Seat Toledo 6C coding error
Alfonso
Mexico
C?ID=295901
I have tried to modify my Seat Toledo 2016, but when I try codding I get this error, do you know what it is?:confused:
As I mentioned I need a code, but what code I enter?.
I hope you can help me to obtain this code and to be able to code.
The full code is:
Tuesday,28,March,2017,22:28:42:59342
VCDS Version: 17.1.3.0  HEX-NET CB: 0.4334.4
VIN: VSSBG2NH4G1016302   License Plate:
Chassis Type: NH (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: VSSBG2NH4G1016302   Mileage: 33870km-21045miles
Address 01: Engine (J623-CJZD)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 9086
   Revision: R4H23---
   Coding: 01190012232410080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001009
   ROD: EV_ECM12TFS01104E906027BC.rod
   VCID: 668066119980037173-8032
   CAN Converter 01:
   Part No SW: 6R0 614 517 CA    HW: 6R0 614 517 CA
   Component: EBC 460 ESP   H52 0002
   Serial number: A010D3N
   Coding: 43F84876897F00D9C226122A9124006110050041
   ASAM Dataset: EV_Brake1ESCEBC460PQ26L 003014
   ROD: EV_Brake1ESCEBC460PQ26L_003.rod
   VCID: 74A40C59DF5CE1E1FD-8020
Address 08: Auto HVAC (J301)       Labels: 6C0-820-045.clb
   Part No SW: 6P0 820 045 B    HW: 6P0 820 045 B
   Component: AC Manuell    H01 0202
   Serial number:  1510161B-1130
   Coding: 000000000000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26_SK25.rod
   VCID: 2B16D72542E2FE196C-807E
   Part No SW: 6C0 937 189 C    HW: 6C0 937 189
   Component: BCM PQ26 Hi4N H08 0086
   Serial number: 001618005094
   Coding: 080008404015005B01A04080B101030000015900570A3500000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005_SK25.rod
   VCID: 312AC54D60CE94C956-8064
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
   Component: FHSG DRV  007 0001
   Serial number: 00000000000010971313
   Coding: 011200
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY1516742MG
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033778749
6154 - Bulb for Rear Right Turn Signal
          B11EB 15 [008] - Open or Short to Plus
                    Reset counter: 75
                    Mileage: 32090 km
                    Date: 2017.03.11
                    Time: 14:16:28
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 E    HW: 6C0 959 655 E
   Component: VW20Airbag813 001 0360
   Revision: --------    Serial number: 003RH007F6MB
   Coding: 88C0C00000000000540000C8002800000000
   Shop #: WSC 73430 790 00063
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3522F15D94A6B8E90A-8060
   Subsystem 1 - Part No SW: -----------    HW: 442 150 911 15
   Component: SideSensor_Df  1CA 0148
   Serial number: 3497A00A31E4D0A593DW
   Subsystem 2 - Part No SW: -----------    HW: 442 150 111 15
   Component: SideSensor_Pf  1CA 0148
   Serial number: 3507A009B1DD0C83124G
   Part No SW: 6JA 920 740 F    HW: 6JA 920 740 F
   Component: KOMBI         205 1422
   Coding: 072404002080000801082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 3D32E97DAC9660A9C2-8068
   Part No SW: 6C0 909 901     HW: 6C0 937 189
   Component: GW MQB A0     H08 0086
   Revision: --------    Serial number: 001618005094
   Coding: 01010008200A640000000000000000000001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_SK25.rod
   VCID: 6582611D648608697A-8030
   Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000A1138071015
   Coding: 002000
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CFBM0421
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW_SE26.rod
   VCID: 6D92193DBC76302932-8038
1074688 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 49
                    Engine speed: 0 /min
                    Vehicle speed: 6.97 km/h
                    Terminal 15 status: Terminal 15 off
                    Voltage terminal 30: 0.00 V
                    Power steering current consumption: 0.00 A
                    Power steering current consumption: 255.99 A
                    End stage temperature: 215 °C
                    Steering assistance: engine output: 0.00 %
                    Sensor for motor position: 511.984 °
                    Sensor for motor position: 32767 /min
                    Steering assistance: target engine torque: 0.00 Nm
                    Steering torque: 0.00 Nm
                    Steering torque: Measured value not available
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5F0 035 871     HW: 5F0 035 871
   Component: MU-E--ER      851 6481
   Serial number: 12111500011466
   Coding: 04520100BE00000011220001001028002F0000C40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_SK25.rod
   VCID: 63867F056AB2765994-8036
End----------(Elapsed Time: 00:48, VBatt start/end: 12.3V/12.3V)-----------
This is a relatively new BCM and no coding info is available for it yet. A security access code is not going to change that.
