Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Rvc calibration
  1. #21
    Dec 2016
    It could be picking up the edge of the protector, if VW can't do it then there must be a genuine reason why it won't work. As I said mine did really easily and quickly.
  2. Likes Uwe liked this post
  3. #22
    Sep 2016
    Quote Originally Posted by welshkaiboy View Post
    I have removed the protector however I checked my friends car the red line is further from his bumper however this could be as his is calibrated , I have also emailed kufatec as my friends camera is different as his lense is flush and mine protrudes I wanted to check i have the correct handle.
  4. #23
    Oct 2014
    I retro fitted the highline camera to my 2016 vw tiguan with discover media headunit and it kept showing a calibration fault through vcds.so had it booked into the dealers which they had all day and they could not get it calibrated no matter what settings they put on it...
    The only way I got it working was to swap my module over with one that was already calibrated via the factory which my friend kindly swapped with me before he got rid of his 2015 vw tiguan!!!!!
    scott
  5. #24
    Sep 2016
    Quote Originally Posted by golfman View Post
    scott
    Well I got a response from Kufatec it pretty much said "it works without being calibrated"
    All I want to do is calibrate it to clear the code's grr
  6. #25
    Jan 2015
    Bosnia and Herzegovina
    Quote Originally Posted by chillout1983 View Post
    calibration will take in to consideration height of camera/car, length, angle etc... so calibration will improve angle for better line of sight also move red line
  7. #26
    Sep 2016
    I now have an incorrect code error on the nav I cant understand it as I think its coded correctly
    Sunday,04,June,2017,21:15:08:04925
    VCDS Version: 17.1.3.0 (x64)
    VIN: WVWZZZ3CZFE037171   License Plate: BEFORE SERVICE
    Mileage: 26710km-16596mi   Repair Order: diesel
    Chassis Type: 3C (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 47 4C 4F 52
              53 55 56 61 62 6C 6D 72
    VIN: WVWZZZ3CZFE037171   Mileage: 26710km-16596miles
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 PA    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   H28 9978
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 001D0012042501080000
       Shop #: WSC 34742 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
       ROD: EV_ECM20TDI01103L906018PA.rod
       VCID: 78F5D876C3C07681D1-802C
       Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4017
       Revision: 05652104    Serial number: 00001406120657
       Shop #: WSC 05311 000 00001
       VCID: 142D8CC63768B2E15D-8040
       Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
       Component: J104   C2 450M VDCB 0040
       Revision: --H07---    Serial number: 00000008306711
       Coding: 0008115
       VCID: 79F3DD7230CA6F89AE-802C
    02214 - Tire Pressure Warning
                        Reset counter: 233
                        Mileage: 26413 km
                        Date: 2017.05.20
                        Time: 17:17:04
                        Speed: 122.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.25 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
       Part No SW: 3AA 907 044 BT    HW: 3AA 907 044 BT
       Component: Climatronic   H05 0607
       Revision: 00001K02
       Coding: 061400C803
       Shop #: WSC 00015 115 00001
       VCID: 030FBF9A8A062559F4-8056
    Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
       Part No SW: 3AA 937 087 Q    HW: 3AA 937 087 Q
       Component: BCM PQ47 H+   422 0475
       Revision: BC422001
       Coding: 0208000000000000009C0080740029F423F54B88676D8760E488C7240041
       Shop #: WSC 05311 123 00001
       VCID: 489568B6FBA0C60161-801C
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 20061  26  0612
       Coding: 00B795
       Component: RLS 110714 05  54  0403
       Coding: 0630ED
    Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
       Part No SW: 3AE 919 475 C    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0018
       Revision: --------    Serial number: 28201418200198
       Coding: 308102
       Shop #: WSC 99999 123 12345
       ASAM Dataset: EV_EPHVA18VW47X0000 001006
       ROD: EV_EPHVA18VW4280000.rod
       VCID: 3F87736AA66E81B9D0-806A
       Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
       Component: J234__10J VW10 HI   2418
       Revision: 29020000    Serial number: 003N5PC03SMZ
       Coding: 0012362
       VCID: 0005B09653103E41E9-8054
       Subsystem 1 - Serial number: 6332MTS672781794
       Subsystem 2 - Serial number: 6342MTS685451754
       Subsystem 3 - Serial number: 6351HTS6JO2O1DKR
       Subsystem 4 - Serial number: 6361HTS627S62DKJ
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C9 953 501 CN    HW: 5K0 953 569 AS
       Revision: FF010042    Serial number: 20140624101118
       Coding: 1992250001
       VCID: 77F7DB4ACEDE79F9D8-8022
       Coding: E30000
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3AA 920 981 A    HW: 3AA 920 981 A
       Component: KOMBI         H03 0705
       Coding: 461F01
       Shop #: WSC 05314 115 00001
       VCID: 336F2F5A9A2655D924-8066
       Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1653
