It could be picking up the edge of the protector, if VW can't do it then there must be a genuine reason why it won't work. As I said mine did really easily and quickly.
I retro fitted the highline camera to my 2016 vw tiguan with discover media headunit and it kept showing a calibration fault through vcds.so had it booked into the dealers which they had all day and they could not get it calibrated no matter what settings they put on it...
The only way I got it working was to swap my module over with one that was already calibrated via the factory which my friend kindly swapped with me before he got rid of his 2015 vw tiguan!!!!!
scott
calibration will take in to consideration height of camera/car, length, angle etc... so calibration will improve angle for better line of sight also move red lineI have removed the protector however I checked my friends car the red line is further from his bumper however this could be as his is calibrated
Sunday,04,June,2017,21:15:08:04925
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZ3CZFE037171 License Plate: BEFORE SERVICE
Mileage: 26710km-16596mi Repair Order: diesel
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 47 4C 4F 52
53 55 56 61 62 6C 6D 72
VIN: WVWZZZ3CZFE037171 Mileage: 26710km-16596miles
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PA HW: 03L 907 309 AE
Component: R4 2.0l TDI H28 9978
Revision: 41H28--- Serial number: 00000000000000
Coding: 001D0012042501080000
Shop #: WSC 34742 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
ROD: EV_ECM20TDI01103L906018PA.rod
VCID: 78F5D876C3C07681D1-802C
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4017
Revision: 05652104 Serial number: 00001406120657
Shop #: WSC 05311 000 00001
VCID: 142D8CC63768B2E15D-8040
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BM HW: 3AA 614 109 BM
Component: J104 C2 450M VDCB 0040
Revision: --H07--- Serial number: 00000008306711
Coding: 0008115
VCID: 79F3DD7230CA6F89AE-802C
02214 - Tire Pressure Warning
Reset counter: 233
Mileage: 26413 km
Date: 2017.05.20
Time: 17:17:04
Speed: 122.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 BT HW: 3AA 907 044 BT
Component: Climatronic H05 0607
Revision: 00001K02
Coding: 061400C803
Shop #: WSC 00015 115 00001
VCID: 030FBF9A8A062559F4-8056
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 Q HW: 3AA 937 087 Q
Component: BCM PQ47 H+ 422 0475
Revision: BC422001
Coding: 0208000000000000009C0080740029F423F54B88676D8760E488C7240041
Shop #: WSC 05311 123 00001
VCID: 489568B6FBA0C60161-801C
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 20061 26 0612
Coding: 00B795
Component: RLS 110714 05 54 0403
Coding: 0630ED
Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb
Part No SW: 3AE 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H06 0018
Revision: -------- Serial number: 28201418200198
Coding: 308102
Shop #: WSC 99999 123 12345
ASAM Dataset: EV_EPHVA18VW47X0000 001006
ROD: EV_EPHVA18VW4280000.rod
VCID: 3F87736AA66E81B9D0-806A
Part No SW: 5N0 959 655 AE HW: 5N0 959 655 AE
Component: J234__10J VW10 HI 2418
Revision: 29020000 Serial number: 003N5PC03SMZ
Coding: 0012362
VCID: 0005B09653103E41E9-8054
Subsystem 1 - Serial number: 6332MTS672781794
Subsystem 2 - Serial number: 6342MTS685451754
Subsystem 3 - Serial number: 6351HTS6JO2O1DKR
Subsystem 4 - Serial number: 6361HTS627S62DKJ
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 CN HW: 5K0 953 569 AS
Revision: FF010042 Serial number: 20140624101118
Coding: 1992250001
VCID: 77F7DB4ACEDE79F9D8-8022
Component: E221__MFL-TK6 H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 981 A HW: 3AA 920 981 A
Component: KOMBI H03 0705
Coding: 461F01
Shop #: WSC 05314 115 00001
VCID: 336F2F5A9A2655D924-8066
Part No SW: 7N0 907 530 AS HW: 7N0 907 530 AN
Component: J533 Gateway H56 1653
Revision: H56 Serial number: 250614F2001170
Coding: 462007
Shop #: WSC 05314 123 00001
VCID: 0103B592981A3749E6-8054
