Ok This car has been driving me a little crazy and off the walls. The story is the cars heat output from the vents never gets to hot or even warm. Engine temp, all interior temp sensors, and actual coolant temps all have been checked and verified to be ok. I can visually watch almost every HVAC control motor operate. If I cant see it I can feel a change in the position of the door by way of air flow. I have completed door motor calibrations. When running the output testing on the doors I can get full range of motion according to stepper motor ranges. The one I'm focused on is the temperature blend door. When I run the output test on this one it functions as normal and Vent Temp output is around 135 F deg, which is fantastic. When running the Auto HVAC system normally no VAG COM connected the Vent temp only gets to around 95 deg. It took me a while to get to this point but I have finally figured out that the difference is the A/C Compressor operation. During the Output test Compressor is not running so the temp is higher. I'm glad I've gotten this far but what else am I missing about this system A/C operation. It should not be blending air when system is set to full Hot. Heater cores are not the issue either. I can physically touch each one and there is around a 15-25 deg temp drop. inlet to outlet. I'm going to look inside the HVAC box with a boroscope today and see if I can see anything. I forgot to do a clear after disconnecting the HVAC unit so there are a lot of communication faults. Also I'm still a bit new on the forum but I see people attaching Auto-scans as a separate box with a scroll bar.. How is that done?
Thanks for any input.
Monday,13,March,2017,16:22:17:64595
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: WAUML44E04N021944 License Plate:
Mileage: 451470km-280530mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E04N021944 Mileage: 451470km-280530miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Sporadic communication error 1000
0E-Media Player 1 -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D1535583
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F47EE5ACE418FB9F0-804A
8 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit - Intermittent
18282 - Valve for Torque Support Mount
P1874 - 001 - Short to Plus
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller - Intermittent
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow
Readiness: 0000 1100
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0031690
VCID: 244DE1B6E727AC61AD-8070
18290 - Powertrain Data Bus
P1882 - 000 - Missing Message from Electric Parking Brake Controller
(no units): 30.0
(no units): 111.0
Temperature: 28.0°C
T.B. Angle: 0.0°
Voltage: 14.16 V
18271 - Powertrain Data Bus
P1863 - 000 - Missing Message from Steering Angle Sensor - Intermittent
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
(no units): 30.0
(no units): 111.0
Temperature: 28.0°C
T.B. Angle: 0.0°
Voltage: 14.16 V
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2241E7AEFD33A251DF-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0D1535583
Coding: 0263168
Shop #: WSC 56078 001 1048576
VCID: 58B58546EBEF3881F1-800C
Component: ELV XXXX
00288 - Steering Column Lock Actuator (N360)
014 - Defective
Fault Status: 01101110
Fault Frequency: 0
Mileage: 451456 km
Date: 2003.11.05
Time: 20:42:08
Fault Frequency: 0
Reset counter: 148
Mileage: 451456 km
Date: 2003.12.02
Time: 14:18:36
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
VCID: 234FE2AAE229AB59D4-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346CF047510631
Coding: 0000103
Shop #: WSC 03078 444 00093
VCID: 2F671E9ABEE11F3940-807A
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000039287
Subsystem 3 - Serial number: 0121.05.070000000100010006ÿ
Subsystem 4 - Serial number: 010006ÿ
00384 - Optical Databus
Fault Status: 00101011
Fault Frequency: 7
Reset counter: 39
Mileage: 451465 km
Date: 2003.12.02
Time: 12:55:30
Control Module Part Number: 4E0 910 043 A HW: 4E0 820 043 B
Component and/or Version: KLIMAAUTOMAT 016 0300
Software Coding: 1085761
Work Shop Code: WSC 02311 785 00200
Additional Info: 4E0910772A Sitzluefter FS H02 010 4E0910772A Sitzluefter BFS H02 010
VCID: 1B3FDA4ADA5993991C-804E
Part No SW: 4E0 910 772 A HW: 4E0 820 043 B
Component: Sitzluefter FS H02 010
Revision: 065A0000 Serial number: 898053000
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 2 - Serial number: 898053000
Subsystem 3 - Serial number: HO19022004065A000000000135ÿ
Subsystem 4 - Serial number: 000135ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Component: ILM Fahrer H12 0170
Coding: 0123113
VCID: 2C5D09968FF7642165-8078
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02313
01800 - Light Switch (E1)
Fault Frequency: 189
Reset counter: 110
Mileage: 449444 km
Date: 2003.11.27
Time: 23:09:34
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000501 Serial number: AUZ5ZBD1035314
VCID: 1933C042D065E1890E-804C
003 - Mechanical Failure
Fault Status: 01100011
Fault Frequency: 92
Reset counter: 150
Mileage: 451456 km
Date: 2003.10.15
Time: 17:20:23
Bin. Bits: 00000010
02261 - Data Medium
Fault Frequency: 92
Reset counter: 150
Mileage: 451456 km
Date: 2003.10.15
Time: 17:20:23
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
