Audi Q5 steering code
mohamed
Egypt
C?ID=211960
Could you help me with the correct code of the steering and how could i do the basic setting ?
Saturday,22,April,2017,18:00:25:22511
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Dealer/Shop Name: Harisa car service
VIN: WAUZZZ8R9AA054409   License Plate:
Mileage: 152870km-94989mi   Repair Order:
Chassis Type: 8R (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 1B 42 46 52 53 56 62 72
VIN: WAUZZZ8R9AA054409   Mileage: 152870km-94989miles
1B-Active Steering -- Status: Malfunction 0010
Address 01: Engine (CL0MA-CDNC)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8R0 907 115 D    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0004
   Revision: E1H15---
   Coding: 01210010240F0160
   Shop #: WSC 36003 360 90504
   ASAM Dataset: EV_ECM20TFS8R0907115D A01004
   ROD: EV_ECM20TFS0118K2907115AJ.rod
   VCID: B52265F0141619961D-80E0
          U1113 00 [039] - -
                    Mileage: 152877 km
                    Date: 2009.06.27
                    Time: 23:11:23
          U1113 00 [039] - -
                    Mileage: 152877 km
                    Date: 2009.06.27
                    Time: 23:11:23
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
                    Mileage: 152877 km
                    Date: 2009.06.27
                    Time: 23:11:23
2859 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [039] - Malfunction / Open Circuit
                    Mileage: 152877 km
                    Date: 2009.06.27
                    Time: 23:11:23
2980 - Intake Manifold Flap Position Sensor (Bank 1)
          P2016 00 [039] - Short to Ground
                    Mileage: 152877 km
                    Date: 2009.06.27
                    Time: 23:11:23
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8R0 927 156 AB    HW: 0B5 927 156 E
   Component: 0B5 20TFSIRdW H04 0004
   Revision: --H04---    Serial number: 0000000955
   Shop #: WSC 44972 000 1048576
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: FBB6B3C872B20FE6AB-80AE
Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 027548
   Shop #: WSC 06335 000 00000
   VCID: CAD8260C65E8666E60-809E
03110 - Active Steering Control Module (J792)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 24
                    Reset counter: 135
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:59
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x000C
                    Hex Value: 0x16A3
                    Hex Value: 0x00FF
03265 - Data Bus Chassis Sensors
                    Reset counter: 135
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:59
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0021
                    Hex Value: 0xB9A3
                    Hex Value: 0x00FF
03033 - ESP Sensor Unit 2 (G536)
                    Reset counter: 135
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:59
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0026
                    Hex Value: 0xB8A3
                    Hex Value: 0x00FF
00493 - ESP-Sensor Unit (G419)
                    Reset counter: 135
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:59
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0005
                    Hex Value: 0x54A3
                    Hex Value: 0x00FF
                    Fault Frequency: 27
                    Reset counter: 135
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:59
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x001B
                    Hex Value: 0x40A3
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 173
                    Mileage: 152851 km
                    Date: 2009.06.26
                    Time: 02:09:20
                    Hex Value: 0x0A00
                    Hex Value: 0x4202
                    Hex Value: 0x1016
                    Hex Value: 0x02B0
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DT    HW: 8K0 907 064 DT
   Component: BCM2 1.1      H02 0326
   Coding: 010500
   VCID: 8542D5300C764916CD-80D0
   Subsystem 1 - Part No SW: 8T0 959 754     HW: 8T0 959 754
                    Reset counter: 173
                    Mileage: 152851 km
                    Date: 2009.06.26
                    Time: 02:09:25
   Part No SW: 8T1 820 043 AB    HW: 8T1 820 043 AB
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C0000000    Serial number: 01070120090634
   Coding: 46002000
   Shop #: WSC 06325 000 00000
   VCID: F1AA91E028FE75B601-80A4
10 Faults Found:
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:14
                    Temperature: 28.0°C
00359 - Left Front Upper Body Outlet Temperature Sensor (G385)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:14
                    Temperature: 28.0°C
                    Voltage: 14.00 V
00360 - Front Right Upper Body Outlet Temperature Sensor (G386)
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:14
                    Temperature: 28.0°C
                    Voltage: 14.00 V
01230 - Left Footwell Vent Temperature Sensor (G261)
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:14
                    Temperature: 28.0°C
                    Voltage: 14.00 V
00797 - Sunlight Photo Sensor (G107)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:14
                    Temperature: 31.0°C
                    Temperature: 28.0°C
                    Output: 1382 W
                    Output: 1382 W
03037 - Rear Temperature Selection Potentiometer (G538)
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:14
                    Voltage: 14.00 V
                    Voltage: 5.00 V
                    Reset counter: 173
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:14
                    Fault Status: 01100101
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:14
01273 - Fresh Air Blower (V2)
                    Fault Status: 00100011
                    Fault Frequency: 36
                    Reset counter: 175
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 03:57:31
                    Temperature: 25.0°C
                    Load: 100.0 %
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Fault Frequency: 17
                    Reset counter: 174
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 03:57:37
                    Temperature: 25.0°C
                    Load: 100.0 %
                    Voltage: 13.10 V
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000504772
   Coding: 260010804030AF311701000000001D0D0F1CC74802010001000000
   Shop #: WSC 07114 002 104857
   VCID: BA3876CC3508F6EEF0-80EE
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 091029  H10 0041
