passat b6 2010 60 plate no ignition
vw754
C?ID=52227
Hi I have a Passat (well someone I know) I did a diagnosis on it today...........car has no ignition coming on at all, so what I did is put a wire in the fuse box and connected it to another fuse resulting in ignition coming on and car starting and drivng with no lights coming on on the dash...........but soon as the wires disconnected the car go's off............so now I know that its not getting ignition what can be the problem.?
I have 2 scans one is before faults cleared and one after
this one below is one taken before the faults were cleared.
Monday,19,June,2017,12:51:24:07086
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
VCDS Version: 17.1.3.0
VIN:    License Plate: 60-PASSAT
Mileage: 206760km-128474mi   Repair Order:
Gateway Installation List:  3C0 907 530 Q
Monday,19,June,2017,12:50:19:07086
VIN: WVWZZZ3CZAP064007   License Plate: 60 PLATE PASSAT
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77
VIN: WVWZZZ3CZAP064007   Mileage: 206760km-128474miles
04-Steering Angle -- Status: Sporadic communication error 1000
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 997 025 P    HW: 03L 907 309
   Component: R4 2,0 EDC  G000SG  0485
   Revision: 13H08---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 50890 001 1048576
   VCID: 3F8750B26E6612B9D0-806A
000144 - Valve for Fuel Metering (N290)
               P0090 - 000 - Open Circuit - Intermittent
                    Mileage: 206763 km
                    Date: 2011.11.10
                    Time: 14:48:31
                    RPM: 552 /min
                    Voltage: 13.30 V
                    Pressure: 0.0 bar
                    Inj. Quantity: 23.9 mg/str
                    Lambda: 44.2 %
                    Lambda: 34.7 %
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 000 - Open Circuit - Intermittent
                    Mileage: 206763 km
                    Date: 2011.11.10
                    Time: 14:48:31
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --026---    Serial number: 00000706009469
   Coding: 0003347
   Shop #: WSC 00028 790 00007
   VCID: 62C1B9C6BD541F519F-8036
00576 - Terminal 15
                    Reset counter: 148
                    Mileage: 206763 km
                    Date: 2011.11.10
                    Time: 14:32:47
                    Hex Value: 0x0000
                    Voltage: 13.25 V
                    Bin. Bits: 00111110
                    Count: 123
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 AC    HW: 3C8 907 336 AC
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000002
   Shop #: WSC 00028 028 00020
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6ED9DDF6B18CAB310B-803A
13701376 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 206763 km
                    Date: 2017.06.19
                    Time: 14:32:56
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 206763 km
                    Date: 2017.06.19
                    Time: 14:32:56
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 148
                    Mileage: 206763 km
                    Date: 2017.06.19
                    Time: 14:33:01
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000006103215
   Coding: 00808F0700041A00470A00000F000000000859435C000120000000000000
   Shop #: WSC 00028 028 00001
   VCID: 32610986AD34CFD12F-8066
   Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 140710 022  0612
   Coding: 00046997
   Shop #: WSC 00028
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 148
                    Mileage: 206763 km
                    Voltage: 13.65 V
02403 - Terminal 15 for Interior
                    Reset counter: 148
                    Mileage: 206763 km
                    Fault Status: 00100110
                    Reset counter: 188
                    Mileage: 206763 km
                    Voltage: 12.75 V
                    Reset counter: 188
                    Mileage: 206763 km
                    Reset counter: 188
                    Mileage: 206763 km
                    Voltage: 12.95 V
                    Reset counter: 188
                    Mileage: 206763 km
   Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
   Component: J234__006 VW10 HI   1916
   Revision: 21014000    Serial number: 003GHPENQK2H
   Coding: 0012342
   VCID: 48954B6E3BA8550161-801C
   Subsystem 1 - Serial number: 6332MTS650301740
   Subsystem 2 - Serial number: 6342MTS671211740
   Subsystem 3 - Serial number: 6351HTS66ME1D6KR
   Subsystem 4 - Serial number: 6361HTS6EA84D6KR
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Component: LENKS.MODUL   009 0135
   Revision: FF010037    Serial number: 20100726300650
   Coding: 0182270002
