Audi A3 8P 1.6 petrol power loss
automech
Poland
C?ID=14925
Hi,
I have strange problem with 2010 Audi A3 1.6 petrol engine, when you start to drive in 1st gear and you let go off the clutch, there is no reaction to gas pedal, revs does not go any higher or lower. But if you touch the clutch pedal lightly (not enough to even slip a little) car goes with normal power until change to 2nd gear when situation repeats.
Problem does not occur on gears 3rd,4th,5th or when clutch pedal sensor or wheel speed sensor is disconnected.
I have changed the clutch sensor but problem is still present.
Things that was already changed:
-clutch pedal sensor
-crankshaft speed sensor
-intake with throttle body and pressure sensor
-ECU
-ABS pump
Things that I have checked with VCDS:
-engine speed
-wheel speed
-pedal monitoring
-engine load
-torque limitation
-injection time
-intake air pressure
-throttle body movement
-gas pedal signal
-ECU coding
-ABS coding
Wednesday,12,April,2017,17:02:19:22573
VCDS Version: 17.1.2.1 (x64)
Data version: 20170131 DS267.1
Workshop Code: 123 12345 076128
VIN: WAUZZZ8P6AA   License Plate:
Mileage: 164210km-102035mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72
VIN: WAUZZZ8P6AA   Mileage: 164210km-102035miles
Address 01: Engine (BSE)       Labels: 06A-906-033-BGU.lbl
   Part No SW: 06A 906 033 JL    HW: 06A 906 033 JL
   Component:  BSE S71 1.6 2V     3460
   Revision: --H01---    Serial number: AUX7Z0I4FNR0PN
   Coding: 0044071
   Shop #: WSC 06314 000 00000
   VCID: 72EBB2E26DF70CD1E4-8026
Readiness: 0010 1101
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 1142201209220003881404ED901B00413800
   VCID: 7EF396D2E9AF58B190-802A
   Part No SW: 8P0 820 043 BK    HW: 8P0 820 043 BK
   Component: KlimavollautomatH09 0130
   Revision: 000241      Serial number: 8P0820043BK
   VCID: 76E38EF2019F10F1C8-8022
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063     HW: 8P0 907 063
   Component: BCM PQ35  B   104 0541
   Revision: 00104 AG
   Coding: 06000A2FB0051AC0203040E00000015C431229AA104DC929E40008A00040
   Shop #: WSC 06314 123 12345
   VCID: 71E9BDEEA8F137C91D-8024
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0140
   Revision: --------    Serial number: 003FB001BVXJ
   Coding: 30314238303830303035554A304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FAD1B16168501392B-801A
   Serial number: 3572DRB400008EB1396
   Serial number: 3582DRB400008EACE98J
   Serial number: 35128RB400004DEB264T
   Serial number: 35228RB400004DEB2EC3
   Serial number: 35547RB400004D9B84E0
   Serial number: 35647RB400004D9B87B1
   Part No SW: 1K0 953 549 DB    HW: 1K0 953 549 DB
   Component: J0527           037 0070
   Coding: 0000002
   VCID: 75E189FE1C991BE9C1-8020
   Part No SW: 8P0 920 902     HW: 8P0 920 902
   Component: KOMBIINSTR. VDO H01 0980
   Revision: D0H01002    Serial number: 1244I002001011
   Coding: 0004028
   Shop #: WSC 56885 001 1048576
   VCID: 6ED3A69279CF283100-803A
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4020K096050050
   Coding: E9807F46000202002102
   VCID: 66C3DEB2513FE07178-8032
   Revision: D0H01002    Serial number: AUX7Z0I4FNR0PN
   Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
   Component: Tuer-SG         H04 0100
   Coding: 0000148
   VCID: 46833E3231FFC07198-8012
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 232    2901
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2F6D7B96BE4561394B-807A
   Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
   Coding: 0000148
   VCID: 479D333636F5D97963-8012
   Part No SW: 8P0 035 152 E    HW: 8P0 035 152 E
   Component: R Chorus2+      H02 0280
   Revision: 00H02000    Serial number: AUZ1Z2I5209596
   Coding: 0000021
   VCID: 2D51619EB449132979-8078
00878 - Connection to Speaker Front Left
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 231
                    Mileage: 164210 km
                    Date: 2017.03.24
                    Time: 00:29:38
00856 - Radio Antenna
                    Reset counter: 231
                    Mileage: 164210 km
                    Date: 2017.03.24
                    Time: 00:29:38
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
   VCID: 428B22221DD7FC51B4-8016
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000118852282
   Coding: 0100000100000000
   Shop #: WSC 25477 000 00000
   VCID: 2F6D7B967E4561394B-807A
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0000144
   VCID: 4385272602CDF559BF-8016
End-------------------------(Elapsed Time: 01:48)--------------------------
Gone But Not Forgotten
Hello OP....:p
Please unplug OXS sensors to isolate possible heater shorts and add a ground strap to the chassis to block + battery to enhance.
