Results 1 to 10 of 15
Thread: Looking forward to place an order...
    Apr 2017
    The Great White North
    Hello Ross-tech and forum users.
    I was very close to buying a package a few years ago when we got my wife's Tiguan, but I didn't think I would get enough use of out it.
    But now that I got a Q3, I think I can justify the purchase, especially since the new model is out!
    So now I'm saving a bit and I will place an order soon, so I thought I would bug users of this forum with some questions.
    I have a couple of immediate needs for the tool, on both cars disabling DRL and enabling TPMS on the Q3. If it has the right ABS module, which I'm still trying to figure out.
    I have no plans to replace or upgrade stuff, but I would like to have control over some features that bug me, such as putting the radio on the Tiguan in timer mode instead of turning off. Normally, it should turn off when the key is removed and this has bugged me from day one. Of course, if it can be done.
    Stuff like that, I'm sure I will find some other tweaks once I get it. I also own a Scangauge II, but that's a different class of tools, useful for real time monitoring and some OBDC code reading, unlike VCDS, which is a true tool that can also change setings.
    From what I saw on the forums, there is a ton of information and codes, so I hope to be able to find what I need, when I will need it.
    Thank you for the opportunity.
    Near Philadelphia, PA, USA
    Hi somedude and welcome to the forum.
    Once you have your VCDS tool, and you can have a full tool for as little as $199 and cover both these cars, you should come back to the forum and post the Autoscans from the vehicle on which you wish to make the mods. With the information in the scans, the community can then look and determine whether or not your desired changes can be performed. We look forward to helping you here.
  3. Likes Boki Ar liked this post
    Apr 2017
    Thank you Bruce.
    I'm hoping to not run into nasty surprises after I get the tool...
    This kind of stuff should be feasible, right?
    I realize it depends on the cars, but my requests aren't far fetched, are they?
    Quote Originally Posted by somedude View Post
    Thank you Bruce.
    It's hard to say exactly what is and isn't possible without seeing scans from the cars in question because much depends on how they're equipped, and in some cases, even the software versions in the modules...
    Apr 2017
    Hi Uwe and thanks for jumping in.
    I'm not polishing the proverbial apple, but being a huge fan of Peter Sellers, every time I see your avatar I smile, thinking of Dr. Strangelove.
    I think I was simply asking whether VCDS is capable of doing those things, but I answered that question by doing some searches.
    Others have disabled daytime running lights, enabled the tire pressure monitor and then some, such as enabling the green menu in the MMI.
    Much to my chagrin, I can't figure out what version of MMI I have, but I will cross that bridge once I get the tool.
    It may not even be MMI, in spite of the display saying so, because this is the base model Q3 without NAV, even without the media interface. If I have my acronym right, it may be the radio based interface RCM or something like that.
    BTW, do you guys also have a store in Lasndale, or just the online one?
  7. Likes Uwe liked this post
    Sure, but I can't promise you that you'll be able to do all those things in the exact cars that you have, and I would rather under-sell than over-sell.
    Our office is there, but it's not a retail store. If a customer wishes to pick up an order, that can be arranged, but we ask that they place the order on-line so that we have it ready for them. If a customer wishes to stop in to have us check something out on their car, we ask that the make an appointment for that. Some days (or even weeks) are better than others.
    Apr 2017
    I can now start posting in the main forum, like a big boy!
    Got my V2 the next day!
    Thanks, Ross-Tech
  10. Likes jyoung8607 liked this post
  11. #8
    Apr 2017
    Until I get the activation code, here is my auto scan with the VIN obfuscated (sorry - paranoia).
    I'd be very interested if I could enable TPMS and Passenger side mirror tilt when backing up.
    Thank you very much
    Thursday,20,April,2017,17:51:05:35103
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
    VIN: WA1ECCFSXHR0xxxxx   License Plate:
    Mileage: 1960km-1217mi   Repair Order:
    Chassis Type: FS (8U0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 5F 62 6D 72
    VIN: WA1ECCFSXHR0xxxxx   Mileage: 1960km-1217miles
    Address 01: Engine (CCT)       Labels: None
       Part No SW: 8U0 907 115 L    HW: 8U0 907 115 J
       Component: 2.0l R4/4V TFSI  06 0002
       Revision: PAH05---    Serial number:
       Coding: 0123010A190F01A0
       Shop #: WSC 00049 770 00119
       VCID: 40DA496FE68B52F76D9-8014
       Part No SW: 09G 927 750 NL    HW: 09G 927 750 NL
       Component: AQ 250 6F           2696
       Revision: 00H97000    Serial number:
       Coding: 0000840
       Shop #: WSC 00049 770 00131
       VCID: 084A914F8E3BAAB7659-805C
    Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
       Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CJ
       Component: ESC-EBC460iV1 H12 0013
       Serial number: A01DDR6
       Coding: 42FF269F492143702077420964C592C20424D000508B4883
       Shop #: WSC 00049 770 00154
       ASAM Dataset: EV_Brake1ESCEPBTRW 006353
       ROD: EV_Brake1ESCEPBTRW_006.rod
       VCID: 71BCDCAB91218B7FD27-8024
       Part No SW: 8U0 820 047 G    HW: 8U0 820 047 G
       Component: J255  Klima Man     0030
       Revision: 00H02001    Serial number: 00000000000000
       VCID: 392C248B8551033F2A7-806C
    Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
