J393 Module
senna1
C?ID=231631
Hi
If changing a J393 Convenience module, i believe they need coding, is this soft coding,
No login required,
select 46 cent Conv.
Coding 07
enter the appropriate valve, do it,,
Where can i find the coding value to enter. is it on the autoscan.
Here is a full scan.
Wednesday,26,April,2017,15:00:37:46146
VCDS Version: 17.1.3.0 (x64)
Dealer/Shop Name:
VIN: WV1ZZZ2KZ7X009472   License Plate:
Mileage: 223210km-138696mi   Repair Order:
Chassis Type: 2K (1K0)
VIN: WV1ZZZ2KZ7X009472   Mileage: 223210km-138696miles
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 AQ    HW: 028 101 239 0
   Component: R4 1,9l EDC  000SG  7872
   Revision: --H02---    Serial number: VWZ7Z0F7005764
   Coding: 0000071
   Shop #: WSC 35110 377 00159
   VCID: 6ED3E282792347310B-803A
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
                    Mileage: 223215 km
                    Time: 12:33:24
                    Voltage: 11.55 V
                    Bin. Bits: 11000100
                    Temperature: 11.7°C
                    Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 223215 km
                    Time: 12:33:24
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
                    Fault Frequency: 32
                    Mileage: 223215 km
                    Time: 14:49:58
                    Voltage: 11.55 V
                    Bin. Bits: 11000100
                    Temperature: 11.7°C
                    Bin. Bits: 00110000
   Part No: 1K0 907 379 P
   Coding: 0017106
   VCID: 3F8D6FC66EC9FEB9D0-806A
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
   Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6BD5EB964A31B2192C-803E
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000005874087
   Coding: 01884F030004100000000000000000000009FF075C
   Shop #: WSC 35110 377 08192
   VCID: 2B552B968AB172196C-807E
   Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 110506 020  0501
   Coding: 00038805
   Shop #: WSC 35110
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 73
                    Mileage: 223215 km
                    Voltage: 12.70 V
            010 - Open or Short to Plus
                    Reset counter: 73
                    Mileage: 223215 km
                    Fault Status: 01101010
                    Reset counter: 73
                    Mileage: 223215 km
                    Voltage: 12.20 V
                    Reset counter: 73
                    Mileage: 223215 km
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD0AFKCN
   Coding: 0012345
   VCID: 7DF1D5CE24452CA982-8028
   Part No SW: 1K0 953 549 BB    HW: 1K0 953 549 BB
   Component: Lenksäulenmodul 035 0070
   Coding: 0000002
   VCID: 73E5F3F612016AD9E4-8026
   Part No SW: 2K0 920 943 A    HW: 2K0 920 943 A
   Component: KOMBIINSTRUMENT VDD 1612
   Revision: V0003000    Serial number: VWZ7Z0F7005764
   Coding: 0017401
   Shop #: WSC 00215 210 86450
   VCID: 2959D19E804D60099E-807C
                    Reset counter: 113
                    Mileage: 223215 km
                    Time: 02:00:34
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H04 0010
   Revision:   H04 02    Serial number: 11050602000770
   Coding: 3D0F034007007401
   VCID: 2C57288A8FBF752165-8078
                    Fault Status: 00110100
                    Reset counter: 113
                    Mileage: 223215 km
                    Time: 02:30:51
                    Reset counter: 113
                    Mileage: 223215 km
                    Time: 00:00:01
                    Reset counter: 113
                    Mileage: 223215 km
                    Time: 00:00:01
                    Reset counter: 113
                    Mileage: 223215 km
                    Time: 00:30:22
   Component: IMMO            VDD 1612
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0160
   Coding: 0000052
   VCID: 74E7F0EA170F6DE1FD-8020
01030 - Central Locking Key Switch; Driver Side; Lock
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.140 H07 1806
   Shop #: WSC 35110 666 38454
   VCID: 35610DEE5CF534E90A-8060
            000 -  -
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 008A0C097F2D8405495A010010C0
   VCID: 79F9C1DE306D1089AE-802C
02483 - Module for Locking of Rear Lid (F327)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Component: Tuer-SG         005 0930
   Coding: 0000560
   VCID: 397901DE70EDD089EE-806C
   Part No: 1K0 035 186 P
   Component: Radio BVX       016 0023
   Coding: 0020200
   VCID: 336533F652812AD924-8066
End-------------------------(Elapsed Time: 01:31)--------------------------
There.
senna1
C?ID=231631
:thumbs: thankyou. is that under coding 07,, or long coding.
That's clearly a long coding, but you never actually need to choose between regular (short) coding and long coding; a module uses one or the other, and VCDS is smart enough to know which is needed.
