- Nov 10, 2014
- 400
- 392
- Oxford, UK
- C?ID=226919
My car is in for it's annual service again today so in following with tradition, a scan of the courtesy car is below
It's another Mk3 Škoda Fabia with the same engine as the one I had last year (scan of that one HERE) but this one appears to have newer engine ECU software and the car as a whole is a much more basic spec model.
Tuesday,11,April,2017,09:42:06:55895
VCDS Version: 17.1.3.0 (x64)
VIN: TMBFM6NJ1HZ059150 License Plate:
Mileage: 3426km-2128mi Repair Order:
Chassis Type: NJ (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: TMBFM6NJ1HZ059150 Mileage: 3426km-2128miles
Address 01: Engine (J623-CJZC) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BB HW: 04E 907 309 AF
Component: R4 1.2l TFS H23 9085
Revision: R4H23---
Coding: 01110032230415080000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM12TFS01104E906027BB 001009
ROD: EV_ECM12TFS01104E906027BB.rod
VCID: 65C194CF64BB91697A-8030
CAN Converter 01:
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 N HW: 6R0 907 379 BA
Component: ESP9.0i H04 0005
Serial number: 08501073160827
Coding: 43F5287D492833C90915106E0051C21492CC9008000DCAF98F00
Shop #: WSC 13765 031 00000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 3A7B17B3BD85CE91E7-806E
Address 08: Auto HVAC (J301) Labels: 6C0-820-045.clb
Part No SW: 6V0 820 045 B HW: 6V0 820 045 B
Component: AC Manuell H01 0203
Serial number: 1608231B-0146
Coding: 100000001100100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 3169309F60F30DC956-8064
Address 09: Cent. Elect. (J519) Labels: 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0094
Serial number: 006308106197
Coding: 0F0008404205405303A04080B10703080000D800D6013500000000000000
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006.rod
Subsystem 1 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY161732QEZ
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000066819764
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 3K H10 0054
Revision: -------- Serial number: 39261625703470
Coding: 0001050001
ROD: EV_EPHVA14AU3700000_SK25.rod
VCID: 3C7711ABB7B1F0A1F5-8068
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 01091603213078
Coding: 00000000FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 K HW: 6C0 959 655 K
Component: VW20Airbag74D 002 0380
Revision: -------- Serial number: 003TJ006XJZF
Coding: 88CCC000000000005C5400CF008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3B7512B7B2BFF799FC-806E
Subsystem 1 - Part No SW: ----------- HW: 410 821 808 16
Component: SideSensor_Df 151 0800
Serial number: 3575H00BD20E298041FU
Subsystem 2 - Part No SW: ----------- HW: 410 821 808 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H009D2134FE090DZ
Subsystem 3 - Part No SW: ----------- HW: 442 151 808 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AB218176203E5
Subsystem 4 - Part No SW: ----------- HW: 442 151 808 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00AD2135004A16$
Part No SW: 6V0 920 940 B HW: 6V0 920 940 B
Component: KOMBI 202 2310
Coding: 272401002180A60001882A011000000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 36630383899D2AF103-8062
Address 19: CAN Gateway (J533) Labels: 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0094
Revision: -------- Serial number: 006308106197
Coding: 030100042F0A640000000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_VW26.rod
VCID: 2643D3C3593D5A71B3-8072
Subsystem 1 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000B1589020916
Subsystem 2 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 53235F45505881500963
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AG HW: 6C2 909 144 D
Component: EPS_TRW_ALow 323 3232
Serial number: CG9C0254
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW_SE26.rod
VCID: 6ED3EBE3B14D52310B-803A
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 842 B HW: 5Q0 035 842 B
Component: MU-S-D-ER H30 0359
Serial number: SKZAZ2S5190618
Coding: 03620000BE00000011111204008808002F0100C60120010002
ROD: EV_MUStd4CTSAT_SK26.rod
VCID: 2E532BE371CD12314B-807A
Subsystem 1 - Part No SW: 6V0 919 604 B HW: 6V0 919 604 B
Component: ABTm_Std2 H42 1041
Serial number: SKZ8Z9SLX00DWU
End-------------------------(Elapsed Time: 02:38)--------------------------