Alfonso
Mexico
C?ID=295901
Do you have a Road Map or something like that, about when do you estimate have those information available?
Not really. It all depends on when we can get a hold of the info ourselves.
Vlado6C
Croatia
C?ID=40534
I have very similar parts in my Polo 6C1, and the code I use is 31347, but that is only the code for Adaptations, and is not relevant for Coding.
For Coding/Helper you'll have to wait until a Label file is ready for your car.
What interests me is the label file for my engine which is the same as yours. Yet yours has the label file, and my does not.
Why is that? Can I use that same label file?
My full log:
Tuesday,28,March,2017,13:15:07:04012
Workshop Code: 648 00788 000255
VIN: WVWZZZ6RZHY181525   License Plate: ZG8054GE
Mileage: 1829km-1136mi   Repair Order:
Chassis Type: 6R (6C0)
VIN: WVWZZZ6RZHY181525   Mileage: 1829km-1136miles
Address 01: Engine (J623-CJZD)       Labels: None
   Part No SW: 04E 906 027 LJ    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 3856
   Revision: R4H23---
   Coding: 01190012230411080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS01104E906027LJ 001001
   VCID: F7F7C2244EC268F958-80A2
   CAN Converter 01:
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08508642161217
   Coding: 21DD4885492B33C10919106B0056841292CC90080005CB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: BE791700217899B15B-80EA
   Part No SW: 6C0 820 045 G    HW: 6C0 820 045 G
   Component: AC Manuell    H03 0204
   Serial number:  1701021B-0483
   Coding: 200000001100100000
   ROD: EV_ACManueKMMValeoPQ26_VW26.rod
   VCID: A34FC674AADAD45954-80F6
   Part No SW: 6C0 937 087 D    HW: 6C0 937 087
   Component: BCM PQ26 Me4R H10 0094
   Serial number: 006298051933
   Coding: 000008404253005B4F844000400703080000580251010000000000000000
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006.rod
   VCID: AF673A44F6126039C0-80FA
   Subsystem 1 - Part No SW: 6R0 959 801 DG    HW: 6R0 959 801 DG  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU009121663446333
   Coding: 0400A0
   Subsystem 2 - Part No SW: 6R0 959 802 DL    HW: 6R0 959 802 DL  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU014121663495697
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU002011770020650
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU013121663482074
   Coding: 1400A0
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00A 002 0380
   Revision: --------    Serial number: 003TH00FD7EC
   Coding: 88C0C000000000005C000000000800000000
   VCID: BA711B103D50B59167-80EE
   Subsystem 1 - Part No SW: -----------    HW: 410 821 912 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A5233EFA3227R
   Subsystem 2 - Part No SW: -----------    HW: 410 821 912 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H009D234FA5322CW
   Subsystem 3 - Part No SW: -----------    HW: 442 151 501 17
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A001E2A519562555
   Subsystem 4 - Part No SW: -----------    HW: 442 151 501 17
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A001E2A5195977CN
   Part No SW: 6C0 920 730 J    HW: 6C0 920 730 J
   Component: KOMBI         103 2310
   Coding: 0720090021000008010808000000000000000000
   VCID: A855D158D3FC370101-80FC
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 087
   Component: GW MQB A0     H10 0094
   Revision: --------    Serial number: 006298051933
   Coding: 030000046F0A560071000000000000010001010000000000000000000000
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: A649DF60D9E8217133-80F2
   Subsystem 1 - Part No SW: 6C0 915 181 B    HW: 6C0 915 181 B
   Component: J367-BDM  H08 0270
   Serial number: 63356F47305881065183
   Part No SW: 6C1 909 144 AJ    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  313 3242
   Serial number: PH1P0213
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   VCID: F0E5F9382BAC3FC199-80A4
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 869 F    HW: 6C0 035 869 F
   Component: MU-E--ER      050 7082
   Serial number: 07121600011009
   Coding: 02620000BE00000041110001000002001F0000840000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   VCID: AE592740F1186931CB-80FA
End-------------------------(Elapsed Time: 02:32)--------------------------
Why is that?
