Jetta Mk6 TDI (2014) - Canadian Highline Model - TPMS?
TooLittleTime
Canada
C?ID=217224
I was wondering if anyone got the TPMS to work on a 2014 Highline (Canadian version)?
I have gone through the major guides on how to enable TPMS on an MK6. Issue is that most of these guides are for a Golf and the Jetta seems to be very different.
One guide that is listed on Ross-Tech under Mk6 Jetta but that does not apply to at least Mk6 Jetta is:
http://www.vwwatercooled.com.au/forums/f112/how-retrofit-indirect-tire-pressure-monitoring-5-minutes-7k6-50164.html
I believe the above guide is for a GLI version of Jetta.
The controllers that I have are:
Address 03: ABS Brakes (J104) HW: 1K0 907 379 BM
Address 17: Instruments (J285) HW: 5C6 920 853 A
I have tried enabling all combinations of bits (TPMS labeled) in both of the above controllers, but can't seem to even get the TPMS light on the dash to light up.
Any suggestions are welcome.
TooLittleTime
Canada
C?ID=217224
It seems to be a difference in the ABS software coding:
Original -> A14B400C492300FD850B02E492200042A1100010
Modified as per Ross-Tech Wiki -> A14B400C492300FD850B02E492200042A5140010
Final changes that enabled functionality -> A14B400C492300FD850B02E492200042A5140022
Instrument coding was changed as follows:
Old -> 370E00
New -> 370E01
It appears that the last byte needs to be 0x22 and not 0x10 to enable full ESP and TPMS functionality. Without this change neither would work.
kdagia
India
C?ID=227529
Hi
Noobie question...
Please guide me to making this change "last byte needs to be 0x22 and not 0x10" in ABS
Hi
Noobie question...
That was based on the NAR market ABS module and the factory coding for it so we would need to see the details from the vehicle in question. Please post the Auto-Scan for review.
OK I see you introduced yourself with a scan (thanks!) so providing this is the car in question:
Chassis Type: 16 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
          77
VIN: WVWG14162EA552297
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: A63B40F8092700FC650D02ED90200082A1100010
   Shop #: WSC 00047 000 00000
   VCID: 7EDD1022E9827BEEE91-802B
   Part No SW: 5C6 920 873 A    HW: 5C6 920 873 A
   Coding: 171D00
   Shop #: WSC 00047 123 00057
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 2C79EA6A477E397E175-8079
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 220314F1001576
   Coding: 351003
   VCID: 79D7033EF0AC5CD6DC3-802C
I would use the Long Coding Helper to change that 03-ABS coding from
to
A63B40F8092700FC650D02ED90200082A5140010
That includes modifications in Bytes 16 and 17.
Next, 17-Instruments should be coded from 171D00 -to- 171D01
Lastly, most MK6 Golf based vehicles require a virtual TPMS module in the 19-CAN Gateway Installation List. This step may not be necessary so I would encourage you to test the TPMS system and run another Auto-Scan after the steps above first. Only if needed, Use the [Installation List] function and add 4C-Tire Pressure II followed by Save Coding.
kdagia
India
C?ID=227529
Thank you Dana. Will test out and post auto scan...
Keep up the fantastic work..
kdagia
India
C?ID=227529
HI Dana
Completed the actions as follows.
