 71
Mileage: 126797 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.65 V
Component: 39 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1BU84H
Coding: 0013113
Shop #: WSC 01373 785 00200
VCID: 3D74BBBB645A01AAE2-8068
Subsystem 1 - Serial number: 6332MSME1C37007FG
Subsystem 2 - Serial number: 6342MSME19663B3EP
Subsystem 3 - Serial number: 6352QSME32244B37D
Subsystem 4 - Serial number: 6362QSME2C5B2D4B
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 036 0070
Coding: 0010012
VCID: 000A024F5328AC42C9-8054
Part No SW: 1K0 920 864 A HW: 1K0 920 864 A
Revision: V0002000 Serial number: VWX7Z0G53NS1IJ
Coding: 0000103
Shop #: WSC 65536 645 577705
VCID: 2A5E80E785D48612B7-807E
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 020707F2001325
Coding: 3F3F034007000002
Shop #: WSC 43102 431 131662
VCID: 2F6891F3BE36E33A60-807A
Fault Frequency: 49
Reset counter: 71
Mileage: 126797 km
Time: 04:24:16
Component: IMMO VDD 1212
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120A
Coding: 0000180
VCID: 387AAAAF4B78248231-806C
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.133 H07 1806
Shop #: WSC 00028 028 00001
VCID: 34629E9F5710C0E21D-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 989002005103087F2D04840560084F03E0FCA0
Shop #: WSC 08224 211 56823
VCID: 03000D43423EB75AD4-8056
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000180
VCID: 397CAFAB70723D8ACE-806C
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1207
Coding: 0000144
Shop #: WSC 01392 785 1012552
014 - Defective
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End-------------------------(Elapsed Time: 02:03)--------------------------