   VCID: 72E1C986A5B48FD1EF-8026
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
   Component: KOMBI         H03 0305
   Coding: 460F00
   VCID: 2D5B1AFA7C0A902972-8078
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P10727000E
   Coding: F9807F06400602001003
   VCID: 2F6700F2BE06E23940-807A
                    Reset counter: 188
                    Mileage: 206763 km
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 7AF1E1A635C4F791A7-802E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
02828 - Enabling Steering Column Lock from Diagnostic Interface
                    Reset counter: 188
                    Mileage: 206763 km
                    Date: 2011.11.10
                    Time: 14:32:47
Address 37: Navigation
   Part No SW: 3C0 959 701     HW: 3C0 959 793
   Component: TUER-SG FT    002 0306
   Revision: 13101005    Serial number: 0001202801
   Coding: 0002B5
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 65CBA2DA647A68697A-8030
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0402
   Serial number: 00000001593334
   Coding: 000290
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 147
                    Mileage: 206763 km
                    Date: 2017.06.19
                    Time: 14:25:01
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 148
                    Mileage: 206763 km
                    Date: 2017.06.19
                    Time: 14:57:06
68107 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 206763 km
                    Date: 2017.06.19
                    Time: 14:32:44
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 195    3001
   Revision: 00H17000
   VCID: 3163068AA832F4C956-8064
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 01910A0001860E763004941570085FCE107C01
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
                    Reset counter: 188
                    Mileage: 206763 km
                    Date: 2011.11.10
                    Time: 14:32:45
00625 - Vehicle Speed Signal
                    Reset counter: 188
                    Mileage: 206763 km
                    Date: 2011.11.10
                    Time: 14:32:45
   Part No SW: 3C0 959 702     HW: 3C0 959 792
   Component: TUER-SG BT    002 0306
   Revision: 15101005    Serial number: 0001201168
   Coding: 0002B4
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 66C9A5D6997C637173-8032
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0402
   Serial number: 00000001594241
   Coding: 000290
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 206763 km
                    Date: 2017.06.19
                    Time: 14:32:44
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   011       Serial number: 00000000349812
   Coding: 0000057
   VCID: 2C5D17FE8F10992165-8078
00576 - Terminal 15
                    Fault Frequency: 9
                    Reset counter: 188
                    Mileage: 206763 km
                    Date: 2011.11.10
                    Time: 14:32:44
                    Voltage: 13.60 V
                    Count: 54
                    Hex Value: 0x1161
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 56: Radio
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A07951336
   Coding: 012120
   VCID: 2A5111E645E4871197-807E
End-------------------------(Elapsed Time: 02:24)--------------------------
Ashraf6119
C?ID=174194
Under the drivers foot well there is a relay box very similar to the picture here I have posted swap those two relays around and see if your ignition is back to live.........Sorry I could not upload the picture but if you look in the are two relays on each corners #460 swap them
Edited: Anyway look in to this link and you will see those relays.......
https://sites.google.com/site/1810martin/b6-relay-assignment-1
vw754
C?ID=52227
Thanks.......if i swop them around and it works....that means one of the relays is no good? simple replacement should do the trick?
Ashraf6119
C?ID=174194
Yes the one on the lift side is for the Ignition 15 make sure you mark them before removing it so, you know which one is faulty
vw754
C?ID=52227
thanks....cars coming to me thursday .....let you know the outcome.
vw754
C?ID=52227
ok....car came today.....running as normal....never got to try changing the relay around as the cars now running and ignition working as normal..........all by itself:confused:
but the guy said it did come up on the instrument cluster as.......column lock fault or column fault..........ive run vcds on it and no faults are stored.....is the steering column lock faulty? is it safe to drive around?
steering column lock ive priced up at 100 quid........how easy it it to fit and code?.........if it is that.