ABS Module - 1K0 907 379 BM .. Dana this is same as opening post NAR module
Instrument module: 5C6 920 873 A
1. 03 ABS Coding :Modifications in Bytes 16 and 17
to
2. 17 - Instruments : Coded from 171D00 TO 171D01
3. No TPMS Orange flash
4. Enabled 4C-Tire Pressure II from 19-Can Gateway - Installation list
5. No TPMS Orange Flash
6. Enabled 65 - Tire Pressure
7. Gets the TPMS sign on but auto scan throws errors
8. Undoing above actions cleared all faults
a) Should we try the suggestion above 03 ABS to end with A5140022 instead of A5140010. If yes how do I do that
wbr
Kishor
Thursday,09,October,2014,15:25:02:29966
VCDS Version: 14.8.1.0 (x64)
Data version: 20140905
VIN: WVWG14162EA552297   License Plate:
Mileage: 2050km-1273mi   Repair Order: 14-10-09-04
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 52 55 56 62
          72 77
VIN: WVWG14162EA552297   Mileage: 2050km-1273miles
4C-Tire Pressure II -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CLCB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 GJ    HW: 03L 907 309 R
   Component: R4 2,0L EDC   H25 9970
   Revision: 42H25---    Serial number: 00000000000000
   Coding: 001D0012042500080000
   Shop #: WSC 00047 000 00057
   ASAM Dataset: EV_ECM20TDI01103L906018GJ 003005
   ROD: EV_ECM20TDI01103L906018GJ.rod
   VCID: 78D1063AC3A645FAE1-802D
   Component: GSG DSG AG6     521 4014
   Revision: 05652104    Serial number: 00001404262417
   Shop #: WSC 02069 000 90108
   VCID: 1409528A370E819A6D-8041
   Revision: 00H46001
   Coding: A63B40F8092700FC650D02ED90200082A5140010
   Shop #: WSC 00047 123 12345
   VCID: 7EDD1022E9827BCAAB-802B
   Part No SW: 3AA 907 044 BP    HW: 3AA 907 044 BP
   Component: Climatronic   H05 0505
   Revision: 00001K02
   Coding: 001001A002
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 7F23ED26E68872C2A0-802A
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0173
   Revision: BC122001
   Coding: 26000A3AD02F00C440080080040089EC0374000872A08120E4C400000040
   Shop #: WSC 00066 123 12345
   VCID: 42A5A4D2DDFADF2A8F-8017
   Component: RLS 180314 05  54  0403
   Coding: 07300A
Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
   Part No SW: 5C6 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 07381404400180
   Coding: 108101
   ASAM Dataset: EV_EPHVA18VW3610000 001003
   ROD: EV_EPHVA18VW3610000.rod
   VCID: 71C73B1EA0DC14B226-8024
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    014 0613
   Serial number: 003G6M0CFHBG
   Coding: 00003241
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 3245F412655A6FAA1F-8067
   Serial number: 3572MSME28311C44ZZZS
   Serial number: 3582MSME56311C44ZZZU
   Serial number: 3516KSME5A2A5C2CZZZ4
   Serial number: 3526KSME311B582CZZZX
   Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
   Revision: FF010042    Serial number: 20140418200670
   Coding: 0892140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79D7033EF8AC5CF29E-802C
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Coding: 830000
   Coding: 171D01
   ROD: EV_Kombi_UDS_VDD_RM09_VW32.rod
   VCID: 2C79EA6A477E395A55-8079
   Coding: 351003
   VCID: 79D7033EF0AC5CF29E-802C
                    Reset counter: 60
                    Mileage: 2054 km
                    Date: 2014.10.09
                    Time: 15:48:38
                    Mileage: 2054 km
                    Date: 2014.10.09
                    Time: 15:41:43
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 100
                    Mileage: 2054 km
                    Date: 2014.10.09
                    Time: 16:16:44
   VCID: 6AF52C728D0AE76A67-803F
Address 2E: Media Player 3
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0515
   Revision: 12110009    Serial number: 0008034911
   Coding: 0016B7
   Shop #: WSC 01383 790 50316
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 1C193AAA17DEC9DA25-8049
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1508
   Serial number: 00000008533638
   Coding: 000690
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   VCID: 3957C33E702C9CF2DE-806C
Address 4C: Tire Pressure II
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0515
   Revision: 14110009    Serial number: 0008000411
   Coding: 0016B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 1D1F37AE0CC4C0D2D2-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1508
   Serial number: 00000008538109
   Coding: 000690
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 081600000B000200
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: 3753C5068E388A8228-8062
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: LeiMo links  H02 0010
   Coding: 860000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: LeiMo rechts  H02 0010
   Coding: 860000
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3P0384500
   Coding: 01000400040006
   VCID: 2469024A27AEF11A9D-8071
Address 77: Telephone (J412)       Labels: None
   Part No SW: 5N0 035 729     HW: 5N0 035 729
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007666189647
   Coding: 0A01000080010101
   ROD: EV_UHVUMI.rod
   VCID: 6DFF276EBCE4F05202-8038
End
kdagia
India
C?ID=227529
Hi added input..car comes in kit form from mexico...
kdagia
India
C?ID=227529
Solved..Thank you Dana and Toolittletime
Final steps
to
2. Using Notepad and Control V pasted new code int long code box changed Byte 19 coding to x22 instead of x10
Final coding is A63B40F8092700FC650D02ED90200082A5140022
3. Enabled 4C-Tire Pressure II from 19-Can Gateway - Installation list
5. Shut down VCDS and ignition off. Reconnected after 15 seconds
6. TPMS Orange Flash in Instrument cluster
7. "Tyre Pressure" Function added to Function List in MFI
Pleasure to have gone through this pain. Time well spent.