   Coding: 01DD13
   Subsystem 2 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
No Faults Found
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0081
   Revision: 11001001    Serial number: 36861219602073
   Coding: 000105
   Shop #: WSC 49394 000 1048576
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 E    HW: 8R0 959 655 E
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GND0DAB9C
   Coding: 30453331313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: C6C0123C79F0820E84-8092
   Serial number: 6344MSME4D01571CH
   Serial number: 6352QSME30422214
   Serial number: 6362QSME3841362EJ
   Serial number: 63732SME3D413318Z
   Serial number: 63832SME6C42413E3
          B1000 1B [137] - Resistance Too High
                    Fault Frequency: 9
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:15
9437979 - Igniter 2  for Passenger's Airbag
          B1003 1B [137] - Resistance Too High
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:15
9443091 - Driver's Side Airbag Crash Sensor
          B1017 15 [137] - Open or Short to Plus
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:13
9447189 - Seat Occupied Sensor; Passenger's Side
          B1027 15 [137] - Open or Short to Plus
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:15
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90304HBK0009H
   Coding: 000017
   VCID: BE307ADC2920DACECC-80EA
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 B    HW: 8R0 920 930 B
   Component: KOMBIINSTR.   H10 0255
   Revision: 00000000    Serial number: CJI75C5C9
   Coding: 0F02220022000008010000
   VCID: B3265BE8126207A633-80E6
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G09A2181F3
   Coding: 00C303
   VCID: D0EC346483B45CBE2E-8084
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Part No SW: 8K0 907 144 D    HW: 8K0 907 144 D
   Component: DYNAMIKLENK.  H06 0570
   Revision: 50001005    Serial number: --------------
   Shop #: WSC 06334 000 00000
   VCID: B02C54E4E3743CBE4E-80E4
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 133
                    Count: 66
                    Count: 1
                    Hex Value: 0x0107
                    Hex Value: 0x0000
                    Hex Value: 0xF4FF
                    Hex Value: 0x0000
            000 -  -  - MIL ON
                    Count: 56
                    Count: 1
                    Hex Value: 0x007F
                    Hex Value: 0x0615
                    Hex Value: 0xF7FF
                    Hex Value: 0x8304
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009601869
   Coding: 011D02204100440004
   VCID: C5C215304CF689168D-8090
   Revision: 00002001    Serial number: 0123558478
   Coding: 01000620203900140530053280000000
   Component: J245EE20SKB13  H01 0220
   Component: J394EE20SKB13  H01 0220
                    Reset counter: 135
                    Mileage: 152877 km
                    Date: 2009.06.27
                    Time: 23:14:44
01512 - Control Module for Sliding Roof
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:18
02907 - Control Module for Roof Shade (J394)
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:18
                    Fault Status: 11101100
                    Reset counter: 134
                    Mileage: 152861 km
                    Date: 2009.06.26
                    Time: 07:55:29
00230 - Transmission Park Selector Switch (F305)
                    Fault Status: 01101000
                    Reset counter: 135
                    Mileage: 152877 km
                    Date: 2009.06.27
                    Time: 23:11:42
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009587060
   VCID: C4C4083447CCB01E9A-8090
   Revision: 00000003    Serial number: 00000000491018
   VCID: B42458F4176C009E2A-80E0
                    Fault Status: 11101101
                    Reset counter: 135
                    Mileage: 152851 km
                    Date: 2009.06.26
                    Time: 02:09:20
                    Voltage: 14.10 V
                    Count: 57
                    Speed: 10.0 km/h
                    Hex Value: 0x0260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
            000 -  -  - Intermittent
                    Reset counter: 173
                    Voltage: 0.00 V
                    Count: 77
                    Hex Value: 0x4060
                    Hex Value: 0x0082
                    Hex Value: 0x4040
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 AA    HW: 8T1 035 195 AA
   Component: Symphony3     H06 0350
   Revision: 00000010    Serial number: AUZ5Z4J1202912
   Coding: 0502008201048500035B070000
   VCID: F6A0A2FC4190528ED4-80A2
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:18
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:18
02981 - Connection between Radio and Impedance Converter 1
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:23
02982 - Connection between Radio and Impedance Converter 2
                    Reset counter: 133
                    Mileage: 152850 km
                    Date: 2009.06.26
                    Time: 00:09:23
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102244704
   Coding: 010C02204000240004
   VCID: C2C80E2C5DD8BE2EA8-8096
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Revision:             Serial number: 0000102244701
End-------------------------(Elapsed Time: 03:30)--------------------------
mohamed
Egypt
C?ID=211960
Could anyone help me ?
DrPeter
16.4905° S, 151.7375° W
The coding of the [1B-Active Steering] is normally performed via a connection to Audi and the SVM test plan using a factory scan tool.
- I did do some research and found that the coding for this controller on a similar vehicles for the [1B-Active Steering] could be either:
Coding: 820000
or
Coding: 020100
We have a Ross-Tech wiki page for this controller and there are sections for Security Access(required for coding) and Basic Settings.
Audi A5 (8T) Active Steering
Please note that the above coding values may be incorrect. Code the controller at your own risk, we can not guarantee the results.
Also Be advised that typically the "replacement of the 1B-Active Steering (J792) control module requires Online Coding and Parameterization using SVM (Software Version Management). SVM is a system used by VW/Audi to flash update control modules, and in certain cases, to change their Coding, Adaptation and configure Parameters. VCDS cannot perform SVM."
Hope this helps,
drpeter
ref: E?ID=311876 E?ID=312039
mohamed
Egypt
C?ID=211960
This is very helpful
Thank you for your efforts