Part No SW: 3AA 959 799 E HW: 3AA 959 799 E
Component: IMMO 090 0409
Revision: 00090000 Serial number: VWZCZ000000000
VCID: 4A9152BE25AC341177-801E
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7666435973
Coding: 020100
VCID: 2B5F373A4A160D196C-807E
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 S HW: 3C8 035 279 S
Component: RNS315-EU H80 0500
Serial number: VWZAZ2P0380543
Coding: 040700410100110000019002
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3B7F077AB2769D99FC-806E
Component: EUR_W_V6 0062
1048641 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 111
Mileage: 24649 km
Date: 2017.03.25
Time: 16:51:40
Correction for sound system: OK
Traffic sign display: OK
CD changer: OK
Status of antenna 2 for radio: OK
Digital radio (DAB): OK
Antenna diagnostic: OK
Telephone baseplate diagnostic: OK
Speaker status: OK
Rearview camera: ERROR
Telephone Transceiver: OK
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0008808303
Coding: 0212F7
Shop #: WSC 05311 115 00001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 356B114294524BE90A-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 005 0503
Serial number: 00000004061119
Coding: 0102D0
67584 - Warning Light for Front Door
B11F5 01 [008] - Electrical Failure
Reset counter: 243
Mileage: 26711 km
Date: 2017.06.04
Time: 17:13:40
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 196 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 39731D72704AAF89EE-806C
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Component: 02 KESSY PQ47 090 0375
Coding: 01900A00D2C34E7634029C3F7E005FCE105800130427BC
Component: Neigungssensor 004 0611
Subsystem 4 - Part No: 3AA 962 243 D
Component: GEB.F.Heckoef 0811
Address 47: Sound System (R184) Labels: 5K0-035-456.clb
Part No SW: 3AA 035 466 HW: 3AA 035 466
Component: KonzernAmp12K H03 6904
Revision: -------- Serial number: A1108A00001899
ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
ROD: EV_AudioVerst12KanalSTT1.rod
VCID: 6DDBF922BC82C32932-8038
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1653
Coding: 00000008
VCID: 6FE7E32ABE8E313900-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0008782149
Coding: 0212F6
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 3669164E895440F103-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 005 0503
Serial number: 00000004054739
Coding: 0102D0
Fault Frequency: 15
Reset counter: 242
Mileage: 24643 km
Date: 2017.03.24
Time: 19:54:36
133120 - Warning Light for Rear Door
B11F7 01 [008] - Electrical Failure
Fault Frequency: 10
Reset counter: 235
Mileage: 24584 km
Date: 2017.03.19
Time: 22:04:45
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000168523
Coding: 0022167
VCID: 387518764B40B68111-806C
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 029600000B000200
VCID: 37771B4A8E5EB9F918-8062
Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 230000
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1653
Coding: 030F1859
VCID: 71E3E552A8BA27C916-8024
Component: J367-BDM H07 0180
Serial number: 41183H11301491466170
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H15000 Serial number: 525PA8-JBX0068
Coding: 0020007
Shop #: WSC 98765 666 38384
VCID: 68D588365B60E60141-803C
Reset counter: 155
Address 6D: Trunk Elect. Labels: None
Part No SW: 3AF 827 383 A HW: 3AF 827 383 A
Component: J605 HECKDECKEL 0860
Revision: 00H52001
Shop #: WSC 05314 000 00001
VCID: 3A71027E754CA491E7-806E
Subsystem 1 - Part No: 3AF 827 384 A
Component: J756 HECKDECKEL 0860
Subsystem 2 - Serial number: 1400H52001001C0311ÿ
End-------------------------(Elapsed Time: 03:42)--------------------------
Address 03: DTCs cleared
The only way to get rid of this error code is to get hold of a calibrated/used module from a (Tiguan) and that will get rid of your fault code!!!!!Well I got a response from Kufatec it pretty much said "it works without being calibrated"
All I want to do is calibrate it to clear the code's grr
scott