Verify ground straps at all locations....
automech
Poland
C?ID=14925
Thanks for reply Jack, I cleaned all ground connections and disconnected OX sensors as you said, unfortunately it did not change the behaviour of the car.
What I noticed today is, engine gets back power when status of clutch sensor switches from position not depressed to partially depressed when car is already moving.
Vehicle Speed 	Switch Positions I
(current)
 km/h
0.0	111 <- driving out on the road from garage
0.0	111
0.0	111
0.0	100
0.0	100
0.0	100
0.0	100
0.0	100
0.0	100
0.0	100
0.0	100
0.0	100
0.0	100
0.0	100
1.0	100
1.0	100
1.0	100
2.0	100
3.0	100
3.0	100
4.0	100
5.0	100
5.0	100
6.0	100
6.0	100
7.0	100
8.0	100
8.0	100
7.0	100
7.0	100
6.0	100
6.0	111
5.0	111
5.0	111
5.0	111
4.0	111
3.0	111
3.0	111
2.0	111
1.0	111
0.0	111
0.0	111
0.0	100 <- accelerating on the road form standstill
0.0	100
0.0	100
0.0	100
0.0	100
0.0	100
1.0	100
1.0	100
2.0	100
3.0	100
4.0	100
5.0	100
7.0	100
8.0	100
10.0	0     <- clutch fully disengaged, gas to the floor
12.0	0
13.0	0
14.0	0
15.0	0
16.0	0
17.0	0
17.0	0
18.0	0
19.0	100 <- light press on clutch (without slipping)
21.0	0 <- car starts to acceleate with full power
25.0	0
27.0	0
29.0	0
31.0	0
34.0	100 <- change to 2nd gear
34.0	100
35.0	100
35.0	100
35.0	100
36.0	100
37.0	0  <- no power again
37.0	0
38.0	0
38.0	0
38.0	0
39.0	0
39.0	0
40.0	0
41.0	0
41.0	100 <- again light touch on clutch pedal without slipping
42.0	100
48.0	0  <- acceleration with normal power again
47.0	0
47.0	0
49.0	0
50.0	0
52.0	0
53.0	0
54.0	0
54.0	0
53.0	0
53.0	0
52.0	0
52.0	0
51.0	11 <- braking to make U-turn
50.0	11
50.0	11
49.0	11
48.0	11
47.0	11
45.0	11
44.0	11
42.0	11
41.0	111
39.0	111
38.0	111
36.0	111
35.0	111
33.0	111
31.0	111
Well the clutch and brake switch work with cruise signals or load offset of TQ request.
They are directly related to EPC.
I would readjust or isolate the switches to verify the condition is gone and then figure on a readjustment or replacement.
These switches in these cars are a POS, since they went to this one time use type..........
automech
Poland
C?ID=14925
I know that switches works with CCS and TQ and that's why I changed clutch sensor in first place, but I don't think it's possible to adjust them as they are hall sensors mounted on pumps, not on the pedal itself.
I was thinking if someone tried to activate CCS, which car is not equipped with, so I deactivated it just to be sure, but it didn't make any change.
But I'll try with the brake switch.
Thanks for the hint, every one counts :)
automech
Poland
C?ID=14925
Today I unplugged brake switch, which made it even worse.
After that I generated readiness codes with result of all systems OK. Strange thing is, it didn't solve the problem, but engine feels smoother and more powerful.
I wonder if a new brake light switch makes a difference or if running a resistor to fake it steady during testing observation.
