I have tried to modify my Seat Toledo 2016, but when I try codding I get this error, do you know what it is?
As I mentioned I need a code, but what code I enter?.
I hope you can help me to obtain this code and to be able to code.
The full code is:
The full code is:
Tuesday,28,March,2017,22:28:42:59342
VCDS Version: 17.1.3.0 HEX-NET CB: 0.4334.4
VIN: VSSBG2NH4G1016302 License Plate:
Chassis Type: NH (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: VSSBG2NH4G1016302 Mileage: 33870km-21045miles
Address 01: Engine (J623-CJZD) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BC HW: 04E 907 309 AF
Component: R4 1.2l TFS H23 9086
Revision: R4H23---
Coding: 01190012232410080000
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ECM12TFS01104E906027BC 001009
ROD: EV_ECM12TFS01104E906027BC.rod
VCID: 668066119980037173-8032
CAN Converter 01:
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 614 517 CA HW: 6R0 614 517 CA
Component: EBC 460 ESP H52 0002
Serial number: A010D3N
Coding: 43F84876897F00D9C226122A9124006110050041
ASAM Dataset: EV_Brake1ESCEBC460PQ26L 003014
ROD: EV_Brake1ESCEBC460PQ26L_003.rod
VCID: 74A40C59DF5CE1E1FD-8020
Address 08: Auto HVAC (J301) Labels: 6C0-820-045.clb
Part No SW: 6P0 820 045 B HW: 6P0 820 045 B
Component: AC Manuell H01 0202
Serial number: 1510161B-1130
Coding: 000000000000100000
ROD: EV_ACManueKMMValeoPQ26_SK25.rod
VCID: 2B16D72542E2FE196C-807E
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 6C0 937 189 C HW: 6C0 937 189
Component: BCM PQ26 Hi4N H08 0086
Serial number: 001618005094
Coding: 080008404015005B01A04080B101030000015900570A3500000000000000
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005_SK25.rod
VCID: 312AC54D60CE94C956-8064
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6V1 959 801 B HW: 6V1 959 801 B
Component: FHSG DRV 007 0001
Serial number: 00000000000010971313
Coding: 011200
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY1516742MG
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0312
Serial number: 00000000000033778749
6154 - Bulb for Rear Right Turn Signal
B11EB 15 [008] - Open or Short to Plus
Reset counter: 75
Mileage: 32090 km
Date: 2017.03.11
Time: 14:16:28
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 E HW: 6C0 959 655 E
Component: VW20Airbag813 001 0360
Revision: -------- Serial number: 003RH007F6MB
Coding: 88C0C00000000000540000C8002800000000
Shop #: WSC 73430 790 00063
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3522F15D94A6B8E90A-8060
Subsystem 1 - Part No SW: ----------- HW: 442 150 911 15
Component: SideSensor_Df 1CA 0148
Serial number: 3497A00A31E4D0A593DW
Subsystem 2 - Part No SW: ----------- HW: 442 150 111 15
Component: SideSensor_Pf 1CA 0148
Serial number: 3507A009B1DD0C83124G
Part No SW: 6JA 920 740 F HW: 6JA 920 740 F
Component: KOMBI 205 1422
Coding: 072404002080000801082A001000000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 3D32E97DAC9660A9C2-8068
Part No SW: 6C0 909 901 HW: 6C0 937 189
Component: GW MQB A0 H08 0086
Revision: -------- Serial number: 001618005094
Coding: 01010008200A640000000000000000000001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_SK25.rod
VCID: 6582611D648608697A-8030
Subsystem 1 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A1138071015
Coding: 002000
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: CFBM0421
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW_SE26.rod
VCID: 6D92193DBC76302932-8038
1074688 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 49
Engine speed: 0 /min
Vehicle speed: 6.97 km/h
Terminal 15 status: Terminal 15 off
Voltage terminal 30: 0.00 V
Power steering current consumption: 0.00 A
Power steering current consumption: 255.99 A
End stage temperature: 215 °C
Steering assistance: engine output: 0.00 %
Sensor for motor position: 511.984 °
Sensor for motor position: 32767 /min
Steering assistance: target engine torque: 0.00 Nm
Steering torque: 0.00 Nm
Steering torque: Measured value not available
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5F0 035 871 HW: 5F0 035 871
Component: MU-E--ER 851 6481
Serial number: 12111500011466
Coding: 04520100BE00000011220001001028002F0000C40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_SK25.rod
VCID: 63867F056AB2765994-8036
End----------(Elapsed Time: 00:48, VBatt start/end: 12.3V/12.3V)-----------
