Greetings from Northern Virginia,
I recently picked up a 2017 VW Golf Alltrack SEL to replace my 2010 TDI Sportwagen and I am looking to locate instructions on how to code a few things I'd like to have on my new Alltrack.
- Gauge Sweep
- DRL's on w/ blinkers
- Windows/Sunroof Open/Close with key-fob
- Auto Rain Closing
I am using the following:
VCDS Version: 17.1.3.0 (x64)
with a Micro-CAN usb interface cable.
Any help with how to accomplish these coding changes would be appreciated. I can follow instructions so long as the instructions are well laid out and understandable. I am not a professional auto mechanic nor am I very experienced with these tools but would appreciate any assistance in achieving these coding changes...
Here is my most recent scan for reference...
Brendan
- Gauge Sweep
- Auto Rain Closing
Sunday,05,March,2017,16:21:03:03724
VIN: 3VWH17AU3HM****** License Plate: BRENODO
Mileage: 309km-192mi Repair Order: 05-MAR-2017.16:20
Chassis Type: AU (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 47 52 55 5F
75 A5
VIN: 3VWH17AU3HM****** Mileage: 309km-192miles
Address 01: Engine (J623-CXBB) Labels: None
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311D00322466002F1000
Shop #: WSC 00066 790 00218
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: N/A
VCID: 46AD8742F9A9617193-8012
No ASAM data for: "EV_ECM18TFS0208V0906264M" (VW37)
Part No SW: 0D9 300 014 M HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5004
Revision: 06454104 Serial number: TFK01612020692
ROD: EV_TCMDQ250021.rod
VCID: 22653BD235C17D51DF-8076
P1734 00 [002] - -
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 60167000001186
Coding: 43FA6AA134220972807C030580CA29C2562C9001C001943C16435052E029430000010312121212B435351919323200
Shop #: WSC 01383 790 50316
VCID: 79D73CBEF8D7DE89AE-802C
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0421897781
Coding: 032C0C
VCID: 3B5BE6B6B26B2C99FC-806E
Part No SW: 5GM 907 044 E HW: 5GM 907 044 E
Component: Climatronic H04 1801
Revision: 00001K04
Coding: 02020024200100000104000012111402
Part No SW: 5Q0 937 087 AN HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 032 0223
Revision: -------- Serial number: C86416011701K1
Shop #: WSC 00066 790 00208
ROD: EV_BCMBOSCH_017.rod
VCID: 07334A46BE23B879A8-8052
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 161127 043 0551
Serial number: 97022066161210203451
Component: RLHS 042 0105
Serial number: S2Y16M12D01H20M31S23
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST001C2RFL00000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST001C2RHN00000
Coding: 191800
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431630901962
Coding: 0031163011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 47B38A46FEA3787968-8012
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Coding: 350000C141FFC428949C810520301600000000000000000000
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3C59E5AAB7652BA1F5-8068
Serial number: 003GCR06T12A
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000006BWWWU
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 000 112 16
Serial number: 3570000000079974402E
Subsystem 3 - Part No SW: ----------- HW: 480 003 011 16
Serial number: 358000000004F5294F1S
Subsystem 4 - Part No SW: ----------- HW: 480 402 012 16
Serial number: 3510001C3237EE336281
Subsystem 5 - Part No SW: ----------- HW: 480 402 012 16
Serial number: 3520001C5237EE349637
Subsystem 6 - Part No SW: ----------- HW: 480 402 911 16
Serial number: 3550002C522E8E11F37D
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 911 16
Serial number: 3560002C522E8E15B217
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 16121604400704
Coding: 0C10
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 09374C7EA837CE09BE-805C
Part No SW: 5G1 920 840 B HW: 5G1 920 840 B
Component: KOMBI 244 8311
Coding: 0BA4101DED90CF0502886A031000000000000000
VCID: 266D27C259E98171B3-8072
Component: GW MQB High 515 5286
Serial number: 26011700840234
Coding: 0901000870085900FB00221A1E0F00000001050000000000000000000000
Shop #: WSC 00066 790 07025
ROD: EV_GatewConti_013.rod
VCID: 2F43C2E67613C03940-807A
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Serial number: 29160001823820126371
Coding: 35FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0296999
Serial number: HA1-00016.11.16
Coding: 0001
VCID: 4AB5B372EDB1851177-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000198719010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 3449CD8A9F35E3E13D-8060
Component: TSG FS 020 0041
Serial number: 070117060501BJ
Coding: 003A13200000020000000000
VCID: 43AB9E56CA9B5459B4-8016
Serial number: 00000000000005014592
Coding: 011000
Address 44: Steering Assist (J500) Labels: None
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 9302
ROD: EV_SteerAssisMQB_013.rod
VCID: 4F83A26616D3A03920-801A
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GMD00641W
VCID: 6DFF18EEBC9F722932-8038
Component: TSG BFS 020 0041
Serial number: 100117060505S6
VCID: 42A59B52D5815D51BF-8016
Serial number: 00000000000005089415
Coding: 091000
Component: AFS-ECU H07 0090
Coding: 062A00010B000400
VCID: 40A1915ADB8D4F41A9-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0753
Coding: 027302020000000051220002001808009F0108F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3245CB926521EDD12F-8066
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX00HWV
Subsystem 2 - Part No SW: 3G0 919 866 BB HW: -----------
Component: NAR 2017 --- 0525
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Component: OCULowMQBUS 007 0570
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 12121612K21981
Coding: 000307020002020100221344C040490084000E100020
ROD: EV_MFKBoschMQBB.rod
End-------------------------(Elapsed Time: 04:06)--------------------------
Brendan