Kishor
PN: :) As a side issue Had activated the ESP Function Test.
Once the Function Test has been started it cannot be cancelled and must be successfully finished.
The Diagnostic Tool should NOT need to be connected while performing the Function Test.
Only then fault codes clear. http://wiki.ross-tech.com/wiki/index.php/ESP_System_Function_Test_(Conti/Teves)
Was an intersting learning curve. Took 30 minutes to get the hang of the procedure
rjsummer
Canada
C?ID=21159
Hi, I just bought my used 2014 TDi, and would like help bringing my TPMS online. I've mucked around in instruments, gateway install list, and ABS controller, trying to code things as this thread indicates. I can't seem to get the TPMS light to come to life at all. I have the same cluster as you but it says 7K0 on my label which apparently means no TPMS light? Anyway, my abs module is a BS, not a BM like yours. Any chance you could help me getting my TPMS working? I assume the BS module works as well for the indirect TPMS? Heres my auto scan after reversing all the changes I made from this thread's instruction.
Thursday,10,November,2016,23:40:57:51584
VCDS Version: 16.8.3.1 (x64)
VIN: 3VWWL7AJ8EM307340   License Plate:
a
Chassis Type: AJ (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
VIN: 3VWWL7AJ8EM307340   Mileage: 113840km-70736miles
   Part No SW: 03L 906 019 KD    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  7553
   Revision: 12H16---    Serial number:
   Coding: 0050072
   Shop #: WSC 00066 000 00000
   VCID: 77FD226C0604C4FA8D-8022
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C49220001850E02E892190042A1100010
   Shop #: WSC 55543 001 104857
   VCID: 040745A087D29F6298-8050
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BL    HW: 5C0 820 047 BL
   Component: J301  Klimaanlage   0204
   Revision: 2001001S    Serial number: 00000002153112
   VCID: 6BD50E1C4A4C701A79-803E
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 5C0 937 086 J    HW: 5C0 937 086 A
   Component: BCM25 JLB M3  H34 0411
   Revision: B0034001    Serial number: 06013141140001
   Coding: 7B994B1808AB0B0000382000240884C50082502E60000000300010002000
   VCID: 3365D67C92FCE8DA71-8066
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14202585140501131429
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584140424150356
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Serial number: 0303213 FLE 20140417
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587140425150712
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14202586140505172223
   Coding: 800000
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD04KF4Q
   Coding: 00004138
   Shop #: WSC 00066 790 00013
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74E71560DF72AFE2A8-8020
   Serial number: 6940000Y1400014Z4E0U
   Coding: 303053
   Serial number: 3572MSME61315842ZZZN
   Serial number: 3582MSME50305842ZZZL
   Serial number: 3516KSME4646542CZZZW
   Serial number: 3526KSME1667542CZZZX
   Serial number: 3556LSME6C0A7C2CZZZC
   Serial number: 3566LSME4A2C7C2CZZZD
   Part No SW: 5C6 920 853 A    HW: 5C6 920 853 A
   Component: KOMBI         H04 0809
   Coding: 370A00
   Shop #: WSC 00066 000 00119
   VCID: 2A5BCB184D36A912C2-807E
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 5C0 937 086 A
   Component: GW-K-CAN TP20 H34 0411
   Revision: B0034001
   Coding: 102200
   VCID: 70EF1970A36A93C24C-8024
   Component: IMMO          H04 0809
   VCID: 6ADB0B188DB6691202-803E
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274     HW: 1K0 035 274
   Component: RNS315-NAR    H05 0011
   Serial number: VWZAZ2L8450501
   Coding: 040004610100000400001000
   ASAM Dataset: EV_RNS315VWNARV1UDS A01005
   ROD: EV_RNS315VWNARV1UDS.rod
   VCID: 61C96C3470802A4AD3-8034
   Revision: 00H22000
   VCID: 3979E4547090128ABB-806C
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Revision: 1B001001    Serial number: 00007665916340
   Coding: 0210030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E53C70871DEC5321E-807A
End-------------------------(Elapsed Time: 02:30)--------------------------
rjsummer
Canada
C?ID=21159
Ok, I figured it out and the TPMS is working now.
