- Apr 23, 2014
- 16
- 0
- C?ID=122556
Ok everyhting works ok but the can does not recognize the phone module or the radio . I know the CAN gateways needed upgrading for the RNS nav radio but I am not certain about the premium 8 radio. There is a dealer can gateway update that can be done will this fix it or do I need a new can module??
Wednesday,30,July,2014,17:24:01:49850
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWKC71K98W053247 License Plate: NEW SCAN
Mileage: 131930km-81977mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56 65 77
VIN: WVWKC71K98W053247 Mileage: 131930km/81977miles
77-Telephone -- Status: Malfunction 1010
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 KB HW: 022 906 032 GP
Component: R32-Flex 032 G Ð;O
Revision: 1QH02--- Serial number: VWX7Z0G53NR93X
Coding: 0000178
Shop #: WSC 00001 000 00000
VCID: 55ABB8B2FCC3ECB6981-8000
8 Faults Found:
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold - MIL ON
Fault Status: 11100010
Mileage: 131478 km
Time: 17:12:10
RPM: 1784 /min
Load: 53.3 %
Speed: 69.0 km/h
Temperature: 96.0°C
Temperature: 55.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.335 V
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - MIL ON
Mileage: 131478 km
Time: 17:12:17
RPM: 1761 /min
Load: 27.8 %
Speed: 68.0 km/h
Temperature: 96.0°C
Temperature: 55.0°C
Voltage: 13.208 V
P0300 - 008 - - Intermittent - MIL ON
Fault Status: 10101000
Fault Frequency: 6
Mileage: 131501 km
Time: 09:40:09
RPM: 872 /min
Load: 42.7 %
Temperature: 39.0°C
Temperature: 32.0°C
Voltage: 13.716 V
000773 - Cylinder 5
P0305 - 008 - Misfire Detected - Intermittent - MIL ON
Fault Frequency: 6
Mileage: 131501 km
Time: 09:40:40
RPM: 814 /min
Load: 41.6 %
Temperature: 45.0°C
Temperature: 33.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent - MIL ON
Mileage: 131501 km
Time: 09:40:40
RPM: 814 /min
Load: 41.6 %
Temperature: 45.0°C
Temperature: 33.0°C
Voltage: 13.589 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent - MIL ON
Mileage: 131527 km
Time: 16:49:21
RPM: 790 /min
Load: 41.2 %
Temperature: 57.0°C
Temperature: 48.0°C
Voltage: 13.589 V
006481 - Radiator Fan 2 (V177)
P1951 - 002 - Movement Restricted / Jammed - Intermittent
Mileage: 131527 km
Time: 16:52:58
RPM: 759 /min
Load: 39.6 %
Temperature: 80.0°C
Temperature: 54.0°C
Voltage: 13.335 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Mileage: 131527 km
Time: 16:52:59
RPM: 763 /min
Load: 39.6 %
Temperature: 80.0°C
Temperature: 54.0°C
Voltage: 13.462 V
Address 02: Auto Trans (UMª) Labels: 02E-927-770.lbl
Part No SW: 02E 300 011 CC HW: 02E 927 770 AD
Component: United 500 082 1405
Revision: 05108020 Serial number: 00001008301795
Shop #: WSC 04940 001 00001
VCID: 52A143AECD2DFB8E7D3-8007
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
Shop #: WSC 01279 785 00200
VCID: 72E1E32E6D6D9B8E9D3-8027
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 79F3D402301BE8D6DC9-802C
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 01000007320153
Coding: E68F8F214004150047140000001400000009730B5C000100000000000000
Shop #: WSC 25807 128 59060
VCID: 71E3EC22686BA096649-8024
Component: Wischer 300607 021 0501
Coding: 00038805
Shop #: WSC 25807
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 070707 046 0204
Coding: 00404254
Shop #: WSC 25807
00061 - Footwell Lights
Fault Status: 00101100
Fault Frequency: 104
Reset counter: 248
Mileage: 129122 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.15 V
02071 - Local Databus
Reset counter: 247
Mileage: 131734 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.15 V
Reset counter: 247
Mileage: 131734 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.15 V
Component: 6T AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D091DLY
Coding: 0013908
Shop #: WSC 01269 785 00200
VCID: 6CDDFD564F494D7E57F-8039
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME1C144C218
Subsystem 3 - Serial number: 6342MSME1C0542163
Subsystem 4 - Serial number: 6352QSME2E722F7D$
Subsystem 5 - Serial number: 6362QSME2D36335DQ
Subsystem 6 - Serial number: 63727SME0D4740682
Subsystem 7 - Serial number: 63827SME0D474C19B
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0012122
VCID: 81033CE2D8CB3016149-80D4
Component: E0221 002 0010
Part No SW: 1K6 920 974 D HW: 1K6 920 974 D
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G53NR93X
Coding: 0000103
Shop #: WSC 00000 785 00200
VCID: 356B18325C83CCB6781-8060
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 270607F2001978
Coding: FF8F03C207000000
VCID: 2F672A5ABEDFF66632D-807A
01304 - Radio
Fault Status: 00110100
Reset counter: 237
Mileage: 131232 km
Time: 21:10:44
Reset counter: 237
Mileage: 131232 km
Time: 21:10:44
02649 - Digital Radio Tuner
Fault Status: 01110100
Reset counter: 201
Mileage: 131421 km
Time: 17:38:00
Mileage: 129122 km
Time: 00:23:28
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 36691F3E4185C7AE71B-8063
Component: IMMO VDD 1216
Shop #: WSC 25016 444 58624
Component: Tuer-SG 006 120A
Coding: 0001077
VCID: 387511064B9131DE637-806D
008 - Implausible Signal
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.141 H08 1901
Shop #: WSC 00000 028 00001
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Coding: 1E900E885103C03F6F02058D30080A04889C00
VCID: 840D35F6C7D9253E3FF-80D1
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C0 035 456 F HW: 3C0 035 456 F
Component: DSP 10 Kanal 0013
Revision: 00010000 Serial number: 00000000001392
VCID: 234FD66AE2174206A65-8076
Fault Status: 01101100
Reset counter: 197
Mileage: 129122 km
Time: 02:08:45
Coding: 0001076
VCID: 39731402709B28D69C9-806C
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000004
VCID: F4ED6536977915BE0FF-80A1
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L1149796
Coding: 01000400040005
VCID: 63CF966A62970206E65-8036
11 Faults Found:
Reset counter: 237
Mileage: 5788 km
Date: 2004.14.19
Time: 17:03:10
Fault Status: 01101011
Reset counter: 197
Mileage: 131232 km
Time: 19:20:16
Reset counter: 197
Mileage: 131232 km
Time: 19:20:16
Reset counter: 197
Mileage: 131232 km
Time: 19:20:16
Reset counter: 197
Mileage: 131232 km
Time: 19:20:16
Reset counter: 197
Mileage: 131232 km
Time: 19:20:17
02633 - Antenna for Satellite Tuner
Fault Status: 00101011
Reset counter: 237
Mileage: 131232 km
Time: 20:26:23
00874 - Treble Speaker Front Left (R20)
Reset counter: 199
Mileage: 131299 km
Time: 15:05:50
00875 - Treble Speaker Front Right (R22)
Reset counter: 199
Mileage: 131299 km
Time: 15:05:50
00876 - Treble Speaker Rear Left (R14)
Reset counter: 199
Mileage: 131299 km
Time: 15:05:50
00877 - Treble Speaker Rear Right (R16)
Reset counter: 199
Mileage: 131299 km
Time: 15:05:50
Component: RDK 0450
Coding: 0100100