       Revision:   H56       Serial number: 250614F2001170
       Coding: 462007
       Shop #: WSC 05314 123 00001
       VCID: 0103B592981A3749E6-8054
       Part No SW: 3AA 959 799 E    HW: 3AA 959 799 E
       Component:    IMMO         090 0409
       Revision: 00090000    Serial number: VWZCZ000000000
       VCID: 4A9152BE25AC341177-801E
       Revision: A1001003    Serial number: 7666435973
       Coding: 020100
       VCID: 2B5F373A4A160D196C-807E
       Part No SW: 3C8 035 279 S    HW: 3C8 035 279 S
       Component: RNS315-EU   H80 0500
       Serial number: VWZAZ2P0380543
       Coding: 040700410100110000019002
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 3B7F077AB2769D99FC-806E
       Component: EUR_W_V6  0062
    1048641 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 111
                        Mileage: 24649 km
                        Date: 2017.03.25
                        Time: 16:51:40
                        Correction for sound system: OK
                        Traffic sign display: OK
                        CD changer: OK
                        Status of antenna 2 for radio: OK
                        Digital radio (DAB): OK
                        Antenna diagnostic: OK
                        Telephone baseplate diagnostic: OK
                        Speaker status: OK
                        Rearview camera: ERROR
                        Telephone Transceiver: OK
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0008808303
       Coding: 0212F7
       Shop #: WSC 05311 115 00001
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 356B114294524BE90A-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  005 0503
       Serial number: 00000004061119
       Coding: 0102D0
    67584 - Warning Light for Front Door
              B11F5 01 [008] - Electrical Failure
                        Reset counter: 243
                        Mileage: 26711 km
                        Date: 2017.06.04
                        Time: 17:13:40
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 196    3501
       Revision: 00H22000
       VCID: 39731D72704AAF89EE-806C
    Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
       Component: 02 KESSY PQ47   090 0375
       Coding: 01900A00D2C34E7634029C3F7E005FCE105800130427BC
       Subsystem 4 - Part No: 3AA 962 243 D
       Component: GEB.F.Heckoef       0811
    Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
       Part No SW: 3AA 035 466     HW: 3AA 035 466
       Component: KonzernAmp12K H03 6904
       Revision: --------    Serial number: A1108A00001899
       ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
       ROD: EV_AudioVerst12KanalSTT1.rod
       VCID: 6DDBF922BC82C32932-8038
       Component: EZE_2         H56 1653
       Coding: 00000008
       VCID: 6FE7E32ABE8E313900-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0004
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0008782149
       Coding: 0212F6
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 3669164E895440F103-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  005 0503
       Serial number: 00000004054739
       Coding: 0102D0
                        Fault Frequency: 15
                        Reset counter: 242
                        Mileage: 24643 km
                        Date: 2017.03.24
                        Time: 19:54:36
    133120 - Warning Light for Rear Door
              B11F7 01 [008] - Electrical Failure
                        Fault Frequency: 10
                        Reset counter: 235
                        Mileage: 24584 km
                        Date: 2017.03.19
                        Time: 22:04:45
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000168523
       Coding: 0022167
       VCID: 387518764B40B68111-806C
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Component: AFS-ECU       H04 0111
       Coding: 029600000B000200
       VCID: 37771B4A8E5EB9F918-8062
       Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 230000
       Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 230000
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Component: Batt.regelung H56 1653
       Coding: 030F1859
       VCID: 71E3E552A8BA27C916-8024
       Component: J367-BDM  H07 0180
       Serial number: 41183H11301491466170
       Part No SW: 3C9 907 441     HW: 3C9 907 441
       Component: J772__Rearview      0020
       Revision: 00H15000    Serial number: 525PA8-JBX0068
       Coding: 0020007
       Shop #: WSC 98765 666 38384
       VCID: 68D588365B60E60141-803C
    03006 - Back-up Camera System not calibrated
                        Reset counter: 155
       Part No SW: 3AF 827 383 A    HW: 3AF 827 383 A
       Component: J605  HECKDECKEL    0860
       Revision: 00H52001
       Shop #: WSC 05314 000 00001
       VCID: 3A71027E754CA491E7-806E
       Subsystem 1 - Part No: 3AF 827 384 A
       Component: J756  HECKDECKEL    0860
       Subsystem 2 - Serial number: 1400H52001001C0311
    End-------------------------(Elapsed Time: 03:42)--------------------------
    Address 03: DTCs cleared
  8. #27
    Oct 2014
    The only way to get rid of this error code is to get hold of a calibrated/used module from a (Tiguan) and that will get rid of your fault code!!!!!
    scott
  9. #28
    Sep 2016
    scott
    Will it clear my fault on my navigation also ?