Component: SDAR
Serial number: AUZ4Z7D7019968
VCID: 2953F082800571099E-807C
Reset counter: 147
Mileage: 451450 km
Date: 2003.10.09
Time: 20:24:58
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
01742 - Igniter for Knee Airbag; Drivers Side (N295)
01743 - Igniter for Knee Airbag; Pass. Side (N296)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Coding: 0012241
VCID: 65CBBCB2AC9D95697A-8030
Component: Lenkradmodul H04 0080
Reset counter: 148
Mileage: 451465 km
Date: 2003.12.02
Time: 13:42:41
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D2005481
Coding: 0016233
Shop #: WSC 63237 001 1048576
VCID: 5CBD99569FD7D4A1D5-8008
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 05005042191696
Coding: FCFE7BDD1B2B04
Shop #: WSC 03078 444 54376
VCID: 2649FBBE911B5E71B3-8072
Fault Frequency: 114
Reset counter: 110
Mileage: 451450 km
Date: 2003.10.12
Time: 13:58:28
Reset counter: 110
Mileage: 451450 km
Date: 2003.10.12
Time: 13:58:28
Reset counter: 140
Mileage: 451458 km
Date: 2003.11.05
Time: 20:13:01
Reset counter: 140
Mileage: 451458 km
Date: 2003.11.05
Time: 20:13:01
Reset counter: 148
Mileage: 451465 km
Date: 2003.12.02
Time: 13:42:41
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
014 - Defective
Fault Frequency: 0
Mileage: 451456 km
Date: 2003.11.05
Time: 20:42:08
Fault Frequency: 0
Reset counter: 148
Mileage: 451456 km
Date: 2003.12.02
Time: 14:18:36
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 254BFCB2EC1D5569BA-8070
01400 - Suspension Level Control
Fault Status: 00100001
Reset counter: 140
Reset counter: 140
Mileage: 451458 km
Date: 2003.11.05
Time: 20:13:01
Reset counter: 140
Mileage: 451458 km
Date: 2003.11.05
Time: 20:13:01
Component: Sitzmemory FS H07 0060
Coding: 4071522
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H43 0570
Revision: 00000000 Serial number: 355CM047516362
VCID: 356B2CF25CBD25E90A-8060
00003 - Control Module
014 - Defective
Reset counter: 0
Mileage: 451450 km
Date: 2003.10.09
Time: 20:27:19
Bin. Bits: 0100
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000404400081
Coding: 0003477
VCID: 1D3BD452C44D9DA9E2-8048
Reset counter: 136
Mileage: 262136 km
Date: 2003.10.16
Time: 02:40:00
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Reset counter: 136
Mileage: 262136 km
Date: 2003.10.16
Time: 02:40:00
Reset counter: 136
Mileage: 262136 km
Date: 2003.10.16
Time: 02:40:00
Reset counter: 136
Mileage: 262136 km
Date: 2003.10.16
Time: 02:40:00
Reset counter: 136
Mileage: 262136 km
Date: 2003.10.16
Time: 02:40:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM007 0110
Coding: 0028196
Shop #: WSC 02311 785 00200
VCID: 5EB9935E89CBC6B1BB-800A
00913 - Window Regulator Switch; Front Right Driver (E81)
Reset counter: 136
Mileage: 451440 km
Date: 2003.10.12
Time: 14:25:12
Reset counter: 136
Mileage: 451440 km
Date: 2003.10.12
Time: 14:25:12
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040402240150
Coding: 0065086
VCID: 2757F6BA9611477988-8072
Component: Heckdeckel H06 0060
Component: Neigungssensor H03 0020
10 Faults Found:
01134 - Alarm Horn (H12)
Reset counter: 109
Mileage: 448927 km
Date: 2003.11.06
Time: 12:24:19
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 110
Mileage: 425072 km
Date: 2014.08.29
Time: 11:32:28
Reset counter: 110
Mileage: 425072 km
Date: 2014.08.29
Time: 11:32:28
00984 - Left Tail Light (M4)
014 - Defective
Reset counter: 110
Mileage: 451297 km
Date: 2003.12.29
Time: 22:06:41
Reset counter: 110
Mileage: 451297 km
Date: 2003.12.29
Time: 22:06:41
01503 - Bulb for 3rd Brake Light (M25)
Fault Frequency: 0
Reset counter: 0
Raw, Form. N/A: 000 000 000
00985 - Right Tail Light (M2)
Fault Frequency: 0
Reset counter: 0
00456 - Control Module for Access and Start Control (J518)
Fault Frequency: 0
Reset counter: 0
Fault Frequency: 0
Reset counter: 0
Fault Frequency: 0
Reset counter: 0
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000546188
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000034617
Coding: 0010111
VCID: 1E39D35EC94B86B1FB-804A
Reset counter: 140
Mileage: 262136 km
Date: 2003.11.05
Time: 20:13:00
Reset counter: 140
Mileage: 262136 km
Date: 2003.11.05
Time: 20:13:00
Reset counter: 140
Mileage: 262136 km
Date: 2003.11.05
Time: 20:13:00
02258 - Door Opener Transmitter
Fault Frequency: 113
Reset counter: 110
Mileage: 262136 km
Date: 2003.10.12
Time: 13:58:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
Address 53: Parking Brake
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
VCID: 62C1A7AEBDB3E2519F-8036
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304CH047581802
VCID: 2045EDA6F33FB041C9-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000001179668
Shop #: WSC 23134 823 51513
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 350215F164
Coding: 303030393135313035444C56413033353032313546313634
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: 5DBB945284CDDDA9A2-8008
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5FC7AE5A8EC1CFB9B0-800A
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3008690
Coding: 0000005
Shop #: WSC 03078 444 53274
VCID: 60C5ADA6B0BFF04189-50C8
01531 - Emergency Battery
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730405500686
Coding: 0001208
VCID: 2143E8A2F835B949C6-8074
