I am going to retrofit some door entry lights in the door cards of my Caddy, as they only come with reflectors, assuming the wiring in already in place.
However, when accessing the coding on the DCM, it seems i should have a bubble pop up with the coding info, but for some reason, it doesn't appear?
I notice that my door modules dont have a J code.
Running latest VCDS software and formware on up to date Windows 10.
Autoscan:
Thanks.
Autoscan:
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 10 13 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZHX100354 Mileage: 2320km-1441miles
Address 01: Engine (J623-DFSB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 016 HB HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1802
Revision: 8AH20---
Coding: 01190032044515090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01104L906016HB 001003
ROD: EV_ECM20TDI01104L906016GR_VN35.rod
VCID: 70BAD99CEA2BB4B7DD9-8024
7158 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [032] - -
Engine speed: 0.00 /min
Coolant temperature: 14 °C
Intake air temperature: 17 °C
Voltage terminal 30: 11.080 V
Engine control module reset status-Bit 0: 0
Engine control module reset status-Bit 8: 0
Limitation: torque: 1000.0 Nm
Limitation: accelerator pedal: 126.6 Nm
Cruise Control System (CCS): status-Bit 0: 0
Accelerator pedal travel: raw value: 0.00 %
Engine torque: -500.0 Nm
Generator: load signal: 30.00 %
15733 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 40107000000821
Coding: 1079409BB262B47E0878027B4D862DE379F5F0
ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
VCID: 3FD84AA0E7F51BCF143-806A
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 1K8 907 044 CH HW: 1K8 907 044 CH
Component: Climatronic H08 0405
Revision: 00001K06
Coding: 0510004003
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 77A8E2808F45E38F1C3-8022
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+ 122 0184
Revision: BD122001
Coding: 491A583E8025E16A088800809100896C037D000862208760E484C7000041
Shop #: WSC 35110 377 08192
VCID: 73B0D6909BBD8FAF20B-8026
Subsystem 1 - Part No: 2K2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 02011 26 0512
Coding: 009F95
Subsystem 2 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 211216 04 42 0106
Coding: 0228DD
Component: Sensor, DWA 0 005 0502
Component: LIN BACKUP HO H01 0008
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 1K8 919 475 D HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0480
Revision: -------- Serial number: 39431634901859
Coding: 0131061041
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00.rod
VCID: 3B203EB0F3ED07EF38B-806E
Address 13: Auto Dist. Reg (J428) Labels: 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Serial number: 04011704388226
Coding: 00000000FE0339
ROD: EV_ACCBEGVW361.rod
VCID: 36362F84C8CFDA87C75-8062
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 2K5 959 655 B HW: 2K5 959 655 B
Component: VW10Airbag00K H08 0018
Revision: -------- Serial number: 003V1002FW42
Coding: 00000000000000000000000000000000304B
ROD: EV_AirbaVW10BPAVN750.rod
Serial number: 3497ARB4004597JCVK9J
Serial number: 3507ARB401457GMESAUW
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 GE HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20170103301131
Coding: 1082C60008
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 75B4E8889549919F0EF-8020
Subsystem 1 - Part No SW: 2K0 959 442 A HW: 2K0 959 442 A Labels: 3C8-959-537.CLB
Serial number: 0021719505201432BC1B
Coding: 2C0000
Part No SW: 2K5 920 976 E HW: 2K5 920 976 E
Component: KOMBI H03 1104
Coding: 410E021200
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 382A21BCC2DB2CF7D59-806C
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 081216F1002876
Coding: 357431
VCID: 7BA0FEB0B3EDC7EF78B-802E
Component: IMMO H03 1104
VCID: 6A8ECBF4CCF74E6793D-803E
Address 42: Door Elect, Driver Labels: None
Part No SW: 2K5 959 701 A HW: 2K5 959 701 A
Component: Tuer-SG 009 2144
Coding: 0135730
VCID: 323E13942827C6A7EBD-8066
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 314 3501
Revision: 00H22000
VCID: 392C24B8F55135FF2A7-806C
Address 52: Door Elect, Pass. Labels: None
Part No SW: 2K5 959 702 A HW: 2K5 959 702 A
Coding: 0135730
VCID: 33301690D73DCFAFE0B-8066
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 E HW: 5C0 035 680 E
Component: MU-S-ND-ER H31 0359
Serial number: VWZAZ2T5016940
Coding: 063307013C00000011111101008808001F0100C600200100CF
ROD: EV_MUStd4CTSAT_SK25.rod
VCID: 2310E6D06B5D5F2F10B-8076
Subsystem 1 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: 030F7873
VCID: 71BCDC98E1A1BDBFD27-8024
Subsystem 1 - Part No SW: 2K0 915 181 HW: 2K0 915 181
Serial number: 75410603001701093018
End----------(Elapsed Time: 01:10, VBatt start/end: 12.3V/12.3V)-----------
Thanks.