Well, it's not exactly the same. ECU part number is different. :)
Probably.
Vlado6C
Croatia
C?ID=40534
OK tnx, I'd like to do that to see what's on the menu.
I seem to remember how to do this with old Vag-Com versions 40X & .lbl files, BUT since this is a .clb file, I'm lost :)
Any help or pointer to a procedure would be appreciated.
Since this is a UDS ECU, there's nothing in that label file except for coding info, and ECU coding really shouldn't be changed.
But if you want to play, you can make a copy of 04E-907-309-V1.clb, drop it into the User sub-folder, and rename it to: 04E-906-027-LJ.clb.
I'm actually not 100% certain this will work, but there's no harm in trying.
Vlado6C
Croatia
C?ID=40534
Hehe, already did it. Decided that it's not nuclear physics, did the same as with old .lbl files and got the helper menus.
It works and there is not much to see :)
Btw, I am looking for a way to permanently disable Start/Stop system
TBAx
C?ID=287144
You should be able to do so using the same adaption as for the Golf MK7, changing start/stop voltage level in the Gateway adaptions.
Vlado6C
Croatia
C?ID=40534
Tnx for the tip, that did the trick.
I tried before to disable S/S via temperature adaptation, but that seems to be disabled on my model, because any new value entered was not accepted, with "Value out of range" message.
Adapting 10V instead default 7.6V disables Start/Stop, but with a message in Infotainment: "Vehicle power consumption is high".
Edit:
Went for a drive and noticed a side effect of this method. It somehow messes with engine's power management on Polo 6C1. Normally battery is not charged during acceleration, but only on deceleration, to save as much fuel as possible and assist in braking.
Now, with this setting, this management is not working. Since it "thinks" that "Power consumption is high" it permanently charges the battery with 14.9V, as on a regular engine with flat battery...
Since this tweak does not satisfy me, it's back to the drawing board :)
Vlado6C
Croatia
C?ID=40534
Hello again,
I know that it is not advisable to mess around with Engine ECU, but I just had to try if this label works on my Polo. So I changed coding for manufacturer from VW to Audi, as that seemed to me benign enough. It worked and now I have an Audi engine :)
Original:
Friday,24,February,2017,14:38:25:04012
Mileage: 134km-83mi   Repair Order: Original Scan
VIN: WVWZZZ6RZHY181525   Mileage: 134km-83miles
   Revision: R4H23---
   CAN Converter 01:
After change:
Saturday,15,April,2017,14:52:58:04012
Mileage: 2213km-1375mi   Repair Order: New Scan
VIN: WVWZZZ6RZHY181525   Mileage: 2213km-1375miles
Address 01: Engine (J623-CJZD)       Labels: User\04E-906-027-LJ.clb
   Revision: R4H23---
   Coding: 02190012230411080000
   CAN Converter 01:
Then I tried the new beta version 17.4 and there is still no engine label for my model.
Beta:
Saturday,15,April,2017,14:10:35:04012
VCDS Version: 17.4.0.3
Data version: 20170413 DS270.3
Mileage: 2213km-1375mi   Repair Order: 17.4 beta
   Revision: R4H23---
   ROD: EV_ECM12TFS01104E906027LH.rod
   VCID: F7F7C2244EC268F849-80A2
   CAN Converter 01:
Is there something that I can do/help to get this label included in next version?