       Part No SW: 8X0 907 063 AG    HW: 8X0 907 063 AG
       Component: BCM PQ35  M   113 0821
       Revision: AB113821
       Coding: AF000A0FA80336C4A4184BC121440D4D50FF66AA016F9523E40A06840045
       Shop #: WSC 00049 770 00015
       VCID: 015C8C6BA1019BFF227-8054
       Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119
       Component: WWS316 161110  H38 0090
       Serial number:         161202235421
       Coding: 0047F7
       Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
       Component: G397_RLS  H06 0004
       Serial number: 50080466
       Coding: 02006E
       Subsystem 3 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
    01134 - Alarm Horn (H12)
                        Reset counter: 75
                        Mileage: 82 km
                        Date: 2017.03.19
                        Time: 11:47:58
                        Voltage: 9.10 V
                            Term 50 On
    Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
       Part No SW: 8U0 959 655 A    HW: 8U0 959 655 A
       Component: AirbagVW-AU10 H53 0723
       Serial number: 003LQD12VCBY
       Coding: 303932313231413130304A55304C38553053
       ASAM Dataset: EV_AirbaAU10SMEAU316 002001
       ROD: EV_AirbaAU10SMEAU316_002.rod
       VCID: 45D4587BF52977DF5EF-8010
       Subsystem 1 - Part No SW: 8U0 959 339     HW: 8U0 959 339
       Component: BF-Gewichtss.  H02 0020
       Serial number: 5810000R160000FXJ7
       Component: S.Sens.Fahr.V
       Serial number: 3574MSME7953485BZZZ4
       Component: S.Sens.Beif.V
       Serial number: 3584MSME1D644B5CZZZ9
       Serial number: 3516KSME4A652040ZZZK
       Serial number: 3526KSME056E0F40ZZZY
       Subsystem 6 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME490E1140ZZZZ
       Subsystem 7 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3565USME58121140ZZZP
    Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
       Part No SW: 8X0 953 501 D    HW: 5K0 953 569 AL
       Revision: FF010018    Serial number: 20161215100521
       Coding: 1984204000
       VCID: 3B203E8383ED312F38B-806E
       Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
       Serial number: 09 12 2016  C0014777
    Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
       Part No SW: 8U0 920 930 H    HW: 8U0 920 930 H
       Component: KOMBI_MEDIUM  H05 0540
       Coding: 32CF00
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       VCID: 3C223D9F86E33617311-8068
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 AS    HW: 8U0 907 468 J
       Component: GAT 4CAN 2L M H13 0090
       Revision: 1R190044    Serial number: 4441R16B3002B7
       Coding: F3460A5A050B0D610253
       VCID: 1370B623CB7D196F80B-8046
       Subsystem 1 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS11.403  H03 0004
       Serial number: 0000FST001BLWSL00000
       Coding: 101E00
       Subsystem 2 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
       Component: J367-BDM  H07 0270
       Serial number: 33342I01145831018801
       Subsystem 3 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS11.403  H03 0004
       Serial number: 0000FST001BLWTM00000
       Coding: 001E00
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7540
       Serial number: HA1-00015.11.16
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_SK12.rod
       VCID: 52FE73273467D067CBD-8006
       Component: IMMO          H05 0540
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
       Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
       Component: TSG FA        H11 0415
       Coding: 011E03200000000000
       VCID: 55F4883B0509C75F2EF-8000
       Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
       Component: J500__APA-BS KL.377 1501
       Revision: 1BH04843    Serial number: 00163140160701
       Coding: 0000258
       VCID: 42DE4367E88740E77BD-8016
    Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
       Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
       Component: TSG BF        H11 0415
       VCID: 54F2753F0EF3DE57D91-8000
    Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
       Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
       Serial number: 161206-0002-130
       Coding: 16C7A41010022400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 44D2457FFE134ED7491-8010
       Part No SW: 8U1 035 187 B    HW: 8U1 035 187 A
       Component: RMC Cnct Sir  H62 0170
       Coding: 01000600028051070023000102010000010000
       VCID: 382A218FB25B1A37D59-806C
       Subsystem 1 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
       Component: DUBasic AU316  H43 0018
       Serial number: AUZ8ZDGCS038WS0
       Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
       Component: TSG HL        H08 0415
       Coding: 010E03200000000000
       VCID: 4FF87A5327D5BD8FE43-801A
    Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
       Part No SW: 8U0 959 107 A    HW: 8U0 959 107 A
       Component: HDSG-Modul    H02 0552
       Revision: 15001001    Serial number: 328601189
       Coding: 183307C102
       ASAM Dataset: EV_HDSGAU316 001001
       ROD: EV_HDSGAU316.rod
       VCID: 3D24309B9DF93F1F06F-8068
       Component: TSG HR        H08 0415
    End----------(Elapsed Time: 01:15, VBatt start/end: 12.5V/12.5V)-----------
  12. Likes Eric liked this post
  13. #9
    Since you ordered your HEX-V2 directly from us, you should not need an activation code; it should be pre-registered to you. I see a registration request from you. Is the software giving you an indication that it needs to be registered?
  14. #10
    [Select]
    [52-Door Elect, Pass.]
    [Coding]
    [Long Coding Helper]
    Click on Byte 4.
    There should be an option for Reverse Gear Mirror Dipping
    But I'm not certain your car supports it.
